[PATCH] bsp/xilinx_zynq: Support configuraton of memory map. Remove SMP variants.
    Chris Johns
    chrisj at rtems.org
    Tue Jan 28 03:07:17 UTC 2014
Generate a linker command file from configure letting the user override the
defaults to suite their custom needs. Refer to configure.ac for the details.
Remove the SMP variants and let --enable-smp control if a BSP is built for
SMP.
Make FAST_IRQ 1 only for the realview qemu BSP.
 c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am       |  9 ---
 c/src/lib/libbsp/arm/xilinx-zynq/configure.ac      | 83 +++++++++++++++++++++-
 .../make/custom/xilinx_zynq_a9_qemu_smp.cfg        |  1 -
 .../make/custom/xilinx_zynq_zc702_smp.cfg          |  1 -
 .../make/custom/xilinx_zynq_zc706_smp.cfg          |  1 -
 .../make/custom/xilinx_zynq_zedboard_smp.cfg       |  1 -
 c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am     | 36 ----------
 .../lib/libbsp/arm/xilinx-zynq/startup/linkcmds.in | 36 ++++++++++
 .../arm/xilinx-zynq/startup/linkcmds.xilinx_zynq   | 27 -------
 .../startup/linkcmds.xilinx_zynq_a9_qemu           | 31 --------
 .../startup/linkcmds.xilinx_zynq_a9_qemu_smp       | 33 ---------
 .../xilinx-zynq/startup/linkcmds.xilinx_zynq_zc702 |  8 ---
 .../startup/linkcmds.xilinx_zynq_zc702_smp         |  3 -
 .../xilinx-zynq/startup/linkcmds.xilinx_zynq_zc706 |  8 ---
 .../startup/linkcmds.xilinx_zynq_zc706_smp         |  3 -
 .../startup/linkcmds.xilinx_zynq_zedboard          |  8 ---
 .../startup/linkcmds.xilinx_zynq_zedboard_smp      |  3 -
 17 files changed, 116 insertions(+), 176 deletions(-)
 delete mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu_smp.cfg
 delete mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zc702_smp.cfg
 delete mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zc706_smp.cfg
 delete mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zedboard_smp.cfg
 create mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.in
 delete mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq
 delete mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu
 delete mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu_smp
 delete mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc702
 delete mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc702_smp
 delete mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc706
 delete mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc706_smp
 delete mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zedboard
 delete mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zedboard_smp
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
index 52711fd..fd5d47a 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
@@ -59,15 +59,6 @@ libbspstart_a_SOURCES = ../shared/start/start.S
 project_lib_DATA = start.$(OBJEXT)
 project_lib_DATA += startup/linkcmds
-project_lib_DATA += startup/linkcmds.xilinx_zynq
-project_lib_DATA += startup/linkcmds.xilinx_zynq_a9_qemu
-project_lib_DATA += startup/linkcmds.xilinx_zynq_a9_qemu_smp
-project_lib_DATA += startup/linkcmds.xilinx_zynq_zc702
-project_lib_DATA += startup/linkcmds.xilinx_zynq_zc702_smp
-project_lib_DATA += startup/linkcmds.xilinx_zynq_zc706
-project_lib_DATA += startup/linkcmds.xilinx_zynq_zc706_smp
-project_lib_DATA += startup/linkcmds.xilinx_zynq_zedboard
-project_lib_DATA += startup/linkcmds.xilinx_zynq_zedboard_smp
 #                  LibBSP                                                     #
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac b/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
index 66b8333..bdc179d 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
@@ -29,7 +29,10 @@ RTEMS_BSPOPTS_SET([BSP_ARM_A9MPCORE_PERIPHCLK],[xilinx_zynq_zedboard*],[66666666
 RTEMS_BSPOPTS_SET([BSP_ARM_A9MPCORE_PERIPHCLK],[*],[100000000U])
 RTEMS_BSPOPTS_HELP([BSP_ARM_A9MPCORE_PERIPHCLK],[ARM Cortex-A9 MPCore PERIPHCLK clock frequency in Hz])
-RTEMS_BSPOPTS_SET([CLOCK_DRIVER_USE_FAST_IDLE],[*qemu],[1])
+USE_FAST_IDLE=0
+AS_IF([test "x${RTEMS_BSP}" == xxilinx_zynq_a9_qemu], [USE_FAST_IDLE=1])
+RTEMS_BSPOPTS_SET([CLOCK_DRIVER_USE_FAST_IDLE],[*qemu],[${USE_FAST_IDLE}])
 RTEMS_BSPOPTS_HELP([CLOCK_DRIVER_USE_FAST_IDLE],
 [This sets a mode where the time runs as fast as possible when a clock ISR
 occurs while the IDLE thread is executing.  This can significantly reduce
@@ -38,11 +41,85 @@ simulation times.])
