[PATCH 01/17] bsp/arm: Invalidate SCU
Wed Feb 26 19:06:47 UTC 2014
On Wed, Feb 26, 2014 at 2:01 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Feb 26, 2014 at 5:51 AM, Ralf Kirchner
> <ralf.kirchner at embedded-brains.de> wrote:
>>  c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h  |   12 ++++++++++++
>>  c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h |   10 ++++++++++
>>  2 Dateien geändert, 22 Zeilen hinzugefügt(+)
>> diff --git a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h
>> index 0910e4c..28640d2 100644
>> --- a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h
>> +++ b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h
>> @@ -46,6 +46,18 @@ typedef struct {
>>  #define A9MPCORE_SCU_CFG_TAG_RAM_SIZE_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
>>    uint32_t pwrst;
>>    uint32_t invss;
>> +#define A9MPCORE_SCU_INVSS_CPU0(ways) BSP_FLD32(val, 0, 3)
>> +#define A9MPCORE_SCU_INVSS_CPU0_GET(reg) /* Write only register */
>> +#define A9MPCORE_SCU_INVSS_CPU0_SET(reg, val) BSP_FLD32SET(reg, val, 0, 3)
>> +#define A9MPCORE_SCU_INVSS_CPU1(ways) BSP_FLD32(val, 4, 7)
>> +#define A9MPCORE_SCU_INVSS_CPU1_GET(reg) /* Write only register */
>> +#define A9MPCORE_SCU_INVSS_CPU1_SET(reg, val) BSP_FLD32SET(reg, val, 4, 7)
>> +#define A9MPCORE_SCU_INVSS_CPU2(ways) BSP_FLD32(val, 8, 11)
>> +#define A9MPCORE_SCU_INVSS_CPU2_GET(reg) /* Write only register */
>> +#define A9MPCORE_SCU_INVSS_CPU2_SET(reg, val) BSP_FLD32SET(reg, val, 8, 11)
>> +#define A9MPCORE_SCU_INVSS_CPU3(ways) BSP_FLD32(val, 12, 15)
>> +#define A9MPCORE_SCU_INVSS_CPU3_GET(reg) /* Write only register */
>> +#define A9MPCORE_SCU_INVSS_CPU3_SET(reg, val) BSP_FLD32SET(reg, val, 12, 15)
>>    uint32_t reserved_10[12];
>>    uint32_t fltstart;
>>    uint32_t fltend;
>> diff --git a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
>> index dd1b7c1..ad4cf42 100644
>> --- a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
>> +++ b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
>> @@ -70,6 +70,13 @@ BSP_START_TEXT_SECTION static inline arm_a9mpcore_start_set_vector_base(void)
>> +BSP_START_TEXT_SECTION static inline arm_a9mpcore_start_scu_invalidate(const uint32_t cpu_id, const uint32_t ways)
>> +  volatile a9mpcore_scu *scu = (volatile a9mpcore_scu *) BSP_ARM_A9MPCORE_SCU_BASE;
>> +  scu->invss = ( ( ways & 0xF ) << ( ( cpu_id & 0x3 ) * 4 ) );
> why masking ways and cpu_id? can ways ever be more than 15? if > 3
> cpus will this work right?
I see now from infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0360f/BABJFIBA.html
there are 4 ways and it is a bitset, and up to 4 cpus.
>>  BSP_START_TEXT_SECTION static inline arm_a9mpcore_start_hook_0(void)
>>  #ifdef RTEMS_SMP
>> @@ -86,6 +93,9 @@ BSP_START_TEXT_SECTION static inline arm_a9mpcore_start_hook_0(void)
>>    arm_cp15_set_auxiliary_control(actlr);
>>    cpu_id = arm_cortex_a9_get_multiprocessor_cpu_id();
>> +  arm_a9mpcore_start_scu_invalidate(cpu_id, 0xF);
>>    if (cpu_id != 0) {
>>      arm_a9mpcore_start_set_vector_base();
>> 1.7.10.4
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
