[PATCH 12/17] libbsp/xilinx-zynq: Share handling for ARM cache controller L2C-310
Gedare Bloom
gedare at rtems.org
Wed Feb 26 19:08:52 UTC 2014
What tests were used for validation of this implementation and on what
zynq target?
On Wed, Feb 26, 2014 at 5:51 AM, Ralf Kirchner
<ralf.kirchner at embedded-brains.de> wrote:
> c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am | 4 +-
> c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h | 2 +
> c/src/lib/libbsp/arm/xilinx-zynq/include/cache_.h | 986 ---------------------
> 3 Dateien geändert, 4 Zeilen hinzugefügt(+), 988 Zeilen entfernt(-)
> delete mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/include/cache_.h
> diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
> index 8eaf98a..808d220 100644
> --- a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
> +++ b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
> @@ -118,8 +118,8 @@ libbsp_a_SOURCES += ../shared/arm-a9mpcore-clock-config.c
> # Cache
> libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
> -libbsp_a_SOURCES += include/cache_.h
> -libbsp_a_CPPFLAGS += -I$(srcdir)/include
> +libbsp_a_SOURCES += ../shared/arm-l2c-310/cache_.h
> +libbsp_a_CPPFLAGS += -I$(srcdir)/../shared/arm-l2c-310
> # Start hooks
> libbsp_a_SOURCES += startup/bspstarthooks.c startup/bspstartmmu.c
> diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h b/c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h
> index c837d0d..635c505 100644
> --- a/c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h
> +++ b/c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h
> @@ -55,6 +55,8 @@ extern "C" {
> #define BSP_ARM_GIC_DIST_BASE 0xf8f01000
> +#define BSP_ARM_L2CC_BASE 0xF8F02000U
> * @brief Zynq specific set up of the MMU.
> diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/include/cache_.h b/c/src/lib/libbsp/arm/xilinx-zynq/include/cache_.h
> deleted file mode 100644
> index 8015136..0000000
> --- a/c/src/lib/libbsp/arm/xilinx-zynq/include/cache_.h
> +++ /dev/null
> @@ -1,986 +0,0 @@
> - * @file
> - * @ingroup zynq_cache
> - * @brief Cache definitions and functions.
> - * Authorship
> - * This software was created by
> - * R. Claus <claus at slac.stanford.edu>, 2013,
> - * Stanford Linear Accelerator Center, Stanford University.
> - * Acknowledgement of sponsorship
> - * This software was produced by
> - * the Stanford Linear Accelerator Center, Stanford University,
> - * under Contract DE-AC03-76SFO0515 with the Department of Energy.
> - * Government disclaimer of liability
> - * Neither the United States nor the United States Department of Energy,
> - * nor any of their employees, makes any warranty, express or implied, or
> - * assumes any legal liability or responsibility for the accuracy,
> - * completeness, or usefulness of any data, apparatus, product, or process
> - * disclosed, or represents that its use would not infringe privately owned
> - * rights.
> - * Stanford disclaimer of liability
> - * Stanford University makes no representations or warranties, express or
> - * implied, nor assumes any liability for the use of this software.
> - * Stanford disclaimer of copyright
> - * Stanford University, owner of the copyright, hereby disclaims its
> - * copyright and all other rights in this software. Hence, anyone may
> - * freely use it for any purpose without restriction.
> - * Maintenance of notices
> - * In the interest of clarity regarding the origin and status of this
> - * SLAC software, this and all the preceding Stanford University notices
> - * are to remain affixed to any copy or derivative of this software made
> - * or distributed by the recipient and are to be affixed to any copy of
> - * software made or distributed by the recipient that contains a copy or
> - * derivative of this software.
> - * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
> -#ifndef LIBBSP_ARM_ZYNQ_CACHE__H
> -#define LIBBSP_ARM_ZYNQ_CACHE__H
> -#include <libcpu/arm-cp15.h>
> -/* These two defines also ensure that the rtems_cache_* functions have bodies */
> -#define CPU_DATA_CACHE_ALIGNMENT 32
> -#define CPU_INSTRUCTION_CACHE_ALIGNMENT 32
> -#define CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS
> -#define L2CC_BASE_ADDR 0xF8F02000U
> -#define ZYNQ_L2_CACHE_LINE_SIZE 32
> - * @defgroup zynq_cache Cache Support
> - * @ingroup arm_zynq
> - * @brief Cache Functions and Defitions
> - * @brief L2CC Register Offsets
> -typedef struct {
> - uint32_t cache_id; /* Cache ID */
> - uint32_t cache_type; /* Cache type */
> - uint8_t reserved_8[0x100 - 8];
> - uint32_t ctrl; /* Control */
> -/** @brief Enables the L2CC */
> -#define L2CC_ENABLE_MASK 0x00000001
> - /** @brief Auxiliary control */
> - uint32_t aux_ctrl;
> -/** @brief Early BRESP Enable */
> -#define L2CC_AUX_EBRESPE_MASK 0x40000000
> -/** @brief Instruction Prefetch Enable */
> -#define L2CC_AUX_IPFE_MASK 0x20000000
> -/** @brief Data Prefetch Enable */
> -#define L2CC_AUX_DPFE_MASK 0x10000000
> -/** @brief Non-secure interrupt access control */
> -#define L2CC_AUX_NSIC_MASK 0x08000000
> -/** @brief Non-secure lockdown enable */
> -#define L2CC_AUX_NSLE_MASK 0x04000000
> -/** @brief Cache replacement policy */
> -#define L2CC_AUX_CRP_MASK 0x02000000
> -/** @brief Force write allocate */
> -#define L2CC_AUX_FWE_MASK 0x01800000
> -/** @breif Shared attribute override enable */
> -#define L2CC_AUX_SAOE_MASK 0x00400000
> -/** @brief Parity enable */
> -#define L2CC_AUX_PE_MASK 0x00200000
> -/** @brief Event monitor bus enable */
> -#define L2CC_AUX_EMBE_MASK 0x00100000
> -/** @brief Way-size */
> -#define L2CC_AUX_WAY_SIZE_MASK 0x000E0000
> -#define L2CC_AUX_ASSOC_MASK 0x00010000
> -/** @brief Shared attribute invalidate enable */
> -#define L2CC_AUX_SAIE_MASK 0x00002000
> -/** @brief Exclusive cache configuration */
> -#define L2CC_AUX_EXCL_CACHE_MASK 0x00001000
> -/** @brief Store buffer device limitation Enable */
> -#define L2CC_AUX_SBDLE_MASK 0x00000800
> -/** @brief High Priority for SO and Dev Reads Enable */
> -#define L2CC_AUX_HPSODRE_MASK 0x00000400
> -/** @brief Full line of zero enable */
> -#define L2CC_AUX_FLZE_MASK 0x00000001
> -/** @brief Enable all prefetching, */
> -#define L2CC_AUX_REG_DEFAULT_MASK 0x72360000
> -#define L2CC_AUX_REG_ZERO_MASK 0xFFF1FFFF
> - /** @brief Latency for tag RAM */
> - uint32_t tag_ram_ctrl;
> -#define L2CC_TAG_RAM_DEFAULT_MASK 0x00000111
> - /** @brief Latency for data RAM */
> - uint32_t data_ram_ctrl;
> -#define L2CC_DATA_RAM_DEFAULT_MASK 0x00000121
> - uint8_t reserved_110[0x200 - 0x110];
> - /** @brief Event counter control */
> - uint32_t ev_ctrl;
