Patches for classic affinity implementation and test
Fri Feb 21 15:06:44 UTC 2014
On 2014-02-21 15:27, Gedare Bloom wrote:
> On Fri, Feb 21, 2014 at 3:00 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de>  wrote:
>> >On 2014-02-20 21:07, Jennifer Averett wrote:
>>> >>+#if __RTEMS_HAVE_SYS_CPUSET_H__ && defined( RTEMS_SMP )
>>> >>+const Cpuset_Control *_Cpuset_Handler_default(void);
>>> >>+#else
>>> >>+#define _Cpuset_Handler_default()   do { } while ( 0 )
>>> >>+#endif
>> >In case the C library doesn't provide an appropriate <sys/cpuset.h> then we
>> >should provide our own header file.  Maybe we should use a special header
>> >file that either uses <sys/cpuset.h> directly or alternatively provides the
>> >missing declarations and functions.
>> >I don't think it makes sense to use a SMP configuration with this API.
> Do you mean UP?
Oh, I meant:
I don't think it makes sense to use a SMP configuration WITHOUT this API.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
