[PATCH 13/17] libchip: Add dwmac 10/100/100 network driver
Gedare Bloom
gedare at rtems.org
Wed Feb 26 19:10:13 UTC 2014
Please fix the Doxygen.
On Wed, Feb 26, 2014 at 5:52 AM, Ralf Kirchner
<ralf.kirchner at embedded-brains.de> wrote:
> c/src/libchip/Makefile.am | 11 +-
> c/src/libchip/network/README.dwmac | 25 +
> c/src/libchip/network/dwmac-1000-core.c | 240 ++
> c/src/libchip/network/dwmac-1000-dma.c | 246 ++
> .../libchip/network/dwmac-1000-ethernet-mac-ops.c | 35 +
> c/src/libchip/network/dwmac-common.h | 372 ++++
> c/src/libchip/network/dwmac-core.c | 408 ++++
> c/src/libchip/network/dwmac-core.h | 78 +
> c/src/libchip/network/dwmac-desc-com.c | 62 +
> c/src/libchip/network/dwmac-desc-com.h | 46 +
> c/src/libchip/network/dwmac-desc-enh.c | 1053 +++++++++
> c/src/libchip/network/dwmac-desc.h | 257 +++
> c/src/libchip/network/dwmac-regs.h | 515 +++++
> c/src/libchip/network/dwmac.c | 2341 ++++++++++++++++++++
> c/src/libchip/network/dwmac.h | 867 ++++++++
> c/src/libchip/preinstall.am | 4 +
> 16 Dateien geändert, 6559 Zeilen hinzugefügt(+), 1 Zeile entfernt(-)
> create mode 100644 c/src/libchip/network/README.dwmac
> create mode 100644 c/src/libchip/network/dwmac-1000-core.c
> create mode 100644 c/src/libchip/network/dwmac-1000-dma.c
> create mode 100644 c/src/libchip/network/dwmac-1000-ethernet-mac-ops.c
> create mode 100644 c/src/libchip/network/dwmac-common.h
> create mode 100644 c/src/libchip/network/dwmac-core.c
> create mode 100644 c/src/libchip/network/dwmac-core.h
> create mode 100644 c/src/libchip/network/dwmac-desc-com.c
> create mode 100644 c/src/libchip/network/dwmac-desc-com.h
> create mode 100644 c/src/libchip/network/dwmac-desc-enh.c
> create mode 100644 c/src/libchip/network/dwmac-desc.h
> create mode 100644 c/src/libchip/network/dwmac-regs.h
> create mode 100644 c/src/libchip/network/dwmac.c
> create mode 100644 c/src/libchip/network/dwmac.h
> diff --git a/c/src/libchip/Makefile.am b/c/src/libchip/Makefile.am
> index eb0d015..003c3c1 100644
> --- a/c/src/libchip/Makefile.am
> +++ b/c/src/libchip/Makefile.am
> @@ -44,11 +44,20 @@ libnetchip_a_SOURCES = network/cs8900.c network/dec21140.c network/i82586.c \
> libnetchip_a_SOURCES += network/greth.c
> include_libchip_HEADERS += network/smc91111.h network/smc91111exp.h
> libnetchip_a_SOURCES += network/smc91111.c network/smc91111config.h
> +include_libchip_HEADERS += network/dwmac.h
> +libnetchip_a_SOURCES += \
> + network/dwmac-1000-core.c \
> + network/dwmac-1000-dma.c \
> + network/dwmac-1000-ethernet-mac-ops.c \
> + network/dwmac-core.c \
> + network/dwmac-desc-com.c \
> + network/dwmac-desc-enh.c \
> + network/dwmac.c
> endif
> EXTRA_DIST += network/README network/README.cs8900 network/README.dec21140 \
> network/README.i82586 network/README.open_eth network/README.sonic \
> - network/cs8900.c.bsp network/README.tulipclone
> + network/cs8900.c.bsp network/README.tulipclone network/README.dwmac
> # rtc
> include_libchip_HEADERS += rtc/rtc.h rtc/icm7170.h rtc/m48t08.h \
> diff --git a/c/src/libchip/network/README.dwmac b/c/src/libchip/network/README.dwmac
> new file mode 100644
> index 0000000..4fd1622
> --- /dev/null
> +++ b/c/src/libchip/network/README.dwmac
> @@ -0,0 +1,25 @@
> +About
> +The dwmac* files implement libchip driver for the DWMAC 10/100/1000
> +ethernet MAC. The DWMAC 10/100/1000 ethernet MAC is a Synopsys IP core.
> +Target Support
> +The target is required to provide the low level support routines as
> +listed in the Configuration section of this file.
> +The file cs8900.[ch].bsp are an example BSP files for DIMMPC target.
> +Conditionals
> +None
> +Todo
> ++ Add support for DWMAC 10/100. currently only support for DWMAC 1000
> + is implemented
> +Configuration
> +See the dwmac.h header file for the documentation.
> \ No newline at end of file
> diff --git a/c/src/libchip/network/dwmac-1000-core.c b/c/src/libchip/network/dwmac-1000-core.c
> index 0000000..f754d34
> --- /dev/null
> +++ b/c/src/libchip/network/dwmac-1000-core.c
> @@ -0,0 +1,240 @@
> + * @file dwmac-1000-core.c
> + * @ingroup [GROUP NAME]
> + * @brief DWMAC 1000 on-chip Ethernet controllers Core Handling
> + * Functions and data which are specific to the DWMAC 1000 Core Handling.
> + * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
> + * embedded brains GmbH
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> + * <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#include <assert.h>
> +#include "dwmac-core.h"
> +#include "dwmac-common.h"
> +#define DWMAC_1000_CORE_DEBUG
> +//#undef DWMAC_1000_CORE_DEBUG
> +#ifdef DWMAC_1000_CORE_DEBUG
> +#define DWMAC_1000_CORE_PRINT_DBG( fmt, args ... ) printk( fmt, ## args )
> +#else
> +#define DWMAC_1000_CORE_PRINT_DBG( fmt, args ... ) do { } while ( 0 )
> +#endif
> +#define DWMAC_1000_CORE_INIT \
> + ( MACGRP_MAC_CONFIGURATION_JD \
> + | MACGRP_MAC_CONFIGURATION_BE ) \
> + & ~MACGRP_MAC_CONFIGURATION_PS \
> +#define DWMAC_1000_CORE_HASH_TABLE_SIZE 256
> +static volatile uint32_t *dwmac_1000_core_get_mac_addr_low(
> + dwmac_common_context *self,
> + const unsigned int mac_addr_index )
> + volatile uint32_t *addr = NULL;
> + assert( self != NULL );
> + assert( mac_addr_index <= 127 );
> + if ( mac_addr_index > 15 ) {
> + addr = &self->macgrp->mac_addr16_127[mac_addr_index].low;
> + } else {
> + addr = &self->macgrp->mac_addr0_15[mac_addr_index].low;
> + return addr;
> +static volatile uint32_t *dwmac_1000_core_get_mac_addr_high(
> + addr = &self->macgrp->mac_addr16_127[mac_addr_index].high;
> + } else {
> + addr = &self->macgrp->mac_addr0_15[mac_addr_index].high;
> + return addr;
> +static void dwmac_1000_core_init( dwmac_common_context *self )
> + uint32_t value = self->macgrp->mac_configuration;
> + value |= DWMAC_1000_CORE_INIT;
> + if ( ( self->dmagrp->hw_feature & DMAGRP_HW_FEATURE_RXTYP1COE ) != 0
> + || ( self->dmagrp->hw_feature & DMAGRP_HW_FEATURE_RXTYP2COE ) != 0 ) {
> + /* Enable RX checksum calculation offload to hardware */
> + value |= MACGRP_MAC_CONFIGURATION_IPC;
> + /* No Jumbo- or Giant frames. The network stack does not support them */
> + value &= ~MACGRP_MAC_CONFIGURATION_JE;
> + value &= ~MACGRP_MAC_CONFIGURATION_TWOKPE;
> + self->macgrp->mac_configuration = value;
> + /* Mask GMAC interrupts */
> + self->macgrp->interrupt_mask =
> + MACGRP_INTERRUPT_MASK_RGSMIIIM
> + | MACGRP_INTERRUPT_MASK_PCSLCHGIM
> + | MACGRP_INTERRUPT_MASK_PCSANCIM
> + | MACGRP_INTERRUPT_MASK_TSIM;
> + /* mask out interrupts because we don't handle them yet */
> + self->macgrp->mmc_receive_interrupt_mask = ( uint32_t ) ~0L;
> + self->macgrp->mmc_transmit_interrupt_mask = ( uint32_t ) ~0L;
> + self->macgrp->mmc_ipc_receive_interrupt_mask = ( uint32_t ) ~0L;
> +static void dwmac_1000_core_set_umac_addr(
> + const uint8_t *addr,
> + unsigned int reg_n )
> + dwmac_core_set_mac_addr(
> + addr,
> + dwmac_1000_core_get_mac_addr_high( self, reg_n ),
> + dwmac_1000_core_get_mac_addr_low( self, reg_n )
> +static void dwmac_1000_core_set_hash_filter(
> + const bool add,
> + struct ifreq *ifr )
> + int eno = 0;
> + struct arpcom *ac = &self->arpcom;
> + if ( add ) {
> + eno = ether_addmulti( ifr, ac );
> + } else {
> + eno = ether_delmulti( ifr, ac );
> + if ( eno == ENETRESET ) {
> + struct ether_multistep step;
> + struct ether_multi *enm;
> + unsigned int num_multi = 0;
> + unsigned int index;
> + ETHER_FIRST_MULTI( step, ac, enm );
> + while ( enm != NULL ) {
> + /* Find out how many multicast addresses we have to handle */
> + uint64_t addrlo = 0;
> + uint64_t addrhi = 0;
> + memcpy( &addrlo, enm->enm_addrlo, ETHER_ADDR_LEN );
> + memcpy( &addrhi, enm->enm_addrhi, ETHER_ADDR_LEN );
> + num_multi += 1U + (uint32_t) ( addrhi - addrlo );
> + if ( num_multi > DWMAC_1000_CORE_HASH_TABLE_SIZE ) {
> + /* Too many addresses to be hashed, Use the
> + * pass all multi option instead */
> + for ( index = 0; index < 8; ++index ) {
> + self->macgrp->hash_table_reg[index] = 0xffffffff;
> + self->macgrp->mac_frame_filter |= MACGRP_MAC_FRAME_FILTER_PM;
> + } else if ( num_multi > 0 ) {
> + uint32_t hash_shadow[8] = {0, 0, 0, 0, 0, 0, 0, 0};
> + while ( addrlo <= addrhi ) {
> + /* XXX: ether_crc32_le() does not work, why? */
> + uint32_t crc = ether_crc32_be( (uint8_t *) &addrlo, ETHER_ADDR_LEN );
> + /* The upper 8 bits of the bit reversed 32 bit CRC are used for hash filtering.
> + * The most significant bits determine the register to be used and the
> + * least significant five bits determine which bit to be set within the register */
> + uint32_t index_reg = ( crc >> 29 ) & 0x7;
> + uint32_t index_bit = ( crc >> 24 ) & 0x1f;
> + hash_shadow[index_reg] |= 1U << index_bit;
> + ++addrlo;
> + ETHER_NEXT_MULTI( step, enm );
> + self->macgrp->hash_table_reg[index] = hash_shadow[index];
> + /* Hash filter for multicast */
> + self->macgrp->mac_frame_filter |= MACGRP_MAC_FRAME_FILTER_HMC;
> + } else {
> + /* Set all hash registers to accect to accept no multicast packets */
> + self->macgrp->hash_table_reg[index] = 0x00000000;
> + DWMAC_1000_CORE_PRINT_DBG(
> + "Frame Filter reg: 0x%08x\n",
> + "Hash regs:\n"
> + "0x%08x\n"
> + "0x%08x\n"
> + "0x%08x\n"
> + "0x%08x\n"
> + "0x%08x\n"
> + "0x%08x\n"
> + "0x%08x\n"
> + "0x%08x\n",
> + self->macgrp->hash_table_reg[0],
> + self->macgrp->hash_table_reg[1],
> + self->macgrp->hash_table_reg[2],
> + self->macgrp->hash_table_reg[3],
> + self->macgrp->hash_table_reg[4],
> + self->macgrp->hash_table_reg[5],
> + self->macgrp->hash_table_reg[6],
> + self->macgrp->hash_table_reg[7]
> +const dwmac_common_core_ops dwmac_core_ops_1000 = {
> + .core_init = dwmac_1000_core_init,
> + .set_hash_filter = dwmac_1000_core_set_hash_filter,
> + .set_umac_addr = dwmac_1000_core_set_umac_addr,
> diff --git a/c/src/libchip/network/dwmac-1000-dma.c b/c/src/libchip/network/dwmac-1000-dma.c
> index 0000000..660f681
> --- /dev/null
> +++ b/c/src/libchip/network/dwmac-1000-dma.c
> @@ -0,0 +1,246 @@
> + * @file dwmac-1000-dma.c
> + * @brief DWMAC 1000 on-chip Ethernet controllers DMA handling
> + * Functions and data which are specific to the DWMAC 1000 DMA Handling.
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#include <errno.h>
> +typedef enum {
> + DWMAC100_OPERATION_MODE_TTC_CONTROL_64 = 0x00000000,
> + DWMAC100_OPERATION_MODE_TTC_CONTROL_128 = 0x00004000,
> + DWMAC100_OPERATION_MODE_TTC_CONTROL_192 = 0x00008000,
> + DWMAC100_OPERATION_MODE_TTC_CONTROL_256 = 0x0000c000,
> + DWMAC100_OPERATION_MODE_TTC_CONTROL_40 = 0x00010000,
> + DWMAC100_OPERATION_MODE_TTC_CONTROL_32 = 0x00014000,
> + DWMAC100_OPERATION_MODE_TTC_CONTROL_24 = 0x00018000,
> + DWMAC100_OPERATION_MODE_TTC_CONTROL_16 = 0x0001c000,
> +} dwmac1000_operation_mode_ttc_control;
> +typedef enum {
> + DWMAC100_OPERATION_MODE_RTC_CONTROL_64 = 0x00000000,
> + DWMAC100_OPERATION_MODE_RTC_CONTROL_32 = 0x00000008,
> + DWMAC100_OPERATION_MODE_RTC_CONTROL_96 = 0x00000010,
> + DWMAC100_OPERATION_MODE_RTC_CONTROL_128 = 0x00000018,
> +} dwmac1000_operation_mode_rtc_control;
> +static int dwmac1000_dma_init(
> + const uint32_t pbl,
> + const uint32_t fb,
> + const uint32_t mb,
> + const bool use_enhanced_desc,
> + const uint32_t burst_len_4_support,
> + const uint32_t burst_len_8_support,
> + const uint32_t burst_len_16_support,
> + const uint32_t burst_boundary,
> + volatile dwmac_desc *dma_tx,
> + volatile dwmac_desc *dma_rx )
> + int eno = 0;
> + uint32_t value = self->dmagrp->bus_mode;
> + int limit = 10;
> + /* DMA SW reset */
> + value |= DMAGRP_BUS_MODE_SWR;
> + self->dmagrp->bus_mode = value;
> + while ( limit-- ) {
> + if ( !( self->dmagrp->bus_mode & DMAGRP_BUS_MODE_SWR ) )
> + break;
> + rtems_task_wake_after( rtems_clock_get_ticks_per_second() / 100 );
> + if ( limit < 0 ) {
> + eno = EBUSY;
> + } else {
> + * Set the DMA PBL (Programmable Burst Length) mode
> + if ( pbl >= DWMAC_DMA_CFG_BUS_MODE_BURST_LENGTH_8 ) {
> + value =
> + DMAGRP_BUS_MODE_PBL( ( pbl + 1 ) / 8 ) | DMAGRP_BUS_MODE_RPBL(
> + ( pbl + 1 ) / 8 ) | DMAGRP_BUS_MODE_EIGHTXPBL;
> + } else {
> + value = DMAGRP_BUS_MODE_PBL( pbl + 1 ) | DMAGRP_BUS_MODE_RPBL( pbl + 1 );
> + /* Set the Fixed burst mode */
> + if ( fb ) {
> + value |= DMAGRP_BUS_MODE_FB;
> + /* Mixed Burst has no effect when fb is set */
> + if ( mb ) {
> + value |= DMAGRP_BUS_MODE_MB;
> + if ( use_enhanced_desc ) {
> + value |= DMAGRP_BUS_MODE_ATDS;
> + /* In case of GMAC AXI configuration, program the DMA_AXI_BUS_MODE
> + * for supported bursts.
> + * Note: This is applicable only for revision GMACv3.61a. For
> + * older version this register is reserved and shall have no
> + * effect.
> + * Note:
> + * For Fixed Burst Mode: if we directly write 0xFF to this
> + * register using the configurations pass from platform code,
> + * this would ensure that all bursts supported by core are set
> + * and those which are not supported would remain ineffective.
> + * For Non Fixed Burst Mode: provide the maximum value of the
> + * burst length. Any burst equal or below the provided burst
> + * length would be allowed to perform. */
> + value = self->dmagrp->axi_bus_mode;
> + if ( burst_len_4_support ) {
> + value |= DMAGRP_AXI_BUS_MODE_BLEND4;
> + } else {
> + value &= ~DMAGRP_AXI_BUS_MODE_BLEND4;
> + if ( burst_len_8_support ) {
> + value |= DMAGRP_AXI_BUS_MODE_BLEND8;
> + } else {
> + value &= ~DMAGRP_AXI_BUS_MODE_BLEND8;
> + if ( burst_len_16_support ) {
> + value |= DMAGRP_AXI_BUS_MODE_BLEND16;
> + } else {
> + value &= ~DMAGRP_AXI_BUS_MODE_BLEND16;
> + if ( burst_boundary ) {
> + value |= DMAGRP_AXI_BUS_MODE_ONEKBBE;
> + } else {
> + value &= ~DMAGRP_AXI_BUS_MODE_ONEKBBE;
> + self->dmagrp->axi_bus_mode = value;
> + /* Mask interrupts by writing to CSR7 */
> + dwmac_core_enable_dma_irq_rx( self );
> + dwmac_core_enable_dma_irq_tx( self );
> + /* The base address of the RX/TX descriptor lists must be written into
> + * DMA CSR3 and CSR4, respectively. */
> + self->dmagrp->transmit_descr_list_addr = (uintptr_t) &dma_tx[0];
> + self->dmagrp->receive_descr_list_addr = (uintptr_t) &dma_rx[0];
> + return eno;
> +static void dwmac1000_dma_operation_mode(
> + const unsigned int txmode,
> + const unsigned int rxmode )
> + uint32_t value = self->dmagrp->operation_mode;
> + if ( txmode == DWMAC_COMMON_DMA_MODE_STORE_AND_FORWARD ) {
> + /* Transmit COE type 2 cannot be done in cut-through mode. */
> + value |= DMAGRP_OPERATION_MODE_TSF;
> + /* Operating on second frame increase the performance
> + * especially when transmit store-and-forward is used.*/
> + value |= DMAGRP_OPERATION_MODE_OSF;
> + } else {
> + value &= ~DMAGRP_OPERATION_MODE_TSF;
> + value &= ~DMAGRP_OPERATION_MODE_TTC_GET( value );
> + /* Set the transmit threshold */
> + if ( txmode <= 32 ) {
> + value |= DMAGRP_OPERATION_MODE_TTC_SET(
> + value,
> + } else if ( txmode <= 64 ) {
> + value = DMAGRP_OPERATION_MODE_TTC_SET(
> + value,
> + } else if ( txmode <= 128 ) {
> + value,
> + } else if ( txmode <= 192 ) {
> + value,
> + } else {
> + value,
> + if ( rxmode == DWMAC_COMMON_DMA_MODE_STORE_AND_FORWARD ) {
> + value |= DMAGRP_OPERATION_MODE_RSF;
> + } else {
> + value &= ~DMAGRP_OPERATION_MODE_RSF;
> + value &= DMAGRP_OPERATION_MODE_RTC_GET( value );
> + if ( rxmode <= 32 ) {
> + value = DMAGRP_OPERATION_MODE_RTC_SET(
> + value,
> + } else if ( rxmode <= 64 ) {
> + value,
> + } else if ( rxmode <= 96 ) {
> + value,
> + } else {
> + value,
> + self->dmagrp->operation_mode = value;
> +const dwmac_common_dma_ops dwmac_dma_ops_1000 = {
> + .init = dwmac1000_dma_init,
> + .dma_mode = dwmac1000_dma_operation_mode,
> diff --git a/c/src/libchip/network/dwmac-1000-ethernet-mac-ops.c b/c/src/libchip/network/dwmac-1000-ethernet-mac-ops.c
> index 0000000..00bc71d
> --- /dev/null
> +++ b/c/src/libchip/network/dwmac-1000-ethernet-mac-ops.c
> @@ -0,0 +1,35 @@
> + * @file dwmac-1000-ethernet-mac-ops.c
> + * @brief Operations for the dwmac 1000 ethernet mac
> + * DWMAC_1000_ETHERNET_MAC_OPS will be accessible in the API header and can be
> + * passed to the configuration data if handling a DWMAC 1000 driver
> + * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +extern const dwmac_common_dma_ops dwmac_dma_ops_1000;
> +extern const dwmac_common_core_ops dwmac_core_ops_1000;
> +const dwmac_ethernet_mac_ops DWMAC_1000_ETHERNET_MAC_OPS =
> + DWMAC_ETHERNET_MAC_OPS_INITIALIZER(
> + &dwmac_core_ops_1000,
> + &dwmac_dma_ops_1000
> diff --git a/c/src/libchip/network/dwmac-common.h b/c/src/libchip/network/dwmac-common.h
> index 0000000..983b4ff
> --- /dev/null
> +++ b/c/src/libchip/network/dwmac-common.h
> @@ -0,0 +1,372 @@
> + * @file dwmac_common.h
> + * @brief [SHORT DESCRIPTION OF MODULE]
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> + * http://www.rtems./license/LICENSE.
> +#ifndef DWMAC_COMMON_H_
> +#define DWMAC_COMMON_H_
> +#define __INSIDE_RTEMS_BSD_TCPIP_STACK__ 1
> +#define __BSD_VISIBLE 1
> +#include <stdint.h>
> +#include <rtems.h>
> +#include <rtems/rtems_bsdnet.h>
> +#include <rtems/rtems_mii_ioctl.h>
> +#include <sys/param.h>
> +#include <sys/socket.h>
> +#include <sys/sockio.h>
> +#include <sys/mbuf.h>
> +#include <net/if.h>
> +#include <net/if_arp.h>
> +#include <netinet/in.h>
> +#include <netinet/if_ether.h>
> +#include <netinet/in_systm.h>
> +#include <netinet/ip.h>
> +#include <libchip/dwmac.h>
> +#include "dwmac-desc.h"
> +#include "dwmac-regs.h"
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> +#define DWMAC_COMMON_DMA_MODE_STORE_AND_FORWARD 1 /* DMA STORE-AND-FORWARD Operation Mode */
> +/* Events */
> +/* Common task events */
> +#define DWMAC_COMMON_EVENT_TASK_INIT RTEMS_EVENT_1
> +#define DWMAC_COMMON_EVENT_TASK_STOP RTEMS_EVENT_2
> +/* Events for the transmit task */
> +#define DWMAC_COMMON_EVENT_TX_TRANSMIT_FRAME RTEMS_EVENT_3
> +#define DWMAC_COMMON_EVENT_TX_FRAME_TRANSMITTED RTEMS_EVENT_4
> +#define DWMAC_COMMON_EVENT_TX_BUMP_UP_DMA_THRESHOLD RTEMS_EVENT_5
> +#define DWMAC_COMMON_EVENT_TX_PHY_STATUS_CHANGE RTEMS_EVENT_6
> +/* Events for the receive task */
> +#define DWMAC_COMMON_EVENT_RX_FRAME_RECEIVED RTEMS_EVENT_3
> +/* Foreward declarations */
> +typedef struct dwmac_common_core_ops dwmac_common_core_ops;
> +typedef struct dwmac_common_dma_ops dwmac_common_dma_ops;
> +typedef struct dwmac_common_desc_ops dwmac_common_desc_ops;
> +typedef enum { /* IPC status */
> + DWMAC_COMMON_RX_FRAME_STATUS_GOOD,
> + DWMAC_COMMON_RX_FRAME_STATUS_DISCARD,
> + DWMAC_COMMON_RX_FRAME_STATUS_CSUM_NONE,
> + DWMAC_COMMON_RX_FRAME_STATUS_LLC_SNAP
> +} dwmac_common_rx_frame_status;
> +typedef enum {
> + DWMAC_COMMON_STATE_DOWN,
> + DWMAC_COMMON_STATE_UP,
> + DWMAC_COMMON_STATE_COUNT
> +} dwmac_common_state;
> +typedef struct {
> + uint32_t link_down;
> + uint32_t link_up;
> +} dwmac_common_phy_status_counts;
> +typedef struct {
> + uint32_t receive;
> + uint32_t transmit;
> + uint32_t tx_underflow;
> + uint32_t tx_jabber;
> + uint32_t rx_overflow;
> + uint32_t rx_early;
> + uint32_t rx_buf_unav;
> + uint32_t rx_process_stopped;
> + uint32_t rx_watchdog;
> + uint32_t tx_early;
> + uint32_t tx_buf_unav;
> + uint32_t tx_process_stopped;
> + uint32_t fatal_bus_error;
> + uint32_t unhandled;
> +} dwmac_common_dma_irq_counts;
> +typedef struct {
> + uint32_t dest_addr_fail; /* When set, this bit indicates a frame that failed in the DA Filter in the MAC. */
> + uint32_t crc_error; /* When set, this bit indicates that a CRC error occurred on the received frame. This field is valid only when the Last
> + Descriptor (RDES0[8]) is set. */
> + uint32_t receive_error; /* When set, this bit indicates that the gmii_rxer_i signal is asserted while gmii_rxdv_i is asserted during frame
> + reception. Error can be of less or no extension, or error (rxd !=0xf) during extension. */
> + uint32_t watchdog_timeout; /* When set, this bit indicates that the receive Watchdog Timer has expired while receiving the current frame and the
> + current frame is truncated after the Watchdog Timeout. */
> + uint32_t late_collision; /* When set, this bit indicates that a late collision has occurred while receiving the frame in the half-duplex mode. */
> + uint32_t giant_frame; /* When advanced timestamp feature is present, when set, this bit indicates that a snapshot of the Timestamp is
> + written in descriptor words 6 (RDES6) and 7 (RDES7). This is valid only when the Last Descriptor bit (RDES0[8]) is
> + set.
> + When IP Checksum Engine (Type 1) is selected, this bit, when set, indicates that the 16-bit IPv4 Header checksum
> + calculated by the EMAC did not match the received checksum bytes.
> + Otherwise, this bit, when set, indicates the Giant frame Status. Giant frames are larger than 1,518-byte (or
> + 1,522-byte for VLAN or 2,000-byte when Bit 27 (2KPE) of MAC Configuration register is set) normal frames and
> + larger than 9,018-byte (9,022-byte for VLAN) frame when Jumbo frame processing is enabled. */
> + uint32_t overflow_error; /* When set, this bit indicates that the received frame was damaged because of buffer overflow in MTL.
> + Note: This bit is set only when the DMA transfers a partial frame to the application. This happens only when the RX
> + FIFO buffer is operating in the threshold mode. In the store-and-forward mode, all partial frames are dropped
> + completely in RX FIFO buffer. */
> + uint32_t descriptor_error; /* When set, this bit indicates a frame truncation caused by a frame that does not fit within the current descriptor
> + buffers, and that the DMA does not own the Next descriptor. The frame is truncated. This field is valid only when the
> + Last Descriptor (RDES0[8]) is set. */
> + uint32_t source_addr_fail; /* When set, this bit indicates that the SA field of frame failed the SA Filter in the MAC. */
> + uint32_t length_error; /* When set, this bit indicates that the actual length of the frame received and that the Length/ Type field does not
> + match. This bit is valid only when the Frame Type (RDES0[5]) bit is reset. */
> + uint32_t vlan_tag; /* When set, this bit indicates that the frame to which this descriptor is pointing is a VLAN frame tagged by the MAC.
> + The VLAN tagging depends on checking the VLAN fields of received frame based on the Register 7 (VLAN Tag
> + Register) setting. */
> + uint32_t ethernet_frames; /* When set, this bit indicates that the receive frame is an Ethernet-type frame (the LT field is greater than or equal to
> + 0x0600). When this bit is reset, it indicates that the received frame is an IEEE802.3 frame. This bit is not valid for
> + Runt frames less than 14 bytes. */
> + uint32_t dribble_bit_error; /* When set, this bit indicates that the received frame has a non-integer multiple of bytes (odd nibbles). This bit is valid
> + only in the MII Mode. */
> +} dwmac_common_desc_status_counts_rx;
> +typedef struct {
> + uint32_t jabber; /* When set, this bit indicates the MAC transmitter has experienced a jabber time-out. This bit is only set when Bit 22
> + (Jabber Disable) of Register 0 (MAC Configuration Register) is not set. */
> + uint32_t frame_flushed; /* When set, this bit indicates that the DMA or MTL flushed the frame because of a software Flush command given by
> + the CPU. */
> + uint32_t losscarrier; /* When set, this bit indicates that a loss of carrier occurred during frame transmission (that is, the gmii_crs_i
> + signal was inactive for one or more transmit clock periods during frame transmission). This is valid only for the
> + frames transmitted without collision when the MAC operates in the half-duplex mode. */
> + uint32_t no_carrier; /* When set, this bit indicates that the Carrier Sense signal form the PHY was not asserted during transmission. */
> + uint32_t excessive_collisions; /* When set, this bit indicates that the transmission was aborted after 16 successive collisions while attempting to
> + transmit the current frame. If Bit 9 (Disable Retry) bit in the Register 0 (MAC Configuration Register) is set, this bit
> + is set after the first collision, and the transmission of the frame is aborted. */
> + uint32_t excessive_deferral; /* When set, this bit indicates that the transmission has ended because of excessive deferral of over 24,288 bit times
> + (155,680 bits times in 1,000-Mbps mode or if Jumbo frame is enabled) if Bit 4 (Deferral Check) bit in Register 0
> + (MAC Configuration Register) is set high. */
> + uint32_t underflow; /* When set, this bit indicates that the MAC aborted the frame because the data arrived late from the Host memory.
> + Underflow Error indicates that the DMA encountered an empty transmit buffer while transmitting the frame. The
> + transmission process enters the Suspended state and sets both Transmit Underflow (Register 5[5]) and Transmit
> + Interrupt (Register 5[0]). */
> + uint32_t ip_header_error; /* When set, this bit indicates that the MAC transmitter detected an error in the IP datagram header. The transmitter
> + checks the header length in the IPv4 packet against the number of header bytes received from the application and
> + indicates an error status if there is a mismatch. For IPv6 frames, a header error is reported if the main header length
> + is not 40 bytes. Furthermore, the Ethernet Length/Type field value for an IPv4 or IPv6 frame must match the IP
> + header version received with the packet. For IPv4 frames, an error status is also indicated if the Header Length field
> + has a value less than 0x5. */
> + uint32_t payload_error; /* When set, this bit indicates that MAC transmitter detected an error in the TCP, UDP, or ICMP IP datagram payload.
