smp test failures on using grsim
Jennifer Averett Jennifer.Averett at OARcorp.com
Fri Jan 31 16:04:38 UTC 2014
I've ran the rtems smp tests for 2 and 4 cores using grsim against the head
and ran into some problems.  If the test isn't listed below it ran for
both 2 and 4 core verisons.
smp08
  2 Core: Doesn't come back to grsim at end of program
  4 Core: Doesn't come back to grsim at end of program
smp05
smp09
  2 Core: Runs
smp02
  2 Core: Runs
smppsxsignal01
  2 Core: Locks and doesn't run past inital test line
  4 Core: Locks and doesn't run past inital test line
smplock01
  2 Core: Locks and doesn't run past initial test line
  4 Core: Locks and doesn't run past initial test line
smpswitchextension01
smpsignal01
smpmigration01
smp01
  2 Core: Runs
  4 Core: Locks after "CPU 0 running Task TA2"
smp03
  2 Core: Runs
  4 Core: Locks after "CPU 3 running task Init"
--Jennifer
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140131/1adae0d3/attachment.html>
