[PATCH 13/17] score: Rename bsp_smp_initialize()
Mon Feb 17 15:51:38 UTC 2014
Rename bsp_smp_initialize() into _CPU_SMP_Initialize() since every CPU
port must supply this function.
 c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c |    2 +-
 c/src/lib/libbsp/i386/shared/smp/smp-imps.c    |    2 +-
 c/src/lib/libbsp/powerpc/qoriq/startup/smp.c   |    2 +-
 c/src/lib/libbsp/shared/smp/smp_stub.c         |    2 +-
 c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c   |    2 +-
 cpukit/score/cpu/arm/rtems/score/cpu.h         |    2 ++
 cpukit/score/cpu/i386/rtems/score/cpu.h        |    2 ++
 cpukit/score/cpu/no_cpu/rtems/score/cpu.h      |   18 ++++++++++++++++++
 cpukit/score/cpu/powerpc/rtems/score/cpu.h     |    2 ++
 cpukit/score/cpu/sparc/rtems/score/cpu.h       |    2 ++
 cpukit/score/include/rtems/bspsmp.h            |   18 ------------------
 cpukit/score/src/percpu.c                      |    3 +--
 cpukit/score/src/smp.c                         |    2 +-
 13 files changed, 33 insertions(+), 26 deletions(-)
diff --git a/c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c b/c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c
index 3005bcf..9f465aa 100644
--- a/c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c
+++ b/c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c
@@ -25,7 +25,7 @@ static void ipi_handler(void *arg)
   rtems_smp_process_interrupt();
-uint32_t bsp_smp_initialize(uint32_t configured_cpu_count)
+uint32_t _CPU_SMP_Initialize(uint32_t configured_cpu_count)
   rtems_status_code sc;
   uint32_t max_cpu_count = arm_gic_irq_processor_count();
diff --git a/c/src/lib/libbsp/i386/shared/smp/smp-imps.c b/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
index d8753c3..a2dbc32 100644
--- a/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
+++ b/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
@@ -787,7 +787,7 @@ static void secondary_cpu_initialize(void)
 #include <rtems/bspsmp.h>
-uint32_t bsp_smp_initialize( uint32_t configured_cpu_count )
+uint32_t _CPU_SMP_Initialize( uint32_t configured_cpu_count )
   int cores;
   /* XXX need to deal with finding too many cores */
diff --git a/c/src/lib/libbsp/powerpc/qoriq/startup/smp.c b/c/src/lib/libbsp/powerpc/qoriq/startup/smp.c
index 38a7305..ea9d1cb 100644
--- a/c/src/lib/libbsp/powerpc/qoriq/startup/smp.c
+++ b/c/src/lib/libbsp/powerpc/qoriq/startup/smp.c
@@ -141,7 +141,7 @@ static void ipi_handler(void *arg)
   uint32_t cores = configured_cpu_count < CORE_COUNT ?
diff --git a/c/src/lib/libbsp/shared/smp/smp_stub.c b/c/src/lib/libbsp/shared/smp/smp_stub.c
index f1fa777..b4a9cc3 100644
--- a/c/src/lib/libbsp/shared/smp/smp_stub.c
+++ b/c/src/lib/libbsp/shared/smp/smp_stub.c
@@ -15,7 +15,7 @@
   /* return the number of CPUs */
   return 1;
diff --git a/c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c b/c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c
index 071d3d3..baf4cfd 100644
--- a/c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c
+++ b/c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c
@@ -47,7 +47,7 @@ void leon3_secondary_cpu_initialize(uint32_t cpu)
   rtems_smp_secondary_cpu_initialize();
   uint32_t max_cpu_count;
   uint32_t used_cpu_count;
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index a0c6b41..a58fa9e 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -467,6 +467,8 @@ void _CPU_Context_volatile_clobber( uintptr_t pattern );
 void _CPU_Context_validate( uintptr_t pattern );
 #ifdef RTEMS_SMP
+  uint32_t _CPU_SMP_Initialize( uint32_t configured_cpu_count );
   RTEMS_COMPILER_PURE_ATTRIBUTE static inline uint32_t
     _CPU_SMP_Get_current_processor( void )
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index 4fe254c..3c37006 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -462,6 +462,8 @@ uint32_t   _CPU_ISR_Get_level( void );
    _CPU_Context_restore( (_the_context) );
 #if defined(RTEMS_SMP)
   RTEMS_COMPILER_PURE_ATTRIBUTE uint32_t _CPU_SMP_Get_current_processor( void );
   void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
index 9fdc7fc..e250639 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
@@ -1462,6 +1462,24 @@ CPU_Counter_ticks _CPU_Counter_difference(
 #ifdef RTEMS_SMP
+   * @brief Performs CPU specific SMP initialization in the context of the main
+   * processor.
