[PATCH v2] score: SMP initialization and shutdown changes
Thu Feb 20 17:36:58 UTC 2014
What RTEMS configure and BSPs do you test this on?
On Thu, Feb 20, 2014 at 11:22 AM, Sebastian Huber
> Rename _SMP_Request_other_cores_to_perform_first_context_switch() into
> _SMP_Request_start_multitasking() since this requests now a multitasking
> start on all configured and available processors.  The name corresponds
> _Thread_Start_multitasking() and
> _SMP_Start_multitasking_on_secondary_processor() actions issued in
> response to this request.  Move in source file to right place.
> Rename PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING into
> PER_CPU_STATE_READY_TO_START_MULTITASKING.
> Rename PER_CPU_STATE_BEGIN_MULTITASKING into
> PER_CPU_STATE_REQUEST_START_MULTITASKING.
> Rename _SMP_Request_other_cores_to_shutdown() into
> _SMP_Request_shutdown().
> Add a per-CPU state lock to protect all changes.  This was necessary to
> offer a controlled shutdown of the system (atomic read/writes alone are
> not sufficient for this kind of synchronization).
> Add documentation for Per_CPU_State.
> Delete debug output.
> New tests smptests/smpfatal01 and smptests/smpfatal02.
>  cpukit/sapi/src/exinit.c                      |    2 +-
>  cpukit/score/include/rtems/score/percpu.h     |   82 ++++++++------
>  cpukit/score/include/rtems/score/smpimpl.h    |   22 ++--
>  cpukit/score/src/interr.c                     |    2 +-
>  cpukit/score/src/percpu.c                     |  158 ++++++++++++++++++++++--
>  cpukit/score/src/smp.c                        |   77 ++++---------
>  cpukit/score/src/threadstartmultitasking.c    |    2 +-
>  testsuites/smptests/Makefile.am               |    2 +
>  testsuites/smptests/configure.ac              |    2 +
>  testsuites/smptests/smpfatal01/Makefile.am    |   19 +++
>  testsuites/smptests/smpfatal01/init.c         |  130 ++++++++++++++++++++
>  testsuites/smptests/smpfatal01/smpfatal01.doc |   12 ++
>  testsuites/smptests/smpfatal01/smpfatal01.scn |    2 +
>  testsuites/smptests/smpfatal02/Makefile.am    |   19 +++
>  testsuites/smptests/smpfatal02/init.c         |  135 +++++++++++++++++++++
>  testsuites/smptests/smpfatal02/smpfatal02.doc |   12 ++
>  testsuites/smptests/smpfatal02/smpfatal02.scn |    2 +
>  17 files changed, 563 insertions(+), 117 deletions(-)
>  create mode 100644 testsuites/smptests/smpfatal01/Makefile.am
>  create mode 100644 testsuites/smptests/smpfatal01/init.c
>  create mode 100644 testsuites/smptests/smpfatal01/smpfatal01.doc
>  create mode 100644 testsuites/smptests/smpfatal01/smpfatal01.scn
>  create mode 100644 testsuites/smptests/smpfatal02/Makefile.am
>  create mode 100644 testsuites/smptests/smpfatal02/init.c
>  create mode 100644 testsuites/smptests/smpfatal02/smpfatal02.doc
>  create mode 100644 testsuites/smptests/smpfatal02/smpfatal02.scn
> diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
> index d265455..ee1c7fd 100644
> --- a/cpukit/sapi/src/exinit.c
> +++ b/cpukit/sapi/src/exinit.c
> @@ -210,7 +210,7 @@ void rtems_initialize_start_multitasking(void)
>    _System_state_Set( SYSTEM_STATE_UP );
> -  _SMP_Request_other_cores_to_perform_first_context_switch();
> +  _SMP_Request_start_multitasking();
>    _Thread_Start_multitasking();
> diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
> index 4c46b50..ca9185e 100644
> --- a/cpukit/score/include/rtems/score/percpu.h
> +++ b/cpukit/score/include/rtems/score/percpu.h
> @@ -70,64 +70,83 @@ typedef struct Thread_Control_struct Thread_Control;
>    #error "deferred FP switch not implemented for SMP"
>  #endif
> + * @brief State of a processor.
