[PATCH 6/8] bsp/leon3: Add L2C registers
    Gedare Bloom
    gedare at rtems.org
    Wed Feb 26 19:33:59 UTC 2014
Maybe it is just me, but l2c looks very close to i2c which might cause
some confusion.
On Wed, Feb 26, 2014 at 10:52 AM, Sebastian Huber
>  c/src/lib/libbsp/sparc/shared/include/grlib.h |   25 +++++++++++++++++++++++++
>  1 files changed, 25 insertions(+), 0 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/shared/include/grlib.h b/c/src/lib/libbsp/sparc/shared/include/grlib.h
> index 9c45038..5a1449f 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/grlib.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/grlib.h
> @@ -88,6 +88,31 @@ struct grgpio_regs {
>    volatile unsigned int bypass;      /* 0x18 Bypass register */
> +/* L2C - Level 2 Cache Controller registers */
> +struct l2c_regs {
> +  volatile unsigned int control;
> +  volatile unsigned int status;
> +  volatile unsigned int flush_mem_addr;
> +  volatile unsigned int flush_set_index;
> +  volatile unsigned int access_counter;
> +  volatile unsigned int hit_counter;
> +  volatile unsigned int bus_cycle_counter;
> +  volatile unsigned int bus_usage_counter;
> +  volatile unsigned int error_status_control;
> +  volatile unsigned int error_addr;
> +  volatile unsigned int tag_check_bit;
> +  volatile unsigned int data_check_bit;
> +  volatile unsigned int scrub_control_status;
> +  volatile unsigned int scrub_delay;
> +  volatile unsigned int error_injection;
> +  volatile unsigned int reserved_3c[17];
> +  volatile unsigned int mtrr;
> +  volatile unsigned int reserved_84[131039];
> +  volatile unsigned int diag_iface_tag[16384];
> +  volatile unsigned int reserved_90000[376832];
> +  volatile unsigned int diag_iface_data[524288];
>  #ifdef __cplusplus
>  #endif
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
