[PATCH v2] score: SMP initialization and shutdown changes
Sebastian Huber
Thu Feb 20 16:22:07 UTC 2014
Rename _SMP_Request_other_cores_to_perform_first_context_switch() into
_SMP_Request_start_multitasking() since this requests now a multitasking
start on all configured and available processors. The name corresponds
_Thread_Start_multitasking() and
_SMP_Start_multitasking_on_secondary_processor() actions issued in
response to this request. Move in source file to right place.
Rename PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING into
PER_CPU_STATE_READY_TO_START_MULTITASKING.
Rename PER_CPU_STATE_BEGIN_MULTITASKING into
PER_CPU_STATE_REQUEST_START_MULTITASKING.
Rename _SMP_Request_other_cores_to_shutdown() into
_SMP_Request_shutdown().
Add a per-CPU state lock to protect all changes. This was necessary to
offer a controlled shutdown of the system (atomic read/writes alone are
not sufficient for this kind of synchronization).
Add documentation for Per_CPU_State.
Delete debug output.
New tests smptests/smpfatal01 and smptests/smpfatal02.
cpukit/sapi/src/exinit.c | 2 +-
cpukit/score/include/rtems/score/percpu.h | 82 ++++++++------
cpukit/score/include/rtems/score/smpimpl.h | 22 ++--
cpukit/score/src/interr.c | 2 +-
cpukit/score/src/percpu.c | 158 ++++++++++++++++++++++--
cpukit/score/src/smp.c | 77 ++++---------
cpukit/score/src/threadstartmultitasking.c | 2 +-
testsuites/smptests/Makefile.am | 2 +
testsuites/smptests/configure.ac | 2 +
testsuites/smptests/smpfatal01/Makefile.am | 19 +++
testsuites/smptests/smpfatal01/init.c | 130 ++++++++++++++++++++
testsuites/smptests/smpfatal01/smpfatal01.doc | 12 ++
testsuites/smptests/smpfatal01/smpfatal01.scn | 2 +
testsuites/smptests/smpfatal02/Makefile.am | 19 +++
testsuites/smptests/smpfatal02/init.c | 135 +++++++++++++++++++++
testsuites/smptests/smpfatal02/smpfatal02.doc | 12 ++
testsuites/smptests/smpfatal02/smpfatal02.scn | 2 +
17 files changed, 563 insertions(+), 117 deletions(-)
create mode 100644 testsuites/smptests/smpfatal01/Makefile.am
create mode 100644 testsuites/smptests/smpfatal01/init.c
create mode 100644 testsuites/smptests/smpfatal01/smpfatal01.doc
create mode 100644 testsuites/smptests/smpfatal01/smpfatal01.scn
create mode 100644 testsuites/smptests/smpfatal02/Makefile.am
create mode 100644 testsuites/smptests/smpfatal02/init.c
create mode 100644 testsuites/smptests/smpfatal02/smpfatal02.doc
create mode 100644 testsuites/smptests/smpfatal02/smpfatal02.scn
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index d265455..ee1c7fd 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -210,7 +210,7 @@ void rtems_initialize_start_multitasking(void)
_System_state_Set( SYSTEM_STATE_UP );
- _SMP_Request_other_cores_to_perform_first_context_switch();
+ _SMP_Request_start_multitasking();
_Thread_Start_multitasking();
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index 4c46b50..ca9185e 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -70,64 +70,83 @@ typedef struct Thread_Control_struct Thread_Control;
#error "deferred FP switch not implemented for SMP"
#endif
+ * @brief State of a processor.
+ * The processor state controls the life cycle of processors at the lowest
+ * level. No multi-threading or other high-level concepts matter here.
+ * State changes must be initiated via _Per_CPU_Change_state(). This function
+ * may not return in case someone requested a shutdown. The
+ * _SMP_Send_message() function will be used to notify other processors about
+ * state changes if the other processor is in the up state.
+ * Due to the sequential nature of the basic system initialization one
+ * processor has a special role. It is the processor executing the boot_card()
+ * function. This processor is called the boot processor. All other
+ * processors are called secondary.
