Posix patchs to support affinity attribute in newlib
Jennifer Averett
Jennifer.Averett at OARcorp.com
Thu Feb 27 15:09:51 UTC 2014
I don't think you can make the default attributes static, as you
can see in pthreadimpl.h it is used by several methods when
to copy the default values into new attributes.
I'll add the copyright and doc :-)
> -----Original Message-----
> From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On
> Behalf Of Gedare Bloom
> Sent: Thursday, February 27, 2014 9:06 AM
> To: Jennifer Averett
> Cc: rtems-devel at rtems.org
> Subject: Re: Posix patchs to support affinity attribute in newlib
> Since you drop const from _POSIX_Threads_Default_attributes it would be
> good to change it to be statically scoped in pthread.c.
> Please add documentation for the rtems_pthread_attribute_compare()
> function, and fix the copyright year (and license url) in the new
> pthreadattrcompare.c file.
> -Gedare
> On Thu, Feb 27, 2014 at 8:24 AM, Jennifer Averett
> <Jennifer.Averett at oarcorp.com> wrote:
> > Attached are files for posix support of the affinity attribute in
> > pthread. The affinity methods and tests will follow.
> > Jennifer Averett
> > On-Line Applications Research
> > rtems-devel mailing list
> > http://www.rtems.org/mailman/listinfo/rtems-devel
