OS Web Monitor
Chirayu Desai
chirayudesai1 at gmail.com
Sat Jan 11 10:34:26 UTC 2014
I have moved oswebmonitor to network-demos, preserving commit history.
The content of the repository osmonweb.git has been added to a new
directory osmonweb.
The tree can be browsed at [1].
All commits but the last 2 don't touch anything in the topdir, only add /
modify content under the osmonweb directory.
It does not build with 4.11 (didn't before this merge, like I said in the
original message), and I do not have 4.10 built and installed currently, so
as of now it is untested.
I will test it by later today / tomorrow if time permits.
Also, looks like the code under http/ (in network-demos) is for "test of
GoAhead web server", which is deprecated, so it doesn't build with 4.11
[1]: https://github.com/chirayudesai/rtems-network-demos
On Tue, Jan 7, 2014 at 2:16 PM, Nick Withers <nick at nickwithers.com> wrote:
> On Mon, 2014-01-06 at 09:44 -0600, Joel Sherrill wrote:
> > On 1/5/2014 5:41 AM, Nick Withers wrote:
> > > On Sun, 2014-01-05 at 12:01 +0530, Chirayu Desai wrote:
> > >> I've uploaded two patches for oswebmonitor, [1] and [2]
> > >> [1] fixes a minor issue with bin2c being installed as rtems-bin2c
> > > I thought that was on purpose...? Not sure it should be installed as
> > > bin2c, as that could clash with a host binary.
> > > Are there actually any RTEMS-specifics in rtems-bin2c?
> > No. It just wasn't packaged and it is a commonly needed utility when
> > building
> > up filesystem images.
> Yeah, fair enough (I'm using it myself).
> It doesn't seem to be packaged on either FreeBSD or Ubuntu, otherwise I
> was gonna suggest removing it in favour of the host binary (which still
> seems like it'd be optimal in the ideal world).
> P.S., Cheers for the earlier clarification Chirayu :-)
> > >> [2] removes support for GoAhead
> > >> [1]:
> https://gist.github.com/chirayudesai/d8e72a999cb02e2d9dcd/raw/a869794c687cfbf9575efe8195245a7a4ac8992d/0001-make-bin2c-is-installed-as-rtems-bin2c.patch
> > >> [2]:
> https://gist.github.com/chirayudesai/d8e72a999cb02e2d9dcd/raw/55b65f128daf2ad532e83b6d44b976de51cae64c/0001-remove-support-for-GoAhead.patch
> Nick Withers
> email: nick at nickwithers.com
> Web: http://www.nickwithers.com
> Mobile: +61 414 397 446
> rtems-devel mailing list
> rtems-devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140111/05f248df/attachment.html>
