Fwd: lpc17xx bsp status
Marcos Díaz marcos.diaz at tallertechnologies.com
Fri Jan 3 15:04:25 UTC 2014
On Fri, Jan 3, 2014 at 8:09 AM, Sebastian Huber
> On 01/02/2014 09:23 PM, Marcos Díaz wrote:
>> Hi, thanks for answering, first of all in the file lpc24xx.h there are
>> two definitions for FIO_BASE_ADDR the second one (which is the one
>> that I use) 0x20098000 is wrong, and when Itried to use the function
>> lpc24xx_gpio_set for testing I noticed that it tried to write based on
>> that value. the correct value 0x2009C000 works fine on my board, and
>> looking into the lpc17xx manual I could see that it`s the correct
>> value for the register.
> In the UM10470 LPC178x/7x User manual Rev. 2.1 — 6 March 2013 we the value
> 0x20098000 for the GPIO register base.  At 0x2009C000 we have the EMC
> registers.
> Can you please provide a link to your manual?
UM10360
LPC17xx User manual
Rev. 2 — 19 August 2010
>> In another part, in the configuration of modules, specifically in the
>> function lpc24xx_module_do_enable in io.c there isn't an option for
>> setting the clock for the module if ARM_MULTILIB_ARCH_V4 isnt defined
>> (my case) so it does nothing in that case. So far this is what we
>> realized and what could be causing us problems. Thanks.
> The LPC17XX has a different clock module.
But is it implemented?
>> PS: So far I thought that the macro ARM_MULTILIB_ARCH_V4 was for
>> separate things that are for the lpc17xx from things of the lpc24xx,
>> but Iḿ not pretty sure if itś true, so, what is this macro for?
> Yes, the ARM_MULTILIB_ARCH_V4 and ARM_MULTILIB_ARCH_V7M defines distinguish
> between LPC24XX and LPC17XX.
Thanks again!
______________________________
Marcos Díaz
Software Engineer
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
Skype: markdiaz22
