[PATCH 16/17] bsp/altera-cyclone-v: Made hwlib compile clean
Ralf Kirchner ralf.kirchner at embedded-brains.de
Wed Feb 26 10:52:03 UTC 2014
Made Alteras hwlib compile clean within the RTEMS build system
 c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am  |    1 +
 .../altera-cyclone-v/hwlib/include/socal/socal.h   |    4 +-
 .../hwlib/src/hwmgr/alt_clock_manager.c            |  282 +-------------------
 3 Dateien geändert, 6 Zeilen hinzugefügt(+), 281 Zeilen entfernt(-)
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am b/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
index e552f23..6b1749b 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
@@ -98,6 +98,7 @@ libbsp_a_LIBADD =
 # for the Altera hwlib
 libbsp_a_CPPFLAGS += -I ${srcdir}/hwlib/include
 libbsp_a_CPPFLAGS += -std=gnu99
+CFLAGS += -Wno-missing-prototypes
 # hwlib from Altera
 libbsp_a_SOURCES += hwlib/src/hwmgr/alt_16550_uart.c
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/socal.h b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/socal.h
index d1a876c..b0375e5 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/socal.h
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/socal.h
@@ -33,6 +33,8 @@
 #ifndef __ALTERA_SOCAL_H__
 #define __ALTERA_SOCAL_H__
+#include <rtems/score/basedefs.h>
 #ifdef __cplusplus
 extern "C"
@@ -344,7 +346,7 @@ typedef char alt_cat_compile_assert_text(assertion_at_##file##_line_, line)[2*!!
  *  \param a - Structure to be evaluated
  *  \param b - Reference size
-#define alt_check_struct_size(a, b) alt_form_compile_assert_line((sizeof(a) <= sizeof(b)),__FILE__,__LINE__)
+#define alt_check_struct_size(a, b) RTEMS_STATIC_ASSERT((sizeof(a) <= sizeof(b)), Invalid_stuct_size)
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/src/hwmgr/alt_clock_manager.c b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/src/hwmgr/alt_clock_manager.c
index ce01ff7..c731ad3 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/src/hwmgr/alt_clock_manager.c
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/src/hwmgr/alt_clock_manager.c
@@ -225,7 +225,7 @@ static void inline alt_clk_mgr_wait(void* reg, uint32_t cnt)
         // to zero and allow for writing a new divisor ratio to it
-ALT_STATUS_CODE alt_clk_plls_settle_wait(void)
+static ALT_STATUS_CODE alt_clk_plls_settle_wait(void)
     int32_t     i = ALT_BYPASS_TIMEOUT_CNT;
     bool        nofini;
@@ -734,7 +734,7 @@ ALT_STATUS_CODE alt_clk_pll_is_bypassed(ALT_CLK_t pll)
 /* alt_clk_pll_source_get() returns the current input of the specified PLL.             */
-ALT_CLK_t alt_clk_pll_source_get(ALT_CLK_t pll)
+static ALT_CLK_t alt_clk_pll_source_get(ALT_CLK_t pll)
     ALT_CLK_t       ret = ALT_CLK_UNKNOWN;
     uint32_t       temp;
@@ -4928,281 +4928,3 @@ ALT_STATUS_CODE alt_clk_group_cfg_raw_set(const ALT_CLK_GROUP_RAW_CFG_t* clk_gro
     if (byp)  { ret = alt_clk_pll_bypass_disable(pll); }
     return ret;
-/* alt_clk_id_to_string() converts a clock ID to a text string.                         */
-ALT_STATUS_CODE alt_clk_id_to_string(ALT_CLK_t clk_id, char *s, size_t num)
-    ALT_STATUS_CODE ret = ALT_E_ERROR;
-    uint32_t        num2;
-    char            *t = NULL;
-    if (s != NULL)
-        s[0] = '\0';
-        switch (clk_id)
-        case    ALT_CLK_IN_PIN_OSC1:
-            t = "ALT_CLK_IN_PIN_OSC1";
-            break;
-        case    ALT_CLK_IN_PIN_OSC2:
-            t = "ALT_CLK_IN_PIN_OSC2";
-            break;
-            /* FPGA Clock Sources External to HPS */
-        case    ALT_CLK_F2H_PERIPH_REF:
-            t = "ALT_CLK_F2H_PERIPH_REF"; \
-            break;
-        case    ALT_CLK_F2H_SDRAM_REF:
-            t = "ALT_CLK_F2H_SDRAM_REF";
-            break;
-            /* Other Clock Sources External to HPS */
-        case    ALT_CLK_IN_PIN_JTAG:
-            t = "ALT_CLK_IN_PIN_JTAG";
-            break;
