[PATCH 03/17] score: Add SYSTEM_STATE_FATAL
Chris Johns
chrisj at rtems.org
Tue Feb 18 07:55:07 UTC 2014
On 18/02/2014 6:08 pm, Sebastian Huber wrote:
> On 2014-02-17 22:41, Chris Johns wrote:
>> On 18/02/2014 2:51 am, Sebastian Huber wrote:
>>> Merge systems states SYSTEM_STATE_SHUTDOWN and SYSTEM_STATE_FAILED into
>>> new system state SYSTEM_STATE_FATAL. This reflects that all system
>>> termination paths end up in _Internal_error_Occurred().
>> Does this mean non-error termination happens here ? If so is the
>> naming suitable ?
> Yes, all (non-error and error) termination paths end up here. The name
> reflects the user extension name that is invoked here. Since this name
> is part of the public API we should not change it.
Should the current function be renamed and the API interface functoin
wrap the name changed function ? It is confusing to end up in an error
handler when there has been no error.
