leon3 broken for hello
Sebastian Huber
Wed Feb 19 07:48:34 UTC 2014
Hello Joel,
since you don't provide much information (e.g. at least a stack trace would
have been helpful) I can only guess. You probably configured only one GPTIMER
instance in the simulators. Since the LEON processors lacks a free-running CPU
counter I had to use a second GPTIMER instance for this.
You should end up in _Internal_error_Occurred() with the_source ==
RTEMS_FATAL_SOURCE_BSP_SPECIFIC. Now you can look at the <bsp.h> of the LEON3
BSP and find this:
typedef enum {
LEON3_FATAL_CPU_COUNTER_INIT
} leon3_fatal_code;
If you search for LEON3_FATAL_CPU_COUNTER_INIT you will find this:
adev = (void *) ambapp_for_each(
&ambapp_plb,
OPTIONS_ALL | OPTIONS_APB_SLVS,
VENDOR_GAISLER,
GAISLER_GPTIMER,
ambapp_find_by_idx,
&idx
if (adev == NULL) {
rtems_fatal(RTEMS_FATAL_SOURCE_BSP_SPECIFIC, LEON3_FATAL_CPU_COUNTER_INIT);
The question is now: is the absence of a second GPTIMER really a fatal error?
We can avoid a fatal error with the attached patch, but in this case the CPU
counter returns invalid results (e.g. a rtems_counter_delay_ticks() will loop
infinitely). We can also redirect the register to the GPTIMER 0 which is used
by the clock drivers and a possible watchdog. The clock driver and watchdog
need processor count + 1 timers. What happens if we don't have that many
timers in GPTIMER 0?
On 2014-02-19 01:10, Joel Sherrill wrote:
> git bisect ran the change down to this. It was running on tsim leon3
> and grsim before this but broke after this.
> -bash-4.2$ git bisect bad
> 24bf11eca11947d961cc9bb5f7d92dabff169e93 is the first bad commit
> commit 24bf11eca11947d961cc9bb5f7d92dabff169e93
> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date: Wed Feb 12 10:31:38 2014 +0100
> score: Add CPU counter support
> Add a CPU counter interface to allow access to a free-running counter.
> It is useful to measure short time intervals. This can be used for
> example to enable profiling of critical low-level functions.
> Add two busy wait functions rtems_counter_delay_ticks() and
> rtems_counter_delay_nanoseconds() implemented via the CPU counter.
> :040000 040000 bb390b07675147a4b04bdfdba13d092726486075
> 948e8ec05ff56398dfee678c61c6e1a1ce2063bb M c
> :040000 040000 3a8d256d93f7e8da95cb5b192a0d2babb3602fd8
> 85357381e4b15e2bbe83eb046290f913c6ed8db5 M cpukit
> :040000 040000 4b7ccb865ac2633739868fafba5bda2e9bce363a
> 6d94e948495a5bca2dc9fb7022bfe1f1402201fc M doc
> :040000 040000 950f06247d20e4b10bf20de2a251afef810a6bc2
> b7e3e1ca1fe5159a1550c5092f096c99f159bcec M testsuites
> On 2/18/2014 1:12 PM, Joel Sherrill wrote:
>> Hi
>> As best Jennifer and I can tell, the leon3 is broken at the moment.
>> hello does not run on either tsim or grsim.
>> Starting a git bisect but feedback is appreciated.
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140219/cf307da6/attachment.bin>