> + * The processor state controls the life cycle of processors at the lowest
> + * level.  No multi-threading or other high-level concepts matter here.
> + * State changes must be initiated via _Per_CPU_Change_state().  This function
> + * may not return in case someone requested a shutdown.  The
> + * _SMP_Send_message() function will be used to notify other processors about
> + * state changes if the other processor is in the up state.
> + * Due to the sequential nature of the basic system initialization one
> + * processor has a special role.  It is the processor executing the boot_card()
> + * function.  This processor is called the boot processor.  All other
> + * processors are called secondary.
> + * @dot
> + * digraph states {
> + *   i [label="PER_CPU_STATE_INITIAL"];
> + *   rdy [label="PER_CPU_STATE_READY_TO_START_MULTITASKING"];
> + *   reqsm [label="PER_CPU_STATE_REQUEST_START_MULTITASKING"];
> + *   u [label="PER_CPU_STATE_UP"];
> + *   s [label="PER_CPU_STATE_SHUTDOWN"];
> + *   i -> rdy [label="processor\ncompleted initialization"];
> + *   rdy -> reqsm [label="boot processor\ncompleted initialization"];
> + *   reqsm -> u [label="processor\nstarts multitasking"];
> + *   i -> s;
> + *   rdy -> s;
> + *   reqsm -> s;
> + *   u -> s;
> + * @enddot
>  typedef enum {
>     * @brief The per CPU controls are initialized to zero.
> -   * In this state the only valid field of the per CPU controls for secondary
> -   * processors is the per CPU state.  The secondary processors should perform
> -   * their basic initialization now and change into the
> -   * PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING state once this is complete.
> -   * The owner of the per CPU state field is the secondary processor in this
> -   * state.
> +   * The boot processor executes the sequential boot code in this state.  The
> +   * secondary processors should perform their basic initialization now and
> +   * change into the PER_CPU_STATE_READY_TO_START_MULTITASKING state once this
> +   * is complete.
> -  PER_CPU_STATE_BEFORE_INITIALIZATION,
> +  PER_CPU_STATE_INITIAL,
> -   * @brief Secondary processor is ready to begin multitasking.
> +   * @brief Processor is ready to start multitasking.
>     * The secondary processor performed its basic initialization and is ready to
>     * receive inter-processor interrupts.  Interrupt delivery must be disabled
>     * in this state, but requested inter-processor interrupts must be recorded
>     * and must be delivered once the secondary processor enables interrupts for
> -   * the first time.  The main processor will wait for all secondary processors
> +   * the first time.  The boot processor will wait for all secondary processors
>     * to change into this state.  In case a secondary processor does not reach
>     * this state the system will not start.  The secondary processors wait now
> -   * for a change into the PER_CPU_STATE_BEGIN_MULTITASKING state set by the
> -   * main processor once all secondary processors reached the
> -   * PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING state.
> -   * The owner of the per CPU state field is the main processor in this state.
> +   * for a change into the PER_CPU_STATE_REQUEST_START_MULTITASKING state set
> +   * by the boot processor once all secondary processors reached the
> +   * PER_CPU_STATE_READY_TO_START_MULTITASKING state.
> -  PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING,
> +  PER_CPU_STATE_READY_TO_START_MULTITASKING,
> -   * @brief Multitasking begin of secondary processor is requested.
> +   * @brief Multitasking start of processor is requested.
> -   * The main processor completed system initialization and is about to perform
> +   * The boot processor completed system initialization and is about to perform
>     * a context switch to its heir thread.  Secondary processors should now
>     * issue a context switch to the heir thread.  This normally enables
>     * interrupts on the processor for the first time.
> -   * state.
> -  PER_CPU_STATE_BEGIN_MULTITASKING,
> +  PER_CPU_STATE_REQUEST_START_MULTITASKING,
>     * @brief Normal multitasking state.
> -   * state.
>    PER_CPU_STATE_UP,
>     * @brief This is the terminal state.
> -   * state.