-        case    ALT_CLK_IN_PIN_ULPI0:
-            t = "ALT_CLK_IN_PIN_ULPI0";
-            break;
-        case    ALT_CLK_IN_PIN_ULPI1:
-            t = "ALT_CLK_IN_PIN_ULPI1";
-            break;
-        case    ALT_CLK_IN_PIN_EMAC0_RX:
-            t = "ALT_CLK_IN_PIN_EMAC0_RX";
-            break;
-        case    ALT_CLK_IN_PIN_EMAC1_RX:
-            t = "ALT_CLK_IN_PIN_EMAC1_RX";
-            break;
-            /* PLLs */
-        case    ALT_CLK_MAIN_PLL:
-            t = "ALT_CLK_MAIN_PLL";
-            break;
-        case    ALT_CLK_PERIPHERAL_PLL:
-            t = "ALT_CLK_PERIPHERAL_PLL";
-            break;
-        case    ALT_CLK_SDRAM_PLL:
-            t = "ALT_CLK_SDRAM_PLL";
-            break;
-            /* OSC1 Clock Group - The OSC1 clock group contains those clocks which are derived
-             * directly from the osc_clk_1_HPS pin */
-        case    ALT_CLK_OSC1:
-            t = "ALT_CLK_OSC1";
-            break;
-            /* Main Clock Group - The following clocks are derived from the Main PLL. */
-        case    ALT_CLK_MAIN_PLL_C0:
-            t = "ALT_CLK_MAIN_PLL_C0";
-            break;
-        case    ALT_CLK_MAIN_PLL_C1:
-            t = "ALT_CLK_MAIN_PLL_C1";
-            break;
-        case    ALT_CLK_MAIN_PLL_C2:
-            t = "ALT_CLK_MAIN_PLL_C2";
-            break;
-        case    ALT_CLK_MAIN_PLL_C3:
-            t = "ALT_CLK_MAIN_PLL_C3";
-            break;
-        case    ALT_CLK_MAIN_PLL_C4:
-            t = "ALT_CLK_MAIN_PLL_C4";
-            break;
-        case    ALT_CLK_MAIN_PLL_C5:
-            t = "ALT_CLK_MAIN_PLL_C5";
-            break;
-        case    ALT_CLK_MPU:
-            t = "ALT_CLK_MPU";
-            break;
-        case    ALT_CLK_MPU_L2_RAM:
-            t = "ALT_CLK_MPU_L2_RAM";
-            break;
-        case    ALT_CLK_MPU_PERIPH:
-            t = "ALT_CLK_MPU_PERIPH";
-            break;
-        case    ALT_CLK_L3_MAIN:
-            t = "ALT_CLK_L3_MAIN";
-            break;
-        case    ALT_CLK_L3_MP:
-            t = "ALT_CLK_L3_MP";
-            break;
-         case   ALT_CLK_L3_SP:
-            t = "ALT_CLK_L3_SP";
-            break;
-        case    ALT_CLK_L4_MAIN:
-            t = "ALT_CLK_L4_MAIN";
-            break;
-        case    ALT_CLK_L4_MP:
-            t = "ALT_CLK_L4_MP";
-            break;
-        case    ALT_CLK_L4_SP:
-            t = "ALT_CLK_L4_SP";
-            break;
-        case    ALT_CLK_DBG_BASE:
-            t = "ALT_CLK_DBG_BASE";
-            break;
-        case    ALT_CLK_DBG_AT:
-            t = "ALT_CLK_DBG_AT\0";
-            break;
-        case    ALT_CLK_DBG_TRACE:
-            t = "ALT_CLK_DBG_TRACE";
-            break;
-        case    ALT_CLK_DBG_TIMER:
-            t = "ALT_CLK_DBG_TIMER";
-            break;
-        case    ALT_CLK_DBG:
-            t = "ALT_CLK_DBG";
-            break;
-        case    ALT_CLK_MAIN_QSPI:
-            t = "ALT_CLK_MAIN_QSPI";
-            break;
-        case    ALT_CLK_MAIN_NAND_SDMMC:
-            t = "ALT_CLK_MAIN_NAND_SDMMC";
-            break;
-        case    ALT_CLK_CFG:
-            t = "ALT_CLK_CFG";
-            break;
-        case    ALT_CLK_H2F_USER0:
-            t = "ALT_CLK_H2F_USER0";
-            break;
-            /* Peripherals Clock Group - The following clocks are derived from the Peripheral PLL */
-        case    ALT_CLK_PERIPHERAL_PLL_C0:
-            t = "ALT_CLK_PERIPHERAL_PLL_C0";
-            break;
-        case    ALT_CLK_PERIPHERAL_PLL_C1:
-            t = "ALT_CLK_PERIPHERAL_PLL_C1";
-            break;
-        case    ALT_CLK_PERIPHERAL_PLL_C2:
-            t = "ALT_CLK_PERIPHERAL_PLL_C2";
-            break;
-        case    ALT_CLK_PERIPHERAL_PLL_C3:
-            t = "ALT_CLK_PERIPHERAL_PLL_C3";
-            break;
-        case    ALT_CLK_PERIPHERAL_PLL_C4:
-            t = "ALT_CLK_PERIPHERAL_PLL_C4";