+ * @dot
+ * digraph states {
+ * i [label="PER_CPU_STATE_INITIAL"];
+ * rdy [label="PER_CPU_STATE_READY_TO_START_MULTITASKING"];
+ * reqsm [label="PER_CPU_STATE_REQUEST_START_MULTITASKING"];
+ * u [label="PER_CPU_STATE_UP"];
+ * s [label="PER_CPU_STATE_SHUTDOWN"];
+ * i -> rdy [label="processor\ncompleted initialization"];
+ * rdy -> reqsm [label="boot processor\ncompleted initialization"];
+ * reqsm -> u [label="processor\nstarts multitasking"];
+ * i -> s;
+ * rdy -> s;
+ * reqsm -> s;
+ * u -> s;
+ * @enddot
typedef enum {
* @brief The per CPU controls are initialized to zero.
- * In this state the only valid field of the per CPU controls for secondary
- * processors is the per CPU state. The secondary processors should perform
- * their basic initialization now and change into the
- * PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING state once this is complete.
- * The owner of the per CPU state field is the secondary processor in this
- * state.
+ * The boot processor executes the sequential boot code in this state. The
+ * secondary processors should perform their basic initialization now and
+ * change into the PER_CPU_STATE_READY_TO_START_MULTITASKING state once this
+ * is complete.
- PER_CPU_STATE_BEFORE_INITIALIZATION,
+ PER_CPU_STATE_INITIAL,
- * @brief Secondary processor is ready to begin multitasking.
+ * @brief Processor is ready to start multitasking.
* The secondary processor performed its basic initialization and is ready to
* receive inter-processor interrupts. Interrupt delivery must be disabled
* in this state, but requested inter-processor interrupts must be recorded
* and must be delivered once the secondary processor enables interrupts for
- * the first time. The main processor will wait for all secondary processors
+ * the first time. The boot processor will wait for all secondary processors
* to change into this state. In case a secondary processor does not reach
* this state the system will not start. The secondary processors wait now
- * for a change into the PER_CPU_STATE_BEGIN_MULTITASKING state set by the
- * main processor once all secondary processors reached the
- * PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING state.
- * The owner of the per CPU state field is the main processor in this state.
+ * for a change into the PER_CPU_STATE_REQUEST_START_MULTITASKING state set
+ * by the boot processor once all secondary processors reached the
+ * PER_CPU_STATE_READY_TO_START_MULTITASKING state.
- PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING,
+ PER_CPU_STATE_READY_TO_START_MULTITASKING,
- * @brief Multitasking begin of secondary processor is requested.
+ * @brief Multitasking start of processor is requested.
- * The main processor completed system initialization and is about to perform
+ * The boot processor completed system initialization and is about to perform
* a context switch to its heir thread. Secondary processors should now
* issue a context switch to the heir thread. This normally enables
* interrupts on the processor for the first time.
- * state.
- PER_CPU_STATE_BEGIN_MULTITASKING,
+ PER_CPU_STATE_REQUEST_START_MULTITASKING,
* @brief Normal multitasking state.
- * state.
PER_CPU_STATE_UP,
* @brief This is the terminal state.
- * state.
} Per_CPU_State;
@@ -313,16 +332,11 @@ static inline void _Per_CPU_Send_interrupt( const Per_CPU_Control *per_cpu )
void _Per_CPU_Initialize(void);
-void _Per_CPU_Change_state(
+void _Per_CPU_State_change(
Per_CPU_Control *per_cpu,
Per_CPU_State new_state
-void _Per_CPU_Wait_for_state(
- const Per_CPU_Control *per_cpu,
- Per_CPU_State desired_state
#endif /* defined( RTEMS_SMP ) */
diff --git a/cpukit/score/include/rtems/score/smpimpl.h b/cpukit/score/include/rtems/score/smpimpl.h
index d68af43..da08cf5 100644
--- a/cpukit/score/include/rtems/score/smpimpl.h
+++ b/cpukit/score/include/rtems/score/smpimpl.h
@@ -108,8 +108,6 @@ static inline void _SMP_Inter_processor_interrupt_handler( void )
_Per_CPU_Release_and_ISR_enable( self_cpu, level );
if ( ( message & SMP_MESSAGE_SHUTDOWN ) != 0 ) {
- _Per_CPU_Change_state( self_cpu, PER_CPU_STATE_SHUTDOWN );
rtems_fatal( RTEMS_FATAL_SOURCE_SMP, SMP_FATAL_SHUTDOWN );
/* does not continue past here */
@@ -143,27 +141,27 @@ void _SMP_Broadcast_message(
- * @brief Request other cores to perform first context switch.
