[PATCH 02/17] bsp/arm: Separate setup for translation table
Chris Johns
chrisj at rtems.org
Thu Feb 27 05:54:07 UTC 2014
Hi Ralf,
Some of these line are far to long. There is no formal policy on this
such as 80 columns however some are way way past a reasonable limit.
There are also some "/* TODO */" statements. Seems we are supporting
doxygen should this be @todo. Also it would be nice if some detail was
added such as why we need these functions and someone should add this code.
There is "#if 0" code. What is the code and why is it removed ?
On 26/02/2014 9:51 pm, Ralf Kirchner wrote:
> .../lib/libbsp/arm/shared/include/arm-cp15-start.h | 26 ++++++++++++++++----
> 1 Datei geändert, 21 Zeilen hinzugefügt(+), 5 Zeilen entfernt(-)
> diff --git a/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h b/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
> index 54f2963..a0fe9b1 100644
> --- a/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
> +++ b/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
> @@ -129,12 +129,11 @@ arm_cp15_start_set_translation_table_entries(
> BSP_START_TEXT_SECTION static inline void
> -arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
> - uint32_t ctrl,
> - uint32_t *ttb,
> - uint32_t client_domain,
> +arm_cp15_start_setup_translation_table(
> + uint32_t *ttb,
> + const uint32_t client_domain,
> const arm_cp15_start_section_config *config_table,
> - size_t config_count
> + const size_t config_count
> uint32_t dac = ARM_CP15_DAC_DOMAIN(client_domain, ARM_CP15_DAC_CLIENT);
> @@ -151,7 +150,24 @@ arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
> for (i = 0; i < config_count; ++i) {
> arm_cp15_start_set_translation_table_entries(ttb, &config_table [i]);
> +BSP_START_TEXT_SECTION static inline void
> +arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
> + uint32_t ctrl,
> + uint32_t *ttb,
> + uint32_t client_domain,
> + const arm_cp15_start_section_config *config_table,
> + size_t config_count
> + arm_cp15_start_setup_translation_table(
> + ttb,
> + client_domain,
> + config_table,
> + config_count
> /* Enable MMU and cache */
> ctrl |= ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M;
