compiling head for xilinx_zynq_zedboard BSP, ld:linkcmds.base:68: syntax error
Giovanni Macciocu G.Macciocu at sron.nl
Mon Jan 20 11:06:31 UTC 2014
Hi All,
I'm trying to compile todays RTEMS head for the BSP 'xilinx_zynq_zedboard'. I've used the following configure options
$ ../configure --target=arm-rtems4.11 --enable-rtemsbsp=xilinx_zynq_zedboard --prefix=/opt/rtems-4.11
$ make
This does not succesfully compile (linker error).
The resulting output:
gmake[6]: Entering directory `/data/giovanni/rtems-4.11/archive/git_clone_20jan2014/rtems/build-rtems/arm-rtems4.11/c/xilinx_zynq_zedboard/testsuites/samples/hello'
arm-rtems4.11-gcc -B../../../../../xilinx_zynq_zedboard/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I. -I../../../../../../../c/src/../../testsuites/samples/hello -I..     -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT init.o -MD -MP -MF .deps/init.Tpo -c -o init.o ../../../../../../../c/src/../../testsuites/samples/hello/init.c
mv -f .deps/init.Tpo .deps/init.Po
arm-rtems4.11-gcc -B../../../../../xilinx_zynq_zedboard/lib/ -specs bsp_specs -qrtems -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs    -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9   -o hello.exe init.o
/opt/rtems-4.11/lib/gcc/arm-rtems4.11/4.8.1/../../../../arm-rtems4.11/bin/ld:linkcmds.base:68: syntax error
collect2: error: ld returned 1 exit status
gmake[6]: *** [hello.exe] Error 1
gmake[6]: Leaving directory `/data/giovanni/rtems-4.11/archive/git_clone_20jan2014/rtems/build-rtems/arm-rtems4.11/c/xilinx_zynq_zedboard/testsuites/samples/hello'
gmake[5]: *** [all-recursive] Error 1
gmake[5]: Leaving directory `/data/giovanni/rtems-4.11/archive/git_clone_20jan2014/rtems/build-rtems/arm-rtems4.11/c/xilinx_zynq_zedboard/testsuites/samples'
gmake[4]: *** [all] Error 2
gmake[4]: Leaving directory `/data/giovanni/rtems-4.11/archive/git_clone_20jan2014/rtems/build-rtems/arm-rtems4.11/c/xilinx_zynq_zedboard/testsuites/samples'
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory `/data/giovanni/rtems-4.11/archive/git_clone_20jan2014/rtems/build-rtems/arm-rtems4.11/c/xilinx_zynq_zedboard/testsuites'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory `/data/giovanni/rtems-4.11/archive/git_clone_20jan2014/rtems/build-rtems/arm-rtems4.11/c/xilinx_zynq_zedboard'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/data/giovanni/rtems-4.11/archive/git_clone_20jan2014/rtems/build-rtems/arm-rtems4.11/c'
Am I missing something here or is the current head broken for the xilinx_zynq_zedboard BSP.
Earlier heads compile without any issues, while using the same configure parameters.
Regards,
Giovanni Macciou, Software Design Engineer
SRON Netherlands Institute for Space Research