- * Send message to other cores requesting them to perform
- * their first context switch operation.
+ * @brief Requests a multitasking start on all configured and available
+ * processors.
#if defined( RTEMS_SMP )
- void _SMP_Request_other_cores_to_perform_first_context_switch( void );
+ void _SMP_Request_start_multitasking( void );
#else
- #define _SMP_Request_other_cores_to_perform_first_context_switch() \
+ #define _SMP_Request_start_multitasking() \
do { } while ( 0 )
#endif
- * @brief Request other cores to shutdown.
+ * @brief Requests a shutdown of all processors.
+ * This function is a part of the system termination procedure.
- * Send message to other cores requesting them to shutdown.
+ * @see _Terminate().
- void _SMP_Request_other_cores_to_shutdown( void );
+ void _SMP_Request_shutdown( void );
#else
- #define _SMP_Request_other_cores_to_shutdown() \
+ #define _SMP_Request_shutdown() \
do { } while ( 0 )
#endif
diff --git a/cpukit/score/src/interr.c b/cpukit/score/src/interr.c
index c2a9fbe..11578a6 100644
--- a/cpukit/score/src/interr.c
+++ b/cpukit/score/src/interr.c
@@ -39,7 +39,7 @@ void _Terminate(
_ISR_Disable_without_giant( level );
(void) level;
- _SMP_Request_other_cores_to_shutdown();
+ _SMP_Request_shutdown();
_User_extensions_Fatal( the_source, is_internal, the_error );
diff --git a/cpukit/score/src/percpu.c b/cpukit/score/src/percpu.c
index c68f378..3a7a845 100644
--- a/cpukit/score/src/percpu.c
+++ b/cpukit/score/src/percpu.c
@@ -19,26 +19,156 @@
#endif
+#include <rtems/score/assert.h>
+#include <rtems/score/smpimpl.h>
+#include <rtems/config.h>
+#include <rtems/fatal.h>
#if defined(RTEMS_SMP)
- void _Per_CPU_Change_state(
- Per_CPU_Control *per_cpu,
- Per_CPU_State new_state
- per_cpu->state = new_state;
- _CPU_SMP_Processor_event_broadcast();
+static SMP_lock_Control _Per_CPU_State_lock = SMP_LOCK_INITIALIZER;
+static ISR_Level _Per_CPU_State_acquire( void )
+ ISR_Level level;
+ _SMP_lock_ISR_disable_and_acquire( &_Per_CPU_State_lock, level );
+ return level;
+static void _Per_CPU_State_release( ISR_Level level )
+ _SMP_lock_Release_and_ISR_enable( &_Per_CPU_State_lock, level );
+static void _Per_CPU_State_busy_wait(
+ const Per_CPU_Control *per_cpu,
+ Per_CPU_State new_state
+ Per_CPU_State state = per_cpu->state;
+ switch ( new_state ) {
+ case PER_CPU_STATE_REQUEST_START_MULTITASKING:
+ while (
+ state != PER_CPU_STATE_READY_TO_START_MULTITASKING
+ && state != PER_CPU_STATE_SHUTDOWN
+ _CPU_SMP_Processor_event_receive();
+ state = per_cpu->state;
+ break;
+ case PER_CPU_STATE_UP:
+ while (
+ state != PER_CPU_STATE_REQUEST_START_MULTITASKING
+ break;
+ default:
+ /* No need to wait */
+ break;
+static Per_CPU_State _Per_CPU_State_get_next(
+ Per_CPU_State current_state,
+ switch ( current_state ) {
+ case PER_CPU_STATE_INITIAL:
+ case PER_CPU_STATE_READY_TO_START_MULTITASKING:
+ case PER_CPU_STATE_SHUTDOWN:
+ /* Change is acceptable */
+ break;
+ default:
+ new_state = PER_CPU_STATE_SHUTDOWN;
+ break;
+ break;
+ break;
+ default:
+ break;
+ break;
+ break;
+ default:
+ break;
+ break;
+ default:
+ break;
- void _Per_CPU_Wait_for_state(
- while ( per_cpu->state != desired_state ) {
- _CPU_SMP_Processor_event_receive();
