Patches for classic affinity implementation and test
Fri Feb 21 15:20:45 UTC 2014
On 2014-02-21 16:16, Joel Sherrill wrote:
> On Feb 21, 2014 9:04 AM, Sebastian Huber <sebastian.huber at embedded-brains.de>
> wrote:
>  > On 2014-02-21 15:27, Gedare Bloom wrote:
>  > > On Fri, Feb 21, 2014 at 3:00 AM, Sebastian Huber
>  > > <sebastian.huber at embedded-brains.de>  wrote:
>  > >> >On 2014-02-20 21:07, Jennifer Averett wrote:
>  > >>> >>+#if __RTEMS_HAVE_SYS_CPUSET_H__ && defined( RTEMS_SMP )
>  > >>> >>+const Cpuset_Control *_Cpuset_Handler_default(void);
>  > >>> >>+#else
>  > >>> >>+#define _Cpuset_Handler_default()   do { } while ( 0 )
>  > >>> >>+#endif
>  > >> >In case the C library doesn't provide an appropriate <sys/cpuset.h> then we
>  > >> >should provide our own header file.  Maybe we should use a special header
>  > >> >file that either uses <sys/cpuset.h> directly or alternatively provides the
>  > >> >missing declarations and functions.
>  > >> >I don't think it makes sense to use a SMP configuration with this API.
>  > > Do you mean UP?
>  > Oh, I meant:
>  > I don't think it makes sense to use a SMP configuration WITHOUT this API.
> Agreed and it only is there to prevent a tool versioning hiccup.
There are not that many RTEMS SMP users out there.  The RTEMS SMP is work in
progress, so I don't think its too much to ask SMP interested users to use
Newlib 2.1.0.  They need also <stdatomic.h>, the __getreent() stuff and the
pthread cleanup changes.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
