[PATCH 05/17] bsp/arm: Add arm-errata.h and arm-release-id.h
Ralf Kirchner ralf.kirchner at embedded-brains.de
Wed Feb 26 10:51:52 UTC 2014
 c/src/lib/libbsp/arm/shared/include/arm-errata.h   |  127 ++++++++++++++++
 .../lib/libbsp/arm/shared/include/arm-release-id.h |  152 ++++++++++++++++++++
 2 Dateien geändert, 279 Zeilen hinzugefügt(+)
 create mode 100644 c/src/lib/libbsp/arm/shared/include/arm-errata.h
 create mode 100644 c/src/lib/libbsp/arm/shared/include/arm-release-id.h
diff --git a/c/src/lib/libbsp/arm/shared/include/arm-errata.h b/c/src/lib/libbsp/arm/shared/include/arm-errata.h
new file mode 100644
index 0000000..6f26c1f
--- /dev/null
+++ b/c/src/lib/libbsp/arm/shared/include/arm-errata.h
@@ -0,0 +1,127 @@
+ * @file arm-errata.h
+ * @ingroup arm_shared
+ * @brief Create #defines which state which erratas shall get applied
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifndef ARM_ERRATA_H_
+#define ARM_ERRATA_H_
+#include <bsp/arm-release-id.h>
+#include <libcpu/arm-cp15.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#if defined( __ARM_ARCH_7A__ )
+static arm_release_id arm_errata_get_processor_release(
+  void
+  const uint32_t MIDR          = arm_cp15_get_id_code();
+  const uint8_t  REVISION      = (MIDR & 0xF00000U) >> 20;
+  const uint8_t  PATCH_LEVEL   = (MIDR & 0xFU);
+  return ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL(
+    REVISION,
+    PATCH_LEVEL
+#endif /* #if defined( __ARM_ARCH_7A__ ) */
+static bool arm_errata_is_applicable_processor_errata_764369(
+  void
+  const arm_release_id RELEASE       = arm_errata_get_processor_release();
+  bool                 is_applicable = false;
+  /* Errata information for Cortex-A9 processors.
+   * Information taken from ARMs
+   * "Cortex-A series processors
+   * - Cortex-A9
+   * - Software Developers Errata Notice
+   * - Revision r4 revisions
+   * - ARM Cortex-A9 processors r4 release Software Developers Errata Notice"
+   * The corresponding link is: http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0360f/BABJFIBA.html
+   * Please see this document for more information on these erratas */
+  switch( RELEASE ) {
+    case ARM_RELEASE_ID_R4_P1:
+    case ARM_RELEASE_ID_R4_P4:
+    case ARM_RELEASE_ID_R3_P0:
+    case ARM_RELEASE_ID_R2_P10:
+    case ARM_RELEASE_ID_R2_P8:
+    case ARM_RELEASE_ID_R2_P6:
+    case ARM_RELEASE_ID_R2_P4:
+    case ARM_RELEASE_ID_R2_P3:
+    case ARM_RELEASE_ID_R2_P2:
+    case ARM_RELEASE_ID_R2_P0:
+      is_applicable = true;
+    default:
+      is_applicable = false;
+    break;
+  return is_applicable;
+static bool arm_errata_is_applicable_processor_errata_775420(
+  void
+  * - Cortex-A9
+    default:
+    break;
+#ifdef __cplusplus
+#endif /* ARM_ERRATA_H_ */
\ No newline at end of file
diff --git a/c/src/lib/libbsp/arm/shared/include/arm-release-id.h b/c/src/lib/libbsp/arm/shared/include/arm-release-id.h
index 0000000..e06be00
--- /dev/null
+++ b/c/src/lib/libbsp/arm/shared/include/arm-release-id.h
@@ -0,0 +1,152 @@
+ * @file arm-release-id.h
+ * @brief Create #defines for release IDs
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifndef ARM_RELEASE_ID_H_
+#define ARM_RELEASE_ID_H_
+#ifdef __cplusplus
+extern "C" {
+/* #define the IDs which identify a release. This must be done
+ * prior to #including bsp.h */
+#define ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( release_no, patch_level ) \
+  ( ( ( ( release_no ) & 0xFFFF ) << 16 ) + ( ( patch_level ) & 0xFFFF ) )
+typedef enum {
+  ARM_RELEASE_ID_R0_P0  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 0 ),
+  ARM_RELEASE_ID_R0_P1  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 1 ),
+  ARM_RELEASE_ID_R0_P2  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 2 ),
+  ARM_RELEASE_ID_R0_P3  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 3 ),
+  ARM_RELEASE_ID_R0_P4  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 4 ),
+  ARM_RELEASE_ID_R0_P5  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 5 ),
+  ARM_RELEASE_ID_R0_P6  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 6 ),
+  ARM_RELEASE_ID_R0_P7  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 7 ),
+  ARM_RELEASE_ID_R0_P8  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 8 ),