> + The transmitter checks the payload length received in the IPv4 or IPv6 header against the actual number of TCP,
> + UDP, or ICMP packet bytes received from the application and issues an error status in case of a mismatch. */
> + uint32_t deferred; /* When set, this bit indicates that the MAC defers before transmission because of the presence of carrier. This bit is
> + valid only in the half-duplex mode. */
> + uint32_t vlan; /* When set, this bit indicates that the transmitted frame is a VLAN-type frame. */
> +} dwmac_common_desc_status_counts_tx;
> +typedef struct {
> + uint32_t errors; /* Frames with errors */
> + uint32_t dropped; /* Frames dropped */
> + uint32_t frames_good; /* Frames passed to the network stack */
> + uint32_t bytes_good; /* Sum of bytes passed to the network stack */
> + uint32_t frames; /* Frames handled (good or bad) */
> + uint32_t dma_suspended; /* The receive DMA was supended due to lack of descriptors */
> +} dwmac_common_rx_frame_counts;
> +typedef struct {
> + uint32_t frames_from_stack; /* Frames received from the network stack fro tranmission */
> + uint32_t frames_to_dma; /* Number of frames transmitted to DMA */
> + uint32_t packets_to_dma; /* Number of packets transmitted to DMA*/
> + uint32_t bytes_to_dma; /* Number of bytes transmitted */
> + uint32_t packet_errors; /* Packets with errors */
> + uint32_t packets_tranmitted_by_DMA; /* Packets tranmitted by the DMA */
> +} dwmac_common_tx_frame_counts;
> +typedef struct {
> + dwmac_common_phy_status_counts phy_status_counts;
> + dwmac_common_dma_irq_counts dma_irq_counts;
> + dwmac_common_desc_status_counts_rx desc_status_counts_rx;
> + dwmac_common_desc_status_counts_tx desc_status_counts_tx;
> + dwmac_common_rx_frame_counts frame_counts_rx;
> + dwmac_common_tx_frame_counts frame_counts_tx;
> +} dwmac_common_stats;
> +typedef struct {
> + struct arpcom arpcom;
> + struct rtems_bsdnet_ifconfig *bsd_config;
> + struct rtems_mdio_info mdio;
> + rtems_id task_id_rx;
> + rtems_id task_id_tx;
> + rtems_id task_id_control;
> + void *arg;
> + volatile macgrp *macgrp;
> + volatile dmagrp *dmagrp;
> + unsigned int csr_clock;
> + dwmac_common_state state;
> + dwmac_common_stats stats;
> + unsigned int dma_threshold_control;
> + volatile dwmac_desc *dma_tx;
> + volatile dwmac_desc *dma_rx;
> + unsigned int idx_rx;
> + struct mbuf **mbuf_addr_rx;
> + struct mbuf **mbuf_addr_tx;
> + const dwmac_cfg *CFG;
> +} dwmac_common_context;
> +struct dwmac_common_core_ops {
> + /* MAC core initialization */
> + void (*core_init) ( dwmac_common_context *self );
> + /* Multicast filter setting */
> + void (*set_hash_filter) (
> + const bool add,
> + struct ifreq *ifr );
> + /* Set/Get Unicast MAC addresses */
> + void (*set_umac_addr) (
> + dwmac_common_context *ioaddr,
> + const unsigned char *addr,
> + const unsigned int reg_n );
> +struct dwmac_common_dma_ops {
> + /* DMA core initialization */
> + int (*init) (
> + volatile dwmac_desc *dma_rx );
> + /* Set tx/rx threshold in the csr6 register
> + * An invalid value enables the store-and-forward mode */
> + void (*dma_mode) (
> + const unsigned int rxmode );
> +struct dwmac_common_desc_ops {
> + /* Verify that it is OK to use the selected descriptor operations */
> + int (*validate) ( dwmac_common_context *self );
> + bool (*use_enhanced_descs) ( dwmac_common_context *self );
> + /* DMA RX descriptor ring allocation */
> + int (*create_rx_desc) ( dwmac_common_context *self );
> + /* DMA TX descriptor ring allocation */
> + int (*create_tx_desc) ( dwmac_common_context *self );
> + /* Free DMA RX descriptor ring */
> + int (*destroy_rx_desc) ( dwmac_common_context *self );
> + /* Free DMA TX descriptor ring */
> + int (*destroy_tx_desc) ( dwmac_common_context *self );
> + /* DMA RX descriptor initialization */
> + void (*init_rx_desc) (
> + const unsigned int index );
> + /* DMA TX descriptor ring initialization */
> + void (*init_tx_desc) ( dwmac_common_context *self );
> + /* Free rx data buffers */
> + void (*release_rx_bufs) ( dwmac_common_context *self );
> + /* Allocate a data buffer */
> + struct mbuf *(*alloc_data_buf)( dwmac_common_context *self );
> + /* Free tx data buffers */
> + void (*release_tx_bufs) ( dwmac_common_context *self );
> + /* Invoked by the xmit function to prepare the tx descriptor */
> + void (*prepare_tx_desc) (
> + const unsigned int idx,
> + const bool is_first,
> + const size_t len,
> + const void *pdata );
> + /* Set/get the owner of the descriptor */
> + void (*release_tx_ownership) (
> + const unsigned int idx_tx );
> + bool (*am_i_tx_owner) (
> + /* Invoked by the xmit function to close the tx descriptor */
> + void (*close_tx_desc) (
> + /* Clean the tx descriptor as soon as the tx irq is received */
> + void (*release_tx_desc) (
> + /* Last tx segment reports the transmit status */
> + int (*get_tx_ls) (
> + /* Return the transmit status looking at the TDES1 */
> + int (*tx_status) (
> + /* Handle extra events on specific interrupts hw dependent */
> + bool (*am_i_rx_owner) (
> + const unsigned int desc_idx );
> + /* Get the receive frame size */
> + size_t (*get_rx_frame_len) (
> + /* Return the reception status looking at the RDES1 */
> + dwmac_common_rx_frame_status (*rx_status) (
> + bool (*is_first_rx_segment) (
> + const unsigned int descriptor_index );
> + bool (*is_last_rx_segment) (
> + void (*print_tx_desc) (
> + volatile dwmac_desc *p,
> + const unsigned int count );
> + void (*print_rx_desc) (
> +#ifdef __cplusplus
> +#endif /* DWMAC_COMMON_H_ */
> diff --git a/c/src/libchip/network/dwmac-core.c b/c/src/libchip/network/dwmac-core.c
> index 0000000..93b6347
> --- /dev/null
> +++ b/c/src/libchip/network/dwmac-core.c
> @@ -0,0 +1,408 @@
> + * @file dwmac-lib.c
> + * @brief DWMAC 10/100/1000 Network Interface Controllers Core Handling
> + * DWMAC 10/100/1000 on-chip Synopsys IP Ethernet controllers.
> + * Driver core handling.
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#undef DWMAC_CORE_DEBUG
> +#ifdef DWMAC_CORE_DEBUG
> +#define DWMAC_CORE_PRINT_DBG( fmt, args ... ) printk( fmt, ## args )
> +#else
> +#define DWMAC_CORE_PRINT_DBG( fmt, args ... ) do { } while ( 0 )
> +#endif
> +/* DMA default interrupt masks */
> +#define DWMAC_CORE_INTR_ENABLE_DEFAULT_MASK_RX \
> + DMAGRP_INTERRUPT_ENABLE_NIE \
> + | DMAGRP_INTERRUPT_ENABLE_RIE \
> +#define DWMAC_CORE_INTR_ENABLE_DEFAULT_MASK_TX \
> + | DMAGRP_INTERRUPT_ENABLE_TIE \
> + | DMAGRP_INTERRUPT_ENABLE_FBE \
> + | DMAGRP_INTERRUPT_ENABLE_UNE \
> + | DMAGRP_INTERRUPT_ENABLE_AIE \
> +#define DWMAC_CORE_INTR_STATUS_DEFAULT_MASK_RX \
> + DMAGRP_STATUS_NIS \
> + | DMAGRP_STATUS_RI \
> +#define DWMAC_CORE_INTR_STATUS_DEFAULT_MASK_TX \
> + | DMAGRP_STATUS_TI \
> + | DMAGRP_STATUS_FBI \
> + | DMAGRP_STATUS_UNF \
> + | DMAGRP_STATUS_AIS \
> +/* CSR1 enables the transmit DMA to check for new descriptor */
> +void dwmac_core_dma_restart_tx( dwmac_common_context *self )
> + self->dmagrp->transmit_poll_demand = 1;
> +void dwmac_core_enable_dma_irq_tx( dwmac_common_context *self )
> + self->dmagrp->interrupt_enable |= DWMAC_CORE_INTR_ENABLE_DEFAULT_MASK_TX;
> +void dwmac_core_enable_dma_irq_rx( dwmac_common_context *self )
> + self->dmagrp->interrupt_enable |= DWMAC_CORE_INTR_ENABLE_DEFAULT_MASK_RX;
> +void dwmac_core_disable_dma_irq_tx( dwmac_common_context *self )
> + self->dmagrp->interrupt_enable &= ~DWMAC_CORE_INTR_ENABLE_DEFAULT_MASK_TX;
> +void dwmac_core_reset_dma_irq_status_tx( dwmac_common_context *self )
> + self->dmagrp->status = DWMAC_CORE_INTR_STATUS_DEFAULT_MASK_TX;
> +void dwmac_core_reset_dma_irq_status_rx( dwmac_common_context *self )
> + self->dmagrp->status = DWMAC_CORE_INTR_STATUS_DEFAULT_MASK_RX;
> +void dwmac_core_disable_dma_irq_rx( dwmac_common_context *self )
> + self->dmagrp->interrupt_enable &= ~DWMAC_CORE_INTR_ENABLE_DEFAULT_MASK_RX;
> +void dwmac_core_dma_start_tx( dwmac_common_context *self )
> + self->dmagrp->operation_mode |= DMAGRP_OPERATION_MODE_ST;
> +void dwmac_core_dma_stop_tx( dwmac_common_context *self )
> + self->dmagrp->operation_mode &= ~DMAGRP_OPERATION_MODE_ST;
> +void dwmac_core_dma_start_rx( dwmac_common_context *self )
> + self->dmagrp->operation_mode |= DMAGRP_OPERATION_MODE_SR;
> +void dwmac_core_dma_stop_rx( dwmac_common_context *self )
> + self->dmagrp->operation_mode &= ~DMAGRP_OPERATION_MODE_SR;
> +void dwmac_core_dma_restart_rx( dwmac_common_context *self )
> + self->dmagrp->receive_poll_demand = 1;
> +static void show_tx_process_state( const uint32_t status )
> + const uint32_t STATE = DMAGRP_STATUS_TS_GET( status );
> + switch ( STATE ) {
> + case 0:
> + DWMAC_CORE_PRINT_DBG( "- TX (Stopped): Reset or Stop command\n" );
> + break;
> + case 1:
> + DWMAC_CORE_PRINT_DBG( "- TX (Running):Fetching the Tx desc\n" );
> + break;
> + case 2:
> + DWMAC_CORE_PRINT_DBG( "- TX (Running): Waiting for end of tx\n" );
> + break;
> + case 3:
> + DWMAC_CORE_PRINT_DBG( "- TX (Running): Reading the data "
> + "and queuing the data into the Tx buf\n" );
> + break;
> + case 6:
> + DWMAC_CORE_PRINT_DBG( "- TX (Suspended): Tx Buff Underflow "
> + "or an unavailable Transmit descriptor\n" );
> + break;
> + case 7:
> + DWMAC_CORE_PRINT_DBG( "- TX (Running): Closing Tx descriptor\n" );
> + break;
> + default:
> + break;
> +static void show_rx_process_state( const uint32_t status )
> + const uint32_t STATE = DMAGRP_STATUS_RS_GET( status );
> + case 0:
> + DWMAC_CORE_PRINT_DBG( "- RX (Stopped): Reset or Stop command\n" );
> + break;
> + case 1:
> + DWMAC_CORE_PRINT_DBG( "- RX (Running): Fetching the Rx desc\n" );
> + break;
> + case 2:
> + DWMAC_CORE_PRINT_DBG( "- RX (Running):Checking for end of pkt\n" );
> + break;
> + case 3:
> + DWMAC_CORE_PRINT_DBG( "- RX (Running): Waiting for Rx pkt\n" );
> + break;
> + case 4:
> + DWMAC_CORE_PRINT_DBG( "- RX (Suspended): Unavailable Rx buf\n" );
> + break;
> + case 5:
> + DWMAC_CORE_PRINT_DBG( "- RX (Running): Closing Rx descriptor\n" );
> + break;
> + case 6:
> + DWMAC_CORE_PRINT_DBG( "- RX(Running): Flushing the current frame"
> + " from the Rx buf\n" );
> + break;
> + case 7:
> + DWMAC_CORE_PRINT_DBG( "- RX (Running): Queuing the Rx frame"
> + " from the Rx buf into memory\n" );
> + break;
> + default:
> + break;
> +#else /* DWMAC_CORE_DEBUG */
> + #define show_tx_process_state( status )
> + #define show_rx_process_state( status )
> +#endif /* DWMAC_CORE_DEBUG */
> +void dwmac_core_dma_interrupt( void *arg )
> + dwmac_common_context *self = (dwmac_common_context *) arg;
> + dwmac_common_dma_irq_counts *count = &self->stats.dma_irq_counts;
> + rtems_event_set events_receive = 0;
> + rtems_event_set events_transmit = 0;
> + /* Get interrupt status */
> + uint32_t irq_status = self->dmagrp->status & self->dmagrp->interrupt_enable;
> + uint32_t irq_handled = 0;
> + uint32_t irq_disable = 0;
> + DWMAC_CORE_PRINT_DBG( "%s: [CSR5: 0x%08x]\n", __func__, irq_status );
> + /* It displays the DMA process states (CSR5 register) if DWMAC_CORE_DEBUG is #defined */
> + show_tx_process_state( self->dmagrp->status );
> + show_rx_process_state( self->dmagrp->status );
> + /* Is there any abnormal interrupt? */
> + if ( irq_status & DMAGRP_STATUS_AIS ) {
> + DWMAC_CORE_PRINT_DBG( "CSR5[15] DMA ABNORMAL IRQ: " );
> + if ( irq_status & DMAGRP_STATUS_UNF ) {
> + DWMAC_CORE_PRINT_DBG( "transmit underflow\n" );
> + events_transmit |= DWMAC_COMMON_EVENT_TX_BUMP_UP_DMA_THRESHOLD;
> + irq_handled |= DMAGRP_STATUS_UNF;
> + irq_disable |= DMAGRP_INTERRUPT_ENABLE_UNE;
> + ++count->tx_underflow;
> + if ( irq_status & DMAGRP_STATUS_TJT ) {
> + DWMAC_CORE_PRINT_DBG( "transmit jabber\n" );
> + irq_handled |= DMAGRP_STATUS_TJT;
> + ++count->tx_jabber;
> + if ( irq_status & DMAGRP_STATUS_OVF ) {
> + DWMAC_CORE_PRINT_DBG( "recv overflow\n" );
> + irq_handled |= DMAGRP_STATUS_OVF;
> + ++count->rx_overflow;
> + if ( irq_status & DMAGRP_STATUS_TU ) {
> + DWMAC_CORE_PRINT_DBG( "transmit buffer unavailable\n" );
> + irq_handled |= DMAGRP_STATUS_TU;
> + ++count->tx_buf_unav;
> + if ( irq_status & DMAGRP_STATUS_RU ) {
> + DWMAC_CORE_PRINT_DBG( "receive buffer unavailable\n" );
> + irq_handled |= DMAGRP_STATUS_RU;
> + ++count->rx_buf_unav;
> + if ( irq_status & DMAGRP_STATUS_RPS ) {
> + DWMAC_CORE_PRINT_DBG( "receive process stopped\n" );
> + irq_handled |= DMAGRP_STATUS_RPS;
> + ++count->rx_process_stopped;
> + if ( irq_status & DMAGRP_STATUS_RWT ) {
> + DWMAC_CORE_PRINT_DBG( "receive watchdog\n" );
> + irq_handled |= DMAGRP_STATUS_RWT;
> + ++count->rx_watchdog;
> + if ( irq_status & DMAGRP_STATUS_ETI ) {
> + DWMAC_CORE_PRINT_DBG( "transmit early interrupt\n" );
> + irq_handled |= DMAGRP_STATUS_ETI;
> + ++count->tx_early;
> + if ( irq_status & DMAGRP_STATUS_ERI ) {
> + DWMAC_CORE_PRINT_DBG( "receive early interrupt\n" );
> + irq_handled |= DMAGRP_STATUS_ERI;
> + ++count->rx_early;
> + if ( irq_status & DMAGRP_STATUS_TPS ) {
> + DWMAC_CORE_PRINT_DBG( "transmit process stopped\n" );
> + events_transmit |= DWMAC_COMMON_EVENT_TASK_INIT;
> + irq_handled |= DMAGRP_STATUS_TPS;
> + irq_disable |= DMAGRP_INTERRUPT_ENABLE_TSE;
> + ++count->tx_process_stopped;
> + if ( irq_status & DMAGRP_STATUS_FBI ) {
> + DWMAC_CORE_PRINT_DBG( "fatal bus error\n" );
> + irq_handled |= DMAGRP_STATUS_FBI;
> + irq_disable |= DMAGRP_INTERRUPT_ENABLE_FBE;
> + ++count->fatal_bus_error;
> + irq_handled |= DMAGRP_STATUS_AIS;
> + /* Is there any normal interrupt? */
> + if ( irq_status & DMAGRP_STATUS_NIS ) {
> + /* Transmit interrupt */
> + if ( irq_status & DMAGRP_STATUS_TI ) {
> + events_transmit |= DWMAC_COMMON_EVENT_TX_FRAME_TRANSMITTED;
> + irq_handled |= DMAGRP_STATUS_TI;
> + irq_disable |= DMAGRP_INTERRUPT_ENABLE_TIE;
> + ++count->transmit;
> + /* Receive interrupt */
> + if ( irq_status & DMAGRP_STATUS_RI ) {
> + events_receive |= DWMAC_COMMON_EVENT_RX_FRAME_RECEIVED;
> + irq_handled |= DMAGRP_STATUS_RI;
> + irq_disable |= DMAGRP_INTERRUPT_ENABLE_RIE;
> + ++count->receive;
> + irq_handled |= DMAGRP_STATUS_NIS;
> + /* Optional hardware blocks, interrupts should be disabled */
> + if ( irq_status
> + & ( DMAGRP_STATUS_GMI | DMAGRP_STATUS_GLI ) ) {
> + DWMAC_CORE_PRINT_DBG( "%s: unexpected status %08x\n", __func__,
> + irq_status );
> + if ( irq_status & DMAGRP_STATUS_GMI ) {
> + irq_handled |= DMAGRP_STATUS_GMI;
> + ++count->unhandled;
> + if ( irq_status & DMAGRP_STATUS_GLI ) {
> + irq_handled |= DMAGRP_STATUS_GLI;
> + /* Count remaining unhandled interrupts (there should not be any) */
> + if ( ( irq_status & 0x1FFCF ) != irq_handled ) {
> + /* Disable interrupts which need further handling by tasks.
> + * The tasks will re-enable them. */
> + self->dmagrp->interrupt_enable &= ~irq_disable;
> + /* Clear interrupts */
> + self->dmagrp->status = irq_handled;
> + /* Send events to receive task */
> + if ( events_receive != 0 ) {
> + (void) rtems_bsdnet_event_send( self->task_id_rx, events_receive );
> + /* Send events to transmit task */
> + if ( events_transmit != 0 ) {
> + (void) rtems_bsdnet_event_send( self->task_id_tx, events_transmit );
> + DWMAC_CORE_PRINT_DBG( "\n\n" );
> +void dwmac_core_dma_flush_tx_fifo( dwmac_common_context *self )
> + self->dmagrp->operation_mode |= DMAGRP_OPERATION_MODE_FTF;
> + do {
> + } while ( ( self->dmagrp->operation_mode & DMAGRP_OPERATION_MODE_FTF ) != 0 );
> +void dwmac_core_set_mac_addr(
> + const uint8_t addr[6],
> + volatile uint32_t *reg_high,
> + volatile uint32_t *reg_low )
> + uint32_t data = MAC_HIGH_ADDRHI( ( addr[5] << 8 ) | addr[4] );
> + /* For MAC Addr registers se have to set the Address Enable (AE)
> + * bit that has no effect on the High Reg 0 where the bit 31 (MO)
> + * is RO.
> + data |= MAC_HIGH_AE;
> + *reg_high = data;
> + data =
> + ( (uint32_t) addr[3] << 24 )
> + | ( (uint32_t) addr[2] << 16 )
> + | ( (uint32_t) addr[1] << 8 )
> + | addr[0];
> + *reg_low = data;
> +/* Enable disable MAC RX/TX */
> +void dwmac_core_set_mac(
> + const bool enable )
> + if ( enable ) {
> + value |= MACGRP_MAC_CONFIGURATION_RE | MACGRP_MAC_CONFIGURATION_TE;
> + } else {
> + value &= ~( MACGRP_MAC_CONFIGURATION_RE | MACGRP_MAC_CONFIGURATION_TE );
> diff --git a/c/src/libchip/network/dwmac-core.h b/c/src/libchip/network/dwmac-core.h
> index 0000000..b9b6a96
> --- /dev/null
> +++ b/c/src/libchip/network/dwmac-core.h
> @@ -0,0 +1,78 @@
> + * @file dwmac-core.h
> + * This header file is NOT part of the driver API.
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#ifndef DWMAC_CORE_H_
> +#define DWMAC_CORE_H_
> +#ifdef __cplusplus
> +extern "C" {
> + volatile uint32_t *reg_low );
> + const bool enable );
> +void dwmac_core_dma_start_tx( dwmac_common_context *self );
> +void dwmac_core_dma_stop_tx( dwmac_common_context *self );
> +void dwmac_core_dma_start_rx( dwmac_common_context *self );
> +void dwmac_core_dma_stop_rx( dwmac_common_context *self );
> +void dwmac_core_dma_restart_rx( dwmac_common_context *self );
> +void dwmac_core_dma_restart_tx( dwmac_common_context *self );
> +void dwmac_core_enable_dma_irq_rx( dwmac_common_context *self );
> +void dwmac_core_enable_dma_irq_tx( dwmac_common_context *self );
> +void dwmac_core_disable_dma_irq_tx( dwmac_common_context *self );
> +void dwmac_core_disable_dma_irq_rx( dwmac_common_context *self );
> +void dwmac_core_reset_dma_irq_status_tx( dwmac_common_context *self );
> +void dwmac_core_reset_dma_irq_status_rx( dwmac_common_context *self );
> +void dwmac_core_dma_interrupt( void *arg );
> +void dwmac_core_dma_flush_tx_fifo( dwmac_common_context *self );
> +#ifdef __cplusplus
> +#endif /* DWMAC_CORE_H_ */
> diff --git a/c/src/libchip/network/dwmac-desc-com.c b/c/src/libchip/network/dwmac-desc-com.c
> index 0000000..a3292c5
> --- /dev/null
> +++ b/c/src/libchip/network/dwmac-desc-com.c
> @@ -0,0 +1,62 @@
> + * @file dwmac-desc-enh.c
> + * @brief DWMAC 10/100/1000 Common Descriptor Handling
> + * DWMAC 10/100/1000 on-chip Ethernet controllers.
> + * Functions which are common to normal and enhanced DMA descriptors.
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#include "dwmac-desc-com.h"
> +#undef DWMAC_DESC_COM_DEBUG
> +#ifdef DWMAC_DESC_COM_DEBUG
> +#define DWMAC_DESC_COM_PRINT_DBG( fmt, args ... ) printk( fmt, ## args )
> +#else
> +#define DWMAC_DESC_COM_PRINT_DBG( fmt, args ... ) do { } while ( 0 )
> +#endif
> +struct mbuf *dwmac_desc_com_new_mbuf( dwmac_common_context *self ) {
> + struct ifnet *ifp = &self->arpcom.ac_if;
> + struct mbuf *m = NULL;
> + MGETHDR( m, M_DONTWAIT, MT_DATA );
> + if ( m != NULL ) {
> + MCLGET( m, M_DONTWAIT );
> + if ( m->m_ext.ext_buf != NULL ) {
> + if ( ( m->m_flags & M_EXT ) != 0 ) {
> + /* Set receive interface */
> + m->m_pkthdr.rcvif = ifp;
> + /* Make sure packet data will be aligned */
> + m->m_data = mtod( m, char * ) + ETHER_ALIGN;
> + return m;
> + } else {
> + m_free( m );
> + } else {
> + m_free( m );
> + return NULL;
> diff --git a/c/src/libchip/network/dwmac-desc-com.h b/c/src/libchip/network/dwmac-desc-com.h
> index 0000000..3b0dd9f
> --- /dev/null
> +++ b/c/src/libchip/network/dwmac-desc-com.h
> @@ -0,0 +1,46 @@
> + * @file dwmac-desc-com.h
> + * @brief DWMAC 10/100/1000 Common Descriptor Handling.
> + * Functions and data which are common to normal and enhanced DMA descriptors.
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#ifndef DWMAC_DESC_COM_H_
> +#define DWMAC_DESC_COM_H_
> +#include <sys/queue.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#define DWMAC_DESC_COM_HW_CRC_BYTES 4
> +#define DWMAC_DESC_COM_BUF_SIZE ( ETHER_MAX_LEN + DWMAC_DESC_COM_HW_CRC_BYTES )
> +struct mbuf *dwmac_desc_com_new_mbuf( dwmac_common_context *self );
> +#ifdef __cplusplus
> +#endif /* DWMAC_DESC_COM_H_ */
> diff --git a/c/src/libchip/network/dwmac-desc-enh.c b/c/src/libchip/network/dwmac-desc-enh.c
> index 0000000..df11b69
> --- /dev/null
> +++ b/c/src/libchip/network/dwmac-desc-enh.c
> @@ -0,0 +1,1053 @@
> + * @brief DWMAC 10/100/1000 Enhanced DMA Descriptor Handling.
> + * Functions and data for the handling of enhanced DMA descriptors.
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#include <stdlib.h>
> +#include <stdio.h>
> +#undef DWMAC_DESC_ENH_DEBUG
> +#ifdef DWMAC_DESC_ENH_DEBUG
> +#define DWMAC_DESC_ENH_PRINT_DBG( fmt, args ... ) printk( fmt, ## args )
> +#else
> +#define DWMAC_DESC_ENH_PRINT_DBG( fmt, args ... ) do { } while ( 0 )
> +#endif
> +typedef enum {
> + DWMAC_IP_PAYLOAD_TYPE_UNKNOWN,
> + DWMAC_IP_PAYLOAD_TYPE_UDP,
> + DWMAC_IP_PAYLOAD_TYPE_TCP,
> + DWMAC_IP_PAYLOAD_TYPE_ICMP
> +} dwmac_ip_payload_type;
> +static void dwmac_desc_enh_rx_set_on_ring_chain(
> + volatile dwmac_desc_ext *p, int end )
> + /* For simplicity reasons we will not use the second buffer.
> + * If we would use it we would have to set the size to MCLBYTES -1 */
> + p->erx.des0_3.des1 = DWMAC_DESC_ERX_DES1_RECEIVE_BUFF_2_SIZE_SET(
> + p->erx.des0_3.des1, 0
> + p->erx.des0_3.des3 = (uint32_t) NULL;
> + if ( end )
> + p->erx.des0_3.des1 |= DWMAC_DESC_ERX_DES1_RECEIVE_END_OF_RING;
> +static void dwmac_desc_enh_tx_set_on_ring_chain(
> + volatile dwmac_desc_ext *p, const bool end )
> + if ( end )
> + p->etx.des0_3.des0 |= DWMAC_DESC_ETX_DES0_TRANSMIT_END_OF_RING;
> +static void dwmac_desc_enh_set_tx_desc_len(
> + volatile dwmac_desc_ext *p_enh, size_t len )
> + p_enh->etx.des0_3.des1 = DWMAC_DESC_ETX_DES1_TRANSMIT_BUFFER_1_SIZE_SET(
> + p_enh->etx.des0_3.des1,
> + len
> +static bool dwmac_desc_enh_is_giant_frame( const uint32_t des0 )
> + return (
> + ( des0
> + & DWMAC_DESC_ERX_DES0_TIMESTAMP_AVAIL_OR_CHECKSUM_ERROR_OR_GIANT_FRAME
> + ) != 0
> +static bool dwmac_desc_enh_is_udp_payload( const uint32_t des4 )
> + return (
> + DWMAC_DESC_EXT_ERX_DES4_IP_PAYLOAD_TYPE_GET( des4 )
> + == DWMAC_IP_PAYLOAD_TYPE_UDP
> +static bool dwmac_desc_enh_is_tcp_payload( const uint32_t des4 )
> + return (
> + == DWMAC_IP_PAYLOAD_TYPE_TCP
> +static bool dwmac_desc_enh_is_icmp_payload( const uint32_t des4 )
> + return (
> + == DWMAC_IP_PAYLOAD_TYPE_ICMP
> +static dwmac_common_rx_frame_status dwmac_desc_enh_coe_status(
> + volatile dwmac_desc_ext *p_enh )
> + dwmac_common_rx_frame_status ret = DWMAC_COMMON_RX_FRAME_STATUS_GOOD;
> + const uint32_t DES0 = p_enh->erx.des0_3.des0;
> + const uint32_t DES4 = p_enh->erx.des4;
> + if ( ( DES0 & DWMAC_DESC_ERX_DES0_EXT_STATUS_AVAIL_OR_RX_MAC_ADDR_STATUS )
> + != 0 ) {
> + if ( !dwmac_desc_enh_is_giant_frame( DES0 )
> + && ( DES0 & DWMAC_DESC_ERX_DES0_FREAME_TYPE ) == 0
> + && ( DES4 & DWMAC_DESC_EXT_ERX_DES4_IPV6_PACKET_RECEIVED ) == 0
> + && ( DES4 & DWMAC_DESC_EXT_ERX_DES4_IPV4_PACKET_RECEIVED ) == 0
> + && ( DES4 & DWMAC_DESC_EXT_ERX_DES4_IP_PAYLOAD_ERROR ) == 0
> + && ( DES4 & DWMAC_DESC_EXT_ERX_DES4_IP_HEADER_ERROR ) == 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "RX Des0 status: IEEE 802.3 Type frame.\n" );
> + ret = DWMAC_COMMON_RX_FRAME_STATUS_LLC_SNAP;
> + } else if ( ( ( DES4 & DWMAC_DESC_EXT_ERX_DES4_IPV6_PACKET_RECEIVED ) != 0
> + || ( DES4 & DWMAC_DESC_EXT_ERX_DES4_IPV4_PACKET_RECEIVED )
> + != 0 )
> + && dwmac_desc_enh_is_giant_frame( DES0 ) ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "RX Des0 status: IPv4/6 No CSUM Error.\n" );
> + ret = DWMAC_COMMON_RX_FRAME_STATUS_GOOD;
> + != 0 )
> + && ( DES4 & DWMAC_DESC_EXT_ERX_DES4_IP_PAYLOAD_ERROR ) != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "RX Des0 status: IPv4/6 Payload Error.\n" );
> + ret = DWMAC_COMMON_RX_FRAME_STATUS_CSUM_NONE;
> + != 0 )
> + && ( DES4 & DWMAC_DESC_EXT_ERX_DES4_IP_HEADER_ERROR ) != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "RX Des0 status: IPv4/6 Header Error.\n" );
> + != 0 )
> + "RX Des0 status: IPv4/6 Header and Payload Error.\n" );
> + != 0 )
> + && ( !dwmac_desc_enh_is_udp_payload( DES4 ) )
> + && ( !dwmac_desc_enh_is_tcp_payload( DES4 ) )
> + && ( !dwmac_desc_enh_is_icmp_payload( DES4 ) ) ) {
> + "RX Des0 status: IPv4/6 unsupported IP PAYLOAD.\n" );
> + ret = DWMAC_COMMON_RX_FRAME_STATUS_DISCARD;
> + } else if ( ( DES4 & DWMAC_DESC_EXT_ERX_DES4_IPV6_PACKET_RECEIVED ) == 0
> + == 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "RX Des0 status: No IPv4, IPv6 frame.\n" );
> + } else {
> + uint32_t status = (
> + (uint32_t) ( dwmac_desc_enh_is_giant_frame( DES0 ) << 2U )
> + | (uint32_t) ( ( ( DES0 & DWMAC_DESC_ERX_DES0_FREAME_TYPE )
> + != 0 ) << 1U ) )
> + & 0x7U;
> + /* bits 5 7 0 | Frame status
> + * 0 0 0 | IEEE 802.3 Type frame (length < 1536 octects)
> + * 1 0 0 | IPv4/6 No CSUM errorS.
