[PATCH 03/17] bsp/arm: Add CP15 methods
Ralf Kirchner ralf.kirchner at embedded-brains.de
Wed Feb 26 10:51:50 UTC 2014
 c/src/lib/libcpu/arm/shared/include/arm-cp15.h |   99 +++++++++++++++++++++++-
 1 Datei geändert, 98 Zeilen hinzugefügt(+), 1 Zeile entfernt(-)
diff --git a/c/src/lib/libcpu/arm/shared/include/arm-cp15.h b/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
index 43da5a2..dd6bba2 100644
--- a/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
+++ b/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
@@ -572,6 +572,7 @@ static inline void arm_cp15_tlb_lockdown_entry(const void *mva)
+/* Read cache type register CTR */
 static inline uint32_t arm_cp15_get_cache_type(void)
   ARM_SWITCH_REGISTERS;
@@ -587,6 +588,7 @@ static inline uint32_t arm_cp15_get_cache_type(void)
   return val;
+/* Read size of smallest cache line of all instruction/data caches controlled by the processor */
 static inline uint32_t arm_cp15_get_min_cache_line_size(void)
   uint32_t mcls = 0;
@@ -594,8 +596,10 @@ static inline uint32_t arm_cp15_get_min_cache_line_size(void)
   uint32_t format = (ct >> 29) & 0x7U;
   if (format == 0x4) {
+    /* ARMv7 format */
     mcls = (1U << (ct & 0xf)) * 4;
   } else if (format == 0x0) {
+    /* ARMv6 format */
     uint32_t mask = (1U << 12) - 1;
     uint32_t dcls = (ct >> 12) & mask;
     uint32_t icls = ct & mask;
@@ -606,6 +610,44 @@ static inline uint32_t arm_cp15_get_min_cache_line_size(void)
   return mcls;
+/* Read size of smallest data cache lines */
+static inline uint32_t arm_cp15_get_data_cache_line_size(void)
+  uint32_t mcls = 0;
+  uint32_t ct = arm_cp15_get_cache_type();
+  uint32_t format = (ct >> 29) & 0x7U;
+  if (format == 0x4) {
+    mcls = (1U << ((ct & 0xf0000) >> 16)) * 4;
+  } else if (format == 0x0) {
+    uint32_t mask = (1U << 12) - 1;
+    mcls = (ct >> 12) & mask;
+  return mcls;
+/* Read size of smallest instruction cache lines */
+static inline uint32_t arm_cp15_get_instruction_cche_line_size(void)
+    mcls = (1U << (ct & 0x0000f)) * 4;
+    mcls = ct & mask;;
+  return mcls;
 /* CCSIDR, Cache Size ID Register */
 static inline uint32_t arm_cp15_get_cache_size_id(void)
@@ -640,6 +682,11 @@ static inline uint32_t arm_cp15_get_cache_level_id(void)
   return val;
+static inline uint32_t arm_cp15_get_level_of_cache_coherency(const uint32_t clidr)
+  return( (clidr & 0x7000000) >> 23 );
 /* CSSELR, Cache Size Selection Register */
 static inline uint32_t arm_cp15_get_cache_size_selection(void)
@@ -686,6 +733,57 @@ static inline void arm_cp15_cache_invalidate(void)
+/* ICIALLUIS, Instruction Cache Invalidate All to PoU, Inner Shareable */
+static inline void arm_cp15_instruction_cache_inner_shareable_invalidate_all(void)
+  ARM_SWITCH_REGISTERS;
+  uint32_t sbz = 0;
+  __asm__ volatile (
+    ARM_SWITCH_TO_ARM
+    "mcr p15, 0, %[sbz], c7, c1, 0\n"
+    ARM_SWITCH_BACK
+    : ARM_SWITCH_OUTPUT
+    : [sbz] "r" (sbz)
+    : "memory"
+/* BPIALLIS, Branch Predictor Invalidate All, Inner Shareable */
+static inline void arm_cp15_branch_predictor_inner_shareable_invalidate_all(void)
+  uint32_t sbz = 0;
+    ARM_SWITCH_TO_ARM
+    "mcr p15, 0, %[sbz], c7, c1, 6\n"
+    ARM_SWITCH_BACK
+    : [sbz] "r" (sbz)
+    : "memory"
+/* BPIALL, Branch Predictor Invalidate All */
+static inline void arm_cp15_branch_predictor_invalidate_all(void)
+  uint32_t sbz = 0;
+    ARM_SWITCH_TO_ARM
+    "mcr p15, 0, %[sbz], c7, c5, 6\n"
+    ARM_SWITCH_BACK
+    : [sbz] "r" (sbz)
+    : "memory"
 static inline void arm_cp15_instruction_cache_invalidate(void)
@@ -855,7 +953,6 @@ static inline void arm_cp15_data_cache_clean_and_invalidate(void)
     : [sbz] "r" (sbz)
     : "memory"
 static inline void arm_cp15_data_cache_clean_and_invalidate_line(const void *mva)
1.7.10.4