+  ARM_RELEASE_ID_R0_P9  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 9 ),
+  ARM_RELEASE_ID_R0_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 10 ),
+  ARM_RELEASE_ID_R1_P0  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 0 ),
+  ARM_RELEASE_ID_R1_P1  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 1 ),
+  ARM_RELEASE_ID_R1_P2  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 2 ),
+  ARM_RELEASE_ID_R1_P3  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 3 ),
+  ARM_RELEASE_ID_R1_P4  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 4 ),
+  ARM_RELEASE_ID_R1_P5  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 5 ),
+  ARM_RELEASE_ID_R1_P6  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 6 ),
+  ARM_RELEASE_ID_R1_P7  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 7 ),
+  ARM_RELEASE_ID_R1_P8  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 8 ),
+  ARM_RELEASE_ID_R1_P9  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 9 ),
+  ARM_RELEASE_ID_R1_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 10 ),
+  ARM_RELEASE_ID_R2_P0  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 0 ),
+  ARM_RELEASE_ID_R2_P1  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 1 ),
+  ARM_RELEASE_ID_R2_P2  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 2 ),
+  ARM_RELEASE_ID_R2_P3  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 3 ),
+  ARM_RELEASE_ID_R2_P4  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 4 ),
+  ARM_RELEASE_ID_R2_P5  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 5 ),
+  ARM_RELEASE_ID_R2_P6  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 6 ),
+  ARM_RELEASE_ID_R2_P7  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 7 ),
+  ARM_RELEASE_ID_R2_P8  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 8 ),
+  ARM_RELEASE_ID_R2_P9  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 9 ),
+  ARM_RELEASE_ID_R2_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 10 ),
+  ARM_RELEASE_ID_R3_P0  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 0 ),
+  ARM_RELEASE_ID_R3_P1  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 1 ),
+  ARM_RELEASE_ID_R3_P2  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 2 ),
+  ARM_RELEASE_ID_R3_P3  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 3 ),
+  ARM_RELEASE_ID_R3_P4  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 4 ),
+  ARM_RELEASE_ID_R3_P5  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 5 ),
+  ARM_RELEASE_ID_R3_P6  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 6 ),
+  ARM_RELEASE_ID_R3_P7  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 7 ),
+  ARM_RELEASE_ID_R3_P8  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 8 ),
+  ARM_RELEASE_ID_R3_P9  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 9 ),
+  ARM_RELEASE_ID_R3_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 10 ),
+  ARM_RELEASE_ID_R4_P0  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 0 ),
+  ARM_RELEASE_ID_R4_P1  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 1 ),
+  ARM_RELEASE_ID_R4_P2  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 2 ),
+  ARM_RELEASE_ID_R4_P3  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 3 ),
+  ARM_RELEASE_ID_R4_P4  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 4 ),
+  ARM_RELEASE_ID_R4_P5  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 5 ),
+  ARM_RELEASE_ID_R4_P6  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 6 ),
+  ARM_RELEASE_ID_R4_P7  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 7 ),
+  ARM_RELEASE_ID_R4_P8  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 8 ),
+  ARM_RELEASE_ID_R4_P9  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 9 ),
+  ARM_RELEASE_ID_R4_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 10 ),
+  ARM_RELEASE_ID_R5_P0  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 0 ),
+  ARM_RELEASE_ID_R5_P1  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 1 ),
+  ARM_RELEASE_ID_R5_P2  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 2 ),
+  ARM_RELEASE_ID_R5_P3  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 3 ),
+  ARM_RELEASE_ID_R5_P4  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 4 ),
