[PATCH] score: Delete _Thread_BSP_context
Fri Feb 14 14:28:34 UTC 2014
On 2014-02-14 15:21, Gedare Bloom wrote:
>>> >>Does it make sense to add noreturn attributes to the initialization
>>> >>call path starting with boot_card through
>>> >>rtems_initialize_start_multitasking()?
>> >Its already there:
>> >http://git.rtems.org/rtems/commit/?id=48bff53b3dec885085b87db413329830110c9bb0
> Ah, it is OK to only put it at the function declaration? Does it hurt
> to replicate the noreturn statement in the function definition? I
> think it can be more obvious to someone who reads the code.
The only place it matters is the function declaration.  This attribute tells
the compiler: hey look, if you call this function, then it will not return so
don't care about what comes next.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