> - /** @brief Event counter 1 configuration */
> - uint32_t ev_cnt1_cfg;
> - /** @brief Event counter 0 configuration */
> - uint32_t ev_cnt0_cfg;
> - /** @brief Event counter 1 value */
> - uint32_t ev_cnt1;
> - /** @brief Event counter 0 value */
> - uint32_t ev_cnt0;
> - /** @brief Interrupt enable mask */
> - uint32_t int_mask;
> - /** @brief Masked interrupt status (read-only)*/
> - uint32_t int_mask_status;
> - /** @brief Unmasked interrupt status */
> - uint32_t int_raw_status;
> - /** @brief Interrupt clear */
> - uint32_t int_clr;
> - * @name Interrupt bit masks
> -/** @brief DECERR from L3 */
> -#define L2CC_INT_DECERR_MASK 0x00000100
> -/** @brief SLVERR from L3 */
> -#define L2CC_INT_SLVERR_MASK 0x00000080
> -/** @brief Error on L2 data RAM (Read) */
> -#define L2CC_INT_ERRRD_MASK 0x00000040
> -/** @brief Error on L2 tag RAM (Read) */
> -#define L2CC_INT_ERRRT_MASK 0x00000020
> -/** @brief Error on L2 data RAM (Write) */
> -#define L2CC_INT_ERRWD_MASK 0x00000010
> -/** @brief Error on L2 tag RAM (Write) */
> -#define L2CC_INT_ERRWT_MASK 0x00000008
> -/** @brief Parity Error on L2 data RAM (Read) */
> -#define L2CC_INT_PARRD_MASK 0x00000004
> -/** @brief Parity Error on L2 tag RAM (Read) */
> -#define L2CC_INT_PARRT_MASK 0x00000002
> -/** @brief Event Counter1/0 Overflow Increment */
> -#define L2CC_INT_ECNTR_MASK 0x00000001
> - uint8_t reserved_224[0x730 - 0x224];
> - /** @brief Drain the STB */
> - uint32_t cache_sync;
> - uint8_t reserved_734[0x770 - 0x734];
> - /** @brief Invalidate line by PA */
> - uint32_t inv_pa;
> - uint8_t reserved_774[0x77c - 0x774];
> - /** @brief Invalidate by Way */
> - uint32_t inv_way;
> - uint8_t reserved_780[0x7b0 - 0x780];
> - /** @brief Clean Line by PA */
> - uint32_t clean_pa;
> - uint8_t reserved_7b4[0x7b8 - 0x7b4];
> - /** @brief Clean Line by Set/Way */
> - uint32_t clean_index;
> - /** @brief Clean by Way */
> - uint32_t clean_way;
> - uint8_t reserved_7c0[0x7f0 - 0x7c0];
> - /** @brief Clean and Invalidate Line by PA */
> - uint32_t clean_inv_pa;
> - uint8_t reserved_7f4[0x7f8 - 0x7f4];
> - /** @brief Clean and Invalidate Line by Set/Way */
> - uint32_t clean_inv_indx;
> - /** @brief Clean and Invalidate by Way */
> - uint32_t clean_inv_way;
> - /** @brief Data lock down 0 */
> - uint32_t d_lockdown_0;
> - /** @brief Instruction lock down 0 */
> - uint32_t i_lockdown_0;
> - /** @brief Data lock down 1 */
> - uint32_t d_lockdown_1;
> - /** @brief Instruction lock down 1 */
> - uint32_t i_lockdown_1;
> - /** @brief Data lock down 2 */
> - uint32_t d_lockdown_2;
> - /** @brief Instruction lock down 2 */
> - uint32_t i_lockdown_2;
> - /** @brief Data lock down 3 */
> - uint32_t d_lockdown_3;
> - /** @brief Instruction lock down 3 */
> - uint32_t i_lockdown_3;
> - /** @brief Data lock down 4 */
> - uint32_t d_lockdown_4;
