sparc 4.11 tools build failure on CentOS 6.x
Thu Jan 30 03:07:49 UTC 2014
On 30/01/2014 10:52 am, Joel Sherrill wrote:
>>> Having . in a PATH is bad and apparently :: gives you the same
>>> effect in at least bash.
>>> Should I file a PR to request that sb-check or the source builder
>>> check this condition?
>> Yes or a patch :).
> You will be lucky to get a PR out of me. I feel swamped.
I have committed a fix. It checks the path for empty components as well
as . and .. and if you add --warn-all it will show which paths are in
your PATH variables that do not exist or point to files rather than
directories.