> + * 1 0 1 | IPv4/6 CSUM PAYLOAD error
> + * 1 1 0 | IPv4/6 CSUM IP HR error
> + * 1 1 1 | IPv4/6 IP PAYLOAD AND HEADER errorS
> + * 0 0 1 | IPv4/6 unsupported IP PAYLOAD
> + * 0 1 1 | COE bypassed.. no IPv4/6 frame
> + * 0 1 0 | Reserved.
> + if ( status == 0x0 ) {
> + } else if ( status == 0x4 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "RX Des0 status: IPv4/6 No CSUM errorS.\n" );
> + } else if ( status == 0x5 ) {
> + } else if ( status == 0x6 ) {
> + } else if ( status == 0x7 ) {
> + } else if ( status == 0x1 ) {
> + } else if ( status == 0x3 ) {
> + return ret;
> +static int dwmac_desc_enh_get_tx_status(
> + int ret = 0;
> + volatile dwmac_desc_ext *dma_tx =
> + (volatile dwmac_desc_ext *) self->dma_tx;
> + volatile dwmac_desc_ext *p_desc = &dma_tx[idx_tx];
> + dwmac_common_desc_status_counts_tx *counts =
> + &self->stats.desc_status_counts_tx;
> + if ( ( p_desc->etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_ERROR_SUMMARY ) != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "DWMAC TX error... 0x%08x\n", p->des01.etx );
> + if ( ( p_desc->etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_JABBER_TIMEOUT )
> + != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "\tjabber_timeout error\n" );
> + ++counts->jabber;
> + if ( ( p_desc->etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_FRAME_FLUSHED )
> + != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "\tframe_flushed error\n" );
> + ++counts->frame_flushed;
> + dwmac_core_dma_flush_tx_fifo( self );
> + if ( ( p_desc->etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_LOSS_OF_CARRIER )
> + != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "\tloss_carrier error\n" );
> + ++counts->losscarrier;
> + if ( ( p_desc->etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_NO_CARRIER )
> + != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "\tno_carrier error\n" );
> + ++counts->no_carrier;
> + if ( ( p_desc->etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_EXCESSIVE_COLLISION )
> + != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "\texcessive_collisions\n" );
> + ++counts->excessive_collisions;
> + if ( ( p_desc->etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_EXCESSIVE_DEFERAL )
> + != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "\texcessive tx_deferral\n" );
> + ++counts->excessive_deferral;
> + if ( ( p_desc->etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_UNDERFLOW_ERROR )
> + != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "\tunderflow error\n" );
> + ++counts->underflow;
> + if ( ( p_desc->etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_IP_HEADER_ERROR )
> + != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "\tTX IP header csum error\n" );
> + ++counts->ip_header_error;
> + if ( ( p_desc->etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_IP_PAYLOAD_ERROR )
> + != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "\tAddr/Payload csum error\n" );
> + ++counts->payload_error;
> + ret = -1;
> + if ( ( p_desc->etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_DEFERRED_BIT ) != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "GMAC TX status: tx deferred\n" );
> + ++counts->deferred;
> + if ( ( p_desc->etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_VLAN_FRAME ) != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "GMAC TX status: VLAN frame\n" );
> + ++counts->vlan;
> + return ret;
> +static dwmac_common_rx_frame_status dwmac_desc_enh_get_rx_status(
> + dwmac_common_desc_status_counts_rx *counts =
> + &self->stats.desc_status_counts_rx;
> + DWMAC_COMMON_RX_FRAME_STATUS_GOOD;
> + volatile dwmac_desc_ext *dma_rx =
> + (volatile dwmac_desc_ext *) self->dma_rx;
> + const uint32_t DES0 = dma_rx[desc_idx].erx.des0_3.des0;
> + if ( ( DES0 & DWMAC_DESC_ERX_DES0_ERROR_SUMMARY ) != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "GMAC RX Error Summary 0x%08x\n",
> + DES0 );
> + if ( ( DES0 & DWMAC_DESC_ERX_DES0_DESCRIPTOR_ERROR ) != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "\tdescriptor error\n" );
> + ++counts->descriptor_error;
> + if ( ( DES0 & DWMAC_DESC_ERX_DES0_OVERFLOW_ERROR ) != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "\toverflow error\n" );
> + ++counts->overflow_error;
> + if ( dwmac_desc_enh_is_giant_frame( DES0 ) ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "\tIPC Csum Error/Giant frame\n" );
> + ++counts->giant_frame;
> + if ( ( DES0 & DWMAC_DESC_ERX_DES0_LATE_COLLISION ) != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "\tlate_collision error\n" );
> + ++counts->late_collision;
> + if ( ( DES0 & DWMAC_DESC_ERX_DES0_RECEIVE_WATCHDOG_TIMEOUT )
> + != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "\treceive_watchdog error\n" );
> + ++counts->watchdog_timeout;
> + if ( ( DES0 & DWMAC_DESC_ERX_DES0_RECEIVE_ERROR ) != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "\tReceive Error\n" );
> + ++counts->receive_error;
> + if ( ( DES0 & DWMAC_DESC_ERX_DES0_CRC_ERROR ) != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "\tCRC error\n" );
> + ++counts->crc_error;
> + if ( ret == DWMAC_COMMON_RX_FRAME_STATUS_GOOD ) {
> + /* After a payload csum error, the ES bit is set.
> + * It doesn't match with the information reported into the databook.
> + * At any rate, we need to understand if the CSUM hw computation is ok
> + * and report this info to the upper layers. */
> + ret = dwmac_desc_enh_coe_status( &dma_rx[desc_idx] );
> + if ( ( DES0 & DWMAC_DESC_ERX_DES0_DRIBBLE_BIT_ERROR ) != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "GMAC RX: dribbling error\n" );
> + ++counts->dribble_bit_error;
> + if ( ( DES0 & DWMAC_DESC_ERX_DES0_SRC_ADDR_FILTER_FAIL ) != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "GMAC RX : Source Address filter fail\n" );
> + ++counts->source_addr_fail;
> + if ( ( DES0 & DWMAC_DESC_ERX_DES0_DEST_ADDR_FILTER_FAIL ) != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "GMAC RX : Dest Address filter fail\n" );
> + ++counts->dest_addr_fail;
> + if ( ( DES0 & DWMAC_DESC_ERX_DES0_LENGTH_ERROR ) != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "GMAC RX: length_error error\n" );
> + ++counts->length_error;
> + if ( ( DES0 & DWMAC_DESC_ERX_DES0_VLAN_TAG ) != 0 ) {
> + DWMAC_DESC_ENH_PRINT_DBG( "GMAC RX: VLAN frame tagged\n" );
> + ++counts->vlan_tag;
> + return ret;
> +static void dwmac_desc_enh_print_tx_desc(
> + volatile dwmac_desc_ext *p_enh = (volatile dwmac_desc_ext *) p;
> + if ( p_enh != NULL ) {
> + for ( index = 0; index < count; ++index ) {
> + printf( "Transmit DMA Descriptor %d\n", index );
> + printf( "des0\n" );
> + printf(
> + " %u own bit\n"
> + " %u IRQ on Completion\n"
> + " %u Last Segment\n"
> + " %u First Segment\n"
> + " %u Disable CRC\n"
> + " %u Disable Pad\n"
> + " %u Transmit Timestamp Enable\n"
> + " %lu Checksum Insertion Control\n"
> + " %u Transmit End of Ring\n"
> + " %u Second Address Chained\n"
> + " %u Transmit Timestamp Status\n"
> + " %u IP Header Error\n"
> + " %u VLAN Frame\n"
> + " %lu Collision Count\n"
> + " %u Deferred Bit\n",
> + ( p_enh[index].etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_OWN_BIT ) != 0,
> + ( p_enh[index].etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_IRQ_ON_COMPLETION ) != 0,
> + ( p_enh[index].etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_LAST_SEGMENT ) != 0,
> + ( p_enh[index].etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_FIRST_SEGMENT ) != 0,
> + ( p_enh[index].etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_DISABLE_CRC ) != 0,
> + ( p_enh[index].etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_DISABLE_PAD ) != 0,
> + & DWMAC_DESC_ETX_DES0_TRANSMIT_TIMESTAMP_ENABLE ) != 0,
> + DWMAC_DESC_ETX_DES0_CHECKSUM_INSERTION_CONTROL_GET( p_enh[index].etx.
> + des0_3.des0 ),
> + & DWMAC_DESC_ETX_DES0_TRANSMIT_END_OF_RING ) != 0,
> + ( p_enh[index].etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_SECOND_ADDR_CHAINED ) != 0,
> + & DWMAC_DESC_ETX_DES0_TRANSMIT_TIMESTAMP_STATUS ) != 0,
> + ( p_enh[index].etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_IP_HEADER_ERROR ) != 0,
> + ( p_enh[index].etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_VLAN_FRAME ) != 0,
> + DWMAC_DESC_ETX_DES0_COLLISION_COUNT_GET( p_enh[index].etx.des0_3.des0 ),
> + ( p_enh[index].etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_DEFERRED_BIT ) != 0
> + if ( ( p_enh[index].etx.des0_3.des0
> + & DWMAC_DESC_ETX_DES0_ERROR_SUMMARY ) != 0 ) {
> + printf( " Error Summary:\n" );
> + if ( p_enh[index].etx.des0_3.des0
> + & DWMAC_DESC_ETX_DES0_JABBER_TIMEOUT ) {
> + printf( " Jabber Timeout\n" );
> + & DWMAC_DESC_ETX_DES0_FRAME_FLUSHED ) != 0 ) {
> + printf( " Frame Flush\n" );
> + & DWMAC_DESC_ETX_DES0_IP_PAYLOAD_ERROR ) != 0 ) {
> + printf( " Payload Error\n" );
> + & DWMAC_DESC_ETX_DES0_LOSS_OF_CARRIER ) != 0 ) {
> + printf( " Loss of Carrier\n" );
> + & DWMAC_DESC_ETX_DES0_NO_CARRIER ) != 0 ) {
> + printf( " No Carrier\n" );
> + & DWMAC_DESC_ETX_DES0_EXCESSIVE_COLLISION ) != 0 ) {
> + printf( " Excessive Collision\n" );
> + printf( " Ecessive Deferral\n" );
> + & DWMAC_DESC_ETX_DES0_UNDERFLOW_ERROR ) != 0 ) {
> + printf( " Undeflow Error\n" );
> + printf( "des1\n" );
> + printf(
> + " %lu Transmit Buffer 2 Size\n"
> + " %lu Transmit Buffer 1 Size\n",
> + DWMAC_DESC_ETX_DES1_TRANSMIT_BUFFER_2_SIZE_GET( p_enh[index].etx.des0_3.
> + des1 ),
> + DWMAC_DESC_ETX_DES1_TRANSMIT_BUFFER_1_SIZE_GET( p_enh[index].etx.des0_3.
> + des1 )
> + printf( "des2\n" );
> + printf( " %p Buffer 1 Address\n", (void *) p_enh[index].etx.des0_3.des2 );
> + printf( "des3\n" );
> + printf( " %p Buffer 2 Address\n", (void *) p_enh[index].etx.des0_3.des3 );
> +static void dwmac_desc_enh_print_rx_desc(
> + printf( "Receive DMA Descriptor %d\n", index );
> + printf(
> + " %u Own Bit\n"
> + " %u Dest. Addr. Filter Fail\n"
> + " %lu Frame Length\n"
> + " %u Source Addr. Filter Fail\n"
> + " %u Length Error\n"
> + " %u VLAN Tag\n"
> + " %u First Descriptor\n"
> + " %u Last Descriptor\n"
> + " %u Frame Type\n"
> + " %u Dribble Bit Error\n"
> + " %u Extended Status Available\n",
> + ( p_enh[index].erx.des0_3.des0 & DWMAC_DESC_ERX_DES0_OWN_BIT ) != 0,
> + & DWMAC_DESC_ERX_DES0_DEST_ADDR_FILTER_FAIL ) != 0,
> + DWMAC_DESC_ERX_DES0_FRAME_LENGTH_GET(
> + p_enh[index].erx.des0_3.des0 ),
> + & DWMAC_DESC_ERX_DES0_SRC_ADDR_FILTER_FAIL ) != 0,
> + ( p_enh[index].erx.des0_3.des0 & DWMAC_DESC_ERX_DES0_LENGTH_ERROR ) != 0,
> + ( p_enh[index].erx.des0_3.des0 & DWMAC_DESC_ERX_DES0_VLAN_TAG ) != 0,
> + ( p_enh[index].erx.des0_3.des0 & DWMAC_DESC_ERX_DES0_FIRST_DESCRIPTOR ) != 0,
> + ( p_enh[index].erx.des0_3.des0 & DWMAC_DESC_ERX_DES0_LAST_DESCRIPTOR ) != 0,
> + ( p_enh[index].erx.des0_3.des0 & DWMAC_DESC_ERX_DES0_FREAME_TYPE ) != 0,
> + ( p_enh[index].erx.des0_3.des0 & DWMAC_DESC_ERX_DES0_DRIBBLE_BIT_ERROR ) != 0,
> + & DWMAC_DESC_ERX_DES0_EXT_STATUS_AVAIL_OR_RX_MAC_ADDR_STATUS ) != 0
> + if ( ( p_enh[index].erx.des0_3.des0
> + & DWMAC_DESC_ERX_DES0_ERROR_SUMMARY ) != 0 ) {
> + & DWMAC_DESC_ERX_DES0_DESCRIPTOR_ERROR ) != 0 ) {
> + printf( " Descriptor Error\n" );
> + & DWMAC_DESC_ERX_DES0_OVERFLOW_ERROR ) != 0 ) {
> + printf( " Overflow Error\n" );
> + DWMAC_DESC_ERX_DES0_TIMESTAMP_AVAIL_OR_CHECKSUM_ERROR_OR_GIANT_FRAME )
> + != 0 ) {
> + printf( " Giant Frame\n" );
> + & DWMAC_DESC_ERX_DES0_LATE_COLLISION ) != 0 ) {
> + printf( " Late Collision\n" );
> + & DWMAC_DESC_ERX_DES0_RECEIVE_WATCHDOG_TIMEOUT ) != 0
> + || ( p_enh[index].erx.des0_3.des0
> + & DWMAC_DESC_ERX_DES0_RECEIVE_ERROR ) != 0 ) {
> + printf( " IP Header or IP Payload:\n" );
> + & DWMAC_DESC_ERX_DES0_RECEIVE_WATCHDOG_TIMEOUT ) != 0 ) {
> + printf( " Watchdog Timeout\n" );
> + printf( " Receive Error\n" );
> + if ( ( p_enh[index].erx.des0_3.des0 & DWMAC_DESC_ERX_DES0_CRC_ERROR )
> + != 0 ) {
> + printf( " CRC Error\n" );
> + printf(
> + " %u Disable Interrupt on Completion\n"
> + " %lu Receive Buffer 2 Size\n"
> + " %u Receive End of Ring\n"
> + " %u Second Addr. Chained\n"
> + " %lu Receive Buffer 1 Size\n",
> + ( p_enh[index].erx.des0_3.des1
> + & DWMAC_DESC_ERX_DES1_DISABLE_IRQ_ON_COMPLETION ) != 0,
> + DWMAC_DESC_ERX_DES1_RECEIVE_BUFF_2_SIZE_GET( p_enh[index].erx.des0_3.
> + des1 ),
> + ( p_enh[index].erx.des0_3.des1 & DWMAC_DESC_ERX_DES1_RECEIVE_END_OF_RING ) != 0,
> + ( p_enh[index].erx.des0_3.des1 & DWMAC_DESC_ERX_DES1_SECOND_ADDR_CHAINED ) != 0,
> + DWMAC_DESC_ERX_DES1_RECEIVE_BUFF_1_SIZE_GET( p_enh[index].erx.des0_3.
> + des1 )
> + printf( " %p Buffer 1 Address\n", (void *) p_enh[index].erx.des0_3.des2 );
> + printf( " %p Buffer 2 Address\n", (void *) p_enh[index].erx.des0_3.des3 );
> +static int dwmac_desc_enh_create_rx_desc( dwmac_common_context *self )
> + int eno = 0;
> + const size_t NUM_DESCS = (size_t) self->bsd_config->rbuf_count;
> + const size_t SIZE_DESCS = NUM_DESCS * sizeof( dwmac_desc_ext );
> + void *desc_mem = NULL;
> + assert( NULL == self->dma_rx );
> + /* Allocate an array of mbuf pointers */
> + self->mbuf_addr_rx = calloc( NUM_DESCS, sizeof( struct mbuf * ) );
> + if ( self->mbuf_addr_rx == NULL ) {
> + eno = ENOMEM;
> + /* Allocate an array of dma descriptors */
> + if ( eno == 0 ) {
> + eno = ( self->CFG->CALLBACK.mem_alloc_nocache )(
> + self->arg,
> + &desc_mem,
> + SIZE_DESCS
> + if ( eno == 0 ) {
> + if ( desc_mem != NULL ) {
> + memset( desc_mem, 0, SIZE_DESCS );
> + _ARM_Data_synchronization_barrier();
> + } else {
> + eno = ENOMEM;
> + if ( eno == 0 ) {
> + self->dma_rx = (volatile dwmac_desc *) desc_mem;
> + return eno;
> +static void dwmac_desc_enh_init_rx_desc(
> + char *clust_start =
> + mtod( self->mbuf_addr_rx[index], char * );
> + assert( NULL != p_enh );
> + rtems_cache_invalidate_multiple_data_lines(
> + clust_start,
> + DWMAC_DESC_COM_BUF_SIZE + ETHER_ALIGN
> + if ( self->mbuf_addr_rx[index] != NULL ) {
> + p_enh[index].erx.des0_3.des1 = DWMAC_DESC_ERX_DES1_RECEIVE_BUFF_1_SIZE_SET(
> + p_enh->erx.des0_3.des1,
> + DWMAC_DESC_COM_BUF_SIZE );
> + } else {
> + 0 );
> + p_enh[index].erx.des0_3.des2 = (uint32_t) clust_start;
> + /* The network controller supports adding a second data buffer to
> + * p_enh->erx.des0_3.des3. For simplicity reasons we will not do this */
> + dwmac_desc_enh_rx_set_on_ring_chain( &p_enh[index],
> + ( index == NUM_DESCS - 1 ) );
> + p_enh[index].erx.des0_3.des0 = DWMAC_DESC_ERX_DES0_OWN_BIT;
> +static int dwmac_desc_enh_destroy_rx_desc( dwmac_common_context *self )
> + int eno = 0;
> + void *desc_mem = __DEVOLATILE( void *, self->dma_rx );
> + if ( self->mbuf_addr_rx != NULL ) {
> + free( self->mbuf_addr_rx, 0 );
> + self->mbuf_addr_rx = NULL;
> + eno = self->CFG->CALLBACK.mem_free_nocache( self->arg, desc_mem );
> + desc_mem = NULL;
> + return eno;
> +static void dwmac_desc_enh_release_rx_bufs( dwmac_common_context *self )
> + volatile dwmac_desc_ext *p_enh = (volatile dwmac_desc_ext *) self->dma_rx;
> + unsigned int i;
> + assert( p_enh != NULL );
> + for ( i = 0; i < NUM_DESCS; ++i ) {
> + if ( p_enh[i].erx.des0_3.des2 != 0 ) {
> + struct mbuf *dummy;
> + assert( self->mbuf_addr_rx[i] != NULL );
> + MFREE( self->mbuf_addr_rx[i], dummy );
> + (void) dummy;
> + memset( __DEVOLATILE( void *,
> + &p_enh[i].erx ), 0, sizeof( dwmac_desc_ext ) );
> + self->dma_rx = (volatile dwmac_desc *) p_enh;
> +static int dwmac_desc_enh_create_tx_desc( dwmac_common_context *self )
> + int eno = 0;
> + void *mem_desc = __DEVOLATILE( void *, self->dma_tx );
> + const size_t NUM_DESCS = (size_t) self->bsd_config->xbuf_count;
> + assert( mem_desc == NULL );
> + self->mbuf_addr_tx = calloc( NUM_DESCS, sizeof( struct mbuf * ) );
> + if ( self->mbuf_addr_tx == NULL ) {
> + eno = ENOMEM;
> + if ( eno == 0 ) {
> + self->arg,
> + &mem_desc,
> + SIZE_DESCS
> + if ( eno == 0 ) {
> + if ( mem_desc != NULL ) {
> + memset( mem_desc, 0, SIZE_DESCS );
> + } else {
> + eno = ENOMEM;
> + if ( eno == 0 ) {
> + self->dma_tx = (volatile dwmac_desc *) mem_desc;
> + return eno;
> +static void dwmac_desc_enh_init_tx_desc( dwmac_common_context *self )
> + volatile dwmac_desc_ext *p_enh = (volatile dwmac_desc_ext *) self->dma_tx;
> + unsigned int i;
> + dwmac_desc_enh_tx_set_on_ring_chain( &p_enh[i], ( i == NUM_DESCS - 1 ) );
> + self->dma_tx = (volatile dwmac_desc *) &p_enh[0];
> +static int dwmac_desc_enh_destroy_tx_desc( dwmac_common_context *self )
> + int eno = 0;
> + if ( self->mbuf_addr_tx != NULL ) {
> + free( self->mbuf_addr_tx, 0 );
> + self->mbuf_addr_tx = NULL;
> + eno = self->CFG->CALLBACK.mem_free_nocache( self->arg, mem_desc );
> + mem_desc = NULL;
> + return eno;
> +static void dwmac_desc_enh_release_tx_bufs( dwmac_common_context *self )
> + unsigned int i;
> + if ( p_enh[i].etx.des0_3.des1 != 0 ) {
> + assert( self->mbuf_addr_tx[i] != NULL );
> + MFREE( self->mbuf_addr_tx[i], dummy );
> + (void) dummy;
> + &p_enh[i].etx ), 0, sizeof( dwmac_desc_ext ) );
> + self->dma_tx = (volatile dwmac_desc *) p_enh;
> +static inline size_t dwmac_desc_enh_get_rx_frame_len(
> + /* The type-1 checksum offload engines append the checksum at
> + * the end of frame and the two bytes of checksum are added in
> + * the length.
> + * Adjust for that in the framelen for type-1 checksum offload
> + * engines. */
> + if ( self->dmagrp->hw_feature & DMAGRP_HW_FEATURE_RXTYP1COE ) {
> + return DWMAC_DESC_ERX_DES0_FRAME_LENGTH_GET( p_enh[desc_idx].erx.des0_3.des0 )
> + - 2U;
> + } else {
> + return DWMAC_DESC_ERX_DES0_FRAME_LENGTH_GET( p_enh[desc_idx].erx.des0_3.des0 );
> +static bool dwmac_desc_enh_am_i_rx_owner(
> + bool am_i_owner;
> + am_i_owner =
> + ( p_enh[desc_idx].erx.des0_3.des0 & DWMAC_DESC_ERX_DES0_OWN_BIT ) == 0;
> + return am_i_owner;
> +static bool dwmac_desc_enh_am_i_tx_owner(
> + bool am_i_owner;
> + am_i_owner =
> + ( p_enh[idx_tx].etx.des0_3.des0 & DWMAC_DESC_ETX_DES0_OWN_BIT ) == 0;
> +static void dwmac_desc_enh_release_tx_ownership(
> + p_enh[idx_tx].erx.des0_3.des0 |= DWMAC_DESC_ETX_DES0_OWN_BIT;
> +static int dwmac_desc_enh_get_tx_ls(
> + return ( ( p_enh[idx_tx].etx.des0_3.des0
> + & DWMAC_DESC_ETX_DES0_LAST_SEGMENT ) != 0 );
> +static void dwmac_desc_enh_release_tx_desc(
> + p_enh[idx_tx].etx.des0_3.des0 =
> + & ( DWMAC_DESC_ETX_DES0_TRANSMIT_END_OF_RING
> + | DWMAC_DESC_ETX_DES0_SECOND_ADDR_CHAINED );
> + p_enh[idx_tx].etx.des0_3.des1 = 0;
> +static void dwmac_desc_enh_prepare_tx_desc(
> + const size_t len,
> + if ( is_first ) {
> + p_enh[idx].etx.des0_3.des0 |= DWMAC_DESC_ETX_DES0_FIRST_SEGMENT;
> + dwmac_desc_enh_set_tx_desc_len( &p_enh[idx], len );
> + p_enh[idx].etx.des0_3.des2 = (uintptr_t) pdata;
> +static void dwmac_desc_enh_close_tx_desc(
> + p_enh[idx_tx].etx.des0_3.des0 |= DWMAC_DESC_ETX_DES0_LAST_SEGMENT;
> + p_enh[idx_tx].etx.des0_3.des0 |= DWMAC_DESC_ETX_DES0_IRQ_ON_COMPLETION;
> +static bool dwmac_desc_enh_is_first_rx_segment(
> + volatile dwmac_desc_ext *p_descs = (volatile dwmac_desc_ext *) self->dma_rx;
> + return ( ( p_descs[descriptor_index].erx.des0_3.des0
> + & DWMAC_DESC_ERX_DES0_FIRST_DESCRIPTOR ) != 0 );
> +static bool dwmac_desc_enh_is_last_rx_segment(
> + & DWMAC_DESC_ERX_DES0_LAST_DESCRIPTOR ) != 0 );
> +int dwmac_desc_enh_validate( dwmac_common_context *self )
> + /* Does the hardware support enhanced descriptors? */
> + if ( ( self->dmagrp->hw_feature & DMAGRP_HW_FEATURE_ENHDESSEL ) != 0 ) {
> + return 0;
> + } else {
> + return EINVAL;
> +bool dwmac_desc_enh_use_enhanced_descs( dwmac_common_context *self )
> + (void) self;
> + /* Yes, we use enhanced descriptors */
> + return true;
> +const dwmac_common_desc_ops dwmac_desc_ops_enhanced = {
> + .validate = dwmac_desc_enh_validate,
> + .use_enhanced_descs = dwmac_desc_enh_use_enhanced_descs,
> + .tx_status = dwmac_desc_enh_get_tx_status,
> + .rx_status = dwmac_desc_enh_get_rx_status,
> + .create_rx_desc = dwmac_desc_enh_create_rx_desc,
> + .create_tx_desc = dwmac_desc_enh_create_tx_desc,
> + .destroy_rx_desc = dwmac_desc_enh_destroy_rx_desc,
> + .destroy_tx_desc = dwmac_desc_enh_destroy_tx_desc,
> + .init_rx_desc = dwmac_desc_enh_init_rx_desc,
> + .init_tx_desc = dwmac_desc_enh_init_tx_desc,
> + .release_rx_bufs = dwmac_desc_enh_release_rx_bufs,
> + .release_tx_bufs = dwmac_desc_enh_release_tx_bufs,
> + .alloc_data_buf = dwmac_desc_com_new_mbuf,
> + .am_i_tx_owner = dwmac_desc_enh_am_i_tx_owner,
> + .am_i_rx_owner = dwmac_desc_enh_am_i_rx_owner,
> + .release_tx_desc = dwmac_desc_enh_release_tx_desc,
> + .prepare_tx_desc = dwmac_desc_enh_prepare_tx_desc,
> + .close_tx_desc = dwmac_desc_enh_close_tx_desc,
> + .get_tx_ls = dwmac_desc_enh_get_tx_ls,
> + .release_tx_ownership = dwmac_desc_enh_release_tx_ownership,
> + .get_rx_frame_len = dwmac_desc_enh_get_rx_frame_len,
> + .is_first_rx_segment = dwmac_desc_enh_is_first_rx_segment,
> + .is_last_rx_segment = dwmac_desc_enh_is_last_rx_segment,
> + .print_tx_desc = dwmac_desc_enh_print_tx_desc,
> + .print_rx_desc = dwmac_desc_enh_print_rx_desc,
> +/* This wrapped function pointer struct can be passed into the
> + * configuration initializer for the driver */
> +const dwmac_descriptor_ops DWMAC_DESCRIPTOR_OPS_ENHANCED =
> + DWMAC_DESCRIPTOR_OPS_INITIALIZER(
> + &dwmac_desc_ops_enhanced
> \ No newline at end of file
> diff --git a/c/src/libchip/network/dwmac-desc.h b/c/src/libchip/network/dwmac-desc.h
> new file mode 100644
> index 0000000..bc5b54a
> --- /dev/null
> +++ b/c/src/libchip/network/dwmac-desc.h
> @@ -0,0 +1,257 @@
> +#ifndef DWMAC_DESC_RX_REGS_H
> +#define DWMAC_DESC_RX_REGS_H
> +#include <bsp/utility.h>
> +typedef struct {
> + uint32_t des0;
> +#define DWMAC_DESC_RX_DES0_OWN_BIT BSP_BIT32(31)
> +#define DWMAC_DESC_RX_DES0_DEST_ADDR_FILTER_FAIL BSP_BIT32(30)
> +#define DWMAC_DESC_RX_DES0_FRAME_LENGTH(val) BSP_FLD32(val, 16, 29)
> +#define DWMAC_DESC_RX_DES0_FRAME_LENGTH_GET(reg) BSP_FLD32GET(reg, 16, 29)
> +#define DWMAC_DESC_RX_DES0_FRAME_LENGTH_SET(reg, val) BSP_FLD32SET(reg, val, 16, 29)
> +#define DWMAC_DESC_RX_DES0_ERROR_SUMMARY BSP_BIT32(15)
> +#define DWMAC_DESC_RX_DES0_DESCRIPTOR_ERROR BSP_BIT32(14)
> +#define DWMAC_DESC_RX_DES0_SRC_ADDR_FILTER_FAIL BSP_BIT32(13)
> +#define DWMAC_DESC_RX_DES0_LENGTH_ERROR BSP_BIT32(12)
> +#define DWMAC_DESC_RX_DES0_OVERFLOW_ERROR BSP_BIT32(11)
> +#define DWMAC_DESC_RX_DES0_VLAN_TAG BSP_BIT32(10)
> +#define DWMAC_DESC_RX_DES0_FIRST_DESCRIPTOR BSP_BIT32(9)
> +#define DWMAC_DESC_RX_DES0_LAST_DESCRIPTOR BSP_BIT32(8)
> +#define DWMAC_DESC_RX_DES0_CHECKSUM_ERROR BSP_BIT32(7)
> +#define DWMAC_DESC_RX_DES0_LATE_COLLISION BSP_BIT32(6)
> +#define DWMAC_DESC_RX_DES0_FRAME_TYPE BSP_BIT32(5)
> +#define DWMAC_DESC_RX_DES0_RECEIVE_WATCHDOG_TIMEOUT BSP_BIT32(4)
> +#define DWMAC_DESC_RX_DES0_RECEIVE_ERROR BSP_BIT32(3)
> +#define DWMAC_DESC_RX_DES0_DRIBBLE_BIT_ERROR BSP_BIT32(2)