>  } Per_CPU_State;
> @@ -313,16 +332,11 @@ static inline void _Per_CPU_Send_interrupt( const Per_CPU_Control *per_cpu )
>  void _Per_CPU_Initialize(void);
> -void _Per_CPU_Change_state(
> +void _Per_CPU_State_change(
>    Per_CPU_Control *per_cpu,
>    Per_CPU_State new_state
> -void _Per_CPU_Wait_for_state(
> -  const Per_CPU_Control *per_cpu,
> -  Per_CPU_State desired_state
>  #endif /* defined( RTEMS_SMP ) */
> diff --git a/cpukit/score/include/rtems/score/smpimpl.h b/cpukit/score/include/rtems/score/smpimpl.h
> index d68af43..da08cf5 100644
> --- a/cpukit/score/include/rtems/score/smpimpl.h
> +++ b/cpukit/score/include/rtems/score/smpimpl.h
> @@ -108,8 +108,6 @@ static inline void _SMP_Inter_processor_interrupt_handler( void )
>      _Per_CPU_Release_and_ISR_enable( self_cpu, level );
>      if ( ( message & SMP_MESSAGE_SHUTDOWN ) != 0 ) {
> -      _Per_CPU_Change_state( self_cpu, PER_CPU_STATE_SHUTDOWN );
>        rtems_fatal( RTEMS_FATAL_SOURCE_SMP, SMP_FATAL_SHUTDOWN );
>        /* does not continue past here */
> @@ -143,27 +141,27 @@ void _SMP_Broadcast_message(
> - *  @brief Request other cores to perform first context switch.
> - *  Send message to other cores requesting them to perform
> - *  their first context switch operation.
> + * @brief Requests a multitasking start on all configured and available
> + * processors.
>  #if defined( RTEMS_SMP )
> -  void _SMP_Request_other_cores_to_perform_first_context_switch( void );
> +  void _SMP_Request_start_multitasking( void );
>  #else
> -  #define _SMP_Request_other_cores_to_perform_first_context_switch() \
> +  #define _SMP_Request_start_multitasking() \
>      do { } while ( 0 )
>  #endif
> - *  @brief Request other cores to shutdown.
> + * @brief Requests a shutdown of all processors.
> + * This function is a part of the system termination procedure.
> - *  Send message to other cores requesting them to shutdown.
> + * @see _Terminate().
> -  void _SMP_Request_other_cores_to_shutdown( void );
> +  void _SMP_Request_shutdown( void );
>  #else
> -  #define _SMP_Request_other_cores_to_shutdown() \
> +  #define _SMP_Request_shutdown() \
>      do { } while ( 0 )
>  #endif
> diff --git a/cpukit/score/src/interr.c b/cpukit/score/src/interr.c
> index c2a9fbe..11578a6 100644
> --- a/cpukit/score/src/interr.c
> +++ b/cpukit/score/src/interr.c
> @@ -39,7 +39,7 @@ void _Terminate(
>    _ISR_Disable_without_giant( level );
>    (void) level;
> -  _SMP_Request_other_cores_to_shutdown();
> +  _SMP_Request_shutdown();
>    _User_extensions_Fatal( the_source, is_internal, the_error );
> diff --git a/cpukit/score/src/percpu.c b/cpukit/score/src/percpu.c
> index c68f378..3a7a845 100644
> --- a/cpukit/score/src/percpu.c
> +++ b/cpukit/score/src/percpu.c
> @@ -19,26 +19,156 @@
>  #endif
>  #include <rtems/score/percpu.h>
> +#include <rtems/score/assert.h>
> +#include <rtems/score/smpimpl.h>
> +#include <rtems/config.h>
> +#include <rtems/fatal.h>
>  #if defined(RTEMS_SMP)
> -  void _Per_CPU_Change_state(
> -    Per_CPU_Control *per_cpu,
> -    Per_CPU_State new_state
> -    per_cpu->state = new_state;
> -    _CPU_SMP_Processor_event_broadcast();
> +static SMP_lock_Control _Per_CPU_State_lock = SMP_LOCK_INITIALIZER;
> +static ISR_Level _Per_CPU_State_acquire( void )
> +  ISR_Level level;
> +  _SMP_lock_ISR_disable_and_acquire( &_Per_CPU_State_lock, level );
> +  return level;
