Status of phycore_mpc5554 with latest RTEMS and RSB built tools
Sun Feb 16 11:49:17 UTC 2014
On 02/15/2014 03:56 PM, Peter Dufault wrote:
> (gdb) where
> #0  bsp_reset () at ../../../../../../../../rtems/c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspreset.c:35
> #1  0x00020958 in _User_extensions_Iterate (arg=arg at entry=0x21015658,
>      visitor=0x208cc <_User_extensions_Fatal_visitor>)
>      at ../../../../../../rtems/c/src/../../cpukit/score/src/userextiterate.c:141
> #2  0x0001e2a8 in _User_extensions_Fatal (error=0x21015690, is_internal=0x0,
>      source=RTEMS_FATAL_SOURCE_EXCEPTION)
>      at ../../cpukit/../../../phycore_mpc5554/lib/include/rtems/score/userextimpl.h:239
> #3  _Internal_error_Occurred (the_source=the_source at entry=RTEMS_FATAL_SOURCE_EXCEPTION,
>      is_internal=is_internal at entry=0x0, the_error=0x21015690)
>      at ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:35
> #4  0x0001c734 in rtems_fatal (source=source at entry=RTEMS_FATAL_SOURCE_EXCEPTION, error=<optimized out>)
>      at ../../../../../../rtems/c/src/../../cpukit/sapi/src/fatal2.c:34
> #5  0x0001494c in C_exception_handler (excPtr=<optimized out>)
>      at ../../../../../../../rtems/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_global_handler.c:24
> #6  0x00013b5c in wrap_call_global_handler_std ()
>      at ../../../../../../../rtems/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h:864
You can use
p *(CPU_Exception_frame *)the_error
to get the offending context if the_source == RTEMS_FATAL_SOURCE_EXCEPTION.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