> +#define DWMAC_DESC_RX_DES0_CRC_ERROR BSP_BIT32(1)
> +#define DWMAC_DESC_RX_DES0_RX_MAC_ADDR_OR_PAYLOAD_CHECKSUM_ERROR BSP_BIT32(0)
> + uint32_t des1;
> +#define DWMAC_DESC_RX_DES1_DISABLE_IRQ_ON_COMPLETION BSP_BIT32(31)
> +#define DWMAC_DESC_RX_DES1_RECEIVE_END_OF_RING BSP_BIT32(25)
> +#define DWMAC_DESC_RX_DES1_SECOND_ADDR_CHAINED BSP_BIT32(24)
> +#define DWMAC_DESC_RX_DES1_RECEIVE_BUFFER_2_SIZE(val) BSP_FLD32(val, 11, 21)
> +#define DWMAC_DESC_RX_DES1_RECEIVE_BUFFER_2_SIZE_GET(reg) BSP_FLD32GET(reg, 11, 21)
> +#define DWMAC_DESC_RX_DES1_RECEIVE_BUFFER_2_SIZE_SET(reg, val) BSP_FLD32SET(reg, val, 11, 21)
> +#define DWMAC_DESC_RX_DES1_RECIVE_BUFFER_1_SIZE(val) BSP_FLD32(val, 0, 10)
> +#define DWMAC_DESC_RX_DES1_RECIVE_BUFFER_1_SIZE_GET(reg) BSP_FLD32GET(reg, 0, 10)
> +#define DWMAC_DESC_RX_DES1_RECIVE_BUFFER_1_SIZE_SET(reg, val) BSP_FLD32SET(reg, val, 0, 10)
> + uint32_t des2;
> +#define DWMAC_DESC_RX_DES2_BUFF_1_ADDR_PTR(val) BSP_FLD32(val, 0, 31)
> +#define DWMAC_DESC_RX_DES2_BUFF_1_ADDR_PTR_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DWMAC_DESC_RX_DES2_BUFF_1_ADDR_PTR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> +#define DWMAC_DESC_RX_DES2_IEEE_RECEIVE_FRAME_TIMESTAMP_LOW(val) BSP_FLD32(val, 0, 31)
> +#define DWMAC_DESC_RX_DES2_IEEE_RECEIVE_FRAME_TIMESTAMP_LOW_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DWMAC_DESC_RX_DES2_IEEE_RECEIVE_FRAME_TIMESTAMP_LOW_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> + uint32_t des3;
> +#define DWMAC_DESC_RX_DES3_BUFF_2_ADDR_PTR(val) BSP_FLD32(val, 0, 31)
> +#define DWMAC_DESC_RX_DES3_BUFF_2_ADDR_PTR_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DWMAC_DESC_RX_DES3_BUFF_2_ADDR_PTR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> +#define DWMAC_DESC_RX_DES3_IEEE_RECEIVE_FRAME_TIMESTAMP_LOW(val) BSP_FLD32(val, 0, 31)
> +#define DWMAC_DESC_RX_DES3_IEEE_RECEIVE_FRAME_TIMESTAMP_LOW_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DWMAC_DESC_RX_DES3_IEEE_RECEIVE_FRAME_TIMESTAMP_LOW_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> +} dwmac_desc_rx;
> +typedef struct {
> + uint32_t des0;
> +#define DWMAC_DESC_TX_DES0_OWN_BIT BSP_BIT32(31)
> +#define DWMAC_DESC_TX_DES0_TX_TIMESTAMP_STATUS BSP_BIT32(17)
> +#define DWMAC_DESC_TX_DES0_IP_HEADER_ERROR BSP_BIT32(16)
> +#define DWMAC_DESC_TX_DES0_ERROR_SUMMARY BSP_BIT32(15)
> +#define DWMAC_DESC_TX_DES0_JABBER_TIMEOUT BSP_BIT32(14)
> +#define DWMAC_DESC_TX_DES0_FRAME_FLUSHED BSP_BIT32(13)
> +#define DWMAC_DESC_TX_DES0_PAYLOAD_CHECKSUM_ERROR BSP_BIT32(12)
> +#define DWMAC_DESC_TX_DES0_LOSS_OF_CARRIER BSP_BIT32(11)
> +#define DWMAC_DESC_TX_DES0_NO_CARRIER BSP_BIT32(10)
> +#define DWMAC_DESC_TX_DES0_EXCESSIVE_COLLISION BSP_BIT32(8)
> +#define DWMAC_DESC_TX_DES0_VLAN_FRAME BSP_BIT32(7)
> +#define DWMAC_DESC_TX_DES0_COLLISION_TIMEOUT(val) BSP_FLD32(val, 3, 6)
> +#define DWMAC_DESC_TX_DES0_COLLISION_TIMEOUT_GET(reg) BSP_FLD32GET(reg, 3, 6)
> +#define DWMAC_DESC_TX_DES0_COLLISION_TIMEOUT_SET(reg, val) BSP_FLD32SET(reg, val, 3, 6)
> +#define DWMAC_DESC_TX_DES0_EXCESSIVE_DEFERAL BSP_BIT32(2)
> +#define DWMAC_DESC_TX_DES0_UNDERFLOW_ERROR BSP_BIT32(1)
> +#define DWMAC_DESC_TX_DES0_DEFERED_BIT BSP_BIT32(0)
> + uint32_t des1;
> +#define DWMAC_DESC_TX_DES1_IRQ_ON_COMPLETION BSP_BIT32(31)
> +#define DWMAC_DESC_TX_DES1_LAST_SEGMENT BSP_BIT32(30)
> +#define DWMAC_DESC_TX_DES1_FIRST_SEGMENT BSP_BIT32(29)
> +#define DWMAC_DESC_TX_DES1_CHECKSUM_INSERTION_CONTROL(val) BSP_FLD32(val, 27, 28)
> +#define DWMAC_DESC_TX_DES1_CHECKSUM_INSERTION_CONTROL_GET(reg) BSP_FLD32GET(reg, 27, 28)
> +#define DWMAC_DESC_TX_DES1_CHECKSUM_INSERTION_CONTROL_SET(reg, val) BSP_FLD32SET(reg, val, 27, 28)
> +#define DWMAC_DESC_TX_DES1_DISABLE_CRC BSP_BIT32(26)
> +#define DWMAC_DESC_TX_DES1_TRANSMIT_END_OF_RING BSP_BIT32(25)
> +#define DWMAC_DESC_TX_DES1_SECOND_ADDRESS_CHAINED BSP_BIT32(24)
> +#define DWMAC_DESC_TX_DES1_DISABLE_PADDING BSP_BIT32(23)
> +#define DWMAC_DESC_TX_DES1_TRANSMIT_TIMESTAMP_ENABLE BSP_BIT32(22)
> +#define DWMAC_DESC_TX_DES1_TRANMIT_BUFFER_2_SIZE(val) BSP_FLD32(val, 11, 21)
> +#define DWMAC_DESC_TX_DES1_TRANMIT_BUFFER_2_SIZE_GET(reg) BSP_FLD32GET(reg, 11, 21)
> +#define DWMAC_DESC_TX_DES1_TRANMIT_BUFFER_2_SIZE_SET(reg, val) BSP_FLD32SET(reg, val, 11, 21)
> +#define DWMAC_DESC_TX_DES1_TRANSMIT_BUFFER_1_SIZE(val) BSP_FLD32(val, 0, 10)
> +#define DWMAC_DESC_TX_DES1_TRANSMIT_BUFFER_1_SIZE_GET(reg) BSP_FLD32GET(reg, 0, 10)
> +#define DWMAC_DESC_TX_DES1_TRANSMIT_BUFFER_1_SIZE_SET(reg, val) BSP_FLD32SET(reg, val, 0, 10)
> + uint32_t des2;
> +#define DWMAC_DESC_TX_DES2_BUFF_1_ADDR_PTR(val) BSP_FLD32(val, 0, 31)
> +#define DWMAC_DESC_TX_DES2_BUFF_1_ADDR_PTR_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DWMAC_DESC_TX_DES2_BUFF_1_ADDR_PTR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> +#define DWMAC_DESC_TX_DES2_IEEE_TRANSMIT_FRAME_TIMESTAMP_LOW(val) BSP_FLD32(val, 0, 31)
> +#define DWMAC_DESC_TX_DES2_IEEE_TRANSMIT_FRAME_TIMESTAMP_LOW_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DWMAC_DESC_TX_DES2_IEEE_TRANSMIT_FRAME_TIMESTAMP_LOW_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> + uint32_t des3;
> +#define DWMAC_DESC_TX_DES3_BUFF_2_ADDR_PTR(val) BSP_FLD32(val, 0, 31)
> +#define DWMAC_DESC_TX_DES3_BUFF_2_ADDR_PTR_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DWMAC_DESC_TX_DES3_BUFF_2_ADDR_PTR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> +#define DWMAC_DESC_TX_DES3_IEEE_TRANSMIT_FRAME_TIMESTAMP_LOW(val) BSP_FLD32(val, 0, 31)
> +#define DWMAC_DESC_TX_DES3_IEEE_TRANSMIT_FRAME_TIMESTAMP_LOW_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DWMAC_DESC_TX_DES3_IEEE_TRANSMIT_FRAME_TIMESTAMP_LOW_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> +} dwmac_desc_tx;
> +typedef struct {
> + uint32_t des0;
> +#define DWMAC_DESC_ERX_DES0_OWN_BIT BSP_BIT32(31)
> +#define DWMAC_DESC_ERX_DES0_DEST_ADDR_FILTER_FAIL BSP_BIT32(30)
> +#define DWMAC_DESC_ERX_DES0_FRAME_LENGTH(val) BSP_FLD32(val, 16, 29)
> +#define DWMAC_DESC_ERX_DES0_FRAME_LENGTH_GET(reg) BSP_FLD32GET(reg, 16, 29)
> +#define DWMAC_DESC_ERX_DES0_FRAME_LENGTH_SET(reg, val) BSP_FLD32SET(reg, val, 16, 29)
> +#define DWMAC_DESC_ERX_DES0_ERROR_SUMMARY BSP_BIT32(15)
> +#define DWMAC_DESC_ERX_DES0_DESCRIPTOR_ERROR BSP_BIT32(14)
> +#define DWMAC_DESC_ERX_DES0_SRC_ADDR_FILTER_FAIL BSP_BIT32(13)
> +#define DWMAC_DESC_ERX_DES0_LENGTH_ERROR BSP_BIT32(12)
> +#define DWMAC_DESC_ERX_DES0_OVERFLOW_ERROR BSP_BIT32(11)
> +#define DWMAC_DESC_ERX_DES0_VLAN_TAG BSP_BIT32(10)
> +#define DWMAC_DESC_ERX_DES0_FIRST_DESCRIPTOR BSP_BIT32(9)
> +#define DWMAC_DESC_ERX_DES0_LAST_DESCRIPTOR BSP_BIT32(8)
> +#define DWMAC_DESC_ERX_DES0_TIMESTAMP_AVAIL_OR_CHECKSUM_ERROR_OR_GIANT_FRAME BSP_BIT32(7)
> +#define DWMAC_DESC_ERX_DES0_LATE_COLLISION BSP_BIT32(6)
> +#define DWMAC_DESC_ERX_DES0_FREAME_TYPE BSP_BIT32(5)
> +#define DWMAC_DESC_ERX_DES0_RECEIVE_WATCHDOG_TIMEOUT BSP_BIT32(4)
> +#define DWMAC_DESC_ERX_DES0_RECEIVE_ERROR BSP_BIT32(3)
> +#define DWMAC_DESC_ERX_DES0_DRIBBLE_BIT_ERROR BSP_BIT32(2)
> +#define DWMAC_DESC_ERX_DES0_CRC_ERROR BSP_BIT32(1)
> +#define DWMAC_DESC_ERX_DES0_EXT_STATUS_AVAIL_OR_RX_MAC_ADDR_STATUS BSP_BIT32(0)
> + uint32_t des1;
> +#define DWMAC_DESC_ERX_DES1_DISABLE_IRQ_ON_COMPLETION BSP_BIT32(31)
> +#define DWMAC_DESC_ERX_DES1_RECEIVE_BUFF_2_SIZE(val) BSP_FLD32(val, 16, 28)
> +#define DWMAC_DESC_ERX_DES1_RECEIVE_BUFF_2_SIZE_GET(reg) BSP_FLD32GET(reg, 16, 28)
> +#define DWMAC_DESC_ERX_DES1_RECEIVE_BUFF_2_SIZE_SET(reg, val) BSP_FLD32SET(reg, val, 16, 28)
> +#define DWMAC_DESC_ERX_DES1_RECEIVE_END_OF_RING BSP_BIT32(15)
> +#define DWMAC_DESC_ERX_DES1_SECOND_ADDR_CHAINED BSP_BIT32(14)
> +#define DWMAC_DESC_ERX_DES1_RECEIVE_BUFF_1_SIZE(val) BSP_FLD32(val, 0, 12)
> +#define DWMAC_DESC_ERX_DES1_RECEIVE_BUFF_1_SIZE_GET(reg) BSP_FLD32GET(reg, 0, 12)
> +#define DWMAC_DESC_ERX_DES1_RECEIVE_BUFF_1_SIZE_SET(reg, val) BSP_FLD32SET(reg, val, 0, 12)
> + uint32_t des2;
> +#define DWMAC_DESC_ERX_DES2_BUFF_1_ADDR_PTR(val) BSP_FLD32(val, 0, 31)
> +#define DWMAC_DESC_ERX_DES2_BUFF_1_ADDR_PTR_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DWMAC_DESC_ERX_DES2_BUFF_1_ADDR_PTR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> + uint32_t des3;
> +#define DWMAC_DESC_ERX_DES3_BUFF_2_ADDR_PTR(val) BSP_FLD32(val, 0, 31)
> +#define DWMAC_DESC_ERX_DES3_BUFF_2_ADDR_PTR_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DWMAC_DESC_ERX_DES3_BUFF_2_ADDR_PTR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> +} dwmac_desc_erx;
> +typedef struct {
> + uint32_t des0;
> +#define DWMAC_DESC_ETX_DES0_OWN_BIT BSP_BIT32(31)
> +#define DWMAC_DESC_ETX_DES0_IRQ_ON_COMPLETION BSP_BIT32(30)
> +#define DWMAC_DESC_ETX_DES0_LAST_SEGMENT BSP_BIT32(29)
> +#define DWMAC_DESC_ETX_DES0_FIRST_SEGMENT BSP_BIT32(28)
> +#define DWMAC_DESC_ETX_DES0_DISABLE_CRC BSP_BIT32(27)
> +#define DWMAC_DESC_ETX_DES0_DISABLE_PAD BSP_BIT32(26)
> +#define DWMAC_DESC_ETX_DES0_TRANSMIT_TIMESTAMP_ENABLE BSP_BIT32(25)
> +#define DWMAC_DESC_ETX_DES0_CHECKSUM_INSERTION_CONTROL(val) BSP_FLD32(val, 22, 23)
> +#define DWMAC_DESC_ETX_DES0_CHECKSUM_INSERTION_CONTROL_GET(reg) BSP_FLD32GET(reg, 22, 23)
> +#define DWMAC_DESC_ETX_DES0_CHECKSUM_INSERTION_CONTROL_SET(reg, val) BSP_FLD32SET(reg, val, 22, 23)
> +#define DWMAC_DESC_ETX_DES0_TRANSMIT_END_OF_RING BSP_BIT32(21)
> +#define DWMAC_DESC_ETX_DES0_SECOND_ADDR_CHAINED BSP_BIT32(20)
> +#define DWMAC_DESC_ETX_DES0_TRANSMIT_TIMESTAMP_STATUS BSP_BIT32(17)
> +#define DWMAC_DESC_ETX_DES0_IP_HEADER_ERROR BSP_BIT32(16)
> +#define DWMAC_DESC_ETX_DES0_ERROR_SUMMARY BSP_BIT32(15)
> +#define DWMAC_DESC_ETX_DES0_JABBER_TIMEOUT BSP_BIT32(14)
> +#define DWMAC_DESC_ETX_DES0_FRAME_FLUSHED BSP_BIT32(13)
> +#define DWMAC_DESC_ETX_DES0_IP_PAYLOAD_ERROR BSP_BIT32(12)
> +#define DWMAC_DESC_ETX_DES0_LOSS_OF_CARRIER BSP_BIT32(11)
> +#define DWMAC_DESC_ETX_DES0_NO_CARRIER BSP_BIT32(10)
> +#define DWMAC_DESC_ETX_DES0_EXCESSIVE_COLLISION BSP_BIT32(8)
> +#define DWMAC_DESC_ETX_DES0_VLAN_FRAME BSP_BIT32(7)
> +#define DWMAC_DESC_ETX_DES0_COLLISION_COUNT(val) BSP_FLD32(val, 3, 6)
> +#define DWMAC_DESC_ETX_DES0_COLLISION_COUNT_GET(reg) BSP_FLD32GET(reg, 3, 6)
> +#define DWMAC_DESC_ETX_DES0_COLLISION_COUNT_SET(reg, val) BSP_FLD32SET(reg, val, 3, 6)
> +#define DWMAC_DESC_ETX_DES0_EXCESSIVE_DEFERAL BSP_BIT32(2)
> +#define DWMAC_DESC_ETX_DES0_UNDERFLOW_ERROR BSP_BIT32(1)
> +#define DWMAC_DESC_ETX_DES0_DEFERRED_BIT BSP_BIT32(0)
> + uint32_t des1;
> +#define DWMAC_DESC_ETX_DES1_TRANSMIT_BUFFER_2_SIZE(val) BSP_FLD32(val, 16, 28)
> +#define DWMAC_DESC_ETX_DES1_TRANSMIT_BUFFER_2_SIZE_GET(reg) BSP_FLD32GET(reg, 16, 28)
> +#define DWMAC_DESC_ETX_DES1_TRANSMIT_BUFFER_2_SIZE_SET(reg, val) BSP_FLD32SET(reg, val, 16, 28)
> +#define DWMAC_DESC_ETX_DES1_TRANSMIT_BUFFER_1_SIZE(val) BSP_FLD32(val, 0, 12)
> +#define DWMAC_DESC_ETX_DES1_TRANSMIT_BUFFER_1_SIZE_GET(reg) BSP_FLD32GET(reg, 0, 12)
> +#define DWMAC_DESC_ETX_DES1_TRANSMIT_BUFFER_1_SIZE_SET(reg, val) BSP_FLD32SET(reg, val, 0, 12)
> + uint32_t des2;
> +#define DWMAC_DESC_ETX_DES2_BUFF_1_ADDR_PTR(val) BSP_FLD32(val, 0, 31)
> +#define DWMAC_DESC_ETX_DES2_BUFF_1_ADDR_PTR_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DWMAC_DESC_ETX_DES2_BUFF_1_ADDR_PTR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> + uint32_t des3;
> +#define DWMAC_DESC_ETX_DES3_BUFF_2_ADDR_PTR(val) BSP_FLD32(val, 0, 31)
> +#define DWMAC_DESC_ETX_DES3_BUFF_2_ADDR_PTR_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DWMAC_DESC_ETX_DES3_BUFF_2_ADDR_PTR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> +} dwmac_desc_etx;
> +typedef union {
> + dwmac_desc_rx rx;
> + dwmac_desc_tx tx;
> + dwmac_desc_erx erx;
> + dwmac_desc_etx etx;
> +} dwmac_desc;
> +typedef struct {
> + dwmac_desc_erx des0_3;
> + uint32_t des4;
> +#define DWMAC_DESC_EXT_ERX_DES4_LAYER3_AND_LAYER4_FILTER_MATCHED(val) BSP_FLD32(val, 26, 27)
> +#define DWMAC_DESC_EXT_ERX_DES4_LAYER3_AND_LAYER4_FILTER_MATCHED_GET(reg) BSP_FLD32GET(reg, 26, 27)
> +#define DWMAC_DESC_EXT_ERX_DES4_LAYER3_AND_LAYER4_FILTER_MATCHED_SET(reg, val) BSP_FLD32SET(reg, val, 26, 27)
> +#define DWMAC_DESC_EXT_ERX_DES4_LAYER4_FILTER_MATCH BSP_BIT32(25)
> +#define DWMAC_DESC_EXT_ERX_DES4_LAYER3_FILTER_MATCH BSP_BIT32(24)
> +#define DWMAC_DESC_EXT_ERX_DES4_TIMESTAMP_DROPPED BSP_BIT32(14)
> +#define DWMAC_DESC_EXT_ERX_DES4_PTP_VERSION BSP_BIT32(13)
> +#define DWMAC_DESC_EXT_ERX_DES4_PTP_FRAME_TYPE BSP_BIT32(12)
> +#define DWMAC_DESC_EXT_ERX_DES4_MESSAGE_TYPE(val) BSP_FLD32(val, 8, 11)
> +#define DWMAC_DESC_EXT_ERX_DES4_MESSAGE_TYPE_GET(reg) BSP_FLD32GET(reg, 8, 11)
> +#define DWMAC_DESC_EXT_ERX_DES4_MESSAGE_TYPE_SET(reg, val) BSP_FLD32SET(reg, val, 8, 11)
> +#define DWMAC_DESC_EXT_ERX_DES4_IPV6_PACKET_RECEIVED BSP_BIT32(7)
> +#define DWMAC_DESC_EXT_ERX_DES4_IPV4_PACKET_RECEIVED BSP_BIT32(6)
> +#define DWMAC_DESC_EXT_ERX_DES4_IP_CHECKSUM_BYPASSED BSP_BIT32(5)
> +#define DWMAC_DESC_EXT_ERX_DES4_IP_PAYLOAD_ERROR BSP_BIT32(4)
> +#define DWMAC_DESC_EXT_ERX_DES4_IP_HEADER_ERROR BSP_BIT32(3)
> +#define DWMAC_DESC_EXT_ERX_DES4_IP_PAYLOAD_TYPE(val) BSP_FLD32(val, 0, 2)
> +#define DWMAC_DESC_EXT_ERX_DES4_IP_PAYLOAD_TYPE_GET(reg) BSP_FLD32GET(reg, 0, 2)
> +#define DWMAC_DESC_EXT_ERX_DES4_IP_PAYLOAD_TYPE_SET(reg, val) BSP_FLD32SET(reg, val, 0, 2)
> + uint32_t des5;
> + uint32_t des6;
> +#define DWMAC_DESC_EXT_ERX_DES6_RECEIVE_FRAME_TIMESTAMP_LOW(val) BSP_FLD32(val, 0, 31)
> +#define DWMAC_DESC_EXT_ERX_DES6_RECEIVE_FRAME_TIMESTAMP_LOW_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DWMAC_DESC_EXT_ERX_DES6_RECEIVE_FRAME_TIMESTAMP_LOW_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> + uint32_t des7;
> +#define DWMAC_DESC_EXT_ERX_DES7_RECEIVE_FRAME_TIMESTAMP_HIGH(val) BSP_FLD32(val, 0, 31)
> +#define DWMAC_DESC_EXT_ERX_DES7_RECEIVE_FRAME_TIMESTAMP_HIGH_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DWMAC_DESC_EXT_ERX_DES7_RECEIVE_FRAME_TIMESTAMP_HIGH_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> +} dwmac_desc_ext_erx;
> +typedef struct {
> + dwmac_desc_etx des0_3;
> + uint32_t des4;
> + uint32_t des5;
> + uint32_t des6;
> +#define DWMAC_DESC_EXT_ETX_DES6_TRANSMIT_FRAME_TIMESTAMP_LOW(val) BSP_FLD32(val, 0, 31)
> +#define DWMAC_DESC_EXT_ETX_DES6_TRANSMIT_FRAME_TIMESTAMP_LOW_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DWMAC_DESC_EXT_ETX_DES6_TRANSMIT_FRAME_TIMESTAMP_LOW_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> + uint32_t des7;
> +#define DWMAC_DESC_EXT_ETX_DES7_TRANSMIT_FRAME_TIMESTAMP_HIGH(val) BSP_FLD32(val, 0, 31)
> +#define DWMAC_DESC_EXT_ETX_DES7_TRANSMIT_FRAME_TIMESTAMP_HIGH_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DWMAC_DESC_EXT_ETX_DES7_TRANSMIT_FRAME_TIMESTAMP_HIGH_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> +} dwmac_desc_ext_etx;
> +typedef union {
> + dwmac_desc_ext_erx erx;
> + dwmac_desc_ext_etx etx;
> +} dwmac_desc_ext;
> +#endif /* DWMAC_DESC_RX_REGS_H */
> diff --git a/c/src/libchip/network/dwmac-regs.h b/c/src/libchip/network/dwmac-regs.h
> index 0000000..53d7486
> --- /dev/null
> +++ b/c/src/libchip/network/dwmac-regs.h
> @@ -0,0 +1,515 @@
> +#ifndef MAC_REGS_H
> +#define MAC_REGS_H
> +typedef struct {
> + uint32_t high;
> +#define MAC_HIGH_ADDRHI(val) BSP_FLD32(val, 0, 15)
> +#define MAC_HIGH_ADDRHI_GET(reg) BSP_FLD32GET(reg, 0, 15)
> +#define MAC_HIGH_ADDRHI_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
> +#define MAC_HIGH_MBC0 BSP_BIT32(24)
> +#define MAC_HIGH_MBC1 BSP_BIT32(25)
> +#define MAC_HIGH_MBC2 BSP_BIT32(26)
> +#define MAC_HIGH_MBC3 BSP_BIT32(27)
> +#define MAC_HIGH_MBC4 BSP_BIT32(28)
> +#define MAC_HIGH_MBC5 BSP_BIT32(29)
> +#define MAC_HIGH_SA BSP_BIT32(30)
> +#define MAC_HIGH_AE BSP_BIT32(31)
> + uint32_t low;
> +#define MAC_LOW_ADDRLO(val) BSP_FLD32(val, 0, 32)
> +#define MAC_LOW_ADDRLO_GET(reg) BSP_FLD32GET(reg, 0, 32)
> +#define MAC_LOW_ADDRLO_SET(reg, val) BSP_FLD32SET(reg, val, 0, 32)
> +} mac;
> +typedef struct {
> + uint32_t mac_configuration;
> +#define MACGRP_MAC_CONFIGURATION_PRELEN(val) BSP_FLD32(val, 0, 1)
> +#define MACGRP_MAC_CONFIGURATION_PRELEN_GET(reg) BSP_FLD32GET(reg, 0, 1)
> +#define MACGRP_MAC_CONFIGURATION_PRELEN_SET(reg, val) BSP_FLD32SET(reg, val, 0, 1)
> +#define MACGRP_MAC_CONFIGURATION_RE BSP_BIT32(2)
> +#define MACGRP_MAC_CONFIGURATION_TE BSP_BIT32(3)
> +#define MACGRP_MAC_CONFIGURATION_DC BSP_BIT32(4)
> +#define MACGRP_MAC_CONFIGURATION_BL(val) BSP_FLD32(val, 5, 6)
> +#define MACGRP_MAC_CONFIGURATION_BL_GET(reg) BSP_FLD32GET(reg, 5, 6)
> +#define MACGRP_MAC_CONFIGURATION_BL_SET(reg, val) BSP_FLD32SET(reg, val, 5, 6)
> +#define MACGRP_MAC_CONFIGURATION_ACS BSP_BIT32(7)
> +#define MACGRP_MAC_CONFIGURATION_LUD BSP_BIT32(8)
> +#define MACGRP_MAC_CONFIGURATION_DR BSP_BIT32(9)
> +#define MACGRP_MAC_CONFIGURATION_IPC BSP_BIT32(10)
> +#define MACGRP_MAC_CONFIGURATION_DM BSP_BIT32(11)
> +#define MACGRP_MAC_CONFIGURATION_LM BSP_BIT32(12)
> +#define MACGRP_MAC_CONFIGURATION_DO BSP_BIT32(13)
> +#define MACGRP_MAC_CONFIGURATION_FES BSP_BIT32(14)
> +#define MACGRP_MAC_CONFIGURATION_PS BSP_BIT32(15)
> +#define MACGRP_MAC_CONFIGURATION_DCRS BSP_BIT32(16)
> +#define MACGRP_MAC_CONFIGURATION_IFG(val) BSP_FLD32(val, 17, 19)
> +#define MACGRP_MAC_CONFIGURATION_IFG_GET(reg) BSP_FLD32GET(reg, 17, 19)
> +#define MACGRP_MAC_CONFIGURATION_IFG_SET(reg, val) BSP_FLD32SET(reg, val, 17, 19)
> +#define MACGRP_MAC_CONFIGURATION_JE BSP_BIT32(20)
> +#define MACGRP_MAC_CONFIGURATION_BE BSP_BIT32(21)
> +#define MACGRP_MAC_CONFIGURATION_JD BSP_BIT32(22)
> +#define MACGRP_MAC_CONFIGURATION_WD BSP_BIT32(23)
> +#define MACGRP_MAC_CONFIGURATION_TC BSP_BIT32(24)
> +#define MACGRP_MAC_CONFIGURATION_CST BSP_BIT32(25)
> +#define MACGRP_MAC_CONFIGURATION_TWOKPE BSP_BIT32(27)
> + uint32_t mac_frame_filter;
> +#define MACGRP_MAC_FRAME_FILTER_PR BSP_BIT32(0)
> +#define MACGRP_MAC_FRAME_FILTER_HUC BSP_BIT32(1)
> +#define MACGRP_MAC_FRAME_FILTER_HMC BSP_BIT32(2)
> +#define MACGRP_MAC_FRAME_FILTER_DAIF BSP_BIT32(3)
> +#define MACGRP_MAC_FRAME_FILTER_PM BSP_BIT32(4)
> +#define MACGRP_MAC_FRAME_FILTER_DBF BSP_BIT32(5)
> +#define MACGRP_MAC_FRAME_FILTER_PCF(val) BSP_FLD32(val, 6, 7)
> +#define MACGRP_MAC_FRAME_FILTER_PCF_GET(reg) BSP_FLD32GET(reg, 6, 7)
> +#define MACGRP_MAC_FRAME_FILTER_PCF_SET(reg, val) BSP_FLD32SET(reg, val, 6, 7)
> +#define MACGRP_MAC_FRAME_FILTER_SAIF BSP_BIT32(8)
> +#define MACGRP_MAC_FRAME_FILTER_SAF BSP_BIT32(9)
> +#define MACGRP_MAC_FRAME_FILTER_HPF BSP_BIT32(10)
> +#define MACGRP_MAC_FRAME_FILTER_VTFE BSP_BIT32(16)
> +#define MACGRP_MAC_FRAME_FILTER_IPFE BSP_BIT32(20)
> +#define MACGRP_MAC_FRAME_FILTER_DNTU BSP_BIT32(21)
> +#define MACGRP_MAC_FRAME_FILTER_RA BSP_BIT32(31)
> + uint32_t reserved_08[2];
> + uint32_t gmii_address;
> +#define MACGRP_GMII_ADDRESS_GMII_BUSY BSP_BIT32(0)
> +#define MACGRP_GMII_ADDRESS_GMII_WRITE BSP_BIT32(1)
> +#define MACGRP_GMII_ADDRESS_CSR_CLOCK_RANGE(val) BSP_FLD32(val, 2, 5)
> +#define MACGRP_GMII_ADDRESS_CSR_CLOCK_RANGE_GET(reg) BSP_FLD32GET(reg, 2, 5)
> +#define MACGRP_GMII_ADDRESS_CSR_CLOCK_RANGE_SET(reg, val) BSP_FLD32SET(reg, val, 2, 5)
> +#define MACGRP_GMII_ADDRESS_GMII_REGISTER(val) BSP_FLD32(val, 6, 10)
> +#define MACGRP_GMII_ADDRESS_GMII_REGISTER_GET(reg) BSP_FLD32GET(reg, 6, 10)
> +#define MACGRP_GMII_ADDRESS_GMII_REGISTER_SET(reg, val) BSP_FLD32SET(reg, val, 6, 10)
> +#define MACGRP_GMII_ADDRESS_PHYSICAL_LAYER_ADDRESS(val) BSP_FLD32(val, 11, 15)
> +#define MACGRP_GMII_ADDRESS_PHYSICAL_LAYER_ADDRESS_GET(reg) BSP_FLD32GET(reg, 11, 15)
> +#define MACGRP_GMII_ADDRESS_PHYSICAL_LAYER_ADDRESS_SET(reg, val) BSP_FLD32SET(reg, val, 11, 15)
> + uint32_t gmii_data;
> +#define MACGRP_GMII_DATA_GMII_DATA(val) BSP_FLD32(val, 0, 15)
> +#define MACGRP_GMII_DATA_GMII_DATA_GET(reg) BSP_FLD32GET(reg, 0, 15)
> +#define MACGRP_GMII_DATA_GMII_DATA_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
> + uint32_t reserved_18[9];
> + uint32_t interrupt_mask;
> +#define MACGRP_INTERRUPT_MASK_RGSMIIIM BSP_BIT32(0)
> +#define MACGRP_INTERRUPT_MASK_PCSLCHGIM BSP_BIT32(1)
> +#define MACGRP_INTERRUPT_MASK_PCSANCIM BSP_BIT32(2)
> +#define MACGRP_INTERRUPT_MASK_TSIM BSP_BIT32(9)
> +#define MACGRP_INTERRUPT_MASK_LPIIM BSP_BIT32(10)
> + mac mac_addr0_15[16];
> + uint32_t reserved_c0[16];
> + uint32_t mmc_control;
> +#define MACGRP_MMC_CONTROL_CNTRST BSP_BIT32(0)
> +#define MACGRP_MMC_CONTROL_CNTSTOPRO BSP_BIT32(1)
> +#define MACGRP_MMC_CONTROL_RSTONRD BSP_BIT32(2)
> +#define MACGRP_MMC_CONTROL_CNTFREEZ BSP_BIT32(3)
> +#define MACGRP_MMC_CONTROL_CNTPRST BSP_BIT32(4)
> +#define MACGRP_MMC_CONTROL_CNTPRSTLVL BSP_BIT32(5)
> +#define MACGRP_MMC_CONTROL_UCDBC BSP_BIT32(8)
> + uint32_t mmc_receive_interrupt;
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXGBFRMIS BSP_BIT32(0)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXGBOCTIS BSP_BIT32(1)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXGOCTIS BSP_BIT32(2)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXBCGFIS BSP_BIT32(3)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXMCGFIS BSP_BIT32(4)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXCRCERFIS BSP_BIT32(5)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXALGNERFIS BSP_BIT32(6)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXRUNTFIS BSP_BIT32(7)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXJABERFIS BSP_BIT32(8)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXUSIZEGFIS BSP_BIT32(9)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXOSIZEGFIS BSP_BIT32(10)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RX64OCTGBFIS BSP_BIT32(11)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RX65T127OCTGBFIS BSP_BIT32(12)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RX128T255OCTGBFIS BSP_BIT32(13)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RX256T511OCTGBFIS BSP_BIT32(14)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RX512T1023OCTGBFIS BSP_BIT32(15)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RX1024TMAXOCTGBFIS BSP_BIT32(16)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXUCGFIS BSP_BIT32(17)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXLENERFIS BSP_BIT32(18)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXORANGEFIS BSP_BIT32(19)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXPAUSFIS BSP_BIT32(20)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXFOVFIS BSP_BIT32(21)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXVLANGBFIS BSP_BIT32(22)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXWDOGFIS BSP_BIT32(23)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXRCVERRFIS BSP_BIT32(24)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_RXCTRLFIS BSP_BIT32(25)
> + uint32_t mmc_transmit_interrupt;