> +static void _Per_CPU_State_release( ISR_Level level )
> +  _SMP_lock_Release_and_ISR_enable( &_Per_CPU_State_lock, level );
> +static void _Per_CPU_State_busy_wait(
> +  const Per_CPU_Control *per_cpu,
> +  Per_CPU_State new_state
> +  Per_CPU_State state = per_cpu->state;
> +  switch ( new_state ) {
> +    case PER_CPU_STATE_REQUEST_START_MULTITASKING:
> +      while (
> +        state != PER_CPU_STATE_READY_TO_START_MULTITASKING
> +          && state != PER_CPU_STATE_SHUTDOWN
> +        _CPU_SMP_Processor_event_receive();
> +        state = per_cpu->state;
> +      break;
> +    case PER_CPU_STATE_UP:
> +      while (
> +        state != PER_CPU_STATE_REQUEST_START_MULTITASKING
> +      break;
> +    default:
> +      /* No need to wait */
> +      break;
> +static Per_CPU_State _Per_CPU_State_get_next(
> +  Per_CPU_State current_state,
> +  switch ( current_state ) {
> +    case PER_CPU_STATE_INITIAL:
> +        case PER_CPU_STATE_READY_TO_START_MULTITASKING:
> +        case PER_CPU_STATE_SHUTDOWN:
> +          /* Change is acceptable */
> +          break;
> +        default:
> +          new_state = PER_CPU_STATE_SHUTDOWN;
> +          break;
> +      break;
> +          break;
> +        default:
> +          break;
> +      break;
> +          break;
> +        default:
> +          break;
> +      break;
> +    default:
> +      break;
> -  void _Per_CPU_Wait_for_state(
> -    while ( per_cpu->state != desired_state ) {
> -      _CPU_SMP_Processor_event_receive();
> +  return new_state;
> +  Per_CPU_Control *per_cpu,
> +  ISR_Level level;
> +  Per_CPU_State next_state;
> +  _Per_CPU_State_busy_wait( per_cpu, new_state );
> +  level = _Per_CPU_State_acquire();
> +  next_state = _Per_CPU_State_get_next( per_cpu->state, new_state );
> +  per_cpu->state = next_state;
> +  if ( next_state == PER_CPU_STATE_SHUTDOWN ) {
> +    uint32_t ncpus = rtems_configuration_get_maximum_processors();
> +    uint32_t cpu;
> +    for ( cpu = 0 ; cpu < ncpus ; ++cpu ) {
> +      Per_CPU_Control *other_cpu = _Per_CPU_Get_by_index( cpu );
> +      if ( per_cpu != other_cpu ) {
> +        switch ( other_cpu->state ) {
> +            _SMP_Send_message( cpu, SMP_MESSAGE_SHUTDOWN );
> +            break;
> +          default:
> +            /* Nothing to do */
> +            break;
> +        other_cpu->state = PER_CPU_STATE_SHUTDOWN;
> +  _CPU_SMP_Processor_event_broadcast();
> +  _Per_CPU_State_release( level );
> +  if (
> +    next_state == PER_CPU_STATE_SHUTDOWN
> +      && new_state != PER_CPU_STATE_SHUTDOWN
> +    rtems_fatal( RTEMS_FATAL_SOURCE_SMP, SMP_FATAL_SHUTDOWN );
>  #else
>     * On single core systems, we can efficiently directly access a single
> diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
> index 59036eb..0f63223 100644
> --- a/cpukit/score/src/smp.c
> +++ b/cpukit/score/src/smp.c
> @@ -24,10 +24,6 @@
>  #include <rtems/score/threadimpl.h>
> -#if defined(RTEMS_DEBUG)
> -  #include <rtems/bspIo.h>
> -#endif
>  void _SMP_Handler_initialize( void )
>    uint32_t max_cpus = rtems_configuration_get_maximum_processors();
> @@ -47,21 +43,38 @@ void _SMP_Handler_initialize( void )
>    _SMP_Processor_count = max_cpus;
> -void _SMP_Start_multitasking_on_secondary_processor( void )
> +void _SMP_Request_start_multitasking( void )
>    Per_CPU_Control *self_cpu = _Per_CPU_Get();
> +  uint32_t ncpus = _SMP_Get_processor_count();
> +  uint32_t cpu;