+ return new_state;
+ Per_CPU_Control *per_cpu,
+ ISR_Level level;
+ Per_CPU_State next_state;
+ _Per_CPU_State_busy_wait( per_cpu, new_state );
+ level = _Per_CPU_State_acquire();
+ next_state = _Per_CPU_State_get_next( per_cpu->state, new_state );
+ per_cpu->state = next_state;
+ if ( next_state == PER_CPU_STATE_SHUTDOWN ) {
+ uint32_t ncpus = rtems_configuration_get_maximum_processors();
+ uint32_t cpu;
+ for ( cpu = 0 ; cpu < ncpus ; ++cpu ) {
+ Per_CPU_Control *other_cpu = _Per_CPU_Get_by_index( cpu );
+ if ( per_cpu != other_cpu ) {
+ switch ( other_cpu->state ) {
+ _SMP_Send_message( cpu, SMP_MESSAGE_SHUTDOWN );
+ break;
+ default:
+ /* Nothing to do */
+ break;
+ other_cpu->state = PER_CPU_STATE_SHUTDOWN;
+ _CPU_SMP_Processor_event_broadcast();
+ _Per_CPU_State_release( level );
+ if (
+ next_state == PER_CPU_STATE_SHUTDOWN
+ && new_state != PER_CPU_STATE_SHUTDOWN
+ rtems_fatal( RTEMS_FATAL_SOURCE_SMP, SMP_FATAL_SHUTDOWN );
#else
* On single core systems, we can efficiently directly access a single
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index 59036eb..0f63223 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -24,10 +24,6 @@
-#if defined(RTEMS_DEBUG)
- #include <rtems/bspIo.h>
-#endif
void _SMP_Handler_initialize( void )
uint32_t max_cpus = rtems_configuration_get_maximum_processors();
@@ -47,21 +43,38 @@ void _SMP_Handler_initialize( void )
_SMP_Processor_count = max_cpus;
-void _SMP_Start_multitasking_on_secondary_processor( void )
+void _SMP_Request_start_multitasking( void )
Per_CPU_Control *self_cpu = _Per_CPU_Get();
+ uint32_t ncpus = _SMP_Get_processor_count();
+ uint32_t cpu;
+ _Per_CPU_State_change( self_cpu, PER_CPU_STATE_READY_TO_START_MULTITASKING );
- #if defined(RTEMS_DEBUG)
- printk( "Made it to %d -- ", _Per_CPU_Get_index( self_cpu ) );
- #endif
+ Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( cpu );
+ _Per_CPU_State_change( per_cpu, PER_CPU_STATE_REQUEST_START_MULTITASKING );
- _Per_CPU_Change_state( self_cpu, PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING );
+void _SMP_Start_multitasking_on_secondary_processor( void )
+ Per_CPU_Control *self_cpu = _Per_CPU_Get();
- _Per_CPU_Wait_for_state( self_cpu, PER_CPU_STATE_BEGIN_MULTITASKING );
+void _SMP_Request_shutdown( void )
+ uint32_t self = _SMP_Get_current_processor();
+ Per_CPU_Control *self_cpu = _Per_CPU_Get_by_index( self );
+ _Per_CPU_State_change( self_cpu, PER_CPU_STATE_SHUTDOWN );
void _SMP_Send_message( uint32_t cpu, uint32_t message )
@@ -88,47 +101,3 @@ void _SMP_Broadcast_message( uint32_t message )
-void _SMP_Request_other_cores_to_perform_first_context_switch( void )
- uint32_t self = _SMP_Get_current_processor();
- uint32_t ncpus = _SMP_Get_processor_count();
- uint32_t cpu;
- for ( cpu = 0 ; cpu < ncpus ; ++cpu ) {
- Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( cpu );
- if ( cpu != self ) {
- per_cpu,
- _Per_CPU_Change_state( per_cpu, PER_CPU_STATE_BEGIN_MULTITASKING );
-void _SMP_Request_other_cores_to_shutdown( void )
- * Do not use _SMP_Get_processor_count() since this value might be not
- * initialized yet. For example due to a fatal error in the middle of
- * _CPU_SMP_Initialize().
