sparc 4.11 tools build failure on CentOS 6.x
Wed Jan 29 22:55:44 UTC 2014
On 01/28/2014 10:04 PM, Alan Cudmore wrote:
> I was just able to build the sparc-rtems4.11 toolchain on Centos 6.5 ,
> 64 bit
> This was on a fresh Centos 6.x VM with all updates, no previous RTEMS
> tools installed.
OK. I have solved it but it was a weird one. My PATH accidentally
had :: in it and that let "." (the current directory) be in my PATH.
GCC creates a shell script called "as" which invokes the cross
assembler. It meant to get the native as but got the script for
the cross.
Having . in a PATH is bad and apparently :: gives you the same
effect in at least bash.
Should I file a PR to request that sb-check or the source builder
check this condition?
> Alan
> [alan at centosvm Desktop]$ sparc-rtems4.11-gcc -v
> Using built-in specs.
> COLLECT_GCC=sparc-rtems4.11-gcc
> COLLECT_LTO_WRAPPER=/home/alan/Projects/rtems/4.11/libexec/gcc/sparc-rtems4.11/4.8.2/lto-wrapper
> Target: sparc-rtems4.11
> Configured with: ../gcc-4.8.2/configure
> --prefix=/home/alan/Projects/rtems/4.11
> --bindir=/home/alan/Projects/rtems/4.11/bin
> --exec_prefix=/home/alan/Projects/rtems/4.11
> --includedir=/home/alan/Projects/rtems/4.11/include
> --libdir=/home/alan/Projects/rtems/4.11/lib
> --libexecdir=/home/alan/Projects/rtems/4.11/libexec
> --mandir=/home/alan/Projects/rtems/4.11/share/man
> --infodir=/home/alan/Projects/rtems/4.11/share/info
> --datadir=/home/alan/Projects/rtems/4.11/share --build=x86_64-linux-gnu
> --host=x86_64-linux-gnu --target=sparc-rtems4.11 --disable-libstdcxx-pch
> --with-gnu-as --with-gnu-ld --verbose --with-newlib --with-system-zlib
> --disable-nls --without-included-gettext --disable-win32-registry
> --enable-version-specific-runtime-libs --disable-lto
> --enable-newlib-io-c99-formats --enable-newlib-iconv
> --enable-newlib-iconv-encodings=big5,cp775,cp850,cp852,cp855,cp866,euc_jp,euc_kr,euc_tw,iso_8859_1,iso_8859_10,iso_8859_11,iso_8859_13,iso_8859_14,iso_8859_15,iso_8859_2,iso_8859_3,iso_8859_4,iso_8859_5,iso_8859_6,iso_8859_7,iso_8859_8,iso_8859_9,iso_ir_111,koi8_r,koi8_ru,koi8_u,koi8_uni,ucs_2,ucs_2_internal,ucs_2be,ucs_2le,ucs_4,ucs_4_internal,ucs_4be,ucs_4le,us_ascii,utf_16,utf_16be,utf_16le,utf_8,win_1250,win_1251,win_1252,win_1253,win_1254,win_1255,win_1256,win_1257,win_1258
> --enable-threads --disable-plugin --enable-languages=c,c++
> Thread model: posix
> gcc version 4.8.2 20131016 (RTEMS
> 4.11-RSB(2be445d2aafae21849c5d626b3787e2ab1ac846b)-1,gcc-4.8.2/newlib-2.1.0)
> (GCC)
> On 1/28/2014 10:38 PM, Chris Johns wrote:
>> On 29/01/2014 3:46 am, Joel Sherrill wrote:
>>> Hi
>>> Not sure what broke recently but something went wrong. :(
>>> Can anyone build sparc-rtems4.11 tools with the rtems-source-builder
>>> head?
>> Yes on FreeBSD 9 and on MacOS Mavrick ....
>>   Build Set: Time 0:08:46.537755
>>>       /bin/sh ../../gcc-4.8.2/gcc/mkconfig.sh bconfig.h
>>> /usr/bin/g++ -O2 -pipe
>>> -I/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/tmp/sb-joel/4.11/rtems-sparc/home/joel/rtems-4.11-work/tools/include
>>> -c   -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -fno-exceptions
>>> -fno-rtti -fasynchronous-unwind-tables -W -Wall -Wwrite-strings
>>> -Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long
>>> -Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H
>>> -DGENERATOR_FILE -I. -Ibuild -I../../gcc-4.8.2/gcc
>>> -I../../gcc-4.8.2/gcc/build -I../../gcc-4.8.2/gcc/../include
>>> -I../../gcc-4.8.2/gcc/../libcpp/include
>>> -I/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.2-newlib-2.1.0-1/build/./gmp
>>> -I/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.2-newlib-2.1.0-1/gcc-4.8.2/gmp
>>> -I/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.2-newlib-2.1.0-1/build/./mpfr
>>> -I/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.2-newlib-2.1.0-1/gcc-4.8.2/mpfr
>>> -I/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.2-newlib-2.1.0-1/gcc-4.8.2/mpc/src
>>> -I../../gcc-4.8.2/gcc/../libdecnumber
>>> -I../../gcc-4.8.2/gcc/../libdecnumber/dpd -I../libdecnumber
>>> -I../../gcc-4.8.2/gcc/../libbacktrace    \
>>>       -DBASEVER="\"4.8.2\"" -DDATESTAMP="\" 20131016\"" \
>>>       -DREVISION="\"\"" \
>>>       -DDEVPHASE="\" (RTEMS
>>> 4.11-RSB(2be445d2aafae21849c5d626b3787e2ab1ac846b)-1,gcc-4.8.2/newlib-2.1.0)\""
>> Same git hash I am using.
>>> -DPKGVERSION="\"(GCC) \"" \
>>>       -DBUGURL="\"<http://gcc.gnu.org/bugs.html>\"" -o build/version.o
>>> ../../gcc-4.8.2/gcc/version.c
>>> {standard input}: Assembler messages:
>>> {standard input}:33: Error: unknown pseudo-op: `.value'
>>> {standard input}:183: Error: unknown pseudo-op: `.value'
>> Anything in your path that could up set up things ?
>> Do the installed RPMs verify ?
>> Chris
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
Joel Sherrill, Ph.D.             Director of Research& Development
Ask me about RTEMS: a free RTOS  Huntsville AL 35806
Support Available               (256) 722-9985