> - /** @brief Instruction lock down 4 */
> - uint32_t i_lockdown_4;
> - /** @brief Data lock down 5 */
> - uint32_t d_lockdown_5;
> - /** @brief Instruction lock down 5 */
> - uint32_t i_lockdown_5;
> - /** @brief Data lock down 6 */
> - uint32_t d_lockdown_6;
> - /** @brief Instruction lock down 6 */
> - uint32_t i_lockdown_6;
> - /** @brief Data lock down 7 */
> - uint32_t d_lockdown_7;
> - /** @brief Instruction lock down 7 */
> - uint32_t i_lockdown_7;
> - uint8_t reserved_940[0x950 - 0x940];
> - /** @brief Lockdown by Line Enable */
> - uint32_t lock_line_en;
> - /** @brief Cache lockdown by way */
> - uint32_t unlock_way;
> - uint8_t reserved_958[0xc00 - 0x958];
> - /** @brief Address range redirect, part 1 */
> - uint32_t addr_filtering_start;
> - /** @brief Address range redirect, part 2 */
> - uint32_t addr_filtering_end;
> -/** @brief Address filtering valid bits*/
> -#define L2CC_ADDR_FILTER_VALID_MASK 0xFFF00000
> -/** @brief Address filtering enable bit*/
> -#define L2CC_ADDR_FILTER_ENABLE_MASK 0x00000001
> - uint8_t reserved_c08[0xf40 - 0xc08];
> - /** @brief Debug control */
> - uint32_t debug_ctrl;
> -/** @brief Debug SPIDEN bit */
> -#define L2CC_DEBUG_SPIDEN_MASK 0x00000004
> -/** @brief Debug DWB bit, forces write through */
> -#define L2CC_DEBUG_DWB_MASK 0x00000002
> -/** @breif Debug DCL bit, disables cache line fill */
> -#define L2CC_DEBUG_DCL_MASK 0x00000002
> - uint8_t reserved_f44[0xf60 - 0xf44];
> - /** @brief Purpose prefetch enables */
> - uint32_t prefetch_ctrl;
> - uint8_t reserved_f64[0xf80 - 0xf64];
> - /** @brief Purpose power controls */
> - uint32_t power_ctrl;
> -} L2CC;
> -static inline void
> -zynq_cache_l1_cache_properties(uint32_t *l1LineSize,
> - uint32_t *l1NumWays,
> - uint32_t *l1NumSets)
> - uint32_t id;
> - /* Select cache level 1 and Data cache in CSSELR */
> - arm_cp15_set_cache_size_selection(0);
> - _ARM_Instruction_synchronization_barrier();
> - id = arm_cp15_get_cache_size_id();
> - *l1LineSize = (id & 0x0007U) + 2 + 2; /* Cache line size (+2 -> bytes) */
> - *l1NumWays = ((id >> 3) & 0x03ffU) + 1; /* Number of Ways */
> - *l1NumSets = ((id >> 13) & 0x7fffU) + 1; /* Number of Sets */
> -static inline void
> -zynq_cache_l1_cache_flush_1_data_line(const void *d_addr)
> - /* Select cache Level 1 and Data cache in CSSELR */
> - /* Flush the Data cache */
> - arm_cp15_data_cache_clean_and_invalidate_line(d_addr);
> - /* Wait for L1 flush to complete */
> - _ARM_Data_synchronization_barrier();
> -static inline void
> -zynq_cache_l1_cache_flush_data_range(const void *d_addr, size_t n_bytes)
> - const void * final_address;
> - * Set d_addr to the beginning of the cache line; final_address indicates
> - * the last address_t which needs to be pushed. Increment d_addr and push
> - * the resulting line until final_address is passed.
