[PATCH] sparc: Increase CPU_STRUCTURE_ALIGNMENT to 32
Tue Feb 11 17:24:13 UTC 2014
Does this change negatively affect the older sparc boards?
On Tue, Feb 11, 2014 at 11:25 AM, Sebastian Huber
> Recent LEON4 systems use a cache line size of 32 bytes.
>  cpukit/score/cpu/sparc/rtems/score/cpu.h |    2 +-
>  1 files changed, 1 insertions(+), 1 deletions(-)
> diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> index fe76fa5..17a9f54 100644
> --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> @@ -211,7 +211,7 @@ extern "C" {
>   * The SPARC does not appear to have particularly strict alignment
>   * requirements.  This value was chosen to take advantages of caches.
> -#define CPU_STRUCTURE_ALIGNMENT          __attribute__ ((aligned (16)))
> +#define CPU_STRUCTURE_ALIGNMENT          __attribute__ ((aligned (32)))
>  #define CPU_TIMESTAMP_USE_INT64_INLINE TRUE
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
