[PATCH] sparc: Fix CPU counter support
Mon Feb 24 15:16:26 UTC 2014
On 2014-02-24 15:20, Daniel Hellstrom wrote:
> Sebastian, I think it's a good solution to rely on the GPTIMER[0].timer0 as a
> fallback.
> Looks good to me, and should work on the TSIM/GRSIM and LEON3 hardware.
> Assuming that the frequency has been initialized to 1MHz for secondary GPTIMER
> may be wrong when invoked from a boot loader, however this can be fixed later
> if determined a problem.
Thanks for the quick review.  I checked in a slightly different version that
uses now only the first GPTIMER to determine the frequency:
http://git.rtems.org/rtems/commit/?id=a4bc90af4ee55e72b18de4b64da6338634490760
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