> +  _Per_CPU_State_change( self_cpu, PER_CPU_STATE_READY_TO_START_MULTITASKING );
> -  #if defined(RTEMS_DEBUG)
> -    printk( "Made it to %d -- ", _Per_CPU_Get_index( self_cpu ) );
> -  #endif
> +    Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( cpu );
> +    _Per_CPU_State_change( per_cpu, PER_CPU_STATE_REQUEST_START_MULTITASKING );
> -  _Per_CPU_Change_state( self_cpu, PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING );
> +void _SMP_Start_multitasking_on_secondary_processor( void )
> +  Per_CPU_Control *self_cpu = _Per_CPU_Get();
> -  _Per_CPU_Wait_for_state( self_cpu, PER_CPU_STATE_BEGIN_MULTITASKING );
> +void _SMP_Request_shutdown( void )
> +  uint32_t self = _SMP_Get_current_processor();
> +  Per_CPU_Control *self_cpu = _Per_CPU_Get_by_index( self );
> +  _Per_CPU_State_change( self_cpu, PER_CPU_STATE_SHUTDOWN );
>  void _SMP_Send_message( uint32_t cpu, uint32_t message )
> @@ -88,47 +101,3 @@ void _SMP_Broadcast_message( uint32_t message )
> -void _SMP_Request_other_cores_to_perform_first_context_switch( void )
> -  uint32_t self = _SMP_Get_current_processor();
> -  uint32_t ncpus = _SMP_Get_processor_count();
> -  uint32_t cpu;
> -  for ( cpu = 0 ; cpu < ncpus ; ++cpu ) {
> -    Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( cpu );
> -    if ( cpu != self ) {
> -        per_cpu,
> -      _Per_CPU_Change_state( per_cpu, PER_CPU_STATE_BEGIN_MULTITASKING );
> -void _SMP_Request_other_cores_to_shutdown( void )
> -   * Do not use _SMP_Get_processor_count() since this value might be not
> -   * initialized yet.  For example due to a fatal error in the middle of
> -   * _CPU_SMP_Initialize().
> -  uint32_t ncpus = rtems_configuration_get_maximum_processors();
> -  uint32_t cpu;
> -      const Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( cpu );
> -      if ( per_cpu->state != PER_CPU_STATE_BEFORE_INITIALIZATION ) {
> -        _SMP_Send_message( cpu, SMP_MESSAGE_SHUTDOWN );
> diff --git a/cpukit/score/src/threadstartmultitasking.c b/cpukit/score/src/threadstartmultitasking.c
> index a61a51c..b9cdaf8 100644
> --- a/cpukit/score/src/threadstartmultitasking.c
> +++ b/cpukit/score/src/threadstartmultitasking.c
> @@ -26,7 +26,7 @@ void _Thread_Start_multitasking( void )
>    Thread_Control  *heir;
> -  _Per_CPU_Change_state( self_cpu, PER_CPU_STATE_UP );
> +  _Per_CPU_State_change( self_cpu, PER_CPU_STATE_UP );
>     * Threads begin execution in the _Thread_Handler() function.   This
> diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
> index 023b7e9..8422f3a 100644
> --- a/testsuites/smptests/Makefile.am
> +++ b/testsuites/smptests/Makefile.am
> @@ -11,6 +11,8 @@ SUBDIRS += smp07
>  SUBDIRS += smp08
>  SUBDIRS += smp09
>  SUBDIRS += smpatomic01
> +SUBDIRS += smpfatal01
> +SUBDIRS += smpfatal02
>  SUBDIRS += smplock01
>  SUBDIRS += smpmigration01
>  SUBDIRS += smpschedule01
> diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
> index 5c68772..19e32f3 100644
> --- a/testsuites/smptests/configure.ac
> +++ b/testsuites/smptests/configure.ac
> @@ -65,6 +65,8 @@ smp07/Makefile
>  smp08/Makefile
>  smp09/Makefile
>  smpatomic01/Makefile
> +smpfatal01/Makefile
> +smpfatal02/Makefile
>  smplock01/Makefile
>  smpmigration01/Makefile
>  smppsxsignal01/Makefile
> diff --git a/testsuites/smptests/smpfatal01/Makefile.am b/testsuites/smptests/smpfatal01/Makefile.am
> new file mode 100644
> index 0000000..2aaee2b
> --- /dev/null
