[PATCH v2] New fstest to check rename POSIX conformance
Andre Marques
andre.lousa.marques at gmail.com
Sat Feb 22 21:57:34 UTC 2014
Hello,
This patch is a newer version of the test presented on
http://www.rtems.org/pipermail/rtems-devel/2014-February/005318.html
Unchecked error cases:
- EIO (physical error)
- ENOSPC (no space left in the new filepath)
- EROFS (already covered on testsuites/fstests/fsrofs01)
Untested functionality:
- File system lock during rename() operation
- If after rename() the link count of a file becomes 0 it should be
removed and the space ocupied by the file shall be freed and no longer
accessible (the function statvfs() gives "not implemented" on the imfs
file system, so this is postponed for now)
Any problem with the patch please let me know.
--André Marques
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140222/0cebec8e/attachment.bin>
