MGHTTPD API Changes was Re: OS Web Monitor
Fri Jan 17 16:08:49 UTC 2014
The network-demos do not build now due to API changes
in mghttpd.
I don't have time to fix this in the next week.
Nick updated Mongoose so probably knows what has to be
updated.
FWIW they are easy to build... build RTEMS with something like this:
../rtems/configure --target=${CPU}-rtems4.11 --enable-rtemsbsp=${BSP} \
  --enable-posix \
  --enable-networking \
  --disable-smp \
  ${DEBUG} \
  --enable-maintainer-mode \
  --prefix=/home/joel/rtems-4.11-work/bsp-install \
  ${TESTS} >c.log 2>&1 && \
make -j6  >b.log 2>&1
Then build network-demos like this:
RTEMS_MAKEFILE_PATH=/home/joel/rtems-4.11-work/bsp-install/sparc-rtems4.11/sis
make clean all
On 1/17/2014 9:08 AM, Gedare Bloom wrote:
> the top 4 commits at
> https://github.com/chirayudesai/rtems-network-demos/commits/osmonweb
> appear to be the ones to look at / test.
> On Fri, Jan 17, 2014 at 10:01 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> Where is the patch so I can review it?
>> On 1/17/2014 8:29 AM, Gedare Bloom wrote:
>>> Hi,
>>> I won't support this relocation until the build is confirmed. Thanks!
>>> On Sat, Jan 11, 2014 at 5:34 AM, Chirayu Desai <chirayudesai1 at gmail.com> wrote:
>>>> I have moved oswebmonitor to network-demos, preserving commit history.
>>>> The content of the repository osmonweb.git has been added to a new directory
>>>> osmonweb.
>>>> The tree can be browsed at [1].
>>>> All commits but the last 2 don't touch anything in the topdir, only add /
>>>> modify content under the osmonweb directory.
>>>> It does not build with 4.11 (didn't before this merge, like I said in the
>>>> original message), and I do not have 4.10 built and installed currently, so
>>>> as of now it is untested.
>>>> I will test it by later today / tomorrow if time permits.
>>>> Also, looks like the code under http/ (in network-demos) is for "test of
>>>> GoAhead web server", which is deprecated, so it doesn't build with 4.11
>>>> [1]: https://github.com/chirayudesai/rtems-network-demos
>>>> On Tue, Jan 7, 2014 at 2:16 PM, Nick Withers <nick at nickwithers.com> wrote:
>>>>> On Mon, 2014-01-06 at 09:44 -0600, Joel Sherrill wrote:
>>>>>> On 1/5/2014 5:41 AM, Nick Withers wrote:
>>>>>>> On Sun, 2014-01-05 at 12:01 +0530, Chirayu Desai wrote:
>>>>>>>> I've uploaded two patches for oswebmonitor, [1] and [2]
>>>>>>>> [1] fixes a minor issue with bin2c being installed as rtems-bin2c
>>>>>>> I thought that was on purpose...? Not sure it should be installed as
>>>>>>> bin2c, as that could clash with a host binary.
>>>>>>> Are there actually any RTEMS-specifics in rtems-bin2c?
>>>>>> No. It just wasn't packaged and it is a commonly needed utility when
>>>>>> building
>>>>>> up filesystem images.
>>>>> Yeah, fair enough (I'm using it myself).
>>>>> It doesn't seem to be packaged on either FreeBSD or Ubuntu, otherwise I
>>>>> was gonna suggest removing it in favour of the host binary (which still
>>>>> seems like it'd be optimal in the ideal world).
>>>>> P.S., Cheers for the earlier clarification Chirayu :-)
>>>>>>>> [2] removes support for GoAhead
>>>>>>>> [1]:
>>>>>>>> https://gist.github.com/chirayudesai/d8e72a999cb02e2d9dcd/raw/a869794c687cfbf9575efe8195245a7a4ac8992d/0001-make-bin2c-is-installed-as-rtems-bin2c.patch
>>>>>>>> [2]:
>>>>>>>> https://gist.github.com/chirayudesai/d8e72a999cb02e2d9dcd/raw/55b65f128daf2ad532e83b6d44b976de51cae64c/0001-remove-support-for-GoAhead.patch
>>>>> Nick Withers
>>>>> email: nick at nickwithers.com
>>>>> Web: http://www.nickwithers.com
>>>>> Mobile: +61 414 397 446
>>>>> _______________________________________________
>>>>> rtems-devel mailing list
>>>>> rtems-devel at rtems.org
>>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
