LPC 17XX
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Jan 16 17:50:44 UTC 2014
On 1/16/2014 11:48 AM, Marcos Díaz wrote:
> Hi, we are adapting the lpc 17xx bsp to one mbed lpc1768, currently we
> could make the hello example to work but only with printk, not with
> printf, so, I wanted to know, what's the difference between those two
> functions, where should I look in order to see what's wrong?
> debugging i've seen that the program compiled with newlib isn't
> calling printf, but it calls _puts, is that ok or there is something
> wrong?
gcc optimizes calls to printf with fixed strings (e.g. no formatting
parameters)
into calls to puts.
Is the console_write() method being called in the BSP?
Sometimes BSPs use interrupts for console I/O and hello can run and exit
before the I/O gets out.
> thanks in advance
--joel