+   * This function is invoked on the main processor by RTEMS during
+   * initialization.  All interrupt stacks are allocated at this point in case
+   * the CPU port allocates the interrupt stacks.
+   * The CPU port should start secondary processors now.
+   * @param[in] configured_cpu_count The count of processors requested by the
+   * application configuration.
+   * @return The count of processors available for the application in the system.
+   * This value is less than or equal to the configured count of processors.
    * @brief Returns the index of the current processor.
    * An architecture specific method must be used to obtain the index of the
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index f4aa9c4..5e9e5f9 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -1034,6 +1034,8 @@ void _CPU_Context_volatile_clobber( uintptr_t pattern );
 #ifdef RTEMS_SMP
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index a3b4a1b..19454a6 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -1161,6 +1161,8 @@ void _CPU_Context_restore(
 ) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
   #if defined(__leon__)
diff --git a/cpukit/score/include/rtems/bspsmp.h b/cpukit/score/include/rtems/bspsmp.h
index d634a36..9cdb6dc 100644
--- a/cpukit/score/include/rtems/bspsmp.h
+++ b/cpukit/score/include/rtems/bspsmp.h
@@ -52,24 +52,6 @@ extern "C" {
 #ifndef ASM
- * @brief Performs BSP specific SMP initialization in the context of the main
- * processor.
- * This function is invoked on the main processor by RTEMS during
- * initialization.  All interrupt stacks are allocated at this point in case
- * the CPU port allocates the interrupt stacks.
- * The BSP may start secondary processors now.
- * @param[in] configured_cpu_count The count of processors requested by the
- * application configuration.
- * @return The count of processors available for the application in the system.
- * This value is less than or equal to the configured count of processors.
-uint32_t bsp_smp_initialize( uint32_t configured_cpu_count );
  *  @brief Generate an interprocessor broadcast interrupt.
  *  This method is invoked when RTEMS wants to let all of the other
diff --git a/cpukit/score/src/percpu.c b/cpukit/score/src/percpu.c
index 201c53b..aa95aa9 100644
--- a/cpukit/score/src/percpu.c
+++ b/cpukit/score/src/percpu.c
@@ -29,7 +29,6 @@
   #include <rtems/score/smp.h>
-  #include <rtems/bspsmp.h>
   void _SMP_Handler_initialize(void)
@@ -39,7 +38,7 @@
      * Discover and initialize the secondary cores in an SMP system.
-    max_cpus = bsp_smp_initialize( max_cpus );
+    max_cpus = _CPU_SMP_Initialize( max_cpus );
     _SMP_Processor_count = max_cpus;
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index c03c148..612c6e9 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -138,7 +138,7 @@ void _SMP_Request_other_cores_to_shutdown( void )
    * Do not use _SMP_Get_processor_count() since this value might be not
    * initialized yet.  For example due to a fatal error in the middle of
-   * bsp_smp_initialize().
+   * _CPU_SMP_Initialize().
   uint32_t ncpus = rtems_configuration_get_maximum_processors();
1.7.7