> - if( n_bytes == 0 )
> - /* Do nothing if number of bytes to flush is zero */
> - return;
> - final_address = (void *)((size_t)d_addr + n_bytes - 1);
> - d_addr = (void *)((size_t)d_addr & ~(CPU_DATA_CACHE_ALIGNMENT - 1));
> - while( d_addr <= final_address ) {
> - arm_cp15_data_cache_clean_and_invalidate_line( d_addr );
> - d_addr = (void *)((size_t)d_addr + CPU_DATA_CACHE_ALIGNMENT);
> -static inline void
> -zynq_cache_l1_cache_flush_entire_data(void)
> - uint32_t l1LineSize, l1NumWays, l1NumSets;
> - uint32_t sets, ways, s, w;
> - /* Get the L1 cache properties */
> - zynq_cache_l1_cache_properties(&l1LineSize, &l1NumWays, &l1NumSets);
> - ways = l1NumWays * (1 << 30);
> - sets = l1NumSets * (1 << l1LineSize);
> - /* Invalidate all the cache lines */
> - for (w = 0; w < ways; w += (1 << 30)) {
> - for (s = 0; s < sets; s += (1 << l1LineSize)) {
> - /* Flush by Set/Way */
> - arm_cp15_data_cache_clean_and_invalidate_line_by_set_and_way(w | s);
> -static inline void
> -zynq_cache_l1_cache_invalidate_1_data_line(const void *d_addr)
> - /* Invalidate the cache line */
> - arm_cp15_data_cache_invalidate_line(d_addr);
> - /* Wait for L1 invalidate to complete */
> -static inline void
> -zynq_cache_l1_cache_invalidate_data_range(const void *d_addr, size_t n_bytes)
> - * the last address_t which needs to be invalidated. Increment d_addr and
> - * invalidate the resulting line until final_address is passed.
> - /* Do nothing if number of bytes to invalidate is zero */
> - return;
> - while( final_address >= d_addr ) {
> - arm_cp15_data_cache_invalidate_line( d_addr );
> -static inline void
> -zynq_cache_l1_cache_invalidate_entire_data(void)
> - /* Invalidate by Set/Way */
> - arm_cp15_data_cache_invalidate_line_by_set_and_way(w | s);
> -static inline void
> -zynq_cache_l1_cache_store_data(const void *d_addr)
> - /* Store the Data cache line */
> - arm_cp15_data_cache_clean_line(d_addr);
> - /* Wait for L1 store to complete */
> -static inline void
> -zynq_cache_l1_cache_freeze_data(void)
> - /* TODO */
> -static inline void
> -zynq_cache_l1_cache_unfreeze_data(void)
> - /* TODO */
> -static inline void
> -zynq_cache_l1_cache_invalidate_1_instruction_line(const void *i_addr)
> - /* Select cache Level 1 and Instruction cache in CSSELR */
> - arm_cp15_set_cache_size_selection(1);
> - /* Invalidate the Instruction cache line */
> - arm_cp15_instruction_cache_invalidate_line(i_addr);
> -static inline void
> -zynq_cache_l1_cache_invalidate_instruction_range(const void *i_addr, size_t n_bytes)
> - * Set i_addr to the beginning of the cache line; final_address indicates
> - * the last address_t which needs to be invalidated. Increment i_addr and
> - return;
> - final_address = (void *)((size_t)i_addr + n_bytes - 1);
> - i_addr = (void *)((size_t)i_addr & ~(CPU_INSTRUCTION_CACHE_ALIGNMENT - 1));
> - while( final_address > i_addr ) {
> - arm_cp15_instruction_cache_invalidate_line( i_addr );
> - i_addr = (void *)((size_t)i_addr + CPU_INSTRUCTION_CACHE_ALIGNMENT);
> -static inline void
> -zynq_cache_l1_cache_invalidate_entire_instruction(void)
> - /* Invalidate the Instruction cache */
> - arm_cp15_instruction_cache_invalidate();
> -static inline void
> -zynq_cache_l1_cache_freeze_instruction(void)
> - /* TODO */