> +++ b/testsuites/smptests/smpfatal01/Makefile.am
> @@ -0,0 +1,19 @@
> +rtems_tests_PROGRAMS = smpfatal01
> +smpfatal01_SOURCES = init.c
> +dist_rtems_tests_DATA = smpfatal01.scn smpfatal01.doc
> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> +include $(top_srcdir)/../automake/compile.am
> +include $(top_srcdir)/../automake/leaf.am
> +AM_CPPFLAGS += -I$(top_srcdir)/../support/include
> +LINK_OBJS = $(smpfatal01_OBJECTS)
> +LINK_LIBS = $(smpfatal01_LDLIBS)
> +smpfatal01$(EXEEXT): $(smpfatal01_OBJECTS) $(smpfatal01_DEPENDENCIES)
> +       @rm -f smpfatal01$(EXEEXT)
> +       $(make-exe)
> +include $(top_srcdir)/../automake/local.am
> diff --git a/testsuites/smptests/smpfatal01/init.c b/testsuites/smptests/smpfatal01/init.c
> index 0000000..c78b29f
> --- /dev/null
> +++ b/testsuites/smptests/smpfatal01/init.c
> @@ -0,0 +1,130 @@
> + * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#ifdef HAVE_CONFIG_H
> +  #include "config.h"
> +#endif
> +#include <rtems.h>
> +#include <rtems/score/percpu.h>
> +#include <assert.h>
> +#include <stdlib.h>
> +#define MAX_CPUS 32
> +static uint32_t main_cpu;
> +static void Init(rtems_task_argument arg)
> +  assert(0);
> +static void end_of_test(void)
> +  printk( "*** END OF TEST SMPFATAL 1 ***\n" );
> +static void fatal_extension(
> +  rtems_fatal_source source,
> +  bool is_internal,
> +  rtems_fatal_code code
> +  if (source == RTEMS_FATAL_SOURCE_SMP) {
> +    uint32_t self = rtems_smp_get_current_processor();
> +    assert(!is_internal);
> +    assert(code == SMP_FATAL_SHUTDOWN);
> +    if (self == main_cpu) {
> +      uint32_t cpu;
> +      for (cpu = 0; cpu < MAX_CPUS; ++cpu) {
> +        const Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( cpu );
> +        assert(state == PER_CPU_STATE_SHUTDOWN);
> +      end_of_test();
> +static rtems_status_code test_driver_init(
> +  rtems_device_major_number major,
> +  rtems_device_minor_number minor,
> +  void *arg
> +  uint32_t cpu_count = rtems_smp_get_processor_count();
> +  uint32_t cpu;
> +  printk("\n\n*** TEST SMPFATAL 1 ***\n");
> +  assert(rtems_configuration_get_maximum_processors() == MAX_CPUS);
> +  main_cpu = self;
> +    if (cpu == self) {
> +      assert(state == PER_CPU_STATE_INITIAL);
> +    } else if (cpu < cpu_count) {
> +      assert(
> +        state == PER_CPU_STATE_INITIAL
> +          || state == PER_CPU_STATE_READY_TO_START_MULTITASKING
> +    } else {
> +  if (cpu_count > 1) {
> +    uint32_t other = (self + 1) % cpu_count;
> +    Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( other );
> +    per_cpu->state = PER_CPU_STATE_SHUTDOWN;
> +  } else {
> +    end_of_test();
> +    exit(0);
> +  return RTEMS_SUCCESSFUL;
> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_APPLICATION_EXTRA_DRIVERS \
> +  { .initialization_entry = test_driver_init }
> +#define CONFIGURE_INITIAL_EXTENSIONS { .fatal = fatal_extension }
> +#define CONFIGURE_SMP_APPLICATION
> +#define CONFIGURE_SMP_MAXIMUM_PROCESSORS MAX_CPUS
> +#define CONFIGURE_MAXIMUM_TASKS 1
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#include <rtems/confdefs.h>
> diff --git a/testsuites/smptests/smpfatal01/smpfatal01.doc b/testsuites/smptests/smpfatal01/smpfatal01.doc
> index 0000000..c037cfe
> --- /dev/null
> +++ b/testsuites/smptests/smpfatal01/smpfatal01.doc
> @@ -0,0 +1,12 @@
> +This file describes the directives and concepts tested by this test set.