 RTEMS_BSPOPTS_SET([BSP_CONSOLE_MINOR],[*],[1])
 RTEMS_BSPOPTS_HELP([BSP_CONSOLE_MINOR],[minor number of console device])
+ZYNQ_CPUS="1"
 RTEMS_CHECK_SMP
 AM_CONDITIONAL(HAS_SMP,[test "$rtems_cv_HAS_SMP" = "yes"])
+AS_IF([test "$rtems_cv_HAS_SMP" = "yes"],
+      [ZYNQ_CPUS="2"])
+# Zynq Memory map can be controlled from the configure command line. Use ...
+#   ..../configure --target=arm-rtems4.11 ... ZYNQ_RAM_LENGTH=256M
+      [ZYNQ_RAM_ORIGIN="0x00000000"
+       ZYNQ_RAM_LENGTH="256M"
+       ZYNQ_RAM_MMU="0x0fffc000"
+       ZYNQ_RAM_MMU_LENGTH="16k"
+       ZYNQ_RAM_ORIGIN_AVAILABLE="${ZYNQ_RAM_ORIGIN}"
+       ZYNQ_RAM_LENGTH_AVAILABLE="${ZYNQ_RAM_LENGTH} - 16k"
+       ZYNQ_RAM_INT_0_ORIGIN="0x00000000"
+       ZYNQ_RAM_INT_0_LENGTH="64k + 64k + 64k"
+       ZYNQ_RAM_INT_1_ORIGIN="0xFFFF0000"
+       ZYNQ_RAM_INT_1_LENGTH="64k - 512"])
+AS_IF([test "x${RTEMS_BSP}" == xxilinx_zynq_zc702],
+      [ZYNQ_RAM_ORIGIN="0x00100000"
+       ZYNQ_RAM_LENGTH="1024M"
+       ZYNQ_RAM_MMU="${ZYNQ_RAM_ORIGIN}"
+       ZYNQ_RAM_ORIGIN_AVAILABLE="${ZYNQ_RAM_ORIGIN} + 0x00004000"
+       ZYNQ_RAM_LENGTH_AVAILABLE="${ZYNQ_RAM_LENGTH} - 1M - 16k"
+AS_IF([test "x${RTEMS_BSP}" == xxilinx_zynq_zc706],
+      [ZYNQ_RAM_ORIGIN="0x00400000"
+       ZYNQ_RAM_LENGTH_AVAILABLE="${ZYNQ_RAM_LENGTH} - 4M - 16k"
+AS_IF([test "x${RTEMS_BSP}" == xxilinx_zynq_zedboard],
+       ZYNQ_RAM_LENGTH="512M"
+AC_DEFUN([ZYNQ_LINKCMD],[
+AC_ARG_VAR([$1],[$2; default $3])dnl
+[$1]=[$]{[$1]:-[$3]}
+ZYNQ_LINKCMD([ZYNQ_CPUS],[Number of active cores],[${ZYNQ_CPUS}])
+ZYNQ_LINKCMD([ZYNQ_RAM_ORIGIN],[normal RAM region origin],[${ZYNQ_RAM_ORIGIN}])
+ZYNQ_LINKCMD([ZYNQ_RAM_LENGTH],[normal RAM region length],[${ZYNQ_RAM_LENGTH}])
+ZYNQ_LINKCMD([ZYNQ_RAM_MMU],[MMU region origin],[${ZYNQ_RAM_MMU}])
+ZYNQ_LINKCMD([ZYNQ_RAM_MMU_LENGTH],[MMU region length],[${ZYNQ_RAM_MMU_LENGTH}])
+ZYNQ_LINKCMD([ZYNQ_RAM_ORIGIN_AVAILABLE],[origin of available RAM],[${ZYNQ_RAM_ORIGIN_AVAILABLE}])
+ZYNQ_LINKCMD([ZYNQ_RAM_LENGTH_AVAILABLE],[length of available RAM],[${ZYNQ_RAM_LENGTH_AVAILABLE}])
+ZYNQ_LINKCMD([ZYNQ_RAM_INT_0_ORIGIN],[internal 0 RAM region origin],[${ZYNQ_RAM_INT_0_ORIGIN}])
+ZYNQ_LINKCMD([ZYNQ_RAM_INT_0_LENGTH],[internal 0 RAM region length],[${ZYNQ_RAM_INT_0_LENGTH}])
+ZYNQ_LINKCMD([ZYNQ_RAM_INT_1_ORIGIN],[internal 1 RAM region origin],[${ZYNQ_RAM_INT_1_ORIGIN}])
+ZYNQ_LINKCMD([ZYNQ_RAM_INT_1_LENGTH],[internal 1 RAM region length],[${ZYNQ_RAM_INT_1_LENGTH}])
 RTEMS_BSP_CLEANUP_OPTIONS(0, 1)
-RTEMS_BSP_LINKCMDS
-AC_CONFIG_FILES([Makefile])
+AC_CONFIG_FILES([
+Makefile
+startup/linkcmds])
 AC_OUTPUT
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu_smp.cfg b/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu_smp.cfg
deleted file mode 100644
index 2a0e35a..0000000
--- a/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu_smp.cfg
+++ /dev/null
@@ -1 +0,0 @@
-include $(RTEMS_ROOT)/make/custom/xilinx_zynq_a9_qemu.cfg
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zc702_smp.cfg b/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zc702_smp.cfg