- uint32_t ncpus = rtems_configuration_get_maximum_processors();
- uint32_t cpu;
- const Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( cpu );
- if ( per_cpu->state != PER_CPU_STATE_BEFORE_INITIALIZATION ) {
- _SMP_Send_message( cpu, SMP_MESSAGE_SHUTDOWN );
diff --git a/cpukit/score/src/threadstartmultitasking.c b/cpukit/score/src/threadstartmultitasking.c
index a61a51c..b9cdaf8 100644
--- a/cpukit/score/src/threadstartmultitasking.c
+++ b/cpukit/score/src/threadstartmultitasking.c
@@ -26,7 +26,7 @@ void _Thread_Start_multitasking( void )
Thread_Control *heir;
- _Per_CPU_Change_state( self_cpu, PER_CPU_STATE_UP );
+ _Per_CPU_State_change( self_cpu, PER_CPU_STATE_UP );
* Threads begin execution in the _Thread_Handler() function. This
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index 023b7e9..8422f3a 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -11,6 +11,8 @@ SUBDIRS += smp07
SUBDIRS += smp08
SUBDIRS += smp09
SUBDIRS += smpatomic01
+SUBDIRS += smpfatal01
+SUBDIRS += smpfatal02
SUBDIRS += smplock01
SUBDIRS += smpmigration01
SUBDIRS += smpschedule01
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index 5c68772..19e32f3 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -65,6 +65,8 @@ smp07/Makefile
smp08/Makefile
smp09/Makefile
smpatomic01/Makefile
+smpfatal01/Makefile
+smpfatal02/Makefile
smplock01/Makefile
smpmigration01/Makefile
smppsxsignal01/Makefile
diff --git a/testsuites/smptests/smpfatal01/Makefile.am b/testsuites/smptests/smpfatal01/Makefile.am
new file mode 100644
index 0000000..2aaee2b
--- /dev/null
+++ b/testsuites/smptests/smpfatal01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smpfatal01
+smpfatal01_SOURCES = init.c
+dist_rtems_tests_DATA = smpfatal01.scn smpfatal01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(smpfatal01_OBJECTS)
+LINK_LIBS = $(smpfatal01_LDLIBS)
+smpfatal01$(EXEEXT): $(smpfatal01_OBJECTS) $(smpfatal01_DEPENDENCIES)
+ @rm -f smpfatal01$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smpfatal01/init.c b/testsuites/smptests/smpfatal01/init.c
index 0000000..c78b29f
--- /dev/null
+++ b/testsuites/smptests/smpfatal01/init.c
@@ -0,0 +1,130 @@
+ * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/score/percpu.h>
+#include <assert.h>
+#include <stdlib.h>
+#define MAX_CPUS 32
+static uint32_t main_cpu;
+static void Init(rtems_task_argument arg)
+ assert(0);
+static void end_of_test(void)
+ printk( "*** END OF TEST SMPFATAL 1 ***\n" );
+static void fatal_extension(
+ rtems_fatal_source source,
+ bool is_internal,
+ rtems_fatal_code code
+ if (source == RTEMS_FATAL_SOURCE_SMP) {
+ uint32_t self = rtems_smp_get_current_processor();
+ assert(!is_internal);
+ assert(code == SMP_FATAL_SHUTDOWN);
+ if (self == main_cpu) {
+ uint32_t cpu;
+ for (cpu = 0; cpu < MAX_CPUS; ++cpu) {
+ const Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( cpu );
+ assert(state == PER_CPU_STATE_SHUTDOWN);
+ end_of_test();
+static rtems_status_code test_driver_init(
+ rtems_device_major_number major,
+ rtems_device_minor_number minor,
+ void *arg
+ uint32_t cpu_count = rtems_smp_get_processor_count();
+ uint32_t cpu;
+ printk("\n\n*** TEST SMPFATAL 1 ***\n");
+ assert(rtems_configuration_get_maximum_processors() == MAX_CPUS);
+ main_cpu = self;
+ if (cpu == self) {
+ assert(state == PER_CPU_STATE_INITIAL);
+ } else if (cpu < cpu_count) {
+ assert(
+ state == PER_CPU_STATE_INITIAL
+ || state == PER_CPU_STATE_READY_TO_START_MULTITASKING
+ } else {
+ if (cpu_count > 1) {
+ uint32_t other = (self + 1) % cpu_count;
+ Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( other );
+ per_cpu->state = PER_CPU_STATE_SHUTDOWN;
+ } else {
+ end_of_test();
+ exit(0);
+ return RTEMS_SUCCESSFUL;
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_EXTRA_DRIVERS \
+ { .initialization_entry = test_driver_init }
+#define CONFIGURE_INITIAL_EXTENSIONS { .fatal = fatal_extension }
+#define CONFIGURE_SMP_APPLICATION
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS MAX_CPUS
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpfatal01/smpfatal01.doc b/testsuites/smptests/smpfatal01/smpfatal01.doc
index 0000000..c037cfe
--- /dev/null
+++ b/testsuites/smptests/smpfatal01/smpfatal01.doc
@@ -0,0 +1,12 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpfatal01
+directives:
+ - _Per_CPU_State_change()
+concepts:
+ - Ensure that the system termination in case of shutdown detection at a
+ secondary processors works during driver initialization.