> +test set name: smpfatal01
> +directives:
> +  - _Per_CPU_State_change()
> +concepts:
> +  - Ensure that the system termination in case of shutdown detection at a
> +    secondary processors works during driver initialization.
> diff --git a/testsuites/smptests/smpfatal01/smpfatal01.scn b/testsuites/smptests/smpfatal01/smpfatal01.scn
> index 0000000..0b67121
> --- /dev/null
> +++ b/testsuites/smptests/smpfatal01/smpfatal01.scn
> @@ -0,0 +1,2 @@
> +*** TEST SMPFATAL 1 ***
> +*** END OF TEST SMPFATAL 1 ***
> diff --git a/testsuites/smptests/smpfatal02/Makefile.am b/testsuites/smptests/smpfatal02/Makefile.am
> index 0000000..bbce3b7
> --- /dev/null
> +++ b/testsuites/smptests/smpfatal02/Makefile.am
> @@ -0,0 +1,19 @@
> +rtems_tests_PROGRAMS = smpfatal02
> +smpfatal02_SOURCES = init.c
> +dist_rtems_tests_DATA = smpfatal02.scn smpfatal02.doc
> +LINK_OBJS = $(smpfatal02_OBJECTS)
> +LINK_LIBS = $(smpfatal02_LDLIBS)
> +smpfatal02$(EXEEXT): $(smpfatal02_OBJECTS) $(smpfatal02_DEPENDENCIES)
> +       @rm -f smpfatal02$(EXEEXT)
> +       $(make-exe)
> diff --git a/testsuites/smptests/smpfatal02/init.c b/testsuites/smptests/smpfatal02/init.c
> index 0000000..1e8da26
> --- /dev/null
> +++ b/testsuites/smptests/smpfatal02/init.c
> @@ -0,0 +1,135 @@
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> +#endif
> +#include <rtems.h>
> +  assert(0);
> +  printk( "*** END OF TEST SMPFATAL 2 ***\n" );
> +  bool is_internal,
> +  if (
> +    source == RTEMS_FATAL_SOURCE_APPLICATION
> +      || source == RTEMS_FATAL_SOURCE_SMP
> +      uint32_t cpu;
> +      assert(source == RTEMS_FATAL_SOURCE_APPLICATION);
> +      assert(code == 0xdeadbeef);
> +      end_of_test();
> +    } else {
> +      assert(source == RTEMS_FATAL_SOURCE_SMP);
> +  void *arg
> +  uint32_t cpu;
> +  printk("\n\n*** TEST SMPFATAL 2 ***\n");
> +  main_cpu = self;
> +      assert(
> +    } else {
> +    rtems_fatal(RTEMS_FATAL_SOURCE_APPLICATION, 0xdeadbeef);
> +  } else {
> +    end_of_test();
> +    exit(0);
> diff --git a/testsuites/smptests/smpfatal02/smpfatal02.doc b/testsuites/smptests/smpfatal02/smpfatal02.doc
> index 0000000..9e2e002
> --- /dev/null
> +++ b/testsuites/smptests/smpfatal02/smpfatal02.doc
> @@ -0,0 +1,12 @@
> +test set name: smpfatal02
> +directives:
> +concepts:
> +  - Ensure that the system termination in case of fatal errors during driver
> +    initialization works.
> diff --git a/testsuites/smptests/smpfatal02/smpfatal02.scn b/testsuites/smptests/smpfatal02/smpfatal02.scn
> index 0000000..cde11a0
> --- /dev/null
> +++ b/testsuites/smptests/smpfatal02/smpfatal02.scn
> @@ -0,0 +1,2 @@
> +*** TEST SMPFATAL 2 ***
> +*** END OF TEST SMPFATAL 2 ***
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
