[PATCH 7/8] bsp/leon3: Add L2 cache support
Wed Feb 26 15:52:48 UTC 2014
 c/src/lib/libbsp/sparc/leon3/include/cache_.h |   81 +++++++++++++++++++++++++
 1 files changed, 81 insertions(+), 0 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/include/cache_.h b/c/src/lib/libbsp/sparc/leon3/include/cache_.h
index eafbb48..32fae4d 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/cache_.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/cache_.h
@@ -15,14 +15,90 @@
 #ifndef LEON3_CACHE_H
 #define LEON3_CACHE_H
+#include <amba.h>
 #ifdef __cplusplus
 extern "C" {
 #endif
 #define CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS
+#define CPU_CACHE_SUPPORT_PROVIDES_CACHE_SIZE_FUNCTIONS
 #define CPU_INSTRUCTION_CACHE_ALIGNMENT 64
+#define CPU_DATA_CACHE_ALIGNMENT 64
+#define L1_CACHE_SIZE 16384
+static inline volatile struct l2c_regs *get_l2c_regs(void)
+  volatile struct l2c_regs *l2c = NULL;
+  struct ambapp_dev *adev;
+  adev = (void *) ambapp_for_each(
+    &ambapp_plb,
+    OPTIONS_ALL | OPTIONS_AHB_SLVS,
+    VENDOR_GAISLER,
+    GAISLER_L2CACHE,
+    ambapp_find_by_idx,
+    NULL
+  if (adev != NULL) {
+    l2c = (volatile struct l2c_regs *) DEV_TO_AHB(adev)->start[1];
+  return l2c;
+static inline size_t get_l2_cache_size(void)
+  size_t size = 0;
+  volatile struct l2c_regs *l2c = get_l2c_regs();
+  if (l2c != NULL) {
+    unsigned status = l2c->status;
+    unsigned ways = (status & 0x3) + 1;
+    unsigned set_size = ((status & 0x7ff) >> 2) * 1024;
+    size = ways * set_size;
+  return size;
+static inline size_t get_max_size(size_t a, size_t b)
+  return a < b ? b : a;
+static inline size_t get_cache_size(uint32_t level)
+  size_t size;
+  switch (level) {
+    case 0:
+      size = get_max_size(L1_CACHE_SIZE, get_l2_cache_size());
+      break;
+    case 1:
+      size = L1_CACHE_SIZE;
+      break;
+    case 2:
+      size = get_l2_cache_size();
+      break;
+    default:
+      size = 0;
+      break;
+  return size;
+static inline size_t _CPU_cache_get_data_cache_size(uint32_t level)
+  return get_cache_size(level);
 static inline void _CPU_cache_flush_data_range(
   const void *d_addr,
   size_t n_bytes
@@ -92,6 +168,11 @@ static inline void _CPU_cache_disable_data(void)
   /* TODO */
+static inline size_t _CPU_cache_get_instruction_cache_size( uint32_t level )
 static inline void _CPU_cache_enable_instruction(void)
   /* TODO */
1.7.7