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXGBOCTIS BSP_BIT32(0)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXGBFRMIS BSP_BIT32(1)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXBCGFIS BSP_BIT32(2)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXMCGFIS BSP_BIT32(3)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TX64OCTGBFIS BSP_BIT32(4)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TX65T127OCTGBFIS BSP_BIT32(5)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TX128T255OCTGBFIS BSP_BIT32(6)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TX256T511OCTGBFIS BSP_BIT32(7)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TX512T1023OCTGBFIS BSP_BIT32(8)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TX1024TMAXOCTGBFIS BSP_BIT32(9)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXUCGBFIS BSP_BIT32(10)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXMCGBFIS BSP_BIT32(11)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXBCGBFIS BSP_BIT32(12)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXUFLOWERFIS BSP_BIT32(13)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXSCOLGFIS BSP_BIT32(14)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXMCOLGFIS BSP_BIT32(15)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXDEFFIS BSP_BIT32(16)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXLATCOLFIS BSP_BIT32(17)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXEXCOLFIS BSP_BIT32(18)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXCARERFIS BSP_BIT32(19)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXGOCTIS BSP_BIT32(20)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXGFRMIS BSP_BIT32(21)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXEXDEFFIS BSP_BIT32(22)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXPAUSFIS BSP_BIT32(23)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXVLANGFIS BSP_BIT32(24)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_TXOSIZEGFIS BSP_BIT32(25)
> + uint32_t mmc_receive_interrupt_mask;
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXGBFRMIM BSP_BIT32(0)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXGBOCTIM BSP_BIT32(1)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXGOCTIM BSP_BIT32(2)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXBCGFIM BSP_BIT32(3)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXMCGFIM BSP_BIT32(4)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXCRCERFIM BSP_BIT32(5)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXALGNERFIM BSP_BIT32(6)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXRUNTFIM BSP_BIT32(7)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXJABERFIM BSP_BIT32(8)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXUSIZEGFIM BSP_BIT32(9)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXOSIZEGFIM BSP_BIT32(10)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RX64OCTGBFIM BSP_BIT32(11)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RX65T127OCTGBFIM BSP_BIT32(12)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RX128T255OCTGBFIM BSP_BIT32(13)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RX256T511OCTGBFIM BSP_BIT32(14)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RX512T1023OCTGBFIM BSP_BIT32(15)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RX1024TMAXOCTGBFIM BSP_BIT32(16)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXUCGFIM BSP_BIT32(17)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXLENERFIM BSP_BIT32(18)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXORANGEFIM BSP_BIT32(19)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXPAUSFIM BSP_BIT32(20)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXFOVFIM BSP_BIT32(21)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXVLANGBFIM BSP_BIT32(22)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXWDOGFIM BSP_BIT32(23)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXRCVERRFIM BSP_BIT32(24)
> +#define MACGRP_MMC_RECEIVE_INTERRUPT_MASK_RXCTRLFIM BSP_BIT32(25)
> + uint32_t mmc_transmit_interrupt_mask;
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXGBOCTIM BSP_BIT32(0)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXGBFRMIM BSP_BIT32(1)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXBCGFIM BSP_BIT32(2)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXMCGFIM BSP_BIT32(3)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TX64OCTGBFIM BSP_BIT32(4)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TX65T127OCTGBFIM BSP_BIT32(5)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TX128T255OCTGBFIM BSP_BIT32(6)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TX256T511OCTGBFIM BSP_BIT32(7)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TX512T1023OCTGBFIM BSP_BIT32(8)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TX1024TMAXOCTGBFIM BSP_BIT32(9)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXUCGBFIM BSP_BIT32(10)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXMCGBFIM BSP_BIT32(11)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXBCGBFIM BSP_BIT32(12)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXUFLOWERFIM BSP_BIT32(13)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXSCOLGFIM BSP_BIT32(14)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXMCOLGFIM BSP_BIT32(15)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXDEFFIM BSP_BIT32(16)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXLATCOLFIM BSP_BIT32(17)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXEXCOLFIM BSP_BIT32(18)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXCARERFIM BSP_BIT32(19)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXGOCTIM BSP_BIT32(20)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXGFRMIM BSP_BIT32(21)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXEXDEFFIM BSP_BIT32(22)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXPAUSFIM BSP_BIT32(23)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXVLANGFIM BSP_BIT32(24)
> +#define MACGRP_MMC_TRANSMIT_INTERRUPT_MASK_TXOSIZEGFIM BSP_BIT32(25)
> + uint32_t txoctetcount_gb;
> + uint32_t txframecount_gb;
> + uint32_t txbroadcastframes_g;
> + uint32_t txmulticastframes_g;
> + uint32_t tx64octets_gb;
> + uint32_t tx65to127octets_gb;
> + uint32_t tx128to255octets_gb;
> + uint32_t tx256to511octets_gb;
> + uint32_t tx512to1023octets_gb;
> + uint32_t tx1024tomaxoctets_gb;
> + uint32_t txunicastframes_gb;
> + uint32_t txmulticastframes_gb;
> + uint32_t txbroadcastframes_gb;
> + uint32_t txunderflowerror;
> + uint32_t txsinglecol_g;
> + uint32_t txmulticol_g;
> + uint32_t txdeferred;
> + uint32_t txlatecol;
> + uint32_t txexesscol;
> + uint32_t txcarriererr;
> + uint32_t txoctetcnt;
> + uint32_t txframecount_g;
> + uint32_t txexcessdef;
> + uint32_t txpauseframes;
> + uint32_t txvlanframes_g;
> + uint32_t txoversize_g;
> + uint32_t reserved_17c;
> + uint32_t rxframecount_gb;
> + uint32_t rxoctetcount_gb;
> + uint32_t rxoctetcount_g;
> + uint32_t rxbroadcastframes_g;
> + uint32_t rxmulticastframes_g;
> + uint32_t rxcrcerror;
> + uint32_t rxalignmenterror;
> + uint32_t rxrunterror;
> + uint32_t rxjabbererror;
> + uint32_t rxundersize_g;
> + uint32_t rxoversize_g;
> + uint32_t rx64octets_gb;
> + uint32_t rx65to127octets_gb;
> + uint32_t rx128to255octets_gb;
> + uint32_t rx256to511octets_gb;
> + uint32_t rx512to1023octets_gb;
> + uint32_t rx1024tomaxoctets_gb;
> + uint32_t rxunicastframes_g;
> + uint32_t rxlengtherror;
> + uint32_t rxoutofrangetype;
> + uint32_t rxpauseframes;
> + uint32_t rxfifooverflow;
> + uint32_t rxvlanframes_gb;
> + uint32_t rxwatchdogerror;
> + uint32_t rxrcverror;
> + uint32_t rxctrlframes_g;
> + uint32_t reserved_1e8[6];
> + uint32_t mmc_ipc_receive_interrupt_mask;
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXIPV4GFIM BSP_BIT32(0)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXIPV4HERFIM BSP_BIT32(1)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXIPV4NOPAYFIM BSP_BIT32(2)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXIPV4FRAGFIM BSP_BIT32(3)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXIPV4UDSBLFIM BSP_BIT32(4)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXIPV6GFIM BSP_BIT32(5)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXIPV6HERFIM BSP_BIT32(6)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXIPV6NOPAYFIM BSP_BIT32(7)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXUDPGFIM BSP_BIT32(8)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXUDPERFIM BSP_BIT32(9)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXTCPGFIM BSP_BIT32(10)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXTCPERFIM BSP_BIT32(11)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXICMPGFIM BSP_BIT32(12)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXICMPERFIM BSP_BIT32(13)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXIPV4GOIM BSP_BIT32(16)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXIPV4HEROIM BSP_BIT32(17)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXIPV4NOPAYOIM BSP_BIT32(18)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXIPV4FRAGOIM BSP_BIT32(19)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXIPV4UDSBLOIM BSP_BIT32(20)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXIPV6GOIM BSP_BIT32(21)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXIPV6HEROIM BSP_BIT32(22)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXIPV6NOPAYOIM BSP_BIT32(23)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXUDPGOIM BSP_BIT32(24)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXUDPEROIM BSP_BIT32(25)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXTCPGOIM BSP_BIT32(26)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXTCPEROIM BSP_BIT32(27)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXICMPGOIM BSP_BIT32(28)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_MASK_RXICMPEROIM BSP_BIT32(29)
> + uint32_t reserved_204;
> + uint32_t mmc_ipc_receive_interrupt;
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXIPV4GFIS BSP_BIT32(0)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXIPV4HERFIS BSP_BIT32(1)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXIPV4NOPAYFIS BSP_BIT32(2)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXIPV4FRAGFIS BSP_BIT32(3)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXIPV4UDSBLFIS BSP_BIT32(4)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXIPV6GFIS BSP_BIT32(5)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXIPV6HERFIS BSP_BIT32(6)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXIPV6NOPAYFIS BSP_BIT32(7)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXUDPGFIS BSP_BIT32(8)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXUDPERFIS BSP_BIT32(9)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXTCPGFIS BSP_BIT32(10)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXTCPERFIS BSP_BIT32(11)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXICMPGFIS BSP_BIT32(12)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXICMPERFIS BSP_BIT32(13)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXIPV4GOIS BSP_BIT32(16)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXIPV4HEROIS BSP_BIT32(17)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXIPV4NOPAYOIS BSP_BIT32(18)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXIPV4FRAGOIS BSP_BIT32(19)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXIPV4UDSBLOIS BSP_BIT32(20)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXIPV6GOIS BSP_BIT32(21)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXIPV6HEROIS BSP_BIT32(22)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXIPV6NOPAYOIS BSP_BIT32(23)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXUDPGOIS BSP_BIT32(24)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXUDPEROIS BSP_BIT32(25)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXTCPGOIS BSP_BIT32(26)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXTCPEROIS BSP_BIT32(27)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXICMPGOIS BSP_BIT32(28)
> +#define MACGRP_MMC_IPC_RECEIVE_INTERRUPT_RXICMPEROIS BSP_BIT32(29)
> + uint32_t reserved_20c;
> + uint32_t rxipv4_gd_frms;
> + uint32_t rxipv4_hdrerr_frms;
> + uint32_t rxipv4_nopay_frms;
> + uint32_t rxipv4_frag_frms;
> + uint32_t rxipv4_udsbl_frms;
> + uint32_t rxipv6_gd_frms;
> + uint32_t rxipv6_hdrerr_frms;
> + uint32_t rxipv6_nopay_frms;
> + uint32_t rxudp_gd_frms;
> + uint32_t rxudp_err_frms;
> + uint32_t rxtcp_gd_frms;
> + uint32_t rxtcp_err_frms;
> + uint32_t rxicmp_gd_frms;
> + uint32_t rxicmp_err_frms;
> + uint32_t reserved_248[2];
> + uint32_t rxipv4_gd_octets;
> + uint32_t rxipv4_hdrerr_octets;
> + uint32_t rxipv4_nopay_octets;
> + uint32_t rxipv4_frag_octets;
> + uint32_t rxipv4_udsbl_octets;
> + uint32_t rxipv6_gd_octets;
> + uint32_t rxipv6_hdrerr_octets;
> + uint32_t rxipv6_nopay_octets;
> + uint32_t rxudp_gd_octets;
> + uint32_t rxudp_err_octets;
> + uint32_t rxtcp_gd_octets;
> + uint32_t rxtcperroctets;
> + uint32_t rxicmp_gd_octets;
> + uint32_t rxicmp_err_octets;
> + uint32_t reserved_288[158];
> + uint32_t hash_table_reg[8];
> + uint32_t reserved_520[184];
> + mac mac_addr16_127[112];
> +} macgrp;
> +typedef struct {
> + uint32_t bus_mode;
> +#define DMAGRP_BUS_MODE_SWR BSP_BIT32(0)
> +#define DMAGRP_BUS_MODE_DSL(val) BSP_FLD32(val, 2, 6)
> +#define DMAGRP_BUS_MODE_DSL_GET(reg) BSP_FLD32GET(reg, 2, 6)
> +#define DMAGRP_BUS_MODE_DSL_SET(reg, val) BSP_FLD32SET(reg, val, 2, 6)
> +#define DMAGRP_BUS_MODE_ATDS BSP_BIT32(7)
> +#define DMAGRP_BUS_MODE_PBL(val) BSP_FLD32(val, 8, 13)
> +#define DMAGRP_BUS_MODE_PBL_GET(reg) BSP_FLD32GET(reg, 8, 13)
> +#define DMAGRP_BUS_MODE_PBL_SET(reg, val) BSP_FLD32SET(reg, val, 8, 13)
> +#define DMAGRP_BUS_MODE_FB BSP_BIT32(16)
> +#define DMAGRP_BUS_MODE_RPBL(val) BSP_FLD32(val, 17, 22)
> +#define DMAGRP_BUS_MODE_RPBL_GET(reg) BSP_FLD32GET(reg, 17, 22)
> +#define DMAGRP_BUS_MODE_RPBL_SET(reg, val) BSP_FLD32SET(reg, val, 17, 22)
> +#define DMAGRP_BUS_MODE_USP BSP_BIT32(23)
> +#define DMAGRP_BUS_MODE_EIGHTXPBL BSP_BIT32(24)
> +#define DMAGRP_BUS_MODE_AAL BSP_BIT32(25)
> +#define DMAGRP_BUS_MODE_MB BSP_BIT32(26)
> + uint32_t transmit_poll_demand;
> +#define DMAGRP_TRANSMIT_POLL_DEMAND_TPD(val) BSP_FLD32(val, 0, 31)
> +#define DMAGRP_TRANSMIT_POLL_DEMAND_TPD_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DMAGRP_TRANSMIT_POLL_DEMAND_TPD_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> + uint32_t receive_poll_demand;
> +#define DMAGRP_RECEIVE_POLL_DEMAND_RPD(val) BSP_FLD32(val, 0, 31)
> +#define DMAGRP_RECEIVE_POLL_DEMAND_RPD_GET(reg) BSP_FLD32GET(reg, 0, 31)
> +#define DMAGRP_RECEIVE_POLL_DEMAND_RPD_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
> + uint32_t receive_descr_list_addr;
> +#define DMAGRP_RECEIVE_DESCR_LIST_ADDR_RDESLA_32BIT(val) BSP_FLD32(val, 2, 31)
> +#define DMAGRP_RECEIVE_DESCR_LIST_ADDR_RDESLA_32BIT_GET(reg) BSP_FLD32GET(reg, 2, 31)
> +#define DMAGRP_RECEIVE_DESCR_LIST_ADDR_RDESLA_32BIT_SET(reg, val) BSP_FLD32SET(reg, val, 2, 31)
> + uint32_t transmit_descr_list_addr;
> +#define DMAGRP_TRANSMIT_DESCR_LIST_ADDR_TDESLA_32BIT(val) BSP_FLD32(val, 2, 31)
> +#define DMAGRP_TRANSMIT_DESCR_LIST_ADDR_TDESLA_32BIT_GET(reg) BSP_FLD32GET(reg, 2, 31)
> +#define DMAGRP_TRANSMIT_DESCR_LIST_ADDR_TDESLA_32BIT_SET(reg, val) BSP_FLD32SET(reg, val, 2, 31)
> + uint32_t status;
> +#define DMAGRP_STATUS_TI BSP_BIT32(0)
> +#define DMAGRP_STATUS_TPS BSP_BIT32(1)
> +#define DMAGRP_STATUS_TU BSP_BIT32(2)
> +#define DMAGRP_STATUS_TJT BSP_BIT32(3)
> +#define DMAGRP_STATUS_OVF BSP_BIT32(4)
> +#define DMAGRP_STATUS_UNF BSP_BIT32(5)
> +#define DMAGRP_STATUS_RI BSP_BIT32(6)
> +#define DMAGRP_STATUS_RU BSP_BIT32(7)
> +#define DMAGRP_STATUS_RPS BSP_BIT32(8)
> +#define DMAGRP_STATUS_RWT BSP_BIT32(9)
> +#define DMAGRP_STATUS_ETI BSP_BIT32(10)
> +#define DMAGRP_STATUS_FBI BSP_BIT32(13)
> +#define DMAGRP_STATUS_ERI BSP_BIT32(14)
> +#define DMAGRP_STATUS_AIS BSP_BIT32(15)
> +#define DMAGRP_STATUS_NIS BSP_BIT32(16)
> +#define DMAGRP_STATUS_RS(val) BSP_FLD32(val, 17, 19)
> +#define DMAGRP_STATUS_RS_GET(reg) BSP_FLD32GET(reg, 17, 19)
> +#define DMAGRP_STATUS_RS_SET(reg, val) BSP_FLD32SET(reg, val, 17, 19)
> +#define DMAGRP_STATUS_TS(val) BSP_FLD32(val, 20, 22)
> +#define DMAGRP_STATUS_TS_GET(reg) BSP_FLD32GET(reg, 20, 22)
> +#define DMAGRP_STATUS_TS_SET(reg, val) BSP_FLD32SET(reg, val, 20, 22)
> +#define DMAGRP_STATUS_EB(val) BSP_FLD32(val, 23, 25)
> +#define DMAGRP_STATUS_EB_GET(reg) BSP_FLD32GET(reg, 23, 25)
> +#define DMAGRP_STATUS_EB_SET(reg, val) BSP_FLD32SET(reg, val, 23, 25)
> +#define DMAGRP_STATUS_GLI BSP_BIT32(26)
> +#define DMAGRP_STATUS_GMI BSP_BIT32(27)
> +#define DMAGRP_STATUS_TTI BSP_BIT32(29)
> +#define DMAGRP_STATUS_GLPII BSP_BIT32(30)
> + uint32_t operation_mode;
> +#define DMAGRP_OPERATION_MODE_SR BSP_BIT32(1)
> +#define DMAGRP_OPERATION_MODE_OSF BSP_BIT32(2)
> +#define DMAGRP_OPERATION_MODE_RTC(val) BSP_FLD32(val, 3, 4)
> +#define DMAGRP_OPERATION_MODE_RTC_GET(reg) BSP_FLD32GET(reg, 3, 4)
> +#define DMAGRP_OPERATION_MODE_RTC_SET(reg, val) BSP_FLD32SET(reg, val, 3, 4)
> +#define DMAGRP_OPERATION_MODE_FUF BSP_BIT32(6)
> +#define DMAGRP_OPERATION_MODE_FEF BSP_BIT32(7)
> +#define DMAGRP_OPERATION_MODE_EFC BSP_BIT32(8)
> +#define DMAGRP_OPERATION_MODE_RFA(val) BSP_FLD32(val, 9, 10)
> +#define DMAGRP_OPERATION_MODE_RFA_GET(reg) BSP_FLD32GET(reg, 9, 10)
> +#define DMAGRP_OPERATION_MODE_RFA_SET(reg, val) BSP_FLD32SET(reg, val, 9, 10)
> +#define DMAGRP_OPERATION_MODE_RFD(val) BSP_FLD32(val, 11, 12)
> +#define DMAGRP_OPERATION_MODE_RFD_GET(reg) BSP_FLD32GET(reg, 11, 12)
> +#define DMAGRP_OPERATION_MODE_RFD_SET(reg, val) BSP_FLD32SET(reg, val, 11, 12)
> +#define DMAGRP_OPERATION_MODE_ST BSP_BIT32(13)
> +#define DMAGRP_OPERATION_MODE_TTC(val) BSP_FLD32(val, 14, 16)
> +#define DMAGRP_OPERATION_MODE_TTC_GET(reg) BSP_FLD32GET(reg, 14, 16)
> +#define DMAGRP_OPERATION_MODE_TTC_SET(reg, val) BSP_FLD32SET(reg, val, 14, 16)
> +#define DMAGRP_OPERATION_MODE_FTF BSP_BIT32(20)
> +#define DMAGRP_OPERATION_MODE_TSF BSP_BIT32(21)
> +#define DMAGRP_OPERATION_MODE_DFF BSP_BIT32(24)
> +#define DMAGRP_OPERATION_MODE_RSF BSP_BIT32(25)
> +#define DMAGRP_OPERATION_MODE_DT BSP_BIT32(26)
> + uint32_t interrupt_enable;
> +#define DMAGRP_INTERRUPT_ENABLE_TIE BSP_BIT32(0)
> +#define DMAGRP_INTERRUPT_ENABLE_TSE BSP_BIT32(1)
> +#define DMAGRP_INTERRUPT_ENABLE_TUE BSP_BIT32(2)
> +#define DMAGRP_INTERRUPT_ENABLE_TJE BSP_BIT32(3)
> +#define DMAGRP_INTERRUPT_ENABLE_OVE BSP_BIT32(4)
> +#define DMAGRP_INTERRUPT_ENABLE_UNE BSP_BIT32(5)
> +#define DMAGRP_INTERRUPT_ENABLE_RIE BSP_BIT32(6)
> +#define DMAGRP_INTERRUPT_ENABLE_RUE BSP_BIT32(7)
> +#define DMAGRP_INTERRUPT_ENABLE_RSE BSP_BIT32(8)
> +#define DMAGRP_INTERRUPT_ENABLE_RWE BSP_BIT32(9)
> +#define DMAGRP_INTERRUPT_ENABLE_ETE BSP_BIT32(10)
> +#define DMAGRP_INTERRUPT_ENABLE_FBE BSP_BIT32(13)
> +#define DMAGRP_INTERRUPT_ENABLE_ERE BSP_BIT32(14)
> +#define DMAGRP_INTERRUPT_ENABLE_AIE BSP_BIT32(15)
> +#define DMAGRP_INTERRUPT_ENABLE_NIE BSP_BIT32(16)
> + uint32_t reserved_20[2];
> + uint32_t axi_bus_mode;
> +#define DMAGRP_AXI_BUS_MODE_UNDEFINED BSP_BIT32(0)
> +#define DMAGRP_AXI_BUS_MODE_BLEND4 BSP_BIT32(1)
> +#define DMAGRP_AXI_BUS_MODE_BLEND8 BSP_BIT32(2)
> +#define DMAGRP_AXI_BUS_MODE_BLEND16 BSP_BIT32(3)
> +#define DMAGRP_AXI_BUS_MODE_AXI_AAL BSP_BIT32(12)
> +#define DMAGRP_AXI_BUS_MODE_ONEKBBE BSP_BIT32(13)
> +#define DMAGRP_AXI_BUS_MODE_RD_OSR_LMT(val) BSP_FLD32(val, 16, 19)
> +#define DMAGRP_AXI_BUS_MODE_RD_OSR_LMT_GET(reg) BSP_FLD32GET(reg, 16, 19)
> +#define DMAGRP_AXI_BUS_MODE_RD_OSR_LMT_SET(reg, val) BSP_FLD32SET(reg, val, 16, 19)
> +#define DMAGRP_AXI_BUS_MODE_WR_OSR_LMT(val) BSP_FLD32(val, 20, 23)
> +#define DMAGRP_AXI_BUS_MODE_WR_OSR_LMT_GET(reg) BSP_FLD32GET(reg, 20, 23)
> +#define DMAGRP_AXI_BUS_MODE_WR_OSR_LMT_SET(reg, val) BSP_FLD32SET(reg, val, 20, 23)
> +#define DMAGRP_AXI_BUS_MODE_LPI_XIT_FRM BSP_BIT32(30)
> +#define DMAGRP_AXI_BUS_MODE_EN_LPI BSP_BIT32(31)
> + uint32_t reserved_2c[11];
> + uint32_t hw_feature;
> +#define DMAGRP_HW_FEATURE_MIISEL BSP_BIT32(0)
> +#define DMAGRP_HW_FEATURE_GMIISEL BSP_BIT32(1)
> +#define DMAGRP_HW_FEATURE_HDSEL BSP_BIT32(2)
> +#define DMAGRP_HW_FEATURE_HASHSEL BSP_BIT32(4)
> +#define DMAGRP_HW_FEATURE_ADDMACADRSEL BSP_BIT32(5)
> +#define DMAGRP_HW_FEATURE_PCSSEL BSP_BIT32(6)
> +#define DMAGRP_HW_FEATURE_SMASEL BSP_BIT32(8)
> +#define DMAGRP_HW_FEATURE_RWKSEL BSP_BIT32(9)
> +#define DMAGRP_HW_FEATURE_MGKSEL BSP_BIT32(10)
> +#define DMAGRP_HW_FEATURE_MMCSEL BSP_BIT32(11)
> +#define DMAGRP_HW_FEATURE_TSVER1SEL BSP_BIT32(12)
> +#define DMAGRP_HW_FEATURE_TSVER2SEL BSP_BIT32(13)
> +#define DMAGRP_HW_FEATURE_EEESEL BSP_BIT32(14)
> +#define DMAGRP_HW_FEATURE_AVSEL BSP_BIT32(15)
> +#define DMAGRP_HW_FEATURE_TXOESEL BSP_BIT32(16)
> +#define DMAGRP_HW_FEATURE_RXTYP1COE BSP_BIT32(17)
> +#define DMAGRP_HW_FEATURE_RXTYP2COE BSP_BIT32(18)
> +#define DMAGRP_HW_FEATURE_RXFIFOSIZE BSP_BIT32(19)
> +#define DMAGRP_HW_FEATURE_RXCHCNT(val) BSP_FLD32(val, 20, 21)
> +#define DMAGRP_HW_FEATURE_RXCHCNT_GET(reg) BSP_FLD32GET(reg, 20, 21)
> +#define DMAGRP_HW_FEATURE_RXCHCNT_SET(reg, val) BSP_FLD32SET(reg, val, 20, 21)
> +#define DMAGRP_HW_FEATURE_TXCHCNT(val) BSP_FLD32(val, 22, 23)
> +#define DMAGRP_HW_FEATURE_TXCHCNT_GET(reg) BSP_FLD32GET(reg, 22, 23)
> +#define DMAGRP_HW_FEATURE_TXCHCNT_SET(reg, val) BSP_FLD32SET(reg, val, 22, 23)
> +#define DMAGRP_HW_FEATURE_ENHDESSEL BSP_BIT32(24)
> +#define DMAGRP_HW_FEATURE_ACTPHYIF(val) BSP_FLD32(val, 28, 30)
> +#define DMAGRP_HW_FEATURE_ACTPHYIF_GET(reg) BSP_FLD32GET(reg, 28, 30)
> +#define DMAGRP_HW_FEATURE_ACTPHYIF_SET(reg, val) BSP_FLD32SET(reg, val, 28, 30)
> +} dmagrp;
> +#endif /* MAC_REGS_H */
> diff --git a/c/src/libchip/network/dwmac.c b/c/src/libchip/network/dwmac.c
> index 0000000..f722031
> --- /dev/null
> +++ b/c/src/libchip/network/dwmac.c
> @@ -0,0 +1,2341 @@
> + * @file dwmac.c
> + * @ingroup [GROUP NAME]
> + * @brief DWMAC 10/100/1000 Network Interface Controller
> + * DWMAC 10/100/1000 on-chip Ethernet controllers are a Synopsys IP Core.
> + * This is the main mode for the network interface controller.
> + * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
> + * embedded brains GmbH
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> + * <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#include <assert.h>
> +#include <stdlib.h>
> +#include <stdio.h>
> +#include <string.h>
> +#include <errno.h>
> +#include <rtems.h>
> +#include <rtems/endian.h>
> +#include "dwmac-common.h"
> +#include "dwmac-core.h"
> +#include <bsp/irq.h>
> +/* PHY events which can be combined to an event set.
