Patches for classic affinity implementation and test
Fri Feb 21 14:27:24 UTC 2014
On Fri, Feb 21, 2014 at 3:00 AM, Sebastian Huber
> On 2014-02-20 21:07, Jennifer Averett wrote:
>> +#if __RTEMS_HAVE_SYS_CPUSET_H__ && defined( RTEMS_SMP )
>> +const Cpuset_Control *_Cpuset_Handler_default(void);
>> +#else
>> +#define _Cpuset_Handler_default()   do { } while ( 0 )
>> +#endif
> In case the C library doesn't provide an appropriate <sys/cpuset.h> then we
> should provide our own header file.  Maybe we should use a special header
> file that either uses <sys/cpuset.h> directly or alternatively provides the
> missing declarations and functions.
> I don't think it makes sense to use a SMP configuration with this API.
Do you mean UP?
> rtems-devel mailing list
> rtems-devel at rtems.org