diff --git a/testsuites/smptests/smpfatal01/smpfatal01.scn b/testsuites/smptests/smpfatal01/smpfatal01.scn
index 0000000..0b67121
--- /dev/null
+++ b/testsuites/smptests/smpfatal01/smpfatal01.scn
@@ -0,0 +1,2 @@
+*** TEST SMPFATAL 1 ***
+*** END OF TEST SMPFATAL 1 ***
diff --git a/testsuites/smptests/smpfatal02/Makefile.am b/testsuites/smptests/smpfatal02/Makefile.am
index 0000000..bbce3b7
--- /dev/null
+++ b/testsuites/smptests/smpfatal02/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smpfatal02
+smpfatal02_SOURCES = init.c
+dist_rtems_tests_DATA = smpfatal02.scn smpfatal02.doc
+LINK_OBJS = $(smpfatal02_OBJECTS)
+LINK_LIBS = $(smpfatal02_LDLIBS)
+smpfatal02$(EXEEXT): $(smpfatal02_OBJECTS) $(smpfatal02_DEPENDENCIES)
+ @rm -f smpfatal02$(EXEEXT)
+ $(make-exe)
diff --git a/testsuites/smptests/smpfatal02/init.c b/testsuites/smptests/smpfatal02/init.c
index 0000000..1e8da26
--- /dev/null
+++ b/testsuites/smptests/smpfatal02/init.c
@@ -0,0 +1,135 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#endif
+#include <rtems.h>
+ assert(0);
+ printk( "*** END OF TEST SMPFATAL 2 ***\n" );
+ bool is_internal,
+ if (
+ source == RTEMS_FATAL_SOURCE_APPLICATION
+ || source == RTEMS_FATAL_SOURCE_SMP
+ uint32_t cpu;
+ assert(source == RTEMS_FATAL_SOURCE_APPLICATION);
+ assert(code == 0xdeadbeef);
+ end_of_test();
+ } else {
+ assert(source == RTEMS_FATAL_SOURCE_SMP);
+ void *arg
+ uint32_t cpu;
+ printk("\n\n*** TEST SMPFATAL 2 ***\n");
+ main_cpu = self;
+ assert(
+ } else {
+ rtems_fatal(RTEMS_FATAL_SOURCE_APPLICATION, 0xdeadbeef);
+ } else {
+ end_of_test();
+ exit(0);
diff --git a/testsuites/smptests/smpfatal02/smpfatal02.doc b/testsuites/smptests/smpfatal02/smpfatal02.doc
index 0000000..9e2e002
--- /dev/null
+++ b/testsuites/smptests/smpfatal02/smpfatal02.doc
@@ -0,0 +1,12 @@
+test set name: smpfatal02
+directives:
+concepts:
+ - Ensure that the system termination in case of fatal errors during driver
+ initialization works.
diff --git a/testsuites/smptests/smpfatal02/smpfatal02.scn b/testsuites/smptests/smpfatal02/smpfatal02.scn
index 0000000..cde11a0
--- /dev/null
+++ b/testsuites/smptests/smpfatal02/smpfatal02.scn
@@ -0,0 +1,2 @@
+*** TEST SMPFATAL 2 ***
+*** END OF TEST SMPFATAL 2 ***
1.7.7