> -static inline void
> -zynq_cache_l1_cache_unfreeze_instruction(void)
> - /* TODO */
> -static inline void
> -zynq_cache_l1_cache_enable_data(void)
> - rtems_interrupt_level level;
> - uint32_t ctrl;
> - rtems_interrupt_disable(level);
> - /* Enable caches only if they are disabled */
> - ctrl = arm_cp15_get_control();
> - if (!(ctrl & ARM_CP15_CTRL_C)) {
> - /* Clean and invalidate the Data cache */
> - zynq_cache_l1_cache_invalidate_entire_data();
> - /* Enable the Data cache */
> - ctrl |= ARM_CP15_CTRL_C;
> - arm_cp15_set_control(ctrl);
> - rtems_interrupt_enable(level);
> -static inline void
> -zynq_cache_l1_cache_disable_data(void)
> - zynq_cache_l1_cache_flush_entire_data();
> - /* Disable the Data cache */
> - arm_cp15_set_control(arm_cp15_get_control() & ~ARM_CP15_CTRL_C);
> -static inline void
> -zynq_cache_l1_cache_enable_instruction(void)
> - uint32_t ctrl;
> - /* Enable Instruction cache only if it is disabled */
> - if (!(ctrl & ARM_CP15_CTRL_I)) {
> - zynq_cache_l1_cache_invalidate_entire_instruction();
> - /* Enable the Instruction cache */
> - ctrl |= ARM_CP15_CTRL_I;
> -static inline void
> -zynq_cache_l1_cache_disable_instruction(void)
> - /* Synchronize the processor */
> - /* Disable the Instruction cache */
> - arm_cp15_set_control(arm_cp15_get_control() & ~ARM_CP15_CTRL_I);
> -static inline void
> -zynq_cache_l2_cache_flush_1_line(const void *d_addr)
> - volatile L2CC* l2cc = (volatile L2CC *)L2CC_BASE_ADDR;
> - l2cc->clean_inv_pa = (uint32_t)d_addr;
> -static inline void
> -zynq_cache_l2_cache_flush_range(const void *d_addr, size_t n_bytes)
> - volatile L2CC *l2cc = (volatile L2CC *)L2CC_BASE_ADDR;
> - if (n_bytes != 0) {
> - uint32_t adx = (uint32_t)d_addr;
> - const uint32_t end = adx + n_bytes;
> - /* Back starting address up to start of a line and flush until end */
> - for (adx &= ~(ZYNQ_L2_CACHE_LINE_SIZE - 1);
> - adx < end;
> - adx += ZYNQ_L2_CACHE_LINE_SIZE) {
> - l2cc->clean_inv_pa = adx;
> - /* Wait for L2 flush to complete */
> - while (l2cc->cache_sync != 0);
> -static inline void
> -zynq_cache_l2_cache_flush_entire(void)
> - /* Flush the caches */
> - l2cc->clean_inv_way = 0x0000FFFFU;
> - /* Wait for the flush to complete */
> -static inline void
> -zynq_cache_l2_cache_invalidate_1_line(const void *d_addr)
> - l2cc->inv_pa = (uint32_t)d_addr;
> -static inline void
> -zynq_cache_l2_cache_invalidate_range(const void* d_addr, size_t n_bytes)
> - /* Back starting address up to start of a line and invalidate until end */
> - adx < end;
> - l2cc->inv_pa = adx;
> - /* Wait for L2 invalidate to complete */
> -static inline void
> -zynq_cache_l2_cache_invalidate_entire(void)
> - /* Invalidate the caches */
> - l2cc->inv_way = 0xFFFFU;
> - /* Wait for the invalidate to complete */
> -static inline void
> -zynq_cache_l2_cache_store(const void *d_addr)
> - l2cc->clean_pa = (uint32_t)d_addr;
> -static inline void
> -zynq_cache_l2_cache_freeze(void)
> - /* TODO */
> -static inline void
> -zynq_cache_l2_cache_unfreeze(void)
> - /* TODO */
> -static inline void
> -zynq_cache_l2_cache_enable(void)
> - /* Only enable if L2CC is currently disabled */
> - if ((l2cc->ctrl & L2CC_ENABLE_MASK) == 0) {
> - uint32_t value;
> - /* Set up the way size and latencies */
> - value = l2cc->aux_ctrl;
