[PATCH 01/17] score: Move SMP interrupt stack initialization
Mon Feb 17 15:51:26 UTC 2014
Move SMP interrupt stack initialization for secondary processors from
_SMP_Handler_initialize() to _ISR_Handler_initialization() to avoid code
duplication.  Apply _CPU_Interrupt_stack_setup() to all interrupt
stacks.
 cpukit/score/src/isr.c    |   40 ++++++++++++++++++++++------------------
 cpukit/score/src/percpu.c |   21 ---------------------
 2 files changed, 22 insertions(+), 39 deletions(-)
diff --git a/cpukit/score/src/isr.c b/cpukit/score/src/isr.c
index 3adea71..b9735e3 100644
--- a/cpukit/score/src/isr.c
+++ b/cpukit/score/src/isr.c
@@ -18,11 +18,11 @@
 #include "config.h"
 #endif
-#include <rtems/system.h>
-#include <rtems/score/address.h>
 #include <rtems/score/isr.h>
-#include <rtems/score/stackimpl.h>
+#include <rtems/score/address.h>
 #include <rtems/score/interr.h>
+#include <rtems/score/percpu.h>
+#include <rtems/score/stackimpl.h>
 #include <rtems/config.h>
@@ -41,6 +41,8 @@ void _ISR_Handler_initialization( void )
 #if ( CPU_ALLOCATE_INTERRUPT_STACK == TRUE )
     size_t stack_size = rtems_configuration_get_interrupt_stack_size();
+    uint32_t max_cpus = rtems_configuration_get_maximum_processors();
+    uint32_t cpu;
     if ( !_Stack_Is_enough( stack_size ) )
       _Internal_error_Occurred(
@@ -49,27 +51,29 @@ void _ISR_Handler_initialization( void )
         INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL
-    _CPU_Interrupt_stack_low = _Workspace_Allocate_or_fatal_error(
-      stack_size
-    _CPU_Interrupt_stack_high = _Addresses_Add_offset(
-      _CPU_Interrupt_stack_low,
-      stack_size
+    for ( cpu = 0 ; cpu < max_cpus; ++cpu ) {
+      Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( cpu );
+      void *low = _Workspace_Allocate_or_fatal_error( stack_size );
+      void *high = _Addresses_Add_offset( low, stack_size );
 #if (CPU_STACK_ALIGNMENT != 0)
-  _CPU_Interrupt_stack_high = (void *)
-    ((uintptr_t) _CPU_Interrupt_stack_high & ~(CPU_STACK_ALIGNMENT - 1));
+      high = _Addresses_Align_down( high, CPU_STACK_ALIGNMENT );
 #endif
-  /* Interrupt stack might have to be aligned and/or setup
-   * in a specific way.
+      per_cpu->interrupt_stack_low = low;
+      per_cpu->interrupt_stack_high = high;
+      /* Interrupt stack might have to be aligned and/or setup
+       * in a specific way.
 #if defined(_CPU_Interrupt_stack_setup)
-  _CPU_Interrupt_stack_setup(_CPU_Interrupt_stack_low, _CPU_Interrupt_stack_high);
+      _CPU_Interrupt_stack_setup(
+        per_cpu->interrupt_stack_low,
 #endif
 #endif
diff --git a/cpukit/score/src/percpu.c b/cpukit/score/src/percpu.c
index b041b45..201c53b 100644
--- a/cpukit/score/src/percpu.c
+++ b/cpukit/score/src/percpu.c
@@ -37,27 +37,6 @@
     uint32_t cpu;
-     *  Initialize per cpu pointer table
-    for ( cpu = 1 ; cpu < max_cpus; ++cpu ) {
-      Per_CPU_Control *p = _Per_CPU_Get_by_index( cpu );
-#if CPU_ALLOCATE_INTERRUPT_STACK == TRUE
-        size_t size = rtems_configuration_get_interrupt_stack_size();
-        uintptr_t ptr;
-        p->interrupt_stack_low = _Workspace_Allocate_or_fatal_error( size );
-        ptr = (uintptr_t) _Addresses_Add_offset( p->interrupt_stack_low, size );
-        ptr &= ~(CPU_STACK_ALIGNMENT - 1);
-        p->interrupt_stack_high = (void *)ptr;
-#endif
      * Discover and initialize the secondary cores in an SMP system.
     max_cpus = bsp_smp_initialize( max_cpus );
1.7.7
