[PATCH] New fstest to check rename POSIX conformance
Fri Feb 21 14:06:45 UTC 2014
On 2014-02-21 14:38, Andre Marques wrote:
> A small issue I have with test_initialize_filesystem() and
> test_shutdown_filesystem() is that I'm calling them from my code as
> test_initialize_filesystem ();
> ... some code ...
> test_shutdown_filesystem();
> which generates
> warning: nested extern declaration of 'test_initialize_filesystem'
> because it is defined both on ./testsuites/fstests/mimfs_support/fs_support.c
> and ./testsuites/fstests/support/fstest_support.h and the first includes the
> former, hence the warning (I believe).
> What would be the best approach to solve this?
Which file do you include before you use test_initialize_filesystem (); ?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
