Uniprocessor Tests in SMP Configuration
Joel Sherrill Joel.Sherrill at OARcorp.com
Mon Feb 24 08:58:56 UTC 2014
OK.. We can talk code specifics tomorrow in person.
Is gxx_wrappers.c still needed?
On Feb 24, 2014 9:56 AM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
On 2014-02-24 09:09, Joel Sherrill wrote:
>  > > 2. Use alternatives to task variables for all RTEMS support components, e.g.
>  > > the file system environment.  Here we can use __getreent() for example with
>  > > struct S {
>  > >   struct _reent reent;
>  > >   rtems_user_env_t env;
> I am missing some detail here. Can you provide details?
Each thread can have its own file system environment.  So we need some sort of
thread-local storage.  Since applications using a file system will very likely
also enable the Newlib re-entrancy we can re-use the __getreent() function for
the file system environment.  In newlib_create_hook() we create a structure
struct S {
   rtems_user_env_t *env;
and assign it to thread->libc_reent;
The file system can then use
(struct S *) __getreent()
to get its file system environment.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140224/e3aa49aa/attachment-0001.html>