-            break;
-        case    ALT_CLK_PERIPHERAL_PLL_C5:
-            t = "ALT_CLK_PERIPHERAL_PLL_C5";
-            break;
-        case    ALT_CLK_USB_MP:
-            t = "ALT_CLK_USB_MP";
-            break;
-        case    ALT_CLK_SPI_M:
-            t = "ALT_CLK_SPI_M";
-            break;
-        case    ALT_CLK_QSPI:
-            t = "ALT_CLK_QSPI";
-            break;
-        case    ALT_CLK_NAND_X:
-            t = "ALT_CLK_NAND_X";
-            break;
-        case    ALT_CLK_NAND:
-            t = "ALT_CLK_NAND";
-            break;
-        case    ALT_CLK_SDMMC:
-            t = "ALT_CLK_SDMMC";
-            break;
-        case    ALT_CLK_EMAC0:
-            t = "ALT_CLK_EMAC0";
-            break;
-        case    ALT_CLK_EMAC1:
-            t = "ALT_CLK_EMAC1";
-            break;
-        case    ALT_CLK_CAN0:
-            t = "ALT_CLK_CAN0";
-            break;
-        case    ALT_CLK_CAN1:
-            t = "ALT_CLK_CAN1";
-            break;
-        case    ALT_CLK_GPIO_DB:
-            t = "ALT_CLK_GPIO_DB";
-            break;
-        case    ALT_CLK_H2F_USER1:
-            t = "ALT_CLK_H2F_USER1";
-            break;
-            /* SDRAM Clock Group - The following clocks are derived from the SDRAM PLL */
-        case    ALT_CLK_SDRAM_PLL_C0:
-            t = "ALT_CLK_SDRAM_PLL_C0";
-            break;
-        case    ALT_CLK_SDRAM_PLL_C1:
-            t = "ALT_CLK_SDRAM_PLL_C1";
-            break;
-        case    ALT_CLK_SDRAM_PLL_C2:
-            t = "ALT_CLK_SDRAM_PLL_C2";
-            break;
-        case    ALT_CLK_SDRAM_PLL_C3:
-            t = "ALT_CLK_SDRAM_PLL_C3";
-            break;
-        case    ALT_CLK_SDRAM_PLL_C4:
-            t = "ALT_CLK_SDRAM_PLL_C4";
-            break;
-        case    ALT_CLK_SDRAM_PLL_C5:
-            t = "ALT_CLK_SDRAM_PLL_C5";
-            break;
-        case    ALT_CLK_DDR_DQS:
-            t = "ALT_CLK_DDR_DQS";
-            break;
-        case    ALT_CLK_DDR_2X_DQS:
-            t = "ALT_CLK_DDR_2X_DQS";
-            break;
-        case    ALT_CLK_DDR_DQ:
-            t = "ALT_CLK_DDR_DQ";
-            break;
-        case    ALT_CLK_H2F_USER2:
-            t = "ALT_CLK_H2F_USER2";
-            break;
-            /* Clock Output Pins */
-        case    ALT_CLK_OUT_PIN_EMAC0_TX:
-            t = "ALT_CLK_OUT_PIN_EMAC0_TX";
-            break;
-        case    ALT_CLK_OUT_PIN_EMAC1_TX:
-            t = "ALT_CLK_OUT_PIN_EMAC1_TX";
-            break;
-        case    ALT_CLK_OUT_PIN_SDMMC:
-            t = "ALT_CLK_OUT_PIN_SDMMC";
-            break;
-        case    ALT_CLK_OUT_PIN_I2C0_SCL:
-            t = "ALT_CLK_OUT_PIN_I2C0_SCL";
-            break;
-        case    ALT_CLK_OUT_PIN_I2C1_SCL:
-            t = "ALT_CLK_OUT_PIN_I2C1_SCL";
-            break;
-        case    ALT_CLK_OUT_PIN_I2C2_SCL:
-            t = "ALT_CLK_OUT_PIN_I2C2_SCL";
-            break;
-        case    ALT_CLK_OUT_PIN_I2C3_SCL:
-            t = "ALT_CLK_OUT_PIN_I2C3_SCL";
-            break;
-        case    ALT_CLK_OUT_PIN_SPIM0:
-            t = "ALT_CLK_OUT_PIN_SPIM0";
-            break;
-        case    ALT_CLK_OUT_PIN_SPIM1:
-            t = "ALT_CLK_OUT_PIN_SPIM1";
-            break;
-        case    ALT_CLK_OUT_PIN_QSPI:
-            t = "ALT_CLK_OUT_PIN_QSPI";
-            break;
-        case    ALT_CLK_UNKNOWN:
-            t = "ALT_CLK_UNKNOWN";
-            break;
-            // do *not* put a 'default' statement here. Then the compiler will throw
-            // an error if another clock id enum is added if the corresponding
-            // string is not added to this function.
-        if (t != NULL) {
-            num2 = strlen(t) + 1;
-            if (num2 < num) { num = num2; }
-            strncpy(s, t, num);
-            if (s[0] != '\0') { ret = ALT_E_SUCCESS; }
-    return ret;
1.7.10.4
