[rtems commit] posix: Set pthread attribute values in detach and setschedparm methods.
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Feb 19 21:19:06 UTC 2014
I am OK with this. These just ensure the attributes structure is
up to date so the new pthread_get_attributes_np() works.
Check the copyright dates on the files.
On 2/19/2014 10:33 AM, Jennifer Averett wrote:
> Module: rtems
> Branch: master
> Commit: 52eecbaa089523a4afaef1024225c7bf5181495e
> Changeset: http://git.rtems.org/rtems/commit/?id=52eecbaa089523a4afaef1024225c7bf5181495e
> Author: Jennifer Averett <jennifer.averett at oarcorp.com>
> Date: Wed Feb 19 10:36:01 2014 -0600
> cpukit/posix/src/pthreaddetach.c | 1 +
> cpukit/posix/src/pthreadsetschedparam.c | 3 +++
> 2 files changed, 4 insertions(+), 0 deletions(-)
> diff --git a/cpukit/posix/src/pthreaddetach.c b/cpukit/posix/src/pthreaddetach.c
> index 1087a2c..88fd0e0 100644
> --- a/cpukit/posix/src/pthreaddetach.c
> +++ b/cpukit/posix/src/pthreaddetach.c
> @@ -42,6 +42,7 @@ int pthread_detach(
> api = the_thread->API_Extensions[ THREAD_API_POSIX ];
> api->detachstate = PTHREAD_CREATE_DETACHED;
> + api->Attributes.detachstate = PTHREAD_CREATE_DETACHED;
> _Objects_Put( &the_thread->Object );
> return 0;
> diff --git a/cpukit/posix/src/pthreadsetschedparam.c b/cpukit/posix/src/pthreadsetschedparam.c
> index 2759609..da948ef 100644
> --- a/cpukit/posix/src/pthreadsetschedparam.c
> +++ b/cpukit/posix/src/pthreadsetschedparam.c
> @@ -73,6 +73,9 @@ int pthread_setschedparam(
> api->schedpolicy = policy;
> api->schedparam = *param;
> + api->Attributes.schedpolicy = policy;
> + api->Attributes.schedparam = *param;
> the_thread->budget_algorithm = budget_algorithm;
> the_thread->budget_callout = budget_callout;
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
