[PATCH 1/5] sparc: Add atomic support for SPARC V8
Sebastian Huber
Fri Feb 14 13:07:24 UTC 2014
Use SWAP instruction with one lock for the system in the SMP case.
cpukit/score/cpu/sparc/Makefile.am | 1 +
cpukit/score/cpu/sparc/sparcv8-atomic.c | 193 +++++++++++++++++++++++++++++++
2 files changed, 194 insertions(+), 0 deletions(-)
create mode 100644 cpukit/score/cpu/sparc/sparcv8-atomic.c
diff --git a/cpukit/score/cpu/sparc/Makefile.am b/cpukit/score/cpu/sparc/Makefile.am
index 3065f3c..6e248a2 100644
--- a/cpukit/score/cpu/sparc/Makefile.am
+++ b/cpukit/score/cpu/sparc/Makefile.am
@@ -12,6 +12,7 @@ include_rtems_score_HEADERS += rtems/score/cpusmplock.h
noinst_LIBRARIES = libscorecpu.a
libscorecpu_a_SOURCES = cpu.c cpu_asm.S
+libscorecpu_a_SOURCES += sparcv8-atomic.c
libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
include $(srcdir)/preinstall.am
diff --git a/cpukit/score/cpu/sparc/sparcv8-atomic.c b/cpukit/score/cpu/sparc/sparcv8-atomic.c
new file mode 100644
index 0000000..c12041f
--- /dev/null
+++ b/cpukit/score/cpu/sparc/sparcv8-atomic.c
@@ -0,0 +1,193 @@
+ * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/score/cpuopts.h>
+#include <rtems/score/isrlevel.h>
+#if defined(RTEMS_SMP)
+static volatile uint32_t _SPARCV8_The_one_lock;
+static inline uint32_t _SPARCV8_Atomic_swap(
+ volatile uint32_t *address,
+ uint32_t value
+ asm volatile (
+ "swap [%2], %0"
+ : "=r" (value)
+ : "0" (value), "r" (address)
+ : "memory"
+ return value;
+#endif
+static ISR_Level _SPARCV8_Acquire_the_one_lock( void )
+ ISR_Level level;
+ _ISR_Disable_without_giant( level );
+ do {
+ while ( _SPARCV8_The_one_lock ) {
+ /* Wait */
+ } while ( _SPARCV8_Atomic_swap( &_SPARCV8_The_one_lock, 1 ) );
+#endif
+ return level;
+static void _SPARCV8_Release_the_one_lock( ISR_Level level )
+ _SPARCV8_The_one_lock = 0;
+#endif
+ _ISR_Enable_without_giant( level );
+uint8_t __atomic_exchange_1( uint8_t *mem, uint8_t val, int model )
+ uint8_t prev;
+ ISR_Level level;
+ level = _SPARCV8_Acquire_the_one_lock();
+ prev = *mem;
+ *mem = val;
+ _SPARCV8_Release_the_one_lock( level );
+ return prev;
+uint32_t __atomic_exchange_4( uint32_t *mem, uint32_t val, int model )
+ uint32_t prev;
+ ISR_Level level;
+ prev = *mem;
+ *mem = val;
+ return prev;
+bool __atomic_compare_exchange_4(
+ uint32_t *mem,
+ uint32_t *expected,
+ uint32_t desired,
+ bool weak,
+ int success,
+ int failure
+ bool equal;
+ ISR_Level level;
+ equal = *mem == *expected;
+ if ( equal ) {
+ *mem = desired;
+ return equal;
+uint32_t __atomic_fetch_add_4( uint32_t *mem, uint32_t val, int model )
+ uint32_t prev;
+ ISR_Level level;
+ prev = *mem;
+ *mem = prev + val;
+ return prev;
+uint32_t __atomic_fetch_sub_4( uint32_t *mem, uint32_t val, int model )
+ uint32_t prev;
+ ISR_Level level;
+ prev = *mem;
+ *mem = prev - val;
+ return prev;
+uint32_t __atomic_fetch_and_4( uint32_t *mem, uint32_t val, int model )
+ uint32_t prev;
+ ISR_Level level;
+ prev = *mem;
+ *mem = prev & val;
+ return prev;
+uint32_t __atomic_fetch_or_4( uint32_t *mem, uint32_t val, int model )
+ uint32_t prev;
+ ISR_Level level;
+ prev = *mem;
+ *mem = prev | val;
+ return prev;
+uint32_t __atomic_fetch_xor_4( uint32_t *mem, uint32_t val, int model )
+ uint32_t prev;
+ ISR_Level level;
+ prev = *mem;
+ *mem = prev ^ val;
+ return prev;
1.7.7
