[PATCH 01/17] bsp/arm: Invalidate SCU
Gedare Bloom
gedare at rtems.org
Wed Feb 26 19:01:47 UTC 2014
On Wed, Feb 26, 2014 at 5:51 AM, Ralf Kirchner
<ralf.kirchner at embedded-brains.de> wrote:
> c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h | 12 ++++++++++++
> c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h | 10 ++++++++++
> 2 Dateien geändert, 22 Zeilen hinzugefügt(+)
> diff --git a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h
> index 0910e4c..28640d2 100644
> --- a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h
> +++ b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h
> @@ -46,6 +46,18 @@ typedef struct {
> #define A9MPCORE_SCU_CFG_TAG_RAM_SIZE_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
> uint32_t pwrst;
> uint32_t invss;
> +#define A9MPCORE_SCU_INVSS_CPU0(ways) BSP_FLD32(val, 0, 3)
> +#define A9MPCORE_SCU_INVSS_CPU0_GET(reg) /* Write only register */
> +#define A9MPCORE_SCU_INVSS_CPU0_SET(reg, val) BSP_FLD32SET(reg, val, 0, 3)
> +#define A9MPCORE_SCU_INVSS_CPU1(ways) BSP_FLD32(val, 4, 7)
> +#define A9MPCORE_SCU_INVSS_CPU1_GET(reg) /* Write only register */
> +#define A9MPCORE_SCU_INVSS_CPU1_SET(reg, val) BSP_FLD32SET(reg, val, 4, 7)
> +#define A9MPCORE_SCU_INVSS_CPU2(ways) BSP_FLD32(val, 8, 11)
> +#define A9MPCORE_SCU_INVSS_CPU2_GET(reg) /* Write only register */
> +#define A9MPCORE_SCU_INVSS_CPU2_SET(reg, val) BSP_FLD32SET(reg, val, 8, 11)
> +#define A9MPCORE_SCU_INVSS_CPU3(ways) BSP_FLD32(val, 12, 15)
> +#define A9MPCORE_SCU_INVSS_CPU3_GET(reg) /* Write only register */
> +#define A9MPCORE_SCU_INVSS_CPU3_SET(reg, val) BSP_FLD32SET(reg, val, 12, 15)
> uint32_t reserved_10[12];
> uint32_t fltstart;
> uint32_t fltend;
> diff --git a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
> index dd1b7c1..ad4cf42 100644
> --- a/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
> +++ b/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
> @@ -70,6 +70,13 @@ BSP_START_TEXT_SECTION static inline arm_a9mpcore_start_set_vector_base(void)
> +BSP_START_TEXT_SECTION static inline arm_a9mpcore_start_scu_invalidate(const uint32_t cpu_id, const uint32_t ways)
> + volatile a9mpcore_scu *scu = (volatile a9mpcore_scu *) BSP_ARM_A9MPCORE_SCU_BASE;
> + scu->invss = ( ( ways & 0xF ) << ( ( cpu_id & 0x3 ) * 4 ) );
why masking ways and cpu_id? can ways ever be more than 15? if > 3
cpus will this work right?
> BSP_START_TEXT_SECTION static inline arm_a9mpcore_start_hook_0(void)
> #ifdef RTEMS_SMP
> @@ -86,6 +93,9 @@ BSP_START_TEXT_SECTION static inline arm_a9mpcore_start_hook_0(void)
> arm_cp15_set_auxiliary_control(actlr);
> cpu_id = arm_cortex_a9_get_multiprocessor_cpu_id();
> + arm_a9mpcore_start_scu_invalidate(cpu_id, 0xF);
> if (cpu_id != 0) {
> arm_a9mpcore_start_set_vector_base();
> 1.7.10.4
> rtems-devel mailing list
> rtems-devel at rtems.org
