RTEMS 4.11: Tool Chain
Ralf Corsepius
ralf.corsepius at rtems.org
Wed Feb 5 09:17:43 UTC 2014
On 02/05/2014 09:01 AM, Sebastian Huber wrote:
> On 2014-02-04 18:50, Ralf Corsepius wrote:
>> On 02/04/2014 04:13 PM, Sebastian Huber wrote:
>>> Hello,
>>> we have to define the tool chain versions intended for RTEMS 4.11.
>>> For Binutils I would like to use release 2.24 with the attached patch.
>>> For GCC we should use a recent 4.8 branch snapshot (e.g.
>>> ftp://ftp.gwdg.de/pub/misc/gcc/snapshots/4.8-20140130/gcc-4.8-20140130.tar.bz2)
>>> and use GCC 4.8.3 for the release. This gives us also some time to test
>>> the RTEMS 4.11 branch, which we should create soon.
>>> In the GCC 4.8.2 release there are several SPARC specific patches not
>>> included which are part of the GCC 4.8 branch. We should submit all
>>> outstanding GCC patches upstream before the GCC 4.8.3 release.
>>> This GCC patch change is still open:
>>> http://www.rtems.org/pipermail/rtems-devel/2013-April/002868.html
>>> See also:
>>> http://gcc.gnu.org/bugzilla/show_bug.cgi?id=47111
>> Well, IMO, this is a general rtems-independent bug in the mips port.
>> When trying to have it fixed in GCC, some years ago, the mips maintainers
>> refused to apply it.
>> So, one may undef it for rtems as a work-around, but this is just
>> playing with
>> symptoms and with a cure to the cause.
> Ok, but we have now this workaround in upstream GCC, so there is no need
> to keep the patch.
As I said before, this work-around actually is wrong.
It's a new bug to pamper an old bug.
>>> This is also an open issue:
>>> http://www.rtems.org/pipermail/rtems-devel/2013-April/002830.html
>> Right, these patches should be upstreamed.
> We should first determine why we need these patches.
> The default seems to be:
> gcc/defaults.h:#ifndef WCHAR_TYPE_SIZE
> gcc/defaults.h:#define WCHAR_TYPE_SIZE INT_TYPE_SIZE
> gcc/defaults.h:#define WCHAR_TYPE "int"
> On m32c we have:
> gcc/config/m32c/m32c.h:#undef WCHAR_TYPE
> gcc/config/m32c/m32c.h:#define WCHAR_TYPE "long int"
> gcc/config/m32c/m32c.h:#undef WCHAR_TYPE_SIZE
> gcc/config/m32c/m32c.h:#define WCHAR_TYPE_SIZE 32
> On m68k we have:
> gcc/config/m68k/m68k.h:#define WCHAR_TYPE "long int"
> gcc/config/m68k/m68k.h:#define WCHAR_TYPE_SIZE 32
> On sh we have:
> gcc/config/sh/sh.h:#define WCHAR_TYPE "short unsigned int"
> gcc/config/sh/sh.h:#define WCHAR_TYPE_SIZE 16
> gcc/config/sh/sh.h:#define SH_ELF_WCHAR_TYPE "long int"
> gcc/config/sh/elf.h:#undef WCHAR_TYPE
> gcc/config/sh/elf.h:#define WCHAR_TYPE SH_ELF_WCHAR_TYPE
> gcc/config/sh/elf.h:#undef WCHAR_TYPE_SIZE
> gcc/config/sh/elf.h:#define WCHAR_TYPE_SIZE 32
> On sparc we have:
> gcc/config/sparc/sparc.h:#define WCHAR_TYPE "short unsigned int"
> gcc/config/sparc/sparc.h:#define WCHAR_TYPE_SIZE 16
> gcc/config/sparc/sp-elf.h:#undef WCHAR_TYPE
> gcc/config/sparc/sp-elf.h:#define WCHAR_TYPE "long int"
> gcc/config/sparc/sp-elf.h:#undef WCHAR_TYPE_SIZE
> gcc/config/sparc/sp-elf.h:#define WCHAR_TYPE_SIZE BITS_PER_WORD
> On v850 we have:
> gcc/config/v850/v850.h:#undef WCHAR_TYPE
> gcc/config/v850/v850.h:#define WCHAR_TYPE "long int"
> gcc/config/v850/v850.h:#undef WCHAR_TYPE_SIZE
> gcc/config/v850/v850.h:#define WCHAR_TYPE_SIZE BITS_PER_WORD
> So to me this seems that the architecture specific headers use "long
> int" instead of the default "int" for WCHAR_TYPE. > What is wrong with this?
Type symmetry as required by GCC's fprintf and newlib (esp.
stdint.h/inttypes.h).
I would not want to exclude these patches have become obsolete, because
I haven't been trying gcc-4.9/newlib-2.x, but at least up to
gcc-4.7.x/newlib-1.2.x these were necessary.
Unfortunately, I have not been able to catch up yet, because the
stdint.h/inttypes.h changes in newlib have broken much of my work on
stdint/inttypes and gcc-types and pushed me back by ca. 2 years of work.
>>> For Newlib I would use 2.1.0 without any patches or a recent snapshot.
>> My trust in newlib-2.x is fairly low, because of the amount of changes
>> it has
>> seen and because it still has not stabilized enough to allow proper
>> testing.
> I use the Newlib HEAD now for two years or so and addressed all problems
> I found. The only remaining issue I am aware of is:
> https://www.rtems.org/bugzilla/show_bug.cgi?id=1247
>> Finally, FYI: Some weeks ago I attempted a stab on porting the
>> rtems-tools
>> chains to x86_64-cygwin, but was badly hit by what I currently assume
>> to be a
>> bug in cyginw's newlib-2.0, which seems to originate from one of these
>> changes.
>> However, I am not sure about it, yet.
> Ok, but this is a Cygwin problem?
I currently believe it's a general bug in newlib, they inherited from
newlib which likely is triggered by Cross-building GCC for
Linux->Cygwin. Unfortunately, I also haven't found enough time to
furtherly investigate this, but am wondering why the cygwin folks have
not yet stumbled over this bug, themselves.
Ralf
