lpc17xx bsp status
Marcos Díaz
marcos.diaz at tallertechnologies.com
Fri Jan 3 15:57:19 UTC 2014
On Fri, Jan 3, 2014 at 9:04 AM, Sebastian Huber
> On 01/03/2014 12:51 PM, Marcos Díaz wrote:
>> On Fri, Jan 3, 2014 at 8:09 AM, Sebastian Huber
>>> >On 01/02/2014 09:23 PM, Marcos Díaz wrote:
>>>> >>Hi, thanks for answering, first of all in the file lpc24xx.h there are
>>>> >>two definitions for FIO_BASE_ADDR the second one (which is the one
>>>> >>that I use) 0x20098000 is wrong, and when Itried to use the function
>>>> >>lpc24xx_gpio_set for testing I noticed that it tried to write based on
>>>> >>that value. the correct value 0x2009C000 works fine on my board, and
>>>> >>looking into the lpc17xx manual I could see that it`s the correct
>>>> >>value for the register.
>>> >In the UM10470 LPC178x/7x User manual Rev. 2.1 — 6 March 2013 we the
>>> > value
>>> >0x20098000 for the GPIO register base. At 0x2009C000 we have the EMC
>>> >registers.
>>> >Can you please provide a link to your manual?
>> UM10360
>> LPC17xx User manual
>> Rev. 2 — 19 August 2010
> Yes, indeed, the memory map is different here. This is quite stupid from
> NXP. Which model to you use?
it's lpc1768
>>>> >>In another part, in the configuration of modules, specifically in the
>>>> >>function lpc24xx_module_do_enable in io.c there isn't an option for
>>>> >>setting the clock for the module if ARM_MULTILIB_ARCH_V4 isnt defined
>>>> >>(my case) so it does nothing in that case. So far this is what we
>>>> >>realized and what could be causing us problems. Thanks.
>>> >The LPC17XX has a different clock module.
>> But is it implemented?
> Yes, at least for the LPC1778.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
Well, we will be developing the bsp for this board (the lpc1768), so
we will appreciate any help you could give us. Thanks!