> + * The PHY can create an event for a corresponding status change */
> +const dwmac_phy_event PHY_EVENT_JABBER = 0x80;
> +const dwmac_phy_event PHY_EVENT_RECEIVE_ERROR = 0x40;
> +const dwmac_phy_event PHY_EVENT_PAGE_RECEIVE = 0x20;
> +const dwmac_phy_event PHY_EVENT_PARALLEL_DETECT_FAULT = 0x10;
> +const dwmac_phy_event PHY_EVENT_LINK_PARTNER_ACK = 0x08;
> +const dwmac_phy_event PHY_EVENT_LINK_DOWN = 0x04;
> +const dwmac_phy_event PHY_EVENT_REMOTE_FAULT = 0x02;
> +const dwmac_phy_event PHY_EVENT_LINK_UP = 0x01;
> +/* Default values for the number of DMA descriptors and mbufs to be used */
> +#define DWMAC_CONFIG_RX_UNIT_COUNT_DEFAULT 256
> +#define DWMAC_CONFIG_RX_UNIT_COUNT_MAX INT_MAX
> +#define DWMAC_CONFIG_TX_UNIT_COUNT_DEFAULT 256
> +#define DWMAC_CONFIG_TX_UNIT_COUNT_MAX INT_MAX
> +/* Default values for the DMA configuration */
> +#define DWMAC_DMA_BUS_MODE_PBL_DEFAULT DWMAC_DMA_CFG_BUS_MODE_BURST_LENGTH_8
> +#define DWMAC_DMA_BUS_MODE_FB_DEFAULT \
> + DWMAC_DMA_CFG_BUS_MODE_BURST_MODE_SINGLE_OR_INCR
> +#define DWMAC_DMA_BUS_MODE_MIXED_BURSTS_DEFAULT \
> + DWMAC_DMA_CFG_BUS_MODE_BURST_NOT_MIXED
> +#define DWMAC_DMA_AXI_BURST_LENGTH_4_DEFAULT \
> + DWMAC_DMA_CFG_AXI_BURST_LENGTH_4_NOT_SUPPORTED
> +#define DWMAC_DMA_AXI_BURST_LENGTH_8_DEFAULT \
> + DWMAC_DMA_CFG_AXI_BURST_LENGTH_8_NOT_SUPPORTED
> +#define DWMAC_DMA_AXI_BURST_LENGTH_16_DEFAULT \
> + DWMAC_DMA_CFG_AXI_BURST_LENGTH_16_NOT_SUPPORTED
> +#define DWMAC_DMA_AXI_BURST_BOUNDARY_DEFAULT \
> + DWMAC_DMA_CFG_AXI_BURST_BOUNDARY_4_KB
> +/* CSR Frequency Access Defines*/
> +#define DWCGNAC3504_CSR_F_35M 35000000
> +#define DWCGNAC3504_CSR_F_60M 60000000
> +#define DWCGNAC3504_CSR_F_100M 100000000
> +#define DWCGNAC3504_CSR_F_150M 150000000
> +#define DWCGNAC3504_CSR_F_250M 250000000
> +#define DWCGNAC3504_CSR_F_300M 300000000
> +/* MDC Clock Selection define*/
> +#define DWCGNAC3504_CSR_60_100M 0x0 /* MDC = clk_scr_i/42 */
> +#define DWCGNAC3504_CSR_100_150M 0x1 /* MDC = clk_scr_i/62 */
> +#define DWCGNAC3504_CSR_20_35M 0x2 /* MDC = clk_scr_i/16 */
> +#define DWCGNAC3504_CSR_35_60M 0x3 /* MDC = clk_scr_i/26 */
> +#define DWCGNAC3504_CSR_150_250M 0x4 /* MDC = clk_scr_i/102 */
> +#define DWCGNAC3504_CSR_250_300M 0x5 /* MDC = clk_scr_i/122 */
> +#define DWMAC_ALIGN( value, num_bytes_to_align_to ) \
> + ( ( ( value ) + ( ( typeof( value ) )( num_bytes_to_align_to ) - 1 ) ) \
> + & ~( ( typeof( value ) )( num_bytes_to_align_to ) - 1 ) )
> +#undef DWMAC_DEBUG
> +#ifdef DWMAC_DEBUG
> +#define DWMAC_PRINT_DBG( fmt, args ... ) printk( fmt, ## args )
> +#else
> +#define DWMAC_PRINT_DBG( fmt, args ... ) do { } while ( 0 )
> +#endif
> +#define DWMAC_DMA_THRESHOLD_CONTROL_DEFAULT 64
> +static int dwmac_if_mdio_busy_wait( const volatile uint32_t *gmii_address )
> + rtems_interval timeout = rtems_clock_get_ticks_per_second();
> + rtems_interval i = 0;
> + while ( ( *gmii_address & MACGRP_GMII_ADDRESS_GMII_BUSY ) != 0
> + && i < timeout ) {
> + rtems_task_wake_after( 1 );
> + ++i;
> + return i < timeout ? 0 : EBUSY;
> +static int dwmac_if_mdio_read(
> + int phy,
> + void *arg,
> + unsigned phy_reg,
> + uint32_t *val )
> + int eno = 0;
> + dwmac_common_context *self = (dwmac_common_context *) arg;
> + volatile uint32_t *mii_address = &self->macgrp->gmii_address;
> + volatile uint32_t *mii_data = &self->macgrp->gmii_data;
> + uint32_t reg_value = 0;
> + if ( phy == -1 ) {
> + reg_value = MACGRP_GMII_ADDRESS_PHYSICAL_LAYER_ADDRESS_SET(
> + reg_value,
> + self->CFG->MDIO_BUS_ADDR
> + } else {
> + reg_value,
> + phy
> + reg_value = MACGRP_GMII_ADDRESS_GMII_REGISTER_SET(
> + reg_value,
> + phy_reg
> + reg_value &= ~MACGRP_GMII_ADDRESS_GMII_WRITE;
> + /* For the 7111 GMAC, we must set BUSY bit in the MII address register while
> + * accessing the PHY registers.
> + * Fortunately, it seems this has no drawback for the 7109 MAC. */
> + reg_value |= MACGRP_GMII_ADDRESS_GMII_BUSY;
> + reg_value = MACGRP_GMII_ADDRESS_CSR_CLOCK_RANGE_SET(
> + reg_value,
> + self->csr_clock
> + eno = dwmac_if_mdio_busy_wait( mii_address );
> + if ( eno == 0 ) {
> + *mii_address = reg_value;
> + if ( dwmac_if_mdio_busy_wait( mii_address ) ) {
> + eno = EBUSY;
> + } else {
> + /* Read the value from the MII data register */
> + *val = MACGRP_GMII_DATA_GMII_DATA_GET( *mii_data );
> + return eno;
> +static int dwmac_if_mdio_write(
> + int phy,
> + void *arg,
> + unsigned phy_reg,
> + uint32_t val )
> + int eno = 0;
> + uint32_t reg_value = *mii_address;
> + reg_value,
> + } else {
> + reg_value,
> + phy
> + reg_value,
> + phy_reg
> + reg_value |= MACGRP_GMII_ADDRESS_GMII_WRITE;
> + reg_value,
> + self->csr_clock
> + /* Wait until any existing MII operation is complete */
> + if ( eno == 0 ) {
> + /* Set the MII address register to write */
> + *mii_data = val;
> + return eno;
> +static int dwmac_get_phy_info(
> + dwmac_common_context *self,
> + const uint8_t mdio_bus_addr,
> + uint32_t *oui,
> + uint8_t *model,
> + uint8_t *revision )
> + int eno = 0;
> + uint32_t read;
> + eno = dwmac_if_mdio_read(
> + mdio_bus_addr,
> + self,
> + 2,
> + &read );
> + if ( eno == 0 ) {
> + *oui = 0 | ( read << 6 );
> + mdio_bus_addr,
> + self,
> + 3,
> + &read );
> + if ( eno == 0 ) {
> + *oui |= ( read & 0xFC00 ) >> 10;
> + *model = (uint8_t) ( ( read & 0x03F0 ) >> 4 );
> + *revision = read & 0x000F;
> + return eno;
> +static inline void dwmac_enable_irq_rx( dwmac_common_context *self )
> + dwmac_core_enable_dma_irq_rx( self );
> +static inline void dwmac_enable_irq_tx( dwmac_common_context *self )
> + dwmac_core_enable_dma_irq_tx( self );
> +static inline void dwmac_disable_irq_rx( dwmac_common_context *self )
> + dwmac_core_disable_dma_irq_rx( self );
> +static inline void dwmac_diable_irq_tx( dwmac_common_context *self )
> + dwmac_core_disable_dma_irq_tx( self );
> +static void dwmac_control_request_complete( const dwmac_common_context *self )
> + rtems_status_code sc = rtems_event_transient_send( self->task_id_control );
> + assert( sc == RTEMS_SUCCESSFUL );
> +static int dwmac_control_request(
> + rtems_id task,
> + rtems_event_set event )
> + int eno = 0;
> + rtems_status_code sc = RTEMS_SUCCESSFUL;
> + uint32_t nest_count = 0;
> + self->task_id_control = rtems_task_self();
> + sc = rtems_bsdnet_event_send( task, event );
> + eno = rtems_status_code_to_errno( sc );
> + if ( eno == 0 ) {
> + nest_count = rtems_bsdnet_semaphore_release_recursive();
> + sc = rtems_event_transient_receive( RTEMS_WAIT, RTEMS_NO_TIMEOUT );
> + if ( eno == 0 ) {
> + rtems_bsdnet_semaphore_obtain_recursive( nest_count );
> + self->task_id_control = 0;
> + return eno;
> +static bool dwmac_if_media_status(
> + int *media,
> + uint8_t phy_address )
> + struct ifnet *ifp = &self->arpcom.ac_if;
> + *media = (int) IFM_MAKEWORD( 0, 0, 0, phy_address );
> + return ( *ifp->if_ioctl )( ifp, SIOCGIFMEDIA, (caddr_t) media ) == 0;
> +#define DWMAC_PRINT_COUNTER( fmt, counter, args ... ) \
> + if ( counter != 0 ) { \
> + printf( fmt, counter, ## args ); \
> +/* Print statistics. Get called via ioctl. */
> +static int dwmac_if_interface_stats( void *arg )
> + int eno = 0;
> + dwmac_common_context *self = arg;
> + volatile macgrp *macgrp = self->macgrp;
> + int media = 0;
> + bool media_ok = dwmac_if_media_status(
> + self, &media, self->CFG->MDIO_BUS_ADDR );
> + uint32_t oui;
> + uint8_t model;
> + uint8_t revision;
> + uint16_t giant_frame_size = 1518;
> + if ( ( MACGRP_MAC_CONFIGURATION_JE & macgrp->mac_configuration ) != 0 ) {
> + /* Jumbo Frames are enabled */
> + giant_frame_size = 9018;
> + if ( media_ok ) {
> + rtems_ifmedia2str( media, NULL, 0 );
> + printf( "\n" );
> + eno = dwmac_get_phy_info(
> + self,
> + self->CFG->MDIO_BUS_ADDR,
> + &oui,
> + &model,
> + &revision );
> + if ( eno == 0 ) {
> + printf( "PHY 0x%02x: OUI = 0x%04" PRIX32 ", Model = 0x%02" PRIX8 ", Rev = "
> + "0x%02" PRIX8 "\n",
> + oui,
> + model,
> + revision );
> + printf( "PHY status counters:\n" );
> + DWMAC_PRINT_COUNTER(
> + "%" PRIu32 " link down\n",
> + self->stats.phy_status_counts.link_down
> + "%" PRIu32 " link up\n",
> + self->stats.phy_status_counts.link_up
> + } else {
> + printf( "PHY %d communication error\n", self->CFG->MDIO_BUS_ADDR );
> + printf( "\nHardware counters:\n" );
> + if ( ( self->dmagrp->hw_feature & DMAGRP_HW_FEATURE_MMCSEL ) != 0 ) {
> + "%" PRIu32 " bytes transmitted, exclusive of preamble and retried bytes, "
> + "in good and bad frames\n",
> + macgrp->txoctetcount_gb
> + "%" PRIu32 " good and bad frames transmitted, exclusive of retried "
> + "frames\n",
> + macgrp->txframecount_gb
> + "%" PRIu32 " good broadcast frames transmitted\n",
> + macgrp->txbroadcastframes_g
> + "%" PRIu32 " good multicast frames transmitted\n",
> + macgrp->txmulticastframes_g
> + "%" PRIu32 " good and bad frames transmitted with length 64 bytes, "
> + "exclusive of preamble and retried frames\n",
> + macgrp->tx64octets_gb
> + "%" PRIu32 " good and bad frames transmitted with length between 65 and "
> + "127 (inclusive) bytes, exclusive of preamble and retried frames\n",
> + macgrp->tx65to127octets_gb
> + "%" PRIu32 " good and bad frames transmitted with length between 128 and "
> + "255 (inclusive) bytes, exclusive of preamble and retried frames\n",
> + macgrp->tx128to255octets_gb
> + "%" PRIu32 " good and bad frames transmitted with length between 256 and "
> + "511 (inclusive) bytes, exclusive of preamble and retried frames\n",
> + macgrp->tx256to511octets_gb
> + "%" PRIu32 " good and bad frames transmitted with length between 512 and "
> + "1,023 (inclusive) bytes, exclusive of preamble and retried frames\n",
> + macgrp->tx512to1023octets_gb
> + "%" PRIu32 " good and bad frames transmitted with length between 1,024 and"
> + " maxsize (inclusive) bytes, exclusive of preamble and retried frames\n",
> + macgrp->tx1024tomaxoctets_gb
> + "%" PRIu32 " good and bad unicast frames transmitted\n",
> + macgrp->txunicastframes_gb
> + "%" PRIu32 " good and bad multicast frames transmitted\n",
> + macgrp->txmulticastframes_gb
> + "%" PRIu32 " good and bad broadcast frames transmitted\n",
> + macgrp->txbroadcastframes_gb
> + "%" PRIu32 " frames aborted due to frame underflow error\n",
> + macgrp->txunderflowerror
> + "%" PRIu32 " successfully transmitted frames after a single collision in "
> + "Half-duplex mode\n",
> + macgrp->txsinglecol_g
> + "%" PRIu32 " successfully transmitted frames after more than a single"
> + " collision in Half-duplex mode\n",
> + macgrp->txmulticol_g
> + "%" PRIu32 " successfully transmitted frames after a deferral in "
> + "Halfduplex mode\n",
> + macgrp->txdeferred
> + "%" PRIu32 " frames aborted due to late collision error\n",
> + macgrp->txlatecol
> + "%" PRIu32 " frames aborted due to excessive (16) collision errors\n",
> + macgrp->txexesscol
> + "%" PRIu32 " frames aborted due to carrier sense error (no carrier or loss"
> + " of carrier)\n",
> + macgrp->txcarriererr
> + "%" PRIu32 " bytes transmitted, exclusive of preamble, in good frames "
> + "only\n",
> + macgrp->txoctetcnt
> + "%" PRIu32 " good frames transmitted\n",
> + "%" PRIu32 " frames aborted due to excessive deferral error (deferred for"
> + " more than two max-sized frame times)\n",
> + macgrp->txexcessdef
> + "%" PRIu32 " good PAUSE frames transmitted\n",
> + macgrp->txpauseframes
> + "%" PRIu32 " good VLAN frames transmitted, exclusive of retried frames\n",
> + macgrp->txvlanframes_g
> + "%" PRIu32 " good and bad frames received\n",
> + macgrp->txoversize_g
> + macgrp->rxframecount_gb
> + "%" PRIu32 " bytes received, exclusive of preamble, in good and bad "
> + "frames\n",
> + macgrp->rxoctetcount_gb
> + "%" PRIu32 " bytes received, exclusive of preamble, only in good frames\n",
> + "%" PRIu32 " good broadcast frames received\n",
> + macgrp->rxbroadcastframes_g
> + "%" PRIu32 " good multicast frames received\n",
> + macgrp->rxmulticastframes_g
> + "%" PRIu32 " frames received with CRC error\n",
> + macgrp->rxcrcerror
> + "%" PRIu32 " frames received with alignment (dribble) error. Valid only"
> + " in 10/100 mode\n",
> + macgrp->rxalignmenterror
> + "%" PRIu32 " frames received with runt (<64 bytes and CRC error) error\n",
> + macgrp->rxrunterror
> + "%" PRIu32 " giant frames received with length (including CRC) greater "
> + "than %" PRIu16 " bytes (%" PRIu16 " bytes for VLAN tagged) and with CRC"
> + " error\n",
> + macgrp->rxjabbererror, giant_frame_size, giant_frame_size + 4
> + "%" PRIu32 " frames received with length less than 64 bytes, without any"
> + " errors\n",
> + macgrp->rxundersize_g
> + "%" PRIu32 " frames received with length greater than the maxsize (1,518"
> + " or 1,522 for VLAN tagged frames), without errors\n",
> + macgrp->rxoversize_g
> + "%" PRIu32 " good and bad frames received with length 64 bytes, exclusive"
> + " of preamble\n",
> + macgrp->rx64octets_gb
> + "%" PRIu32 " good and bad frames received with length between 65 and 127"
> + " (inclusive) bytes, exclusive of preamble\n",
> + macgrp->rx65to127octets_gb
> + "%" PRIu32 " good and bad frames received with length between 128 and 255"
> + macgrp->rx128to255octets_gb
> + "%" PRIu32 " good and bad frames received with length between 256 and 511"
> + macgrp->rx256to511octets_gb
> + "%" PRIu32 " good and bad frames received with length between 512 and "
> + "1,023 (inclusive) bytes, exclusive of preamble\n",
> + macgrp->rx512to1023octets_gb
> + "%" PRIu32 " good and bad frames received with length between 1,024 and"
> + macgrp->rx1024tomaxoctets_gb
> + "%" PRIu32 " good unicast frames received\n",
> + macgrp->rxunicastframes_g
> + "%" PRIu32 " frames received with length error (length type field not "
> + "equal to frame size), for all frames with valid length field\n",
> + macgrp->rxlengtherror
> + "%" PRIu32 " frames received with length field not equal to the valid "
> + "frame size (greater than 1,500 but less than 1,536)\n",
> + macgrp->rxoutofrangetype
> + "%" PRIu32 " good and valid PAUSE frames received\n",
> + macgrp->rxpauseframes
> + "%" PRIu32 " missed received frames due to FIFO overflow\n",
> + macgrp->rxfifooverflow
> + "%" PRIu32 " good and bad VLAN frames received\n",
> + macgrp->rxvlanframes_gb
> + "%" PRIu32 " frames received with error due to watchdog timeout error "
> + "(frames with a data load larger than 2,048 bytes)\n",
> + macgrp->rxwatchdogerror
> + "%" PRIu32 " frames received with Receive error or Frame Extension error"
> + " on the GMII or MII interface\n",
> + macgrp->rxrcverror
> + "%" PRIu32 " received good control frames\n",
> + macgrp->rxctrlframes_g
> + printf( "\n" );
> + "%" PRIu32 " good IPv4 datagrams received with the TCP, UDP, or ICMP "
> + "payload\n",
> + macgrp->rxipv4_gd_frms
> + "%" PRIu32 " IPv4 datagrams received with header (checksum, length, or "
> + "version mismatch) errors\n",
> + macgrp->rxipv4_hdrerr_frms
> + "%" PRIu32 " IPv4 datagram frames received that did not have a TCP, UDP, "
> + "or ICMP payload processed by the Checksum engine\n",
> + macgrp->rxipv4_nopay_frms
> + "%" PRIu32 " good IPv4 datagrams with fragmentation\n",
> + macgrp->rxipv4_frag_frms
> + "%" PRIu32 " good IPv4 datagrams received that had a UDP payload with "
> + "checksum disabled\n",
> + macgrp->rxipv4_udsbl_frms
> + "%" PRIu32 " good IPv6 datagrams received with TCP, UDP, or ICMP "
> + "payloads\n",
> + macgrp->rxipv6_gd_frms
> + "%" PRIu32 " IPv6 datagrams received with header errors (length or "
> + "version mismatch)\n",
> + macgrp->rxipv6_hdrerr_frms
> + "%" PRIu32 " IPv6 datagram frames received that did not have a TCP, UDP,"
> + " or ICMP payload. This includes all IPv6 datagrams with fragmentation"
> + " or security extension headers\n",
> + macgrp->rxipv6_nopay_frms
> + "%" PRIu32 " good IP datagrams with a good UDP payload. This counter is "
> + "not updated when the counter is incremented\n",
> + macgrp->rxudp_gd_frms
> + "%" PRIu32 " good IP datagrams whose UDP payload has a checksum error\n",
> + macgrp->rxudp_err_frms
> + "%" PRIu32 " good IP datagrams with a good TCP payload\n",
> + macgrp->rxtcp_gd_frms
> + "%" PRIu32 " good IP datagrams whose TCP payload has a checksum error\n",
> + macgrp->rxtcp_err_frms
> + "%" PRIu32 " good IP datagrams with a good ICMP payload\n",
> + macgrp->rxicmp_gd_frms
> + "%" PRIu32 " good IP datagrams whose ICMP payload has a checksum error\n",
> + macgrp->rxicmp_err_frms
> + "%" PRIu32 " bytes received in good IPv4 datagrams encapsulating TCP, UDP,"
> + " or ICMP data\n",
> + macgrp->rxipv4_gd_octets
> + "%" PRIu32 " bytes received in IPv4 datagrams with header errors (checksum,"
> + " length, version mismatch). The value in the Length field of IPv4 "
> + "header is used to update this counter\n",
> + macgrp->rxipv4_hdrerr_octets
> + "%" PRIu32 " bytes received in IPv4 datagrams that did not have a TCP, UDP"
> + ", or ICMP payload. The value in the IPv4 headers Length field is used"
> + " to update this counter\n",
> + macgrp->rxipv4_nopay_octets
> + "%" PRIu32 " bytes received in fragmented IPv4 datagrams. The value in the"
> + " IPv4 headers Length field is used to update this counter\n",
> + macgrp->rxipv4_frag_octets
> + "%" PRIu32 " bytes received in a UDP segment that had the UDP checksum "
> + "disabled. This counter does not count IP Header bytes\n",
> + macgrp->rxipv4_udsbl_octets
> + "%" PRIu32 " bytes received in good IPv6 datagrams encapsulating TCP, UDP "
> + "or ICMPv6 data\n",
> + macgrp->rxipv6_gd_octets
> + "%" PRIu32 " bytes received in IPv6 datagrams with header errors (length, "
> + "version mismatch). The value in the IPv6 headers Length field is used "
> + "to update this counter\n",
> + macgrp->rxipv6_hdrerr_octets
> + "%" PRIu32 " bytes received in IPv6 datagrams that did not have a TCP, UDP"
> + ", or ICMP payload. The value in the IPv6 headers Length field is used "
> + macgrp->rxipv6_nopay_octets
> + "%" PRIu32 " bytes received in a good UDP segment. This counter does not "
> + "count IP header bytes\n",
> + macgrp->rxudp_gd_octets
> + "%" PRIu32 " bytes received in a UDP segment that had checksum errors\n",
> + macgrp->rxudp_err_octets
> + "%" PRIu32 " bytes received in a good TCP segment\n",
> + macgrp->rxtcp_gd_octets
> + "%" PRIu32 " bytes received in a TCP segment with checksum errors\n",
> + macgrp->rxtcperroctets
> + "%" PRIu32 " bytes received in a good ICMP segment\n",
> + macgrp->rxicmp_gd_octets
> + "%" PRIu32 " bytes received in an ICMP segment with checksum errors\n",
> + macgrp->rxicmp_err_octets
> + if ( eno == 0 ) {
> + printf( "\nInterrupt counts:\n" );
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " receive interrputs\n",
> + self->stats.dma_irq_counts.receive
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " transmit interrupts\n",
> + self->stats.dma_irq_counts.transmit
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " tx jabber interrupts\n",
> + self->stats.dma_irq_counts.tx_jabber
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " rx overflow interrupts\n",
> + self->stats.dma_irq_counts.rx_overflow
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " rx early interrupts\n",
> + self->stats.dma_irq_counts.rx_early
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " rx buffer unavailable interrupts\n",
> + self->stats.dma_irq_counts.rx_buf_unav
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " rx process stopped interrupts\n",
> + self->stats.dma_irq_counts.rx_process_stopped
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " rx watchdog interrupts\n",
> + self->stats.dma_irq_counts.rx_watchdog
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " tx early interrupts\n",
> + self->stats.dma_irq_counts.tx_early
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " tx buffer unavailable interrupts\n",
> + self->stats.dma_irq_counts.tx_buf_unav
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " tx process stopped interrupts\n",
> + self->stats.dma_irq_counts.tx_process_stopped
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " tx underflow interrupts\n",
> + self->stats.dma_irq_counts.tx_underflow
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " fatal bus error interrupts\n",
> + self->stats.dma_irq_counts.fatal_bus_error
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " unhandled interrupts\n",
> + self->stats.dma_irq_counts.unhandled
> + printf( "\nRX DMA status counts:\n" );
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " CRC errors\n",
> + self->stats.desc_status_counts_rx.crc_error
> + "%" PRIu32 " late collision when receing in half duplex mode\n",
> + self->stats.desc_status_counts_rx.late_collision
> + "%" PRIu32 " giant frame or timestamp or checksum error\n",
> + self->stats.desc_status_counts_rx.giant_frame
> + if ( self->stats.desc_status_counts_rx.watchdog_timeout != 0
> + || self->stats.desc_status_counts_rx.receive_error != 0 ) {
> + printf( " IP Header or IP Payload:\n" );
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " receive watchdog timeout\n",
> + self->stats.desc_status_counts_rx.watchdog_timeout
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " receive error\n",
> + self->stats.desc_status_counts_rx.receive_error
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " buffer overflows in MTL\n",
> + self->stats.desc_status_counts_rx.overflow_error
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " descriptor buffers too small\n",
> + self->stats.desc_status_counts_rx.descriptor_error
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " length errors\n",
> + self->stats.desc_status_counts_rx.length_error
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " dribble bit errors\n",
> + self->stats.desc_status_counts_rx.dribble_bit_error
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " vlan tags\n",
> + self->stats.desc_status_counts_rx.vlan_tag
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " ethernet frames\n",
> + self->stats.desc_status_counts_rx.ethernet_frames
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " destination address filter failures\n",
> + self->stats.desc_status_counts_rx.dest_addr_fail
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " source addresss filter failures\n",
> + self->stats.desc_status_counts_rx.source_addr_fail
> + printf( "\nTX DMA status counts:\n" );
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " jabber time-outs\n",
> + self->stats.desc_status_counts_tx.jabber
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " frame flushes\n",
> + self->stats.desc_status_counts_tx.frame_flushed
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " losses of carrier\n",
> + self->stats.desc_status_counts_tx.losscarrier
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " no carriers\n",
> + self->stats.desc_status_counts_tx.no_carrier
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " excessive collisions\n",
> + self->stats.desc_status_counts_tx.excessive_collisions
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " excessive deferrals\n",
> + self->stats.desc_status_counts_tx.excessive_deferral
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " underfolw errors\n",
> + self->stats.desc_status_counts_tx.underflow
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " IP header error\n",
> + self->stats.desc_status_counts_tx.ip_header_error
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " payload error\n",
> + "%" PRIu32 " MAC defers before transmission because of the presence of carrier\n",
> + self->stats.desc_status_counts_tx.deferred
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " VLAN frames\n",
> + self->stats.desc_status_counts_tx.vlan
> + printf( "\nRX frame counts:\n" );
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " frames with errors\n",
> + self->stats.frame_counts_rx.errors
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " frames dropped\n",
> + self->stats.frame_counts_rx.dropped
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " frames good\n",
> + self->stats.frame_counts_rx.frames_good
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " bytes in good frames\n",
> + self->stats.frame_counts_rx.bytes_good
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " frames good or bad\n",
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " DMA suspended\n",
> + self->stats.frame_counts_rx.dma_suspended
> + printf( "\nTX frame counts:\n" );
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " frames received from network stack\n",
> + self->stats.frame_counts_tx.frames_from_stack
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " frames tranmitted to DMA\n",
> + self->stats.frame_counts_tx.frames_to_dma
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " packets tranmitted to DMA\n",
> + self->stats.frame_counts_tx.packets_to_dma
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " bytes tranmitted to DMA\n",
> + self->stats.frame_counts_tx.bytes_to_dma
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " packets tranmitted by DMA\n",
> + self->stats.frame_counts_tx.packets_tranmitted_by_DMA
> + DWMAC_PRINT_COUNTER( "%" PRIu32 " packet errors\n",
> + self->stats.frame_counts_tx.packet_errors
> + printf( "\n" );
> +#ifdef RTEMS_DEBUG
> + const dwmac_common_desc_ops *DESC_OPS =
> + (const dwmac_common_desc_ops *) self->CFG->DESC_OPS->ops;
> + ( DESC_OPS->print_rx_desc )(
> + self->dma_rx,
> + (unsigned int) self->bsd_config->xbuf_count
> + ( DESC_OPS->print_tx_desc )(
> + self->dma_tx,
> +#endif /* RTEMS_DEBUG */
> + return eno;
> +static void dwmac_prefetch(
> + volatile void *ptr )
> + if ( ( self )->CFG->ARCH_HAS_PREFETCH ) {
> + __asm__ __volatile__ (
> + "pld\t%a0"
> + : "p" ( ptr )
> + : "cc" );
> +static inline unsigned int dwmac_increment(
> + const unsigned int value,
> + const unsigned int cycle )
> + if ( value < cycle ) {
> + return value + 1;
> + } else {
> + return 0;
> +/* Receive task
> + * It handles receiving frames */
> +static void dwmac_task_rx( void *arg )
> + dwmac_common_rx_frame_counts *counts = &self->stats.frame_counts_rx;
> + const unsigned int INDEX_MAX =
> + (unsigned int) self->bsd_config->rbuf_count - 1U;
> + size_t frame_len_last = 0;
> + size_t segment_size;
> + while ( true ) {
> + rtems_event_set events;
> + rtems_status_code sc = rtems_bsdnet_event_receive(
> + DWMAC_COMMON_EVENT_TASK_INIT
> + | DWMAC_COMMON_EVENT_TASK_STOP
> + | DWMAC_COMMON_EVENT_RX_FRAME_RECEIVED,
> + RTEMS_EVENT_ANY | RTEMS_WAIT,
> + RTEMS_NO_TIMEOUT,
> + &events
> + /* Stop the task */
> + if ( ( events & DWMAC_COMMON_EVENT_TASK_STOP ) != 0 ) {
> + dwmac_core_dma_stop_rx( self );
> + dwmac_disable_irq_rx( self );
> + /* Release all tx mbufs at the risk of data loss */
> + ( DESC_OPS->release_rx_bufs )( self );
> + dwmac_control_request_complete( self );
> + /* Return to events reception without re-enabling the interrupts
> + * The task needs a re-initialization to to resume work */
> + continue;
> + /* Ininitialize / Re-initialize reception handling */
> + if ( ( events & DWMAC_COMMON_EVENT_TASK_INIT ) != 0 ) {
> + unsigned int index;
> + for ( index = 0; index <= INDEX_MAX; ++index ) {
> + self->mbuf_addr_rx[index] = ( DESC_OPS->alloc_data_buf )( self );
> + assert( self->mbuf_addr_rx[index] != NULL );
> + ( DESC_OPS->init_rx_desc )( self, index );
> + self->idx_rx = 0;
> + frame_len_last = 0;
> + /* Clear our interrupt statuses */
> + dwmac_core_reset_dma_irq_status_rx( self );
> + dwmac_core_dma_start_rx( self );
> + events = events
> + & (rtems_event_set) ( ~DWMAC_COMMON_EVENT_RX_FRAME_RECEIVED );
> + /* Handle the reception of one or more frames */
> + if ( ( events & DWMAC_COMMON_EVENT_RX_FRAME_RECEIVED ) != 0 ) {
> + unsigned int idx = self->idx_rx;
> + /* Only handle frames for which we own the DMA descriptor */
> + while ( ( DESC_OPS->am_i_rx_owner )( self, idx ) ) {
> + struct mbuf *p_m_new;
> + dwmac_common_rx_frame_status status;
> + unsigned int idx_next = dwmac_increment(
> + self->idx_rx, INDEX_MAX );
> + /* Assign the next index (with wrap around) */
> + self->idx_rx = idx_next;
> + /* read the status of the incoming frame */
> + status = ( DESC_OPS->rx_status )( self, idx );
> + if ( status == DWMAC_COMMON_RX_FRAME_STATUS_DISCARD
> + || status == DWMAC_COMMON_RX_FRAME_STATUS_CSUM_NONE ) {
> + DWMAC_PRINT_DBG(
> + "rx discarded: %02u\n",
> + idx
> + ++counts->errors;
> + /* simply re-initialize the DMA descriptor */
> + ( DESC_OPS->init_rx_desc )( self, idx );
> + } else if ( status == DWMAC_COMMON_RX_FRAME_STATUS_LLC_SNAP ) {
> + DWMAC_PRINT_DBG(
> + "rx dropped llc snap: %02u\n",
> + idx
> + ++counts->dropped;
> + } else {
> + /* Before actually handling the valid frame, make sure we get a new
> + * mbuf */
> + p_m_new = ( DESC_OPS->alloc_data_buf )( self );
> + if ( p_m_new != NULL ) {
> + bool is_first_seg;
> + bool is_last_seg;
> + struct mbuf *p_m;
> + uint32_t frame_len = ( DESC_OPS->get_rx_frame_len )(
> + self, idx );
> + /* frame_len is the cummulated size of all segments of a frame.
