Unexpected overlap between .start and *COM* on phycore_mpc5554
Sebastian Huber
Mon Feb 10 13:53:05 UTC 2014
On 2014-02-10 14:18, Peter Dufault wrote:
> On Feb 10, 2014, at 07:58 , Sebastian Huber<sebastian.huber at embedded-brains.de> wrote:
>> >Hello Peter,
>> >do you use the GCC option -fno-common?
> Yes, twice for some reason. Here's the final link command:
> powerpc-rtems4.11-gcc -B../../../../../phycore_mpc5554/lib/ -specs bsp_specs -qrtems -mcpu=8540 -meabi -msdata -fno-common -mspe -mabi=spe -mfloat-gprs=single -D__ppc_generic -mstrict-align -O2 -g -fno-keep-inline-functions -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -mcpu=8540 -meabi -msdata -fno-common -mspe -mabi=spe -mfloat-gprs=single -D__ppc_generic -mstrict-align -o ticker.exe init.o tasks.o
Ok, this is pretty strange. Normally the common symbols show up if you omit
the -fno-common option (common symbols are the work of the devil). Do you see
this *COM* section in the linker map file?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
