[PATCH 05/17] score: Disable ISR in _Internal_error_Occurred()
Mon Feb 17 15:51:30 UTC 2014
Disable interrupts as the first step in _Internal_error_Occurred() to
get a defined execution context for the fatal extensions.
 cpukit/score/include/rtems/score/interr.h |    4 +++-
 cpukit/score/src/interr.c                 |    6 ++++++
 2 files changed, 9 insertions(+), 1 deletions(-)
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index 8f8d905..87abc7a 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -176,7 +176,9 @@ extern Internal_errors_Information _Internal_errors_What_happened;
  * determines that a fatal error has occurred or a final system state is
  * reached (for example after exit()).
- * The first action of this function is to call the fatal handler of the user
+ * The first action is to disable interrupts.
+ * The second action of this function is to call the fatal handler of the user
  * extensions.  For the initial extensions the following conditions are
  * required
  * - a valid stack pointer and enough stack space,
diff --git a/cpukit/score/src/interr.c b/cpukit/score/src/interr.c
index 69e7681..38ac455 100644
--- a/cpukit/score/src/interr.c
+++ b/cpukit/score/src/interr.c
@@ -19,6 +19,7 @@
 #endif
 #include <rtems/score/interr.h>
+#include <rtems/score/isrlevel.h>
 #include <rtems/score/sysstate.h>
 #include <rtems/score/userextimpl.h>
@@ -32,6 +33,11 @@ void _Internal_error_Occurred(
   Internal_errors_t       the_error
+  ISR_Level level;
+  _ISR_Disable( level );
+  (void) level;
   _User_extensions_Fatal( the_source, is_internal, the_error );
   _Internal_errors_What_happened.the_source  = the_source;
1.7.7