> + * But what we need is the size of the single segment */
> + is_first_seg = ( DESC_OPS->is_first_rx_segment )( self, idx );
> + is_last_seg = ( DESC_OPS->is_last_rx_segment )( self, idx );
> + if ( is_first_seg ) {
> + segment_size = frame_len;
> + } else {
> + segment_size = frame_len - frame_len_last;
> + frame_len_last = frame_len;
> + p_m = self->mbuf_addr_rx[idx];
> + dwmac_prefetch( self, mtod( p_m - ETHER_ALIGN, void * ) );
> + self->mbuf_addr_rx[idx] = p_m_new;
> + /* Initialize the DMA descriptor with the new mbuf */
> + if ( p_m != NULL ) {
> + /* Ethernet header */
> + struct ether_header *eh = mtod( p_m, struct ether_header * );
> + int sz = (int) segment_size;
> + rtems_cache_invalidate_multiple_data_lines(
> + eh, segment_size );
> + /* Discard Ethernet header and CRC */
> + if ( is_last_seg ) {
> + sz -= ( ETHER_HDR_LEN + ETHER_CRC_LEN );
> + } else {
> + sz -= ETHER_HDR_LEN;
> + /* Update mbuf */
> + p_m->m_len = sz;
> + p_m->m_pkthdr.len = sz;
> + p_m->m_data = mtod( p_m, char * ) + ETHER_HDR_LEN;
> + _ARM_Data_synchronization_barrier();
> + DWMAC_PRINT_DBG(
> + "rx: %02u: %u %s%s\n",
> + idx,
> + segment_size,
> + ( is_first_seg ) ? ( "F" ) : ( "" ),
> + ( is_last_seg ) ? ( "L" ) : ( "" )
> + ether_input( &self->arpcom.ac_if, eh, p_m );
> + ++counts->frames_good;
> + counts->bytes_good += (uint32_t) p_m->m_len;
> + } else {
> + DWMAC_PRINT_DBG( "rx: %s: Inconsistent Rx descriptor chain\n",
> + self->arpcom.ac_if.if_name );
> + } else {
> + /* We have to discard the received frame because we did not get a new
> + * mbuf to replace the frame's mbuf. */
> + /* simply re-initialize the DMA descriptor with the existing mbuf */
> + DWMAC_PRINT_DBG(
> + "rx dropped: %02u\n",
> + idx
> + if ( ( self->dmagrp->status & DMAGRP_STATUS_RU ) != 0 ) {
> + /* The receive DMA is suspended and needs to get restarted */
> + dwmac_core_dma_restart_rx( self );
> + DWMAC_PRINT_DBG(
> + "rx DMA restart: %02u\n",
> + idx
> + ++counts->dma_suspended;
> + idx = idx_next;
> + ++counts->frames;
> + /* Clear interrupt */
> + self->dmagrp->status = DMAGRP_STATUS_RI;
> + /* Re-enable the IRQs */
> + dwmac_enable_irq_rx( self );
> +static struct mbuf *dwmac_next_fragment(
> + struct ifnet *ifp,
> + struct mbuf *m,
> + bool *is_first,
> + bool *is_last,
> + size_t *size ) {
> + struct mbuf *n = NULL;
> + int sz = 0;
> + while ( true ) {
> + if ( m == NULL ) {
> + /* Dequeue first fragment of the next frame */
> + IF_DEQUEUE( &ifp->if_snd, m );
> + /* Empty queue? */
> + return m;
> + /* The sum of all fragments lengths must fit into one
> + * ethernet transfer unit */
> + assert( ETHER_MAX_LEN >= m->m_pkthdr.len );
> + *is_first = true;
> + /* Get fragment size */
> + sz = m->m_len;
> + if ( sz > 0 ) {
> + /* Now we have a not empty fragment */
> + break;
> + } else {
> + /* Discard empty fragments */
> + m = m_free( m );
> + /* Set fragment size */
> + *size = (size_t) sz;
> + /* Discard empty successive fragments */
> + n = m->m_next;
> + while ( n != NULL && n->m_len <= 0 ) {
> + n = m_free( n );
> + m->m_next = n;
> + /* Is our fragment the last in the frame? */
> + if ( n == NULL ) {
> + *is_last = true;
> + } else {
> + *is_last = false;
> + return m;
> +static int dwmac_update_autonegotiation_params( dwmac_common_context *self )
> + int eno = 0;
> + uint32_t value = self->macgrp->mac_configuration;
> + int media = 0;
> + if ( media_ok ) {
> + /* only ethernet supported, so far */
> + if ( IFM_ETHER == IFM_TYPE( media ) ) {
> + if ( IFM_NONE != IFM_SUBTYPE( media ) ) {
> + if ( IFM_FDX & media ) {
> + /* Enable duplex mode */
> + value |= MACGRP_MAC_CONFIGURATION_DM;
> + } else {
> + /* Disable duplex mode */
> + value &= ~MACGRP_MAC_CONFIGURATION_DM;
> + switch ( IFM_SUBTYPE( media ) ) {
> + case IFM_10_T:
> + /* Set RMII/RGMII speed to 10Mbps */
> + value &= ~MACGRP_MAC_CONFIGURATION_FES;
> + /* MII 10/100 Mbps */
> + value |= MACGRP_MAC_CONFIGURATION_PS;
> + break;
> + case IFM_100_TX:
> + /* Set RMII/RGMII speed to 100Mbps */
> + value |= MACGRP_MAC_CONFIGURATION_FES;
> + break;
> + case IFM_1000_T:
> + /* RMII/RGMII speed irrelevant for 1000baseT */
> + /* GMII 1000 Mbps */
> + value &= ~MACGRP_MAC_CONFIGURATION_PS;
> + break;
> + default:
> + eno = ENOTSUP;
> + break;
> + } else {
> + eno = ENOTSUP;
> + } else {
> + eno = ENOTSUP;
> + } else {
> + eno = ENOTSUP;
> + if ( eno == 0 ) {
> + self->macgrp->mac_configuration = value;
> + return eno;
> +/* Transmit task
> + * It handles transmitting frames */
> +static void dwmac_task_tx( void *arg )
> + unsigned int idx_transmit = 0;
> + unsigned int idx_transmit_first = 0;
> + unsigned int idx_transmitted = 0;
> + unsigned int idx_release = 0;
> + struct mbuf *p_m = NULL;
> + bool is_first = false;
> + bool is_last = false;
> + size_t size = 0;
> + (unsigned int) self->bsd_config->xbuf_count - 1U;
> + const dwmac_common_dma_ops *DMA_OPS =
> + (const dwmac_common_dma_ops *) self->CFG->MAC_OPS->dma;
> + const dwmac_callback_cfg *CALLBACK = &self->CFG->CALLBACK;
> + while ( true ) {
> + rtems_event_set events = 0;
> + | DWMAC_COMMON_EVENT_TX_TRANSMIT_FRAME
> + | DWMAC_COMMON_EVENT_TX_FRAME_TRANSMITTED
> + | DWMAC_COMMON_EVENT_TX_BUMP_UP_DMA_THRESHOLD
> + | DWMAC_COMMON_EVENT_TX_PHY_STATUS_CHANGE,
> + RTEMS_NO_TIMEOUT,
> + &events
> + /* Handle a status change of the ethernet PHY */
> + if ( ( events & DWMAC_COMMON_EVENT_TX_PHY_STATUS_CHANGE ) != 0 ) {
> + dwmac_common_phy_status_counts *counts =
> + &self->stats.phy_status_counts;
> + dwmac_phy_event phy_events = 0;
> + int eno;
> + /* Get tripped PHY events */
> + eno = CALLBACK->phy_events_get(
> + self->arg,
> + &phy_events
> + if ( eno == 0 ) {
> + /* Clear the PHY events */
> + eno = CALLBACK->phy_event_clear( self->arg );
> + if ( eno == 0 ) {
> + if ( ( phy_events & PHY_EVENT_LINK_DOWN ) != 0 ) {
> + ++counts->link_down;
> + if ( ( phy_events & PHY_EVENT_LINK_UP ) != 0 ) {
> + ++counts->link_up;
> + /* A link up events means that we have a new connection.
> + * Thus the autonegotiation paremeters must get updated */
> + (void) dwmac_update_autonegotiation_params( self );
> + assert( eno == 0 );
> + dwmac_core_dma_stop_tx( self );
> + dwmac_diable_irq_tx( self );
> + ( DESC_OPS->release_tx_bufs )( self );
> + continue;
> + /* Ininitialize / Re-initialize transmission handling */
> + idx_transmit = 0;
> + idx_transmit_first = 0;
> + idx_transmitted = 0;
> + idx_release = 0;
> + p_m = NULL;
> + is_first = false;
> + is_last = false;
> + size = 0;
> + ( DESC_OPS->init_tx_desc )( self );
> + dwmac_core_dma_start_tx( self );
> + dwmac_core_dma_restart_tx( self );
> + dwmac_core_reset_dma_irq_status_tx( self );
> + /* Try to bump up the dma threshold due to a failure */
> + if ( ( events & DWMAC_COMMON_EVENT_TX_BUMP_UP_DMA_THRESHOLD ) != 0 ) {
> + if ( self->dma_threshold_control
> + != DWMAC_COMMON_DMA_MODE_STORE_AND_FORWARD
> + && self->dma_threshold_control <= 256 ) {
> + self->dma_threshold_control += 64;
> + ( DMA_OPS->dma_mode )(
> + self,
> + self->dma_threshold_control,
> + DWMAC_COMMON_DMA_MODE_STORE_AND_FORWARD
> + /* Handle one or more transmitted frames */
> + if ( ( events & DWMAC_COMMON_EVENT_TX_FRAME_TRANSMITTED ) != 0 ) {
> + dwmac_common_tx_frame_counts *counts = &self->stats.frame_counts_tx;
> + /* Next index to be transmitted */
> + unsigned int idx_transmitted_next = dwmac_increment(
> + idx_transmitted, INDEX_MAX );
> + /* Free consumed fragments */
> + while ( idx_release != idx_transmitted_next
> + && ( DESC_OPS->am_i_tx_owner )( self, idx_release ) ) {
> + /* Status handling per packet */
> + if ( ( DESC_OPS->get_tx_ls )( self, idx_release ) ) {
> + int status = ( DESC_OPS->tx_status )(
> + self, idx_release
> + if ( status == 0 ) {
> + ++counts->packets_tranmitted_by_DMA;
> + } else {
> + ++counts->packet_errors;
> + DWMAC_PRINT_DBG(
> + "tx: release %u\n",
> + idx_release
> + /* Release the DMA descriptor */
> + ( DESC_OPS->release_tx_desc )( self, idx_release );
> + /* Release mbuf */
> + m_free( self->mbuf_addr_tx[idx_release] );
> + self->mbuf_addr_tx[idx_release] = NULL;
> + /* Next release index */
> + idx_release = dwmac_increment(
> + idx_release, INDEX_MAX );
> + /* Clear transmit interrupt status */
> + self->dmagrp->status = DMAGRP_STATUS_TI;
> + if ( ( self->arpcom.ac_if.if_flags & IFF_OACTIVE ) != 0 ) {
> + /* The last tranmission has been incomplete
> + * (for example due to lack of DMA descriptors).
> + * Continue it now! */
> + events |= DWMAC_COMMON_EVENT_TX_TRANSMIT_FRAME;
> + /* There are one or more frames to be transmitted. */
> + if ( ( events & DWMAC_COMMON_EVENT_TX_TRANSMIT_FRAME ) != 0 ) {
> + /* This frame will get re-counted */
> + --counts->frames_from_stack;
> + while ( true ) {
> + unsigned int idx = dwmac_increment(
> + idx_transmit, INDEX_MAX );
> + p_m = dwmac_next_fragment(
> + &self->arpcom.ac_if,
> + p_m,
> + &is_first,
> + &is_last,
> + &size
> + /* New fragment? */
> + ++counts->frames_from_stack;
> + /* Queue full? */
> + if ( idx == idx_release ) {
> + DWMAC_PRINT_DBG( "tx: full queue: 0x%08x\n", p_m );
> + /* The queue is full, wait for transmitted interrupt */
> + break;
> + /* Set the transfer data */
> + rtems_cache_flush_multiple_data_lines(
> + mtod( p_m, const void * ),
> + size
> + ( DESC_OPS->prepare_tx_desc )(
> + self,
> + idx_transmit,
> + is_first,
> + size,
> + self->mbuf_addr_tx[idx_transmit] = p_m;
> + ++counts->frames_to_dma;
> + counts->bytes_to_dma += size;
> + DWMAC_PRINT_DBG(
> + "tx: %02" PRIu32 ": %u %s%s\n",
> + idx_transmit, size,
> + ( is_first != false ) ? ( "F" ) : ( "" ),
> + ( is_last != false ) ? ( "L" ) : ( "" )
> + if ( is_first ) {
> + idx_transmit_first = idx_transmit;
> + is_first = false;
> + } else {
> + /* To avoid race condition */
> + ( DESC_OPS->release_tx_ownership )( self, idx_transmit );
> + if ( is_last ) {
> + /* Interrupt on completition only for the latest fragment */
> + ( DESC_OPS->close_tx_desc )( self, idx_transmit );
> + ( DESC_OPS->release_tx_ownership )( self, idx_transmit_first );
> + idx_transmitted = idx_transmit;
> + if ( ( self->dmagrp->status & DMAGRP_STATUS_TU ) != 0 ) {
> + /* Re-enable the tranmit DMA */
> + DWMAC_PRINT_DBG(
> + "tx DMA restart: %02u\n",
> + /* Next transmit index */
> + idx_transmit = idx;
> + if ( is_last ) {
> + ++counts->packets_to_dma;
> + /* Next fragment of the frame */
> + p_m = p_m->m_next;
> + } else {
> + /* Nothing to transmit */
> + break;
> + /* No more packets and fragments? */
> + if ( p_m == NULL ) {
> + /* Interface is now inactive */
> + self->arpcom.ac_if.if_flags &= ~IFF_OACTIVE;
> + } else {
> + /* There are more packets pending to be sent,
> + * but we have run out of DMA descriptors.
> + * We will continue sending once descriptors
> + * have been freed due to a transmitted interupt */
> + DWMAC_PRINT_DBG( "tx: transmission incomplete\n" );
> + /* TODO: Add handling */
> + DWMAC_PRINT_DBG( "tx: enable transmit interrupts\n" );
> + /* Re-enable transmit interrupts */
> + dwmac_enable_irq_tx( self );
> +/* Major driver initialization method. Gets called
> + * by the network stack automatically */
> +static void dwmac_if_interface_init( void *arg )
> + (void) arg;
> +static void dwmac_if_set_promiscous_mode(
> + const bool enabled )
> + if ( enabled ) {
> + /* Enable promiscuos mode */
> + self->macgrp->mac_frame_filter |= MACGRP_MAC_FRAME_FILTER_PR;
> + } else {
> + /* Hash filter or perfect match */
> + self->macgrp->mac_frame_filter &= ~MACGRP_MAC_FRAME_FILTER_PR;
> + self->macgrp->mac_frame_filter &= ~MACGRP_MAC_FRAME_FILTER_HUC;
> + self->macgrp->mac_frame_filter |= MACGRP_MAC_FRAME_FILTER_HPF;
> +static int dwmac_create_dma_desc_rings( dwmac_common_context *self )
> + int eno = 0;
> + /* create and initialize the Rx/Tx descriptors */
> + eno = ( DESC_OPS->create_rx_desc )( self );
> + if ( eno == 0 ) {
> + eno = ( DESC_OPS->create_tx_desc )( self );
> + return eno;
> +static int dwmac_destroy_dma_desc_rings( dwmac_common_context *self )
> + int eno = 0;
> + /* Free the Rx/Tx descriptors and the data buffers */
> + eno = ( DESC_OPS->destroy_rx_desc )( self );
> + if ( eno == 0 ) {
> + eno = ( DESC_OPS->destroy_tx_desc )( self );
> + return eno;
> +static int dwmac_init_dma_engine( dwmac_common_context *self )
> + uint32_t pbl =
> + DWMAC_DMA_BUS_MODE_PBL_DEFAULT;
> + uint32_t fixed_burst =
> + DWMAC_DMA_BUS_MODE_FB_DEFAULT;
> + uint32_t mixed_burst =
> + DWMAC_DMA_BUS_MODE_MIXED_BURSTS_DEFAULT;
> + uint32_t burst_len_4_support =
> + DWMAC_DMA_AXI_BURST_LENGTH_4_DEFAULT;
> + uint32_t burst_len_8_support =
> + DWMAC_DMA_AXI_BURST_LENGTH_8_DEFAULT;
> + uint32_t burst_len_16_support =
> + DWMAC_DMA_AXI_BURST_LENGTH_16_DEFAULT;
> + uint32_t burst_boundary =
> + DWMAC_DMA_AXI_BURST_BOUNDARY_DEFAULT;
> + /* The DMA configuration is optional */
> + if ( self->CFG->DMA_CFG != NULL ) {
> + const dwmac_dma_cfg *DMA_CFG = self->CFG->DMA_CFG;
> + pbl = DMA_CFG->bus_mode_burst_length;
> + fixed_burst = DMA_CFG->bus_mode_burst_mode;
> + mixed_burst = DMA_CFG->bus_mode_burst_mixed;
> + burst_len_4_support = DMA_CFG->axi_burst_length_4_support;
> + burst_len_8_support = DMA_CFG->axi_burst_length_8_support;
> + burst_len_16_support = DMA_CFG->axi_burst_length_16_support;
> + burst_boundary = DMA_CFG->axi_burst_boundary;
> + return ( DMA_OPS->init )(
> + self,
> + pbl,
> + fixed_burst,
> + mixed_burst,
> + ( DESC_OPS->use_enhanced_descs )( self ),
> + burst_len_4_support,
> + burst_len_8_support,
> + burst_len_16_support,
> + burst_boundary,
> + &self->dma_tx[0],
> + &self->dma_rx[0]
> +static void dwmac_dma_operation_mode( dwmac_common_context *self )
> + if ( ( self->dmagrp->hw_feature & DMAGRP_HW_FEATURE_TXOESEL ) != 0 ) {
> + self,
> + DWMAC_COMMON_DMA_MODE_STORE_AND_FORWARD,
> + self->dma_threshold_control = DWMAC_COMMON_DMA_MODE_STORE_AND_FORWARD;
> + } else {
> + self,
> +static void dwmac_mmc_setup( dwmac_common_context *self )
> + /* Mask MMC irq, counters are managed in HW and registers
> + * are not cleared on each READ eventually. */
> + /* No MAC Management Counters available */
> + assert( ( self->dmagrp->hw_feature & DMAGRP_HW_FEATURE_MMCSEL ) != 0 );
> + self->macgrp->mmc_control = MACGRP_MMC_CONTROL_CNTRST;
> +static int dwmac_if_up_or_down(
> + const bool up )
> + int eno = 0;
> + const dwmac_common_core_ops *CORE_OPS =
> + (const dwmac_common_core_ops *) self->CFG->MAC_OPS->core;
> + if ( up && self->state == DWMAC_COMMON_STATE_DOWN ) {
> + eno = CALLBACK->nic_enable( self->arg );
> + if ( eno == 0 ) {
> + eno = CALLBACK->phy_enable( self->arg );
> + if ( eno == 0 ) {
> + eno = CALLBACK->phy_event_enable(
> + self->arg,
> + PHY_EVENT_LINK_DOWN
> + | PHY_EVENT_LINK_UP
> + if ( eno == 0 ) {
> + eno = dwmac_create_dma_desc_rings( self );
> + if ( eno == 0 ) {
> + eno = dwmac_init_dma_engine( self );
> + if ( eno == 0 ) {
> + /* Copy the MAC addr into the HW */
> + ( CORE_OPS->set_umac_addr )( self, self->arpcom.ac_enaddr, 0 );
> + eno = ( CALLBACK->bus_setup )( self->arg );
> + if ( eno == 0 ) {
> + /* Initialize the MAC Core */
> + ( CORE_OPS->core_init )( self );
> + /* Enable the MAC Rx/Tx */
> + dwmac_core_set_mac( self, true );
> + /* Set the HW DMA mode and the COE */
> + dwmac_dma_operation_mode( self );
> + /* Set up mmc counters */
> + dwmac_mmc_setup( self );
> + /* Install interrupt handler */
> + sc = rtems_interrupt_handler_install(
> + self->CFG->IRQ_EMAC,
> + "Ethernet",
> + RTEMS_INTERRUPT_UNIQUE,
> + dwmac_core_dma_interrupt,
> + self
> + if ( eno == 0 ) {
> + /* Start the ball rolling ... */
> + sc = dwmac_control_request(
> + self, self->task_id_tx, DWMAC_COMMON_EVENT_TASK_INIT );
> + if ( eno == 0 ) {
> + self, self->task_id_rx, DWMAC_COMMON_EVENT_TASK_INIT );
> + if ( eno == 0 ) {
> + /* Start the phy */
> + eno = ( CALLBACK->phy_start )( self->arg );
> + if ( eno == 0 ) {
> + self->state = DWMAC_COMMON_STATE_UP;
> + } else {
> + ifp->if_flags &= ~IFF_UP;
> + (void) dwmac_control_request(
> + self, self->task_id_tx, DWMAC_COMMON_EVENT_TASK_STOP );
> + self, self->task_id_rx, DWMAC_COMMON_EVENT_TASK_STOP );
> + (void) rtems_interrupt_handler_remove(
> + self
> + (void) ( CALLBACK->phy_stop )( self->arg );
> + (void) ( CALLBACK->phy_disable )( self->arg );
> + /* Disable the MAC Rx/Tx */
> + dwmac_core_set_mac( self, false );
> + (void) ( CALLBACK->nic_disable )( self->arg );
> + (void) dwmac_destroy_dma_desc_rings( self );
> + } else if ( !up && self->state == DWMAC_COMMON_STATE_UP ) {
> + if ( eno == 0 ) {
> + if ( eno == 0 ) {
> + if ( eno == 0 ) {
> + sc = rtems_interrupt_handler_remove(
> + self
> + if ( eno == 0 ) {
> + eno = ( CALLBACK->phy_stop )( self->arg );
> + if ( eno == 0 ) {
> + eno = ( CALLBACK->phy_disable )( self->arg );
> + if ( eno == 0 ) {
> + eno = CALLBACK->nic_disable( self->arg );
> + if ( eno == 0 ) {
> + eno = dwmac_destroy_dma_desc_rings( self );
> + if ( eno == 0 ) {
> + /* Reset counters to be printed */
> + memset( &self->stats, 0, sizeof( dwmac_common_stats ) );
> + /* Change state */
> + self->state = DWMAC_COMMON_STATE_DOWN;
> + return eno;
> +/* Get commands executed by the driver. This method gets called
> + * automatically from the network stack */
> +static int dwmac_if_interface_ioctl(
> + ioctl_command_t cmd,
> + caddr_t data )
> + dwmac_common_context *self = ifp->if_softc;
> + int eno = 0;
> + switch ( cmd ) {
> + case SIOCGIFMEDIA:
> + case SIOCSIFMEDIA:
> + rtems_mii_ioctl( &self->mdio, self, cmd, (int *) data );
> + break;
> + case SIOCGIFADDR:
> + case SIOCSIFADDR:
> + ether_ioctl( ifp, cmd, data );
> + break;
> + case SIOCSIFFLAGS:
> + eno = dwmac_if_up_or_down( self, ( ifp->if_flags & IFF_UP ) != 0 );
> + if ( eno == 0 && ( ifp->if_flags & IFF_UP ) != 0 ) {
> + dwmac_if_set_promiscous_mode( self, ( ifp->if_flags & IFF_PROMISC )
> + != 0 );
> + } else {
> + break;
> + case SIOCADDMULTI:
> + case SIOCDELMULTI:
> +#ifndef COMMENTED_OUT
> + eno = ENOTSUP;
> +#else /* COMMENTED_OUT */
> + struct ifreq *ifr = (struct ifreq *) data;
> + ( CORE_OPS->set_hash_filter )( self, cmd == SIOCADDMULTI, ifr );
> +#endif /* COMMENTED_OUT */
> + break;
> + case SIO_RTEMS_SHOW_STATS:
> + eno = dwmac_if_interface_stats( self );
> + break;
> + default:
> + eno = EINVAL;
> + break;
> + return eno;
> +/* Method called by the network stack if there are frames to be transmitted */
> +static void dwmac_if_interface_start( struct ifnet *ifp )
> + rtems_status_code sc;
> + /* Mark that we are transmitting */
> + ifp->if_flags |= IFF_OACTIVE;
> + if ( self->state == DWMAC_COMMON_STATE_UP ) {
> + /* Wake up our task */
> + sc = rtems_bsdnet_event_send( self->task_id_tx,
> + DWMAC_COMMON_EVENT_TX_TRANSMIT_FRAME );
> +static int dwmac_if_clk_csr_set(
> + const uint32_t gmii_clk_rate,
> + dwmac_common_context *self )
> + int eno = 0;
> + if ( gmii_clk_rate < DWCGNAC3504_CSR_F_35M ) {
> + self->csr_clock = DWCGNAC3504_CSR_20_35M;
> + } else if ( ( gmii_clk_rate >= DWCGNAC3504_CSR_F_35M )
> + && ( gmii_clk_rate < DWCGNAC3504_CSR_F_60M ) ) {
> + self->csr_clock = DWCGNAC3504_CSR_35_60M;
> + } else if ( ( gmii_clk_rate >= DWCGNAC3504_CSR_F_60M )
> + && ( gmii_clk_rate < DWCGNAC3504_CSR_F_100M ) ) {
> + self->csr_clock = DWCGNAC3504_CSR_60_100M;
> + } else if ( ( gmii_clk_rate >= DWCGNAC3504_CSR_F_100M )
> + && ( gmii_clk_rate < DWCGNAC3504_CSR_F_150M ) ) {
> + self->csr_clock = DWCGNAC3504_CSR_100_150M;
> + } else if ( ( gmii_clk_rate >= DWCGNAC3504_CSR_F_150M )
> + && ( gmii_clk_rate < DWCGNAC3504_CSR_F_250M ) ) {
> + self->csr_clock = DWCGNAC3504_CSR_150_250M;
> + } else if ( ( gmii_clk_rate >= DWCGNAC3504_CSR_F_250M )
> + && ( gmii_clk_rate < DWCGNAC3504_CSR_F_300M ) ) {
> + self->csr_clock = DWCGNAC3504_CSR_250_300M;
> + } else {
> + eno = EINVAL;
> + return eno;
> +static int dwmac_fixup_unit_count(
> + const dwmac_common_context *self,
> + const int count,
> + const int default_value,
> + const int max )
> + int ret = count;
> + if ( ret <= 0 ) {
> + ret = DWMAC_ALIGN( default_value, self->CFG->L1_CACHE_LINE_SIZE );
> + } else if ( ret > max ) {
> + ret = DWMAC_ALIGN( max, self->CFG->L1_CACHE_LINE_SIZE );
> + return ret;
> +/* Called during initial setup */
> +static int dwmac_if_attach(
> + struct rtems_bsdnet_ifconfig *bsd_config,
> + const dwmac_cfg *driver_config,
> + void *arg )
> + int eno = 0;
> + char *unit_name = NULL;
> + int unit_number = rtems_bsdnet_parse_driver_name(
> + bsd_config,
> + &unit_name );
> + const dwmac_callback_cfg *CALLBACK = &driver_config->CALLBACK;
> + (const dwmac_common_desc_ops *) driver_config->DESC_OPS->ops;
> + assert( self != NULL );
> + assert( bsd_config != NULL );
> + assert( driver_config != NULL );
> + assert( CALLBACK != NULL );
> + if ( self == NULL
> + || bsd_config == NULL
> + || driver_config == NULL
> + || CALLBACK == NULL
> + eno = EINVAL;
> + } else {
> + assert( CALLBACK->nic_enable != NULL );
> + assert( CALLBACK->nic_disable != NULL );
> + assert( CALLBACK->phy_enable != NULL );
> + assert( CALLBACK->phy_disable != NULL );
> + assert( CALLBACK->phy_event_enable != NULL );
> + assert( CALLBACK->phy_event_clear != NULL );
> + assert( CALLBACK->phy_events_get != NULL );
> + assert( CALLBACK->phy_start != NULL );
> + assert( CALLBACK->phy_stop != NULL );
> + assert( CALLBACK->mem_alloc_nocache != NULL );
> + assert( CALLBACK->mem_free_nocache != NULL );
> + assert( CALLBACK->bus_setup != NULL );
> + if ( CALLBACK->nic_enable == NULL
> + || CALLBACK->nic_disable == NULL
> + || CALLBACK->phy_enable == NULL
> + || CALLBACK->phy_disable == NULL
> + || CALLBACK->phy_event_enable == NULL
> + || CALLBACK->phy_event_clear == NULL
> + || CALLBACK->phy_events_get == NULL
> + || CALLBACK->phy_start == NULL
> + || CALLBACK->phy_stop == NULL
> + || CALLBACK->mem_alloc_nocache == NULL
> + || CALLBACK->mem_free_nocache == NULL
> + || CALLBACK->bus_setup == NULL
> + eno = EINVAL;
> + if ( eno == 0 ) {
> + self->dma_threshold_control = DWMAC_DMA_THRESHOLD_CONTROL_DEFAULT;
> + if ( driver_config->addr_gmac_regs != NULL ) {
> + self->macgrp = driver_config->addr_gmac_regs;
> + if ( driver_config->addr_dma_regs != NULL ) {
> + self->dmagrp = driver_config->addr_dma_regs;
> + } else {
> + eno = EINVAL;
> + } else {
> + eno = EINVAL;
> + if ( eno == 0 ) {
> + eno = dwmac_if_clk_csr_set(
> + driver_config->GMII_CLK_RATE,
> + self
> + if ( eno == 0 ) {
> + assert( 32 >= driver_config->MDIO_BUS_ADDR );
> + if ( 32 < driver_config->MDIO_BUS_ADDR ) {
> + eno = EINVAL;
> + if ( eno == 0 ) {
> + self->arg = arg; /* Optional argument from upper layer */
> + self->bsd_config = bsd_config; /* BSD-Net configuration.
