LEON3 Clock and Timer Driver
Wed Feb 12 13:33:23 UTC 2014
On 2014-02-12 12:11, Daniel Hellstrom wrote:
> I'm not familiar with this, but indeed it look a bit wrong. The timer resources
> on LEON is not per-CPU, they area shared and we never know how many timers are
> available. Most systems have at least two timers. In case of a multi-processor
> system the LEON3 usually configured which timer it takes by looking at the CPU
> index. It seems like there are two ways, of course the preferable way would be
> to look at LEON3_Cpu_Index in case the AMP CPUs does not involve CPU0. How does
> other AMP systems assign resources? I guess it would be better to solve it in
> another way, by a BSP configuration option instead so select timer? But then
> you would need different kernel libraries...
Ok, I will change this to use LEON3_Cpu_Index instead of
rtems_configuration_get_user_multiprocessing_table()->node.
> Is there a reason why having both timer and ckinit using the same timer?
Its a bit unusual.  On other BSPs this is separate.  Also the timer
initialization will destroy the setup of the clock driver.
> Perhaps it is assumed that the timer interface is only used when the clock
> timer is disabled?
I don't know.  For the timer driver one dedicated timer should be enough.
With the new CPU counter API we can also use a generic benchmark timer and get
rid of the problem with the timer driver.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