index 2de871d..0000000
--- a/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zc702_smp.cfg
+++ /dev/null
@@ -1 +0,0 @@
-include $(RTEMS_ROOT)/make/custom/xilinx_zynq.inc
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zc706_smp.cfg b/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zc706_smp.cfg
--- a/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zc706_smp.cfg
+++ /dev/null
@@ -1 +0,0 @@
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zedboard_smp.cfg b/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zedboard_smp.cfg
--- a/c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zedboard_smp.cfg
+++ /dev/null
@@ -1 +0,0 @@
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am b/c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am
index 1666ad9..3762d07 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am
@@ -146,39 +146,3 @@ $(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
 TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds
-$(PROJECT_LIB)/linkcmds.xilinx_zynq: startup/linkcmds.xilinx_zynq $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.xilinx_zynq
-TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.xilinx_zynq
-$(PROJECT_LIB)/linkcmds.xilinx_zynq_a9_qemu: startup/linkcmds.xilinx_zynq_a9_qemu $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.xilinx_zynq_a9_qemu
-TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.xilinx_zynq_a9_qemu
-$(PROJECT_LIB)/linkcmds.xilinx_zynq_a9_qemu_smp: startup/linkcmds.xilinx_zynq_a9_qemu_smp $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.xilinx_zynq_a9_qemu_smp
-TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.xilinx_zynq_a9_qemu_smp
-$(PROJECT_LIB)/linkcmds.xilinx_zynq_zc702: startup/linkcmds.xilinx_zynq_zc702 $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.xilinx_zynq_zc702
-TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.xilinx_zynq_zc702
-$(PROJECT_LIB)/linkcmds.xilinx_zynq_zc702_smp: startup/linkcmds.xilinx_zynq_zc702_smp $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.xilinx_zynq_zc702_smp
-TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.xilinx_zynq_zc702_smp
-$(PROJECT_LIB)/linkcmds.xilinx_zynq_zc706: startup/linkcmds.xilinx_zynq_zc706 $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.xilinx_zynq_zc706
-TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.xilinx_zynq_zc706
-$(PROJECT_LIB)/linkcmds.xilinx_zynq_zc706_smp: startup/linkcmds.xilinx_zynq_zc706_smp $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.xilinx_zynq_zc706_smp
-TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.xilinx_zynq_zc706_smp
-$(PROJECT_LIB)/linkcmds.xilinx_zynq_zedboard: startup/linkcmds.xilinx_zynq_zedboard $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.xilinx_zynq_zedboard
-TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.xilinx_zynq_zedboard
-$(PROJECT_LIB)/linkcmds.xilinx_zynq_zedboard_smp: startup/linkcmds.xilinx_zynq_zedboard_smp $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.xilinx_zynq_zedboard_smp
-TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.xilinx_zynq_zedboard_smp
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.in b/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.in
new file mode 100644
index 0000000..7239f0d
--- /dev/null
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.in
@@ -0,0 +1,36 @@
+MEMORY {
+   RAM_INT_0 : ORIGIN = @ZYNQ_RAM_INT_0_ORIGIN@, LENGTH = @ZYNQ_RAM_INT_0_LENGTH@
+   RAM_INT_1 : ORIGIN = @ZYNQ_RAM_INT_1_ORIGIN@, LENGTH = @ZYNQ_RAM_INT_1_LENGTH@
+   RAM_MMU   : ORIGIN = @ZYNQ_RAM_MMU@, LENGTH = @ZYNQ_RAM_MMU_LENGTH@
+   RAM       : ORIGIN = @ZYNQ_RAM_ORIGIN_AVAILABLE@, LENGTH = @ZYNQ_RAM_LENGTH_AVAILABLE@
+bsp_processor_count = DEFINED (bsp_processor_count) ? bsp_processor_count : @ZYNQ_CPUS@;
+REGION_ALIAS ("REGION_START",          RAM);
+REGION_ALIAS ("REGION_VECTOR",         RAM);
+REGION_ALIAS ("REGION_TEXT",           RAM);
+REGION_ALIAS ("REGION_TEXT_LOAD",      RAM);
+REGION_ALIAS ("REGION_RODATA",         RAM);
+REGION_ALIAS ("REGION_RODATA_LOAD",    RAM);
+REGION_ALIAS ("REGION_DATA",           RAM);
+REGION_ALIAS ("REGION_DATA_LOAD",      RAM);
+REGION_ALIAS ("REGION_FAST_TEXT",      RAM);
+REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
+REGION_ALIAS ("REGION_FAST_DATA",      RAM);
+REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
+REGION_ALIAS ("REGION_BSS",            RAM);
+REGION_ALIAS ("REGION_WORK",           RAM);
+REGION_ALIAS ("REGION_STACK",          RAM);
+bsp_stack_irq_size = DEFINED (bsp_stack_irq_size) ? bsp_stack_irq_size : 4096;
+bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size : 1024;
+bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
+bsp_vector_table_in_start_section = 1;
+bsp_translation_table_base = ORIGIN (RAM_MMU);
+bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
+INCLUDE linkcmds.armv4
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq b/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq
index ecac6df..0000000
--- a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq
+++ /dev/null
@@ -1,27 +0,0 @@
-REGION_ALIAS ("REGION_START",          RAM);
-REGION_ALIAS ("REGION_VECTOR",         RAM);
-REGION_ALIAS ("REGION_TEXT",           RAM);
-REGION_ALIAS ("REGION_TEXT_LOAD",      RAM);
-REGION_ALIAS ("REGION_RODATA",         RAM);
-REGION_ALIAS ("REGION_RODATA_LOAD",    RAM);
-REGION_ALIAS ("REGION_DATA",           RAM);
-REGION_ALIAS ("REGION_DATA_LOAD",      RAM);
-REGION_ALIAS ("REGION_FAST_TEXT",      RAM);
-REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
-REGION_ALIAS ("REGION_FAST_DATA",      RAM);
-REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
-REGION_ALIAS ("REGION_BSS",            RAM);
-REGION_ALIAS ("REGION_WORK",           RAM);
-REGION_ALIAS ("REGION_STACK",          RAM);
-bsp_stack_irq_size = DEFINED (bsp_stack_irq_size) ? bsp_stack_irq_size : 4096;
-bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size : 1024;
-bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
-bsp_vector_table_in_start_section = 1;
-bsp_translation_table_base = ORIGIN (RAM_MMU);
-bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
-INCLUDE linkcmds.armv4
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu b/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu
index 0b5e3e0..0000000
--- a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu
+++ /dev/null
@@ -1,31 +0,0 @@
-MEMORY {
-	RAM : ORIGIN = 0x00000000, LENGTH = 256M - 16k
-	RAM_MMU : ORIGIN = 0x0fffc000, LENGTH = 16k
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu_smp b/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu_smp
index d76dd2e..0000000
--- a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu_smp
+++ /dev/null
@@ -1,33 +0,0 @@
-MEMORY {
-bsp_processor_count = DEFINED (bsp_processor_count) ? bsp_processor_count : 8;
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc702 b/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc702
index 2978aff..0000000
--- a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc702
+++ /dev/null
@@ -1,8 +0,0 @@
-MEMORY {
-   RAM_INT_0 : ORIGIN = 0x00000000, LENGTH = 64k + 64k + 64k
-   RAM_INT_1 : ORIGIN = 0xFFFF0000, LENGTH = 64k - 512
-   RAM_MMU   : ORIGIN = 0x00100000, LENGTH = 16k
-   RAM       : ORIGIN = 0x00104000, LENGTH = 1024M - 1M - 16k
-INCLUDE linkcmds.xilinx_zynq
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc702_smp b/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc702_smp
index 86ff4b1..0000000
--- a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc702_smp
+++ /dev/null
@@ -1,3 +0,0 @@
-bsp_processor_count = DEFINED (bsp_processor_count) ? bsp_processor_count : 2;
-INCLUDE linkcmds.xilinx_zynq_zc702
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc706 b/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc706
index 33b32ba..0000000
--- a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc706
+++ /dev/null
@@ -1,8 +0,0 @@
-MEMORY {
-   RAM_MMU   : ORIGIN = 0x00400000, LENGTH = 16k
-   RAM       : ORIGIN = 0x00404000, LENGTH = 1024M - 4M - 16k
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc706_smp b/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc706_smp
index d698425..0000000
--- a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc706_smp
+++ /dev/null
@@ -1,3 +0,0 @@
-INCLUDE linkcmds.xilinx_zynq_zc706
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zedboard b/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zedboard
index 5c01676..0000000
--- a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zedboard
+++ /dev/null
@@ -1,8 +0,0 @@
-MEMORY {
-   RAM       : ORIGIN = 0x00104000, LENGTH = 512M - 1M - 16k
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zedboard_smp b/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zedboard_smp
index f01e278..0000000
--- a/c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zedboard_smp
+++ /dev/null
@@ -1,3 +0,0 @@
-INCLUDE linkcmds.xilinx_zynq_zedboard
1.8.3.4 (Apple Git-47)