+  ARM_RELEASE_ID_R5_P5  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 5 ),
+  ARM_RELEASE_ID_R5_P6  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 6 ),
+  ARM_RELEASE_ID_R5_P7  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 7 ),
+  ARM_RELEASE_ID_R5_P8  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 8 ),
+  ARM_RELEASE_ID_R5_P9  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 9 ),
+  ARM_RELEASE_ID_R5_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 10 ),
+  ARM_RELEASE_ID_R6_P0  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 0 ),
+  ARM_RELEASE_ID_R6_P1  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 1 ),
+  ARM_RELEASE_ID_R6_P2  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 2 ),
+  ARM_RELEASE_ID_R6_P3  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 3 ),
+  ARM_RELEASE_ID_R6_P4  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 4 ),
+  ARM_RELEASE_ID_R6_P5  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 5 ),
+  ARM_RELEASE_ID_R6_P6  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 6 ),
+  ARM_RELEASE_ID_R6_P7  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 7 ),
+  ARM_RELEASE_ID_R6_P8  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 8 ),
+  ARM_RELEASE_ID_R6_P9  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 9 ),
+  ARM_RELEASE_ID_R6_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 10 ),
+  ARM_RELEASE_ID_R7_P0  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 0 ),
+  ARM_RELEASE_ID_R7_P1  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 1 ),
+  ARM_RELEASE_ID_R7_P2  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 2 ),
+  ARM_RELEASE_ID_R7_P3  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 3 ),
+  ARM_RELEASE_ID_R7_P4  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 4 ),
+  ARM_RELEASE_ID_R7_P5  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 5 ),
+  ARM_RELEASE_ID_R7_P6  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 6 ),
+  ARM_RELEASE_ID_R7_P7  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 7 ),
+  ARM_RELEASE_ID_R7_P8  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 8 ),
+  ARM_RELEASE_ID_R7_P9  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 9 ),
+  ARM_RELEASE_ID_R7_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 10 ),
+  ARM_RELEASE_ID_R8_P0  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 0 ),
+  ARM_RELEASE_ID_R8_P1  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 1 ),
+  ARM_RELEASE_ID_R8_P2  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 2 ),
+  ARM_RELEASE_ID_R8_P3  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 3 ),
+  ARM_RELEASE_ID_R8_P4  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 4 ),
+  ARM_RELEASE_ID_R8_P5  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 5 ),
+  ARM_RELEASE_ID_R8_P6  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 6 ),
+  ARM_RELEASE_ID_R8_P7  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 7 ),
+  ARM_RELEASE_ID_R8_P8  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 8 ),
+  ARM_RELEASE_ID_R8_P9  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 9 ),
+  ARM_RELEASE_ID_R8_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 10 ),
+  ARM_RELEASE_ID_R9_P0  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 0 ),
+  ARM_RELEASE_ID_R9_P1  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 1 ),
+  ARM_RELEASE_ID_R9_P2  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 2 ),
+  ARM_RELEASE_ID_R9_P3  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 3 ),
+  ARM_RELEASE_ID_R9_P4  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 4 ),
+  ARM_RELEASE_ID_R9_P5  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 5 ),
+  ARM_RELEASE_ID_R9_P6  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 6 ),
+  ARM_RELEASE_ID_R9_P7  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 7 ),
+  ARM_RELEASE_ID_R9_P8  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 8 ),
+  ARM_RELEASE_ID_R9_P9  = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 9 ),
+  ARM_RELEASE_ID_R9_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 10 )
+} arm_release_id;
+#ifdef __cplusplus
+#endif /* ARM_RELEASE_ID_H_ */
1.7.10.4