> - value &= L2CC_AUX_REG_ZERO_MASK;
> - value |= L2CC_AUX_REG_DEFAULT_MASK;
> - l2cc->aux_ctrl = value;
> - l2cc->tag_ram_ctrl = L2CC_TAG_RAM_DEFAULT_MASK;
> - l2cc->data_ram_ctrl = L2CC_DATA_RAM_DEFAULT_MASK;
> - /* Clear the pending interrupts */
> - l2cc->int_clr = l2cc->int_raw_status;
> - /* Enable the L2CC */
> - l2cc->ctrl |= L2CC_ENABLE_MASK;
> - arm_cp15_set_control(arm_cp15_get_control() | ARM_CP15_CTRL_C);
> -static inline void
> -zynq_cache_l2_cache_disable(void)
> - if (l2cc->ctrl & L2CC_ENABLE_MASK) {
> - uint32_t ctrl;
> - /* Disable the L1 Data cache */
> - ctrl &= ~ARM_CP15_CTRL_C;
> - /* Clean and Invalidate L2 Cache */
> - zynq_cache_l2_cache_flush_entire();
> - /* Disable the L2 cache */
> - l2cc->ctrl &= ~L2CC_ENABLE_MASK;
> - /* Enable the L1 Data cache */
> -static inline void
> -_CPU_cache_enable_data(void)
> - zynq_cache_l1_cache_enable_data();
> - zynq_cache_l2_cache_enable();
> -static inline void
> -_CPU_cache_disable_data(void)
> - zynq_cache_l1_cache_disable_data();
> - zynq_cache_l2_cache_disable();
> -static inline void
> -_CPU_cache_enable_instruction(void)
> - zynq_cache_l1_cache_enable_instruction();
> -static inline void
> -_CPU_cache_disable_instruction(void)
> - zynq_cache_l1_cache_disable_instruction();
> -static inline void
> -_CPU_cache_flush_data_range(const void *d_addr, size_t n_bytes)
> - for (adx &= ~(CPU_DATA_CACHE_ALIGNMENT - 1);
> - adx < end;
> - adx += CPU_DATA_CACHE_ALIGNMENT) {
> - /* Flush L1 Data cache line */
> - arm_cp15_data_cache_clean_and_invalidate_line( (const void*)adx );
> - /* Flush L2 cache line */
> - /* Wait for L1 and L2 flush to complete */
> -static inline void
> -_CPU_cache_flush_entire_data(void)
> -static inline void
> -_CPU_cache_invalidate_data_range(const void *d_addr, size_t n_bytes)
> - adx < end;
> - /* Invalidate L2 cache line */
> - /* Invalidate L1 Data cache line */
> - arm_cp15_data_cache_invalidate_line( (const void *)adx );
> - /* Wait for L1 and L2 invalidate to complete */
> -static inline void
> -_CPU_cache_invalidate_entire_data(void)
> - zynq_cache_l2_cache_invalidate_entire();
> -static inline void
> -_CPU_cache_store_data_line(const void *d_addr)
> - zynq_cache_l1_cache_store_data(d_addr);
> - zynq_cache_l2_cache_store(d_addr);
> -static inline void
> -_CPU_cache_freeze_data(void)
> - zynq_cache_l1_cache_freeze_data();
> - zynq_cache_l2_cache_freeze();
> -static inline void
> -_CPU_cache_unfreeze_data(void)
> - zynq_cache_l1_cache_unfreeze_data();
> - zynq_cache_l2_cache_unfreeze();
> -static inline void
> -_CPU_cache_invalidate_instruction_range(const void *i_addr, size_t n_bytes)
> - uint32_t adx = (uint32_t)i_addr;
> - for (adx &= ~(CPU_INSTRUCTION_CACHE_ALIGNMENT - 1);
> - adx < end;
> - adx += CPU_INSTRUCTION_CACHE_ALIGNMENT) {
> - /* Invalidate L1 I-cache line */
> - arm_cp15_instruction_cache_invalidate_line( (const void *)adx );
> -static inline void
> -_CPU_cache_invalidate_entire_instruction(void)
> -static inline void
> -_CPU_cache_freeze_instruction(void)
> - zynq_cache_l1_cache_freeze_instruction();
> -static inline void
> -_CPU_cache_unfreeze_instruction(void)
> - zynq_cache_l1_cache_unfreeze_instruction();
> -#endif /* LIBBSP_ARM_ZYNQ_CACHE__H */
> 1.7.10.4
> rtems-devel mailing list
> rtems-devel at rtems.org
