Uniprocessor Tests in SMP Configuration
    Sebastian Huber
    Tue Feb 18 07:12:58 UTC 2014
Hello Joel,
On 2014-02-17 18:08, Joel Sherrill wrote:
> Hi
> Has anyone reviewed the results yet?
I executed the tests during development of the SMP priority scheduler.  All
tests using unimplemented features fail.
> With at least no-preempt and ISR disable level not honored
> in the thread mode when SMP is enabled, I would assume
> multiple tests are expected to break.
I collected unsupported features in SMP mode here:
http://git.rtems.org/rtems/tree/testsuites/smptests/smpunsupported01/init.c
What do you mean with "ISR disable level not honored in the thread mode when
SMP is enabled"?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
