[PATCH 2/4] score: SMP initialization and shutdown changes
Wed Feb 19 15:50:00 UTC 2014
On 2014-02-19 16:11, Gedare Bloom wrote:
> There is dissimilarity between the SMP handler function names
> * _SMP_Request_processors_to_shutdown
> * _SMP_Request_start_multitasking_on_secondary_processors()
> Note the order switch between the verb and object. If you like the
> similar with _Thread_Start_multitasking, I recommend using
> _SMP_Request_shutdown_on_secondary_processors().
> I also do not think it is necessary to include
> "on_secondary_processors()" however. You could just use
> * _SMP_Request_shutdown()
The shutdown request affects all processors.  This name is better since it is
shorter, i will use it.
> * _SMP_Request_start_multitasking()
This function will be called from the main processor only and the other
processors (= secondary processors) are the targets of this request.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