> + Exists for ll BSD based network divers */
> + /* Device control */
> + bsd_config->drv_ctrl = NULL;
> + /* MDIO */
> + self->mdio.mdio_r = dwmac_if_mdio_read; /* read from phy
> + registers */
> + self->mdio.mdio_w = dwmac_if_mdio_write; /* write to phy
> + registers */
> + if ( driver_config->MAC_OPS == &DWMAC_1000_ETHERNET_MAC_OPS ) {
> + self->mdio.has_gmii = 1;
> + } else {
> + self->mdio.has_gmii = 0;
> + /* dwmac_dma_ops_100 and dwmac_core_ops_100 is not yet implemented! */
> + assert( driver_config->MAC_OPS == &DWMAC_1000_ETHERNET_MAC_OPS );
> + eno = ENOTSUP;
> + if ( eno == 0 ) {
> + self->CFG = driver_config;
> + ifp->if_ioctl = dwmac_if_interface_ioctl; /* Execute commands
> + at runtime */
> + ifp->if_init = dwmac_if_interface_init; /* Initialization
> + (called once) */
> + /* Receive unit count */
> + bsd_config->rbuf_count = dwmac_fixup_unit_count(
> + self,
> + bsd_config->rbuf_count,
> + DWMAC_CONFIG_RX_UNIT_COUNT_DEFAULT,
> + DWMAC_CONFIG_RX_UNIT_COUNT_MAX
> + /* Transmit unit count */
> + bsd_config->xbuf_count = dwmac_fixup_unit_count(
> + self,
> + bsd_config->xbuf_count,
> + DWMAC_CONFIG_TX_UNIT_COUNT_DEFAULT,
> + DWMAC_CONFIG_TX_UNIT_COUNT_MAX
> + /* Copy MAC address */
> + memcpy(
> + self->arpcom.ac_enaddr,
> + bsd_config->hardware_address,
> + ETHER_ADDR_LEN
> + /* Set interface data */
> + ifp->if_softc = self;
> + ifp->if_unit = (short) unit_number;
> + ifp->if_name = unit_name;
> + ifp->if_start = dwmac_if_interface_start; /* Start transmitting
> + frames */
> + ifp->if_output = ether_output;
> + ifp->if_watchdog = NULL;
> + ifp->if_flags = IFF_BROADCAST | IFF_SIMPLEX;
> + ifp->if_snd.ifq_maxlen = ifqmaxlen;
> + ifp->if_timer = 0;
> + ifp->if_mtu =
> + bsd_config->mtu > 0 ? (u_long) bsd_config->mtu : ETHERMTU;
> + eno = DESC_OPS->validate( self );
> + if ( eno == 0 ) {
> + /* Create and start the receive task for our driver */
> + assert( self->task_id_rx == RTEMS_ID_NONE );
> + self->task_id_rx = rtems_bsdnet_newproc(
> + "ntrx",
> + 4096,
> + dwmac_task_rx,
> + self
> + assert( self->task_id_rx != RTEMS_ID_NONE );
> + if ( self->task_id_rx == RTEMS_ID_NONE ) {
> + eno = ENOMEM;
> + if ( eno == 0 ) {
> + /* Create and start the transmit task for our driver */
> + assert( self->task_id_tx == RTEMS_ID_NONE );
> + self->task_id_tx = rtems_bsdnet_newproc(
> + "nttx",
> + 4096,
> + dwmac_task_tx,
> + self
> + assert( self->task_id_tx != RTEMS_ID_NONE );
> + if ( self->task_id_tx == RTEMS_ID_NONE ) {
> + eno = ENOMEM;
> + if ( eno == 0 ) {
> + /* Change status */
> + ifp->if_flags |= IFF_RUNNING;
> + /* Attach the interface */
> + if_attach( ifp );
> + ether_ifattach( ifp );
> + return eno;
> +/* Initial setup method. Part of the driver API
> + * Returns the address of the driver context on success and NULL on failure */
> +void *dwmac_network_if_attach_detach(
> + void *arg,
> + int attaching )
> + int eno = 0;
> + dwmac_common_context *context = NULL;
> + if ( attaching ) {
> + context = calloc( 1, sizeof( dwmac_common_context ) );
> + assert( context != NULL );
> + if ( context != NULL ) {
> + eno = dwmac_if_attach(
> + context,
> + bsd_config,
> + driver_config,
> + arg
> + if ( eno != 0 ) {
> + free( context, 0 );
> + context = NULL;
> + } else {
> + /* Detaching is not supported */
> + assert( attaching != false );
> + return context;
> +int dwmac_if_read_from_phy(
> + void *arg,
> + const unsigned phy_reg,
> + uint16_t *val )
> + int eno = EINVAL;
> + uint32_t value;
> + if ( arg != NULL ) {
> + self,
> + phy_reg,
> + &value );
> + if ( eno == 0 ) {
> + *val = (uint16_t) value;
> + return eno;
> +int dwmac_if_write_to_phy(
> + void *arg,
> + const uint16_t val )
> + int eno = EINVAL;
> + eno = dwmac_if_mdio_write(
> + self,
> + phy_reg,
> + val );
> + return eno;
> +int dwmac_if_handle_phy_event( void *arg )
> + int eno;
> + self->task_id_tx,
> + DWMAC_COMMON_EVENT_TX_PHY_STATUS_CHANGE
> + return eno;
> \ No newline at end of file
> diff --git a/c/src/libchip/network/dwmac.h b/c/src/libchip/network/dwmac.h
> new file mode 100644
> index 0000000..3592f26
> --- /dev/null
> +++ b/c/src/libchip/network/dwmac.h
> @@ -0,0 +1,867 @@
> + * @file dwmac.h
> + * @brief API header for the DWMAC 10/100/1000 Network Interface Controllers
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#ifndef DWMAC_H_
> +#define DWMAC_H_
> +#include <stddef.h>
> +#include <stdint.h>
> +#include <rtems/rtems_bsdnet.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> +/** @brief PHY event.
> + * Data type to be used for PHY events and event sets.
> +typedef uint8_t dwmac_phy_event;
> +/** @brief PHY event Jabber. */
> +extern const dwmac_phy_event PHY_EVENT_JABBER;
> +/** @brief PHY event Receive Error. */
> +extern const dwmac_phy_event PHY_EVENT_RECEIVE_ERROR;
> +/** @brief PHY event Page Receive. */
> +extern const dwmac_phy_event PHY_EVENT_PAGE_RECEIVE;
> +/** @brief PHY event Parallel Detect Fault. */
> +extern const dwmac_phy_event PHY_EVENT_PARALLEL_DETECT_FAULT;
> +/** @brief PHY event Link Partner Acknowledge. */
> +extern const dwmac_phy_event PHY_EVENT_LINK_PARTNER_ACK;
> +/** @brief PHY event Ling Down. */
> +extern const dwmac_phy_event PHY_EVENT_LINK_DOWN;
> +/** @brief PHY event Remote Fault. */
> +extern const dwmac_phy_event PHY_EVENT_REMOTE_FAULT;
> +/** @brief PHY event Link Up. */
> +extern const dwmac_phy_event PHY_EVENT_LINK_UP;
> +/** @brief NIC enable
> + * Enables (powers up) the network interface card.
> + * @param[in] arg The void pointer argument passed to
> + * @see dwmac_network_if_attach_detach.
> + * @retval 0 on success, error code from errno.h on failure.
> +typedef int
> +(*dwmac_if_nic_enable)( void *arg );
> +/** @brief NIC disable.
> + * Disables (powers down) the network interface card.
> +typedef int
> +(*dwmac_if_nic_disable)( void *arg );
> +/** @brief PHY enable.
> + * Enables (powers up) the network PHY.
> +typedef int
> +(*dwmac_if_phy_enable)( void *arg );
> +/** @brief PHY disable.
> + * Disables (powers down) the network PHY.
> +typedef int
> +(*dwmac_if_phy_disable)( void *arg );
> +/** @brief PHY event enable.
> + * Enables generation of events for an event set.
> + * @param[in] event_set Set of events. For these events shall get generated
> + * upon PHY status change.
> +typedef int
> +(*dwmac_if_phy_event_enable)(
> + void *arg,
> + const dwmac_phy_event event_set );
> +/** @brief Clear phy event status.
> + * Clears all PHY event statuses.
> +typedef int
> +(*dwmac_if_phy_event_status_clear)( void *arg );
> + * @brief Get the PHY event status.
> + * Reports status on PHY events (e.g. PHY interrupts).
> + * @param[out] event_set Pointer to a buffer for a set of events for which a
> + * PHY status change was detected.
> + * For events see @see dwmac_phy_event.
> +typedef int
> +(*dwmac_if_phy_events_status_get)(
> + void *arg,
> + dwmac_phy_event *event_set );
> + * @brief Start the network PHY.
> + * Do anything necessary to start the network PHY (start generating
> + * events, ...).
> +typedef int
> +(*dwcmac_if_phy_start)( void *arg );
> + * @brief Stop the network PHY.
> + * Do anything necessary to stop the network PHY (stop generating events, ...).
> +typedef int
> +(*dwcmac_if_phy_stop)( void *arg );
> + * @brief Allocate nocache RAM.
> + * Allocate uncached RAM.
> + * @param[out] memory Pointer of a buffer to write the address of the
> + * allocated memory to.
> + * @param[in] size Number of bytes to be allocated
> +typedef int
> +(*dwmac_if_mem_alloc_nocache)(
> + void *arg,
> + void **memory,
> + const size_t size );
> + * @brief Free nocache RAM.
> + * Release uncached RAM.
> + * @param[in] memory Pointer to the memory to be freed.
> +typedef int
> +(*dwmac_if_mem_free_nocache)(
> + void *arg,
> + void *memory );
> + * @brief Bus setup.
> + * Callback method for setting up the system bus for the network driver.
> +typedef int
> +(*dwcmac_if_bus_setup)( void *arg );
> + * @brief Callback methods.
> + * The address of an instance of such a callback struct must get passed
> + * to @see dwmac_network_if_attach_detach() for initialization.
> + * Via these callback methods, those parts of the network driver which
> + * are micro controller specific or PCB specific will get handled.
> +typedef struct {
> + /** @brief Enable the network interface controller. */
> + dwmac_if_nic_enable nic_enable;
> + /** @brief Disable the network interface controller. */
> + dwmac_if_nic_disable nic_disable;
> + /** @brief Enable (power up, ... ) the network PHY. */
> + dwmac_if_phy_enable phy_enable;
> + /** @brief Disable (power down, ... ) the network PHY. */
> + dwmac_if_phy_disable phy_disable;
> + /** @brief Enable a set of PHY events for generation upon status change. */
> + dwmac_if_phy_event_enable phy_event_enable;
> + /** @brief Clear the event status (e.g. interrupt staus) of the PHY. */
> + dwmac_if_phy_event_status_clear phy_event_clear;
> + /** @brief Get set of tripped events from PHY. */
> + dwmac_if_phy_events_status_get phy_events_get;
> + /** @brief Start the phy (start generating events, ...). */
> + dwcmac_if_phy_start phy_start;
> + /** @brief Stop the phy (stop generating events, ...). */
> + dwcmac_if_phy_stop phy_stop;
> + /** @brief Allocate uncached memory. */
> + dwmac_if_mem_alloc_nocache mem_alloc_nocache;
> + /** @brief Free uncached memory. */
> + dwmac_if_mem_free_nocache mem_free_nocache;
> + /** @brief Setup handling for bus upon device up. */
> + dwcmac_if_bus_setup bus_setup;
> +} dwmac_callback_cfg;
> +/** @brief Initializer for callback methods.
> + * Initializes a struct which contains pointers to the callback methods
> + * required by the driver.
> + * For the struct see @see dwmac_callback_cfg.
> + * @param[in] nic_enable Callback method for for enabling the
> + * network interface controller.
> + * (@see dwmac_if_nic_enable)
> + * @param[in] nic_disable Callback method for disabling the
> + * (@see dwmac_if_nic_disable)
> + * @param[in] phy_enable Callback method for enabling the
> + * network PHY.
> + * (@see dwmac_if_phy_enable)
> + * @param[in] phy_disable Callback method for disabling the
> + * network PHY.
> + * (@see dwmac_if_phy_disable)
> + * @param[in] phy_event_enable Callback method for enabling PHY status
> + * changes for event generation.
> + * (@see dwmac_if_phy_event_enable)
> + * @param[in] phy_event_clear Callback method for
> + * clearing/acknowledging PHY events.
> + * (@see dwmac_if_phy_event_status_clear)
> + * @param[in] phy_events_get Callback method for reading the status of
> + * PHY events.
> + * (@see dwmac_if_phy_events_status_get)
> + * @param[in] phy_start Callback method for starting event
> + * generation by the network PHY.
> + * (@see dwcmac_if_phy_start)
> + * @param[in] phy_stop Callback method for stoping event
> + * (@see dwcmac_if_phy_stop)
> + * @param[in] mem_alloc_nocache Callback method for allocating uncached
> + * RAM.
> + * (@see dwmac_if_mem_alloc_nocache)
> + * @param[in] mem_free_nocache Callback method for releasing uncached
> + * RAM.
> + * (@see dwmac_if_mem_free_nocache)
> + * @param[in] bus_setup Callback method for setting up the system
> + * bus.
> + * (@see dwcmac_if_bus_setup)
> + * @retval An initialized struct of pointers to callback methods.
> +#define DWMAC_CALLBACK_CFG_INITIALIZER( \
> + nic_enable, \
> + nic_disable, \
> + phy_enable, \
> + phy_disable, \
> + phy_event_enable, \
> + phy_event_clear, \
> + phy_events_get, \
> + phy_start, \
> + phy_stop, \
> + mem_alloc_nocache, \
> + mem_free_nocache, \
> + bus_setup \
> + nic_enable, \
> + nic_disable, \
> + phy_enable, \
> + phy_disable, \
> + phy_events_get, \
> + phy_start, \
> + phy_stop, \
> + bus_setup \
> +/** @brief Ethernet MAC operations.
> + * Actually this is a mere wrapper which contains void ponters to the core
> + * operations and DMA operations to be used by the driver (void pointer
> + * for the purpose of information hiding).
> + * There will be two instances of such a struct:
> + * One for DWMAC 10/100 ethernet operations: @see DWMAC_100_ETHERNET_MAC_OPS.
> + * And one for DWMAC 1000 ethernet operations: @see DWMAC_1000_ETHERNET_MAC_OPS.
> + * The address of either of these must get passed to @see DWMAC_CFG_INITIALIZER
> + * for configuring the driver.
> + * For an initializer see @see DWMAC_ETHERNET_MAC_OPS_INITIALIZER
> +typedef struct {
> + const void *core;
> + const void *dma;
> +} dwmac_ethernet_mac_ops;
> +/** @brief Ethernet MAC operations initializer.
> + * Initializes a structure of ethernet MAC operations.
> + * For the struct @see dwmac_ethernet_mac_ops.
> + * @param core_ops_addr Address of the core operations to be used by the
> + * driver.
> + * @param dma_ops_addr Address of the DMA operations to be used by the driver.
> + * @retval An initialized struct of ethernet mac operations
> +#define DWMAC_ETHERNET_MAC_OPS_INITIALIZER( \
> + core_ops_addr, \
> + dma_ops_addr \
> + core_ops_addr, \
> + dma_ops_addr \
> +/** @brief Descriptor operations.
> + * Actually this is a mere wrapper which contains a void pointer to a
> + * descriptor operations struct which can be used by the driver (void pointer
> + * One for normal DMA descriptors @see DWMAC_DESCRIPTOR_OPS_NORMAL.
> + * And one for enhanced DMA descriptors @see DWMAC_DESCRIPTOR_OPS_ENHANCED.
> + * For an initializer @see DWMAC_DESCRIPTOR_OPS_INITIALIZER.
> +typedef struct {
> + /** @brief Address of the descriptor operations to be used by the driver */
> + const void *ops;
> +} dwmac_descriptor_ops;
> +/** @brief Initializer for descriptor operations.
> + * Initializes a struct of type @see dwmac_descriptor_ops.
> + * @param desc_ops_addr Address of the descriptor operations.
> + * @retval Returns an initialized descriptor operations struct.
> +#define DWMAC_DESCRIPTOR_OPS_INITIALIZER( \
> + desc_ops_addr \
> + desc_ops_addr \
> +/** @brief Ethernet MAC operations for DWMAC 1000.
> + * Pass the address of DWMAC_1000_ETHERNET_MAC_OPS to
> + * @see DWMAC_CFG_INITIALIZER
> + * if the driver is supposed to control a DWMAC 1000. */
> +extern const dwmac_ethernet_mac_ops DWMAC_1000_ETHERNET_MAC_OPS;
> +/* TODO: To be implemented in the future */
> +/** @brief Ethernet MAC operations for DWMAC 10/100.
> + * Pass the address of DWMAC_100_ETHERNET_MAC_OPS to
> + * if the driver is supposed to control a DWMAC 10/100. */
> +/*extern const dwmac_ethernet_mac_ops DWMAC_100_ETHERNET_MAC_OPS; */
> +/** @brief DMA Descriptor operations for normal descriptors.
> + * Pass the address of DWMAC_DESCRIPTOR_OPS_NORMAL to
> + * if you intend to use the normal DMA descriptors. */
> +/*extern const dwmac_descriptor_ops DWMAC_DESCRIPTOR_OPS_NORMAL;*/
> +/** @brief DMA Descriptor operations for enhanced descriptors.
> + * Pass the address of DWMAC_DESCRIPTOR_OPS_ENHANCED to
> + * if you intend to use the enhanced DMA descriptors. */
> +extern const dwmac_descriptor_ops DWMAC_DESCRIPTOR_OPS_ENHANCED;
> +/** @brief Burst size. */
> +typedef enum {
> + /** @brief Burst size = 1. */
> + DWMAC_DMA_CFG_BUS_MODE_BURST_LENGTH_1 = 0,
> + /** @brief Burst size = 2. */
> + DWMAC_DMA_CFG_BUS_MODE_BURST_LENGTH_2 = 1,
> + /** @brief Burst size = 4. */
> + DWMAC_DMA_CFG_BUS_MODE_BURST_LENGTH_4 = 3,
> + /** @brief Burst size = 8. */
> + DWMAC_DMA_CFG_BUS_MODE_BURST_LENGTH_8 = 7,
> + /** @brief Burst size = 16. */
> + DWMAC_DMA_CFG_BUS_MODE_BURST_LENGTH_16 = 15,
> + /** @brief Burst size = 32. */
> + DWMAC_DMA_CFG_BUS_MODE_BURST_LENGTH_32 = 31,
> + /** @brief Burst size = 64. */
> + DWMAC_DMA_CFG_BUS_MODE_BURST_LENGTH_64 = 63,
> + /** @brief Burst size = 128. */
> + DWMAC_DMA_CFG_BUS_MODE_BURST_LENGTH_128 = 127,
> + /** @brief Burst size = 256. */
> + DWMAC_DMA_CFG_BUS_MODE_BURST_LENGTH_256 = 255
> +} dwmac_dma_cfg_bus_mode_burst_length;
> +/** @brief Burst mode. */
> +typedef enum {
> + /** @brief Single burst or incrment bursts. */
> + DWMAC_DMA_CFG_BUS_MODE_BURST_MODE_SINGLE_OR_INCR,
> + /** @brief Fixed burst size. */
> + DWMAC_DMA_CFG_BUS_MODE_BURST_MODE_FIXED
> +} dwmac_dma_cfg_bus_mode_burst_mode;
> +/** @brief Mixed burst mode support. */
> +typedef enum {
> + /** @brief Mixed burst mode is not supported. */
> + DWMAC_DMA_CFG_BUS_MODE_BURST_NOT_MIXED,
> + DWMAC_DMA_CFG_BUS_MODE_BURST_MIXED
> +} dwmac_dma_cfg_bus_mode_burst_mixed;
> +/** @brief Burst length 4 support. */
> +typedef enum {
> + /** @brief Bursts of length 4 are not supported. */
> + DWMAC_DMA_CFG_AXI_BURST_LENGTH_4_NOT_SUPPORTED,
> + /** @brief Bursts of length 4 are supported. */
> + DWMAC_DMA_CFG_AXI_BURST_LENGTH_4_SUPPORTED
> +} dwmac_dma_cfg_axi_burst_length_4_support;
> +/** @brief Burst length 8 support. */
> +typedef enum {
> + /** @brief Bursts of length 8 are not supported. */
> + DWMAC_DMA_CFG_AXI_BURST_LENGTH_8_NOT_SUPPORTED,
> + /** @brief Bursts of length 8 are supported. */
> + DWMAC_DMA_CFG_AXI_BURST_LENGTH_8_SUPPORTED
> +} dwmac_dma_cfg_axi_burst_length_8_support;
> +/** @brief Burst length 16 support. */
> +typedef enum {
> + /** @brief Bursts of length 16 are not supported. */
> + DWMAC_DMA_CFG_AXI_BURST_LENGTH_16_NOT_SUPPORTED,
> + /** @brief Bursts of length 16 are supported. */
> + DWMAC_DMA_CFG_AXI_BURST_LENGTH_16_SUPPORTED
> +} dwmac_dma_cfg_axi_burst_length_16_support;
> +/** @brief DMA Burst Boundary parameters. */
> +typedef enum {
> + /** @brief Transfers do not cross 4 kB boundary. */
> + DWMAC_DMA_CFG_AXI_BURST_BOUNDARY_4_KB,
> + /** @brief Transfers do not cross 1 kB boundary. */
> + DWMAC_DMA_CFG_AXI_BURST_BOUNDARY_1_KB
> +} dwmac_dma_cfg_axi_burst_boundary;
> + * @brief DMA configuration.
> + * Configuration data for the DMA of the network driver. See
> + * @see DWMAC_DMA_CFG_INITIALIZER
> + * for an inititializer.
> +typedef union {
> + uint16_t raw;
> + struct {
> + /** @brief Maximum number of beats to be transferred in one DMA transaction.
> + * This is the maximum value that is used in a single block Read or Write.
> + * The DMA always attempts to burst as specified in bus_mode_burst_length
> + * each time it starts a Burst transfer on the host bus.
> + * bus_mode_burst_length can be programmed with permissible values as
> + * specified in @see dwmac_dma_cfg_bus_mode_burst_length.
> + * Any other value results in undefined behavior.
> + * The bus_mode_burst_length values have the following limitation:
> + * The maximum number of possible beats (bus_mode_burst_length) is limited
> + * by the size of the Tx FIFO and Rx FIFO in the MTL layer and the data bus
> + * width on the DMA.
> + * The FIFO has a constraint that the maximum beat supported is half the
> + * depth of the FIFO, except when specified. */
> + uint16_t bus_mode_burst_length : 6;
> + /** @brief Controls whether the AXI Master performs fixed bursts or not.
> + * For valid parameters see:
> + * @see dwmac_dma_cfg_bus_mode_burst_mode.
> + * When set to DWMAC_DMA_CFG_BUS_MODE_BURST_MODE_FIXED, the AXI interface
> + * uses FIXED bursts during the start of the normal burst transfers.
> + * When set to DWMAC_DMA_CFG_BUS_MODE_BURST_MODE_SINGLE_OR_INCR, the AXI
> + * interface uses SINGLE and INCR burst transfer operations. */
> + uint16_t bus_mode_burst_mode : 1;
> + /** @brief Controls whether mixed bursts will be used or not.
> + * @see dwmac_dma_cfg_bus_mode_burst_mixed.
> + * Mixed burst has no effect when if DWMAC_DMA_CFG_BUS_MODE_BURST_MODE_FIXED is set. */
> + uint16_t bus_mode_burst_mixed : 1;
> + /** @brief Controls support of burst length 4.
> + * @see dwmac_dma_cfg_axi_burst_length_4_support.
> + * When set to DWMAC_DMA_CFG_AXI_BURST_LENGTH_4_SUPPORTED, the GMAC-AXI is
> + * allowed to select a burst length of 4 on the AXI Master interface.*/
> + uint16_t axi_burst_length_4_support : 1;
> + /** @brief Controls support of burst length 8.
> + * @see dwmac_dma_cfg_axi_burst_length_8_support.
> + * When set to DWMAC_DMA_CFG_AXI_BURST_LENGTH_8_SUPPORTED, the GMAC-AXI is
> + * allowed to select a burst length of 8 on the AXI Master interface. */
> + uint16_t axi_burst_length_8_support : 1;
> + /** @brief Controls support of burst length 16.
> + * @see dwmac_dma_cfg_axi_burst_length_16_support.
> + * When set to DWMAC_DMA_CFG_AXI_BURST_LENGTH_16_SUPPORTED fixed bust is
> + * not selected, the GMAC-AXI is allowed to select a burst length of 16 on
> + * the AXI Master interface. */
> + uint16_t axi_burst_length_16_support : 1;
> + /** @brief Select Burst Boundary.
> + * @see dwmac_dma_cfg_axi_burst_boundary.
> + * When set to DWMAC_DMA_CFG_AXI_BURST_BOUNDARY_1_KB, the GMAC-AXI Master
> + * performs burst transfers that do not cross 1 KB boundary.
> + * When set to DWMAC_DMA_CFG_AXI_BURST_BOUNDARY_4_KB, the GMAC-AXI Master
> + * performs burst transfers that do not cross 4 KB boundary.*/
> + uint16_t axi_burst_boundary : 1;
> + uint16_t unused : 4;
> +} dwmac_dma_cfg;
> +/** @brief DMA Configuration initializer.
> + * Initializer for a DMA configuration struct.
> + * @param[in] bus_mode_burst_length Number of bytes to be sent in one
> + * burst within a DMA transfer on the
> + * bus .
> + * (@see dwmac_dma_cfg_bus_mode_burst_length)
> + * @param[in] bus_mode_burst_mode Mode to be used for burst transfers.
> + * (@see dwmac_dma_cfg_bus_mode_burst_mode)
> + * @param[in] bus_mode_burst_mixed Use mixed bursts or not. Fixed bursts
> + * have priority over mixed bursts.
> + * (@see dwmac_dma_cfg_bus_mode_burst_mixed)
> + * @param[in] axi_burst_length_4_support Support or don't support burst
> + * lengths of 4.
> + * (@see dwmac_dma_cfg_axi_burst_length_4_support)
> + * @param[in] axi_burst_length_8_support Support or don't support burst
> + * lengths of 8.
> + * (@see dwmac_dma_cfg_axi_burst_length_8_support)
> + * @param[in] axi_burst_length_16_support Support or don't support burst
> + * lengths of 16.
> + * (@see dwmac_dma_cfg_axi_burst_length_16_support)
> + * @param[in] axi_burst_boundary Select the burst boundary.
> + * (@see dwmac_dma_cfg_axi_burst_boundary)
> + * @retval An initialized struct of DMA configuration parameters.
> +#define DWMAC_DMA_CFG_INITIALIZER( \
> + bus_mode_burst_length, \
> + bus_mode_burst_mode, \
> + bus_mode_burst_mixed, \
> + axi_burst_length_4_support, \
> + axi_burst_length_8_support, \
> + axi_burst_length_16_support, \
> + axi_burst_boundary \
> + BSP_FLD16( bus_mode_burst_length, 0, 5 ) \
> + | BSP_FLD16( bus_mode_burst_mode, 6, 6 ) \
> + | BSP_FLD16( bus_mode_burst_mixed, 7, 7 ) \
> + | BSP_FLD16( axi_burst_length_4_support, 8, 8 ) \
> + | BSP_FLD16( axi_burst_length_8_support, 9, 9 ) \
> + | BSP_FLD16( axi_burst_length_16_support, 10, 10 ) \
> + | BSP_FLD16( axi_burst_boundary, 11, 11 ) \
> + * @brief Driver configuration.
> + * Configuration data for the network driver.
> + * See @see DWMAC_CFG_INITIALIZER
> + * for an initializer.
> +typedef struct {
> + /** @brief The clock to be used for the gmii interface in Hz. */
> + const uint32_t GMII_CLK_RATE;
> + /** @brief Start address of the MAC group registers. */
> + volatile void *addr_gmac_regs;
> + /** @brief Start address of the DMA group registers. */
> + volatile void *addr_dma_regs;
> + /** @brief Address of the PHY on the mdio bus (5 bit). */
> + const uint8_t MDIO_BUS_ADDR;
> + /** @brief Bytes per L1 cache line. */
> + const uint8_t L1_CACHE_LINE_SIZE;
> + /** @brief Interrupt vector number for EMAC IRQs. */
> + const rtems_vector_number IRQ_EMAC;
> + /** @brief Set to true if prefetching into cache via PLD is supported. */
> + const bool ARCH_HAS_PREFETCH;
> + /** @brief Optional configuration for bus mode and axi bus mode. */
> + const dwmac_dma_cfg *DMA_CFG;
> + /** @brief Methods which must get provided to the by the micro controller. */
> + const dwmac_callback_cfg CALLBACK;
> + /** @brief Operations which are specific to the ethernet MAC. */
> + const dwmac_ethernet_mac_ops *MAC_OPS;
> + /** @brief DMA descriptor operations. */
> + const dwmac_descriptor_ops *DESC_OPS;
> +} dwmac_cfg;
> + * @brief Configuration initializer.
> + * Initializes the configuration data to be passed to
> + * the initialization method (@see dwmac_network_if_attach_detach()).
> + * @param[in] mdio_clk_rate The clock to be used for the gmii
> + * interface in Hz.
> + * @param[in] macgrp_regs_addr Base address of the MAC group registers.
> + * @param[in] dmagrp_regs_addr Base address of the DMA group registers.
> + * @param[in] mdio_bus_addr Address of the network PHY on the
> + * mdio bus.
> + * @param[in] l1_cache_line_size Size of a cache line in the level 1 cache.
> + * @param[in] irq_emac Number of the EMAC interrupt.
> + * @param[in] arch_has_prefetch True if architecture supports.
> + * prefetching, false if not.
> + * @param[in] dma_cfg_addr Address of the optional DMA configuration.
> + * Set to NULL for defaults.
> + * (@see dwmac_dma_cfg)
> + * network PHY.
> + * network PHY.
> + * PHY events.
> + * RAM.
> + * RAM.
> + * bus.
> + * @param[in] ethernet_mac_ops_addr Address of a struct encapsulating
> + * ethernet MAC operations for DWMAC 1000 or
> + * DWMAC 10/100.
> + * (@see DWMAC_1000_ETHERNET_MAC_OPS)
> + * (@see DWMAC_100_ETHERNET_MAC_OPS)
> + * @param[in] descriptor_ops_addr Address of a struct encasulating DMA
> + * descriptor operations for either normal
> + * descriptors or enhanced descriptors.
> + * (@see DWMAC_DESCRIPTOR_OPS_NORMAL)
> + * (@see DWMAC_DESCRIPTOR_OPS_ENHANCED)
> + * @retval An initialized struct of configuration parameters (@see dwmac_cfg).
> +#define DWMAC_CFG_INITIALIZER( \
> + mdio_clk_rate, \
> + macgrp_regs_addr, \
> + dmagrp_regs_addr, \
> + mdio_bus_addr, \
> + l1_cache_line_size, \
> + irq_emac, \
> + arch_has_prefetch, \
> + dma_cfg_addr, \
> + nic_enable, \
> + nic_disable, \
> + phy_enable, \
> + phy_disable, \
> + phy_events_get, \
> + phy_start, \
> + phy_stop, \
> + bus_setup, \
> + ethernet_mac_ops_addr, \
> + descriptor_ops_addr \
> + mdio_clk_rate, \
> + mdio_bus_addr, \
> + irq_emac, \
> + dma_cfg_addr, \
> + DWMAC_CALLBACK_CFG_INITIALIZER( \
> + nic_enable, \
> + nic_disable, \
> + phy_enable, \
> + phy_disable, \
> + phy_events_get, \
> + phy_start, \
> + phy_stop, \
> + bus_setup \
> + * @brief Initialization method.
> + * Initialized the network driver and "links" it to the network stack.
> + * @param[in] bsd_config The BSD configuation passed to all
> + * network_if_attach_detach() methods.
> + * @param[in] driver_config Address of of a struct containing driver
> + * specific configuration data.
> + * @see dwmac_cfg
> + * @see DWMAC_CFG_INITIALIZER()
> + * @param[in] arg An optional argument which will get passed to all
> + * callback methods.
> + * @param[in] attching 1 for attching and 0 for detaching.
> + * @retval Address of the drivers context if successful or NULL if not
> + * successful.
> + void *arg,
> + int attaching );
> + * @brief Read from PHY
> + * Read a value from a register of the network PHY.
> + * @param[in] arg Pointer returned from dwmac_network_if_attach_detach.
> + * @see dwmac_network_if_attach_detach()
> + * @param[in] phy_reg The PHY register to be read from.
> + * @param[out] val Buffer address for the value to be read.
> + void *arg,
> + uint16_t *val );
> + * @brief Write to PHY.
> + * Write a value to a register of the network PHY.
> + * @param[in] phy_reg The PHY register to be written to.
> + * @param[in] val The value to be written.
> + void *arg,
> + const uint16_t val );
> + * @brief Handle PHY event.
> + * Handle an event from the network PHY.
> +int dwmac_if_handle_phy_event( void *arg );
> +#ifdef __cplusplus
> +#endif /* DWMAC_H_ */
> diff --git a/c/src/libchip/preinstall.am b/c/src/libchip/preinstall.am
> index 8b9a0bb..452818f 100644
> --- a/c/src/libchip/preinstall.am
> +++ b/c/src/libchip/preinstall.am
> @@ -97,6 +97,10 @@ PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/smc91111.h
> $(PROJECT_INCLUDE)/libchip/smc91111exp.h: network/smc91111exp.h $(PROJECT_INCLUDE)/libchip/$(dirstamp)
> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/smc91111exp.h
> PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/smc91111exp.h
> +$(PROJECT_INCLUDE)/libchip/dwmac.h: network/dwmac.h $(PROJECT_INCLUDE)/libchip/$(dirstamp)
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/dwmac.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/dwmac.h
> endif
> $(PROJECT_INCLUDE)/libchip/rtc.h: rtc/rtc.h $(PROJECT_INCLUDE)/libchip/$(dirstamp)
> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/rtc.h
> 1.7.10.4
> rtems-devel mailing list
> rtems-devel at rtems.org
