pthread get attribute
Thu Feb 27 16:56:45 UTC 2014
Ahh, ok.
On Thu, Feb 27, 2014 at 10:53 AM, Jennifer Averett
<Jennifer.Averett at oarcorp.com> wrote:
> I dug into this one a little more and on that path the object isn't
> found so there is no reason to call put.
>> -----Original Message-----
>> From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On
>> Behalf Of Gedare Bloom
>> Sent: Thursday, February 27, 2014 9:18 AM
>> To: Jennifer Averett
>> Cc: rtems-devel at rtems.org
>> Subject: Re: pthread get attribute
>> In case of an error ESRCH, shouldn't there be an _Objects_Put() call before
>> returning?
>> On Thu, Feb 27, 2014 at 8:30 AM, Jennifer Averett
>> > Attached is the modified pthread get attribute patch and its
>> > corresponding test.
>> > Jennifer Averett
>> > On-Line Applications Research
>> > _______________________________________________
>> > rtems-devel mailing list
>> > http://www.rtems.org/mailman/listinfo/rtems-devel
