[PATCH] altera-cyclone-v: Create new BSP
Wed Feb 26 19:21:07 UTC 2014
I skimmed these patches and made notes where I saw anything suspect. I
assume you have done the sufficient testing for the altera cyclone v
itself, but please also verify you tested for other impacted ARM
targets especially the zynq and targets that use the new errata
handling (I think one of the lpc BSPs?)
On Wed, Feb 26, 2014 at 5:47 AM, Ralf Kirchner
<ralf.kirchner at embedded-brains.de> wrote:
> These patches create a new BSP for the Alteras Cyclone-V.
> This BSP supports SMP on two cores.
> It uses a new libchip driver for the Synopsys IP DWMAC 1000
> onchip network controller.
> It suuports the L2C-310 level 2 cache controller from arm in
> arm/shared/arm-l2c-310/cache_.h.
> In addition the general level 1 cache handling for the arm level 1
> cache controller has been separated to /arm/include/arm-cache-l1.h.
> With arm/include/arm-errata.h and arm/include/arm-release-id.h it
> also supports a basic errata handling which was required for
> implementing the L2C-310 level 2 cache.
> Patches 1 - 4   do preparation work for the BSP
> Patches 5 - 9   add the basic arrata handling.
> Patch 10        partially applies one of the erratas which is required
>                 for the L2 cache handling
> Patches 11 - 12 implement the cache handling and share it with the
>                 xilinx-zynq BSP
> Patch 13        Adds the Synopsys IP DWMAC 1000 network driver as a
>                 libchip driver
> Patches 14 - 17 Implement the new BSP for Alteras Cyclone-V
> rtems-devel mailing list
> rtems-devel at rtems.org
