[PATCH] IMFS: Improved support for generic nodes
Sebastian Huber
Thu Jan 16 12:17:04 UTC 2014
The rtems_filesystem_location_info_t::node_access_2 was unused by the
IMFS. Use it to hold the context of generic nodes. This makes it
possible to use file node handlers for objects with and without a
corresponding file system node.
For example network sockets created with socket() have only a file
descriptor, but no corresponding file system node. The UNIX(4) domain
sockets can be bound to file system nodes. In both cases the
rtems_filesystem_location_info_t must provide a pointer to the socket
structure used by the socket file system node handlers. With the
context pointer (for sockets, this is the socket structure) in
rtems_filesystem_location_info_t::node_access_2 the same file node
handlers can be used in both cases.
cpukit/libfs/src/imfs/imfs_eval.c | 2 ++
1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/cpukit/libfs/src/imfs/imfs_eval.c b/cpukit/libfs/src/imfs/imfs_eval.c
index 9e2ebae..5307390 100644
--- a/cpukit/libfs/src/imfs/imfs_eval.c
+++ b/cpukit/libfs/src/imfs/imfs_eval.c
@@ -134,6 +134,8 @@ static rtems_filesystem_eval_path_generic_status IMFS_eval_token(
--dir->reference_count;
++entry->reference_count;
currentloc->node_access = entry;
+ currentloc->node_access_2 =
+ IMFS_generic_get_context_by_node( entry );
IMFS_Set_handlers( currentloc );
if ( !terminal ) {
1.7.7
