[PATCH] New fstest to check rename POSIX conformance
Andre Marques
andre.lousa.marques at gmail.com
Wed Feb 19 23:36:07 UTC 2014
On 02/19/14 14:00, Sebastian Huber wrote:
> On 2014-02-19 11:27, Andre Marques wrote:
>> Sorry for the delay.
>> I'm almost ready to send the patch with the test, but there are some
>> questions.
> This is nice.
>> On 02/10/14 08:14, Sebastian Huber wrote:
>>> Hello Andre,
>>> thanks for the test case.
>>> On 2014-02-08 13:26, Andre Marques wrote:
>>>> Hi,
>>>> As discussed in [1], I created a new fstest to check the rename()
>>>> implementation against the POSIX specification [2].
>>>> What the attached patch does not test:
>>>> - Testing the existance of a link visible to other processes during
>>>> the rename
>>>> process (ensuring that there is always a reference to the file).
>>>> Not sure about
>>>> the best way to test this.
>>> The file system instance is locked during the rename operation, so
>>> other
>>> threads cannot interfere here.
>> Should I test the lock then?
> I think a test would be quite difficult. I would postpone this.
>>> What happens if you rename a file with an open file descriptor
>>> should be tested.
>> That is already covered on the test.
>>>> - Testing that after all processes close their references to a file
>>>> after it
>>>> was removed by rename() the file contents are removed (or marked as
>>>> free space,
>>>> I guess). I only found platform dependent ways of dealing with disk
>>>> block's.
>>> Maybe you can use the statvfs() function for this.
>> The statvfs() function gives "not implemented" on the IMFS
>> filesystem, so I
>> changed the used filesystem to MOUNTED RFS.
> Ok, maybe we should implement this function for the IMFS or skip the
> test case if statvfs() is not available.
Skipping for now.
>>>> - Testing errno values in error situations. There is already a
>>>> fstest named
>>>> fserror which purpose seems to be checking errno values for a bunch of
>>>> functions (rename included, but with some errno values missing).
>>>> Not sure if I
>>>> should put them in this test or add to fserror.
>>> I would move all rename related tests to this new test program.
>> About the errno value testing, I'm currently missing EIO, ENOSPC,
>> EROFS and EXDEV.
>> EROFS and EXDEV require mounting a second filesystem. How can I do
>> this in
>> RTEMS? Can it be done at runtime? I've been looking at the fileio
>> sample, which
>> uses the fsmount() function, but I need a disk to mount with it.
> For EROFS there is already a test in fstests/fsrofs01.
So I leave EROFS out of this test?
> You can mount as many file system instances as you want. You can do
> this with mount(). The mount() parameters are file system dependent.
> The generic file system tests (and your rename test should be one of
> them) use a support file for this:
> ./testsuites/fstests/mrfs_support/fs_support.c
> ./testsuites/fstests/mimfs_support/fs_support.c
> ./testsuites/fstests/mdosfs_support/fs_support.c
> ./testsuites/fstests/imfs_support/fs_support.c
> ./testsuites/fstests/jffs2_support/fs_support.c
Yes I'm using support files on Makefile.am.
For mount() should I use a ramdisk for the device file?
I tried to create a ramdisk as in
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__rtems__ramdisk.html#gac6c99eed9f3b92bb4cf5184b25972e65
but the program exits during the rtems_blkdev_create() call, if I use
"/dev/rda" as the device path.
> You can use the system file system as the second file system for the
> EXDEV test.
I'm reading this as mounting an instance of the system filesystem. Am I
right?
>> For ENOSPC I'm thinking in mounting a small disk and testing that
>> way, but for
>> EIO I don't know how to simulate a physical error. How can I generate
>> an I/O
>> error?
> Generating an IO error will be difficult or impossible (e.g. for
> IMFS). For the disk device based file systems you need a special
> driver. I would ignore this for now.
>>>> This test uses the MOUNTED IMFS filesystem, for no particular
>>>> reason, so if
>>>> that's an issue please let me know.
>>>> [1] -
>>>> http://www.rtems.org/pipermail/rtems-users/2014-January/012378.html
>>>> [2] -
>>>> http://pubs.opengroup.org/onlinepubs/9699919799/functions/rename.html
>>>> --André Marques
