sparc 4.11 tools build failure on CentOS 6.x
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Jan 28 16:46:41 UTC 2014
Hi
Not sure what broke recently but something went wrong. :(
Can anyone build sparc-rtems4.11 tools with the rtems-source-builder
head?
/bin/sh ../../gcc-4.8.2/gcc/mkconfig.sh bconfig.h
/usr/bin/g++ -O2 -pipe
-I/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/tmp/sb-joel/4.11/rtems-sparc/home/joel/rtems-4.11-work/tools/include
-c -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions
-fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings
-Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long
-Wno-variadic-macros -Wno-overlength-strings -DHAVE_CONFIG_H
-DGENERATOR_FILE -I. -Ibuild -I../../gcc-4.8.2/gcc
-I../../gcc-4.8.2/gcc/build -I../../gcc-4.8.2/gcc/../include
-I../../gcc-4.8.2/gcc/../libcpp/include
-I/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.2-newlib-2.1.0-1/build/./gmp
-I/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.2-newlib-2.1.0-1/gcc-4.8.2/gmp
-I/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.2-newlib-2.1.0-1/build/./mpfr
-I/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.2-newlib-2.1.0-1/gcc-4.8.2/mpfr
-I/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.2-newlib-2.1.0-1/gcc-4.8.2/mpc/src
-I../../gcc-4.8.2/gcc/../libdecnumber
-I../../gcc-4.8.2/gcc/../libdecnumber/dpd -I../libdecnumber
-I../../gcc-4.8.2/gcc/../libbacktrace \
-DBASEVER="\"4.8.2\"" -DDATESTAMP="\" 20131016\"" \
-DREVISION="\"\"" \
-DDEVPHASE="\" (RTEMS
4.11-RSB(2be445d2aafae21849c5d626b3787e2ab1ac846b)-1,gcc-4.8.2/newlib-2.1.0)\""
-DPKGVERSION="\"(GCC) \"" \
-DBUGURL="\"<http://gcc.gnu.org/bugs.html>\"" -o build/version.o
../../gcc-4.8.2/gcc/version.c
{standard input}: Assembler messages:
{standard input}:33: Error: unknown pseudo-op: `.value'
{standard input}:183: Error: unknown pseudo-op: `.value'
Joel Sherrill, Ph.D. Director of Research& Development
Ask me about RTEMS: a free RTOS Huntsville AL 35806
